[petsc-users] Computing Vector Norm Field wise
Thu Aug 21 10:00:31 CDT 2014
On Mon, Aug 18, 2014 at 2:42 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Aug 18, 2014 2:28 PM, "Luc Berger-Vergiat" <lb2653 at columbia.edu> wrote:
> > Hi all,
> > I am using the fieldsplit/DM facility to work on a multiphysics problem.
> > I would like to get some field dependent convergence information.
> > Is there something similar to the VecStrideNorm function that can
> compute a residual for each field defined in the DM?
> > Or should I use the DM to extract subvectors and compute their norms?
> I wroteca monitor that does this. I am currently out of internet range,
> but I will mail it Wed when I get back.
Okay, what I have is not exactly what you want. I wrote something to look
at the errors by field:
    ierr = DMPlexComputeL2FieldDiff(dm, user->exactFuncs, (void *) ctxs, u,
ferror);CHKERRQ(ierr);
but you want the residual. If we do not care too much about performance, we
can easily do this using
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecGetSubVector.html
and then VecNorm, where we get the IS from
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitGetIS.html
You can write a simple monitor that calls these two.
     Matt
>  Thanks
>       Matt
> > Best,
> > Luc
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140821/97e4668e/attachment.html>
