[petsc-users] Solving tridiagonal hermitian generalized eigenvalue problem with SLEPC
Jed Brown jed at jedbrown.org
Tue Aug 19 08:40:35 CDT 2014
Toon Weyens <tweyens at fis.uc3m.es> writes:
> Okay I reread again your answers and it seems that I missed the fact that I
> do not need shift invert to find the EV with the largest real part?
Correct, inversion is way more expensive and used to find internal
eigenvalues.
> Then the "trick" of ex. 13 does not apply (they look for something
> close to 0).  So what could I do to avoid the LU?
Is your matrix B singular?  What are its boundary conditions?  You have
to solve with B for the generalized eigenvalue problem.  That could be
done iteratively, but a direct solve makes sense for a tridiagonal
system and the zero pivot likely indicates a deeper issue with the
formulation that won't vanish simply by avoiding LU.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140819/7753f6c5/attachment.pgp>
