[petsc-users] superlu_dist and MatSolveTranspose
Antoine De Blois antoine.deblois at aero.bombardier.com
Fri Aug 29 14:58:40 CDT 2014
Hello Jed,
Thank you for your quick response. So I spent some time to dig deeper into my problem. I coded a shell script that passes through a bunch of ksp_type, pc_type and sub_pc_type. So please disregard the comment about the "does not converge properly for transpose". I had taken that conclusion from my own code (and not from the ex10 and extracted matrix), and a KSPSetFromOptions was missing. Apologies for that.
What remains is the performance issue. The MatSolveTranspose takes a very long time to converge. For a matrix of 3 million rows, MatSolveTranspose takes roughly 5 minutes on 64 cpus, whereas the MatSolve is almost instantaneous!. When I gdb my code, petsc seems to be stalled in the MatLUFactorNumeric_SeqAIJ_Inode () for a long time. I also did a top on the compute node to check the RAM usage. It was hovering over 2 gig, so memory usage does not seem to be an issue here.
#0  0x00002afe8dfebd08 in MatLUFactorNumeric_SeqAIJ_Inode ()
   from /gpfs/fs2/aero/SOFTWARE/FLOW_SOLVERS/FANSC/EXT_LIB/petsc-3.5.1/lib/libpetsc.so.3.5
#1  0x00002afe8e07f15c in MatLUFactorNumeric ()
#2  0x00002afe8e2afa99 in PCSetUp_ILU ()
#3  0x00002afe8e337c0d in PCSetUp ()
#4  0x00002afe8e39d643 in KSPSetUp ()
#5  0x00002afe8e39e3ee in KSPSolveTranspose ()
#6  0x00002afe8e300f8c in PCApplyTranspose_ASM ()
#7  0x00002afe8e338c13 in PCApplyTranspose ()
#8  0x00002afe8e3a8a84 in KSPInitialResidual ()
#9  0x00002afe8e376c32 in KSPSolve_GMRES ()
#10 0x00002afe8e39e425 in KSPSolveTranspose ()
For that particular application, I was using:
ksp_type:			gmres
pc_type:			asm
sub_pc_type:			ilu
adj_sub_pc_factor_levels 	1
For small matrices, the MatSolveTranspose computing time is very similar to the simple MatSolve.
And if I want to revert to a MatTranspose followed by the MatSolve, then the MatTranspose takes forever to finish... For a matrix of 3 million rows, MatTranspose takes 30 minutes on 64 cpus!!
So thank you for implementing the transpose solve in superlu_dist. It would also be nice to have it with hypre.
Let me know what you think and ideas on how to improve my computational time,
Antoine
-----Message d'origine-----
De : Jed Brown [mailto:jed at jedbrown.org]
Envoyé : Thursday, August 28, 2014 5:01 PM
À : Antoine De Blois; 'petsc-users at mcs.anl.gov'
Objet : Re: [petsc-users] superlu_dist and MatSolveTranspose
Antoine De Blois <antoine.deblois at aero.bombardier.com> writes:
> Hello everyone,
> I am trying to solve a A^T x = b system. For my applications, I had
> realized that the MatSolveTranspose does not converge properly.
What do you mean "does not converge properly"?  Can you send a test case where the transpose solve should be equivalent, but is not?  We have only a few tests for transpose solve and not all preconditioners support it, but where it is supported, we want to ensure that it is correct.
> Therefore, I had implemented a MatTranspose followed by a MatSolve.
> This proved to converge perfectly (which is strange since the
> transposed matrix has the same eigenvalues as the untransposed...).
> The problem is that for bigger matrices, the MatTranspose is very
> costly and thus cannot be used.
Costly in terms of memory?  (I want you to be able to use KSPSolveTranspose, but I'm curious what you're experiencing.)
