[petsc-users] how to install two different version petsc in the same pc
Jed Brown jed at jedbrown.org
Mon Aug 18 07:47:37 CDT 2014
丁老师 <ztdepyahoo at 163.com> writes:
> how to set the PETSC_DIR with two different  value.
It is an environment variable used with PETSc makefiles (see the users
manual for more on PETSC_DIR and PETSC_ARCH).  If you use a different
configuration system (autotools, cmake, etc.) then it will probably
respect the environment variable at configure time, plus offer some
flags to set as an alternative.  We recommend using PETSc makefiles when
possible.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140818/25d43cca/attachment-0001.pgp>
