[petsc-users] Data Distribution from zero-rank process
Mari Pecha pecha.mari at gmail.com
Tue Aug 12 08:53:33 CDT 2014
Good morning,
I'm Mari and I'm beginner PETSc user and I'd like to ask about tough
problem, especially for me.
I solve problem of data-set distribution, which are saved only on
zero-rank process, to DMDA global vector. It means that every process
stores a appropriate  subset of data-set. I used
DMDAGlobalToNaturalAllCreate and DMDANaturalAllToGlobalCreate function,
and then VecScatterBegin and VecScatterEnd functions ... see please code
below
     ierr = DMDAGlobalToNaturalAllCreate( da, &tolocalall   );
CHKERRQ(ierr);
     ierr = DMDANaturalAllToGlobalCreate( da, &fromlocalall );
CHKERRQ(ierr);
     if( rank == 0  )
         ierr = VecCreateSeq( PETSC_COMM_SELF, SIZE, &localall );
         ierr = VecScatterBegin( tolocalall, x, localall, ADD_VALUES,
SCATTER_FORWARD_LOCAL ); CHKERRQ(ierr);
         ierr = VecScatterEnd(   tolocalall, x, localall, ADD_VALUES,
         ierr = VecGetArray( x, &vlocal ); CHKERRQ(ierr);
         PetscInt s;
         VecGetSize( localall, &s );
         ierr = VecView( localall, PETSC_VIEWER_STDOUT_SELF ); CHKERRQ(
ierr );
         //create data on zero rank process
         for ( int i = 0; i < s; i++) *vlocal++ = i;
         ierr = VecRestoreArray( localall, &vlocal ); CHKERRQ(ierr);
         ierr = VecScatterBegin(fromlocalall, localall, x, ADD_VALUES,
         ierr = VecScatterEnd(  fromlocalall, localall, x, ADD_VALUES,
But the piece of code gets and distributes only vector-values belong to
zero-rank process. So, I haven't any idea how can I solve my problem
only with PETSc functions. I'd like to get all values from global vector
to zero-rank process and put back all data-set only from zero-rank to
global vector. Can you help me, please?
Thanks for your response
Mari
