[petsc-users] running error
paul zhang paulhuaizhang at gmail.com
Mon Dec 1 15:20:47 CST 2014
Sorry. I should reply it to the lists.
[hzh225 at dlxlogin2-2 petsc-3.5.2]$ make
PETSC_DIR=/home/hzh225/LIB_CFD/nP/petsc-3.5.2 PETSC_ARCH=linux-gnu-intel
test
Running test examples to verify correct installation
Using PETSC_DIR=/home/hzh225/LIB_CFD/nP/petsc-3.5.2 and
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1 MPI
process
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2 MPI
processes
Fortran example src/snes/examples/tutorials/ex5f run successfully with 1
MPI process
Completed test examples
Now to evaluate the computer systems you plan use - do:
make PETSC_DIR=/home/hzh225/LIB_CFD/nP/petsc-3.5.2
PETSC_ARCH=linux-gnu-intel streams NPMAX=<number of MPI processes you
intend to use>
Huaibao (Paul) Zhang
*Gas Surface Interactions Lab*
Department of Mechanical Engineering
University of Kentucky,
Lexington,
KY, 40506-0503
*Office*: 216 Ralph G. Anderson Building
*Web*:gsil.engineering.uky.edu
On Mon, Dec 1, 2014 at 4:18 PM, Jed Brown <jed at jedbrown.org> wrote:
> paul zhang <paulhuaizhang at gmail.com> writes:
> > Hi Jed,
> > Does this mean I've passed the default test?
> It's an MPI test.  Run this to see if PETSc solvers are running correctly:
> PETSC_ARCH=linux-gnu-intel test
> > Is the "open matplotlib " an issue?
> No, it's just a Python library that would be used to create a nice
> figure if you had it installed.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141201/5ce29bbd/attachment.html>