> I tried using the superlu_dist package. Although it the package works perfectly for the MatSolve, I get the an "No support for this operation for this object type" error  with MatSolveTransopse. I reproduced the error using the MatView an ex10 tutorial. I can provide the matrix and rhs upon request. My command line was:
> ex10 -f0 A_and_rhs.bin -pc_type lu -pc_factor_mat_solver_package
> superlu_dist -trans
> So it there an additional parameter I need to use for the transposed solve?
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: No support for this operation for this object type
> [0]PETSC ERROR: Matrix type mpiaij
This is easy to add.  I'll do it now.
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.5.1, unknown [0]PETSC ERROR:
> /gpfs/fs1/aero/SOFTWARE/TOOLS/PROGRAMMING/petsc/src/ksp/ksp/examples/t
> utorials/ex10 on a ARGUS_impi_opt named hpc-user11 by ad007804 Thu Aug
> 28 16:41:15 2014 [0]PETSC ERROR: Configure options --CFLAGS="-xHost
> -axAVX" --download-hypre --download-metis --download-ml
> --download-parmetis --download-scalapack --download-superlu_dist
> --download-mumps --with-c2html=0 --with-cc=mpiicc --with-fc=mpiifort
> --with-cxx=mpiicpc --with-debugging=yes
> --prefix=/gpfs/fs1/aero/SOFTWARE/TOOLS/PROGRAMMING/petsc/petsc-3.5.1
> --with-cmake=/gpfs/fs1/aero/SOFTWARE/TOOLS/CMAKE/cmake-2.8.7/bin/cmake
> --with-valgrind=/gpfs/fs1/aero/SOFTWARE/TOOLS/PROGRAMMING/valgrind-3.9
> .0/bin/valgrind --with-shared-libraries=0 [0]PETSC ERROR: #1
> MatSolveTranspose() line 3473 in
> /gpfs/fs2/aero/SOFTWARE/TOOLS/PROGRAMMING/petsc/src/mat/interface/matr
> ix.c [0]PETSC ERROR: #2 PCApplyTranspose_LU() line 214 in
> /gpfs/fs2/aero/SOFTWARE/TOOLS/PROGRAMMING/petsc/src/ksp/pc/impls/facto
> r/lu/lu.c [0]PETSC ERROR: #3 PCApplyTranspose() line 573 in
> /gpfs/fs2/aero/SOFTWARE/TOOLS/PROGRAMMING/petsc/src/ksp/pc/interface/p
> recon.c [0]PETSC ERROR: #4 KSP_PCApply() line 233 in
> /gpfs/fs2/aero/SOFTWARE/TOOLS/PROGRAMMING/petsc/include/petsc-private/
> kspimpl.h [0]PETSC ERROR: #5 KSPInitialResidual() line 63 in
> /gpfs/fs2/aero/SOFTWARE/TOOLS/PROGRAMMING/petsc/src/ksp/ksp/interface/
> itres.c [0]PETSC ERROR: #6 KSPSolve_GMRES() line 234 in
> /gpfs/fs2/aero/SOFTWARE/TOOLS/PROGRAMMING/petsc/src/ksp/ksp/impls/gmre
> s/gmres.c [0]PETSC ERROR: #7 KSPSolveTranspose() line 704 in
> itfunc.c [0]PETSC ERROR: #8 main() line 324 in
> utorials/ex10.c
> FYI, the transpose solve is a typical application for adjoint optimization. There should be a big adjoint community of developers that try to solve the transposed matrix.
> Any help is much appreciated,
> Best,
> Antoine
> Antoine DeBlois
> Specialiste ingenierie, MDO lead / Engineering Specialist, MDO lead
> Aéronautique / Aerospace 514-855-5001, x 50862
> antoine.deblois at aero.bombardier.com<mailto:antoine.deblois at aero.bombar
> dier.com>
> 2351 Blvd Alfred-Nobel
> Montreal, Qc
> H4S 1A9
> [Description : Description :
> http://signatures.ca.aero.bombardier.net/eom_logo_164x39_fr.jpg]
> CONFIDENTIALITY NOTICE - This communication may contain privileged or confidential information.
> If you are not the intended recipient or received this communication
> by error, please notify the sender and delete the message without
> copying
