[petsc-users] flops performed on each processor
Xiangdong epscodes at gmail.com
Fri Aug 22 13:58:06 CDT 2014
simply replacing -log_summary with -log_view ::ascii_info_detail does not
produce anything. (Sams as -log_view ascii:filename:ascii_info_detail.)
Where does it dump the log? Is this the feature of new petsc? I am using
petsc-3.4.3.
Thanks.
Xiangdong
On Fri, Aug 22, 2014 at 2:53 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Aug 22, 2014, at 1:28 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Fri, Aug 22, 2014 at 1:24 PM, Xiangdong <epscodes at gmail.com> wrote:
> > Hello everyone,
> > In the PETSc log_summary, it outputs the Max flops, the ratio of Max/Min
> flops. If it is far from 1.0, I would like to know the distributions of
> flops among all the procs. How can I obtain the flops performed on each
> proc?
>   We don’t have it properly documented yet but this outputs python
> dictionaries that contain the various performance counters for each process
> and stages and events. You can then write simple Python code to process the
> data any way you like, for example plotting distributions etc. I recommend
> starting by collecting data for just 2 or 3 processes and using that data
> to write your python scripts. Once you have the scripts you want you can
> make parallel runs with more processes and use the already debugged scripts.
> >   Thanks,
> >      Matt
> > Thank you.
> > Best,
> > Xiangdong
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140822/10a0abd4/attachment.html>
