[petsc-users] Identifying mesh points within DMPlex FEM
Justin Chang jychang48 at gmail.com
Tue Aug 26 02:11:47 CDT 2014
Matt,
I see how parameters (e.g., nu) change across the domain, but from what I
understand they are all functions of the point coordinate x[ ]. This would
be no problem if my parameters were analytical functions as shown in your
examples or if the domain has several nicely layered regions which can be
easily distinguished (i.e., I could simply use conditionals to determine a
mesh point's region based on the coordinates).
However, what if I wanted nu (or any parameter for that matter) to be
supplied through a user created data file? In PFLOTRAN, that's how physical
data and parameters are associated with a given cell or mesh point. Here's
the way I imagine my PETSc code would look using DMPlex:
1) Create DMPlex mesh from an input mesh file
2) Read data file that links physical parameters (e.g., diffusivity,
source, etc) to DMPlex mesh points. This should create some sort of data
structure or Vec that maps these parameters to the corresponding DMPlex
mesh points.
3) Set up FEM discretization and boundary conditions. Like the physical
parameters, boundary conditions are also generated/specified through the
data file.
4) Solve problem
5) Post-process solution to mesh file.
In step 4, the pointwise functions f0_u, f1_u, g3_uu, etc are called upon
for each element/mesh point iteration. I suppose my question is, is there
any way to incorporate the data formulated from step 2 into said pointwise
functions?
Justin
On Mon, Aug 25, 2014 at 4:33 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Aug 25, 2014 at 2:10 PM, Justin Chang <jychang48 at gmail.com> wrote:
>> Hi all,
>> In the discretization schemes for the DMPlex FEM examples (ex12 and
>> ex62), it lets us specify equations as pointwise functions. But what if I
>> wanted to assign "regions" to different points within the domain? In one of
>> my problems, I want the diffusivity tensor and/or forcing function to
>> differ for various layers/regions within the computational domain. I would
>> imagine calling something like DMPlexGetLabelValue() to identify a region
>> associated with a given mesh point but is it possible to do something like
>> this within the f0/f1/g3/etc functions?
> 1) Changing parameters across the domain is straightforward. ex12 does
> this for "diffusivity".
> 2) Changing the function across the domain should probably be accomplished
> by changing
>      a marker parameter, which is checked inside the function itself.
>    Matt
>> Thanks,
>> Justin
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140826/688cbb93/attachment.html>
