[petsc-users] running error
paul zhang paulhuaizhang at gmail.com
Mon Dec 1 15:39:05 CST 2014
I better send you original files. The compressed files triggered some
warnings I guess.
Attached is the MPI test been verified.
Huaibao (Paul) Zhang
*Gas Surface Interactions Lab*
Department of Mechanical Engineering
University of Kentucky,
Lexington,
KY, 40506-0503
*Office*: 216 Ralph G. Anderson Building
*Web*:gsil.engineering.uky.edu
On Mon, Dec 1, 2014 at 4:33 PM, paul zhang <paulhuaizhang at gmail.com> wrote:
> Hi Jed,
> Now I see PETSc is compiled correctly. However, when I attempted to call
> "petscksp.h" in my own program (quite simple one), it failed for some
> reason. Attached you can see two cases. The first is just the test of MPI,
> which is fine. The second is one added PETSc, which has segment fault as it
> went to
>         MPI_Comm_rank (MPI_COMM_WORLD, &rank);        /* get current
> process id */
> Can you shed some light? The MPI version is 1.8.3.
> Thanks,
> Paul
> Lexington,
> KY, 40506-0503
> On Mon, Dec 1, 2014 at 4:20 PM, paul zhang <paulhuaizhang at gmail.com>
> wrote:
>> Sorry. I should reply it to the lists.
>> [hzh225 at dlxlogin2-2 petsc-3.5.2]$ make
>> PETSC_DIR=/home/hzh225/LIB_CFD/nP/petsc-3.5.2 PETSC_ARCH=linux-gnu-intel
>> test
>> Running test examples to verify correct installation
>> Using PETSC_DIR=/home/hzh225/LIB_CFD/nP/petsc-3.5.2 and
>> C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
>> MPI process
>> C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2
>> MPI processes
>> Fortran example src/snes/examples/tutorials/ex5f run successfully with 1
>> MPI process
>> Completed test examples
>> Now to evaluate the computer systems you plan use - do:
>> make PETSC_DIR=/home/hzh225/LIB_CFD/nP/petsc-3.5.2
>> PETSC_ARCH=linux-gnu-intel streams NPMAX=<number of MPI processes you
>> intend to use>
>> Lexington,
>> KY, 40506-0503
>> On Mon, Dec 1, 2014 at 4:18 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> paul zhang <paulhuaizhang at gmail.com> writes:
>>> > Hi Jed,
>>> > Does this mean I've passed the default test?
>>> It's an MPI test.  Run this to see if PETSc solvers are running
>>> correctly:
>>> PETSC_ARCH=linux-gnu-intel test
>>> > Is the "open matplotlib " an issue?
>>> No, it's just a Python library that would be used to create a nice
>>> figure if you had it installed.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141201/123a2daa/attachment.html>
set (CMAKE_CXX_COMPILER /home/hzh225/LIB_CFD/openmpi-1.8.3/bin/mpiCC)
set (CMAKE_CXX_FLAGS "-O3")
cmake_minimum_required(VERSION 2.6)
project(kats)
set (kats_VERSION_MAJOR 2)
set (kats_VERSION_MINOR 0)
list (APPEND CMAKE_MODULE_PATH "${kats_SOURCE_DIR}/CMake")
# Pass some CMake settings to source code through a header file
configure_file (
	"${PROJECT_SOURCE_DIR}/cmake_vars.h.in"
	"${PROJECT_BINARY_DIR}/cmake_vars.h"
set (CMAKE_INSTALL_PREFIX ${PROJECT_SOURCE_DIR}/../)
# add to the include search path
include_directories("${PROJECT_SOURCE_DIR}")
#set (EXTRA_LIBS parmetis metis cgns petsc)# imf m)
#add the executable
set (SOURCES
main.cc
cmake_vars.h
add_executable(kats ${SOURCES})
#target_link_libraries (kats ${FCFD_LIBS} })
install (TARGETS kats RUNTIME DESTINATION bin)
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141201/123a2daa/attachment.cc>
