[petsc-users] Use of PCFieldSplitSetSchurPre
Jed Brown jed at jedbrown.org
Thu Aug 21 16:11:52 CDT 2014
Mark Adams <mfadams at lbl.gov> writes:
> I have fixed this by setting the KSP op:
>        call PCFieldSplitGetSubKSP(spc,i,subksp,ierr)
>        call KSPSetOperators(subksp(2),solver%schur,solver%schur,ierr)
Mark, where is the information getting lost?  If the interface does not
work correctly, we (PETSc) need to fix the interface, not just find a
workaround.  That's why I suggested running in a debugger.
> Thanks,
>> > I am creating an Schur complement matrix explicitly (solver%schur) and
>> > setting it with code like:
>> > call SNESGetKSP(solver%snes,innerksp,ierr)
>> > call KSPGetPC(innerksp,spc,ierr)
>> > call
>> PCFieldSplitSetSchurPre(spc,PC_FIELDSPLIT_SCHUR_PRE_USER,solver%schur,ierr)
>> > I would think that the "inner" solver would not be used but it is getting
>> > used.
>> > PC Object:(fsa_) 4 MPI processes
>> >   type: fieldsplit
>> >     FieldSplit with Schur preconditioner, factorization FULL
>> >     Preconditioner for the Schur complement formed from A11
>> I would set a breakpoint at PCFieldSplitSetSchurPre_FieldSplit and then
>> watch -l jac->schurpre since it appears that your information is being
>> lost somewhere.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140821/71a4a34a/attachment.pgp>
