[petsc-users] PETSC-3.5.0 with SuperLU and Hypre
Kai Song ksong at lbl.gov
Fri Aug 29 12:01:06 CDT 2014
Hi Satish,
Here is the command that I ran:
$ make --version
GNU Make 3.81
Copyright (C) 2006  Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for x86_64-redhat-linux-gnu
$ make allclean
$ make PETSC_DIR=/clusterfs/voltaire/home/software/source/petsc-3.5.0
PETSC_ARCH=arch-linux2-c-debug all
Both make.log and arch-linux2-c-debug/conf/files are in the attachment.
Kai
On Fri, Aug 29, 2014 at 9:47 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Fri, 29 Aug 2014, Satish Balay wrote:
> > src/ksp/pc/impls/hypre/hypre.c is listed in files.
> > However make.log is empty.
> > Can you do 'make allclean' again' and resend
> Sorry should have said:
> make allclean
> make all
> And resend logs.
> satish
> > And what do you have for:
> > make --version
> > Satish
> > On Fri, 29 Aug 2014, Kai Song wrote:
> > > Hi Satish and Jed,
> > > I did a "make allclean", and reconfigured with
> "-with-shared-libraries=0".
> > > I am still seeing the same error.
> > > Then I deleted arch-linux2-c-debug/conf/files, and remake. The "make
> test"
> > > failed again.
> > > I have attached the new configure.log, make.log, and
> > > rch-linux2-c-debug/conf/files in this email.
> > > Thanks,
> > > Kai
> > > On Fri, Aug 29, 2014 at 9:25 AM, Jed Brown <jedbrown at mcs.anl.gov>
> wrote:
> > > > Matthew Knepley <knepley at gmail.com> writes:
> > > > > On Fri, Aug 29, 2014 at 10:59 AM, Kai Song <ksong at lbl.gov> wrote:
> > > > >> Hi Matt,
> > > > >> Thanks for the quick response. Both logs are included in the
> attachment.
> > > > >> Let me know if more log files are needed.
> > > > > Jed, why does this not enter src/mat/impls/aij/seq/superlu?
> > > > Kai, can you delete
> > > > and re-run make (it should regenerate this file).  If superlu is not
> > > > compiled, please send the contents of that file.
Kai Song
<ksong at lbl.gov> 1.510.495.2180
1 Cyclotron Rd. Berkeley, CA94720, MS-50B 3209
High Performance Computing Services (HPCS)
Lawrence Berkeley National Laboratory - http://scs.lbl.gov
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140829/abaac0f0/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140829/abaac0f0/attachment-0001.obj>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140829/abaac0f0/attachment-0001.bin>
