[petsc-users] Operations available for different types?
murat keçeli keceli at gmail.com
Tue Aug 26 21:35:35 CDT 2014
>    Since sbaij only stores the above diagonal half of the matrix getting the row mins is more complicated and would require communication.
> Hence we have not implemented. What do you want it for?
I see. I was just trying to get some metrics about the matrices I
have. I am actually curious in a more general way, to figure out which
operations are implemented for a specific type. I thought that there
might be a table somewhere showing available operations for different
matrix types. I guess the only way currently is to grep the source
code.
Thank you,
Murat
On Tue, Aug 26, 2014 at 5:13 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Aug 26, 2014, at 12:58 PM, murat keçeli <keceli at gmail.com> wrote:
> > Hi,
> > I tried to use MatGetRowMinAbs and found that it's not available for seqsbaij type.
>    Since sbaij only stores the above diagonal half of the matrix getting the row mins is more complicated and would require communication. Hence we have not implemented. What do you want it for?
>    barry
> > Docs say "This code is only implemented for a couple of matrix formats" but doesn't tell which ones. What is the best way to find out which operations are available for certain types?
> > Thank you,
> > Murat Keceli
