[petsc-users] Convert matrix to 1-D array
priyank patel priyankpatel22 at live.com
Tue Aug 19 11:39:29 CDT 2014
Hello,
 I have a matrix generated from matrix matrix multiplication. I want that matrix to convert to 1 dimensional array. my code is as below
	//Multiplication A * B (A is MPIAIJ & B is MPIDENSE)
	MatMatMult(A, B,  MAT_INITIAL_MATRIX,  PETSC_DEFAULT, &C);
	MatView(C,PETSC_VIEWER_STDOUT_WORLD);
	//Convert Matrix C to 1D vector h_C
	for(i = 0; i < m; i++)
		for(j = 0; j < k; j++)
			ierr = MatGetValues(C, 1, &i, 1, &j, &h_C[IDX2C(i,j,end1)]);CHKERRQ(ierr);
	//printArray(h_B, m, k, "h_B");
	printArray(h_C, m, k, "A * X0");
when I tried the routine MatGetValues() it shows some error as below
--------------------- Error Message ------------------------------------
[1]PETSC ERROR: No support for this operation for this object type!
[1]PETSC ERROR: Only local values currently supported!
[1]PETSC ERROR: ------------------------------------------------------------------------
[1]PETSC ERROR: Petsc Release Version 3.3.0, Patch 0, Tue Jun  5 14:20:42 CDT 2012
[1]PETSC ERROR: See docs/changes/index.html for recent updates.
[1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[1]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR: ./blockCG_1 on a arch-linu named hpcd.cs.odu.edu by ppatel Tue Aug 19 12:29:41 2014
[1]PETSC ERROR: Libraries linked from /export/software/petsc-3.3/lib
[1]PETSC ERROR: Configure run at Wed Jun  6 16:29:21 2012
[1]PETSC ERROR: Configure options --prefix=/export/software/petsc-3.3 --download-f-blas-lapack=1
[1]PETSC ERROR: MatGetValues_MPIDense() line 180 in src/mat/impls/dense/mpi/mpidense.c
[1]PETSC ERROR: MatGetValues() line 1602 in src/mat/interface/matrix.c
[1]PETSC ERROR: main() line 343 in blockCG_1.c
MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
with errorcode 56.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
what is the efficient way to create a 1-D array from the PETSC matrix?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140819/fa842a2b/attachment-0001.html>
