[petsc-users] PCFieldSplitSetSchurPre in fortran
Fri Aug 29 09:14:53 CDT 2014
On Fri, Aug 29, 2014 at 8:55 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> I'm trying PCFieldSplitSetSchurPre with
> PC_FIELDSPLIT_SCHUR_PRE_SELFP in petsc-3.5.1 using fortran.
> The first problem is that PC_FIELDSPLIT_SCHUR_PRE_SELFP seems to
> be missing in fortran, I get the compile error:
> This name does not have a type, and must have an explicit type.
>  [PC_FIELDSPLIT_SCHUR_PRE_SELFP]
> while compilation works fine with _A11, _SELF and _USER.
Mark Adams has just fixed this.
> The second problem is that the call doesn't seem to have any
> effect. For example, I have
> CALL PCFieldSplitSetSchurPre(pc,PC_FIELDSPLIT_SCHUR_PRE_USER,aa,ierr)
> CALL PCFieldSplitSetSchurFactType(pc,PC_FIELDSPLIT_SCHUR_FACT_LOWER,ierr)
> This compiles and runs, but ksp_view tells me
> PC Object:(sys_) 3 MPI processes
>   type: fieldsplit
>     FieldSplit with Schur preconditioner, factorization LOWER
>     Preconditioner for the Schur complement formed from A11
> So changing the factorization from the default FULL to LOWER did
> work, but changing the preconditioner from A11 to USER didn't.
> I've also tried to run directly from the command line using
> -sys_pc_fieldsplit_schur_precondition user -sys_ksp_view
> This works in the sense that I don't get the "WARNING! There are
> options you set that were not used!" message, but still ksp_view
> reports A11 instead of user provided matrix.
Can you send a small test code, since I use this everyday here and it works.
     Matt
> Chris
> dr. ir. Christiaan Klaij
> CFD Researcher
> Research & Development
> E mailto:C.Klaij at marin.nl
> T +31 317 49 33 44
> MARIN
> 2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
> T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140829/4affbdb5/attachment.html>
