[petsc-users] KSPSolve crashes with petsc-3.5.1
Mon Aug 11 15:15:28 CDT 2014
On Mon, Aug 11, 2014 at 2:53 PM, Alexander Grayver <agrayver at gfz-potsdam.de>
wrote:
> Dear PETSc devs,
> I am getting the following error with petsc-3.5.1:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Null argument, when expecting valid pointer
> [0]PETSC ERROR: Null Object: Parameter # 1
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.5.1, Jul, 24, 2014
> [0]PETSC ERROR: /build/main on a openmpi-gcc-double-debug-c-shared named
> e1334 by ag Mon Aug 11 18:42:07 2014
> [0]PETSC ERROR: Configure options
> --with-petsc-arch=openmpi-gcc-double-debug-c-shared --with-x=0
> --download-mumps --download-metis --download-scalapack --download-blacs
> --with-scalar-type=real --download-blas-lapack --with-precision=double
> --download-parmetis --with-shared-libraries=1 --with-debugging=1
> --with-hypre-dir=/lib/hypre-2.9.1a --download-fblaslapack=1
> [0]PETSC ERROR: #1 PetscObjectStateGet() line 38 in
> /lib/petsc-3.5.1/src/sys/objects/state.c
> [0]PETSC ERROR: #2 PCSetUp() line 875 in
> /lib/petsc-3.5.1/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #3 KSPSetUp() line 305 in
> /lib/petsc-3.5.1/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #4 KSPSolve() line 417 in
> I have used LSQR here which was setup in the following way:
>   KSPCreate(communicator, &ksp);
>   KSPSetType(ksp, KSPLSQR);
>   KSPSetTolerances(ksp, tol, PETSC_DEFAULT, PETSC_DEFAULT, max_iterations);
>   KSPSetFromOptions(ksp);
>   KSPGetPC(ksp, &pc);
>   PCSetType(pc, PCNONE);
>   KSPSetOperators(ksp, A, PETSC_NULL);
You want 'A' instead of 'PETSC_NULL' above. We just had no check before.
     Matt
>   KSPSolve(ksp, b, x);
> The code works fine with petsc-3.4.4 (provided that I pass
> DIFFERENT_NONZERO_PATTERN to the KSPSetFromOptions). Any idea?
> Regards,
> Alexander
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140811/12295a6d/attachment-0001.html>
