[petsc-users] valgrind
paul zhang paulhuaizhang at gmail.com
Mon Dec 1 10:43:35 CST 2014
Matt,
Thanks for your reply. I am able to compile PETSc. And I went through the
default tests. Now when I go to my code, I got problems.
[hzh225 at dlxlogin2-1 petsc-3.5]$ make all
[100%] Building CXX object CMakeFiles/kats.dir/main.cc.o
/home/hzh225/LIB_CFD/nP/petsc-3.5.2/include/petscsys.h(1760): catastrophic
error: cannot open source file "valgrind/valgrind.h"
  #  include <valgrind/valgrind.h>
compilation aborted for /home/hzh225/CMake/petsc/petsc-3.5/main.cc (code 4)
make[2]: *** [CMakeFiles/kats.dir/main.cc.o] Error 4
make[1]: *** [CMakeFiles/kats.dir/all] Error 2
make: *** [all] Error 2
Huaibao (Paul) Zhang
*Gas Surface Interactions Lab*
Department of Mechanical Engineering
University of Kentucky,
Lexington,
KY, 40506-0503
*Office*: 216 Ralph G. Anderson Building
*Web*:gsil.engineering.uky.edu
On Mon, Dec 1, 2014 at 11:28 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Dec 1, 2014 at 10:21 AM, paul zhang <paulhuaizhang at gmail.com>
> wrote:
>> Hi All,
>> How to enable the valgrind flag? I installed that by myself locally.
>>       It appears you do not have valgrind installed on your system.
>>                  We HIGHLY recommend you install it from www.valgrind.org
>>                             Or install valgrind-devel or equivalent using
>> your package manager.
>>                                        Then rerun ./configure
> We could not find the valgrind header (valgrind.h). You can use
>   --with-valgrind-dir=<path>
> so that it can find the path/include/valgrind/valgrind.h
>   Thanks,
>     Matt
>> Thanks,
>> Paul
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141201/551df207/attachment.html>
