[petsc-users] Error to TaoSolve() call
Jason Sarich jason.sarich at gmail.com
Mon Aug 11 10:17:28 CDT 2014
Hello Khai
The likely culprit is in petsc/src/vec/vec/utils/projection.c, at the
end of the VecMedian() there are three calls to VecRestore(), the last
of which is wrong and needs to be corrected and recompiled:
@@ -852,7 +852,7 @@ PetscErrorCode VecMedian(Vec Vec1, Vec Vec2, Vec
Vec3, Vec VMedian)
   ierr = VecRestoreArray(Vec1,&v1);CHKERRQ(ierr);
   ierr = VecRestoreArray(Vec2,&v2);CHKERRQ(ierr);
-  ierr = VecRestoreArray(Vec3,&v2);CHKERRQ(ierr);
+  ierr = VecRestoreArray(Vec3,&v3);CHKERRQ(ierr);
   if (VMedian!=Vec1 && VMedian != Vec2 && VMedian != Vec3){
     ierr = VecRestoreArray(VMedian,&vmed);CHKERRQ(ierr);
Jason Sarich
On Mon, Aug 11, 2014 at 9:23 AM, Khai Hong Pham <khaipham at utexas.edu> wrote:
> Hello,
> I call TaosSolve() in my code. The solution vector is a nested and Jacobian
> matrix is nested too. It shows me the error:
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC ERROR:
> or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
> corruption errors
> [1]PETSC ERROR: [0]PETSC ERROR: likely location of problem given in stack
> below
> [0]PETSC ERROR: ---------------------  Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> [0]PETSC ERROR:       is given.
> [0]PETSC ERROR: [0] VecRestoreArray_Nest line 731
> /home/khp/bin/petsc-3.5.1/src/vec/vec/impls/nest/vecnest.c
> [0]PETSC ERROR: [0] VecRestoreArray line 1656
> /home/khp/bin/petsc-3.5.1/src/vec/vec/interface/rvector.c
> [0]PETSC ERROR: [0] VecMedian line 806
> /home/khp/bin/petsc-3.5.1/src/vec/vec/utils/projection.c
> [0]PETSC ERROR: [0] TaoSolve_SSILS line 52
> /home/khp/bin/petsc-3.5.1/src/tao/complementarity/impls/ssls/ssils.c
> [0]PETSC ERROR: [0] TaoSolve line 171
> /home/khp/bin/petsc-3.5.1/src/tao/interface/taosolver.c
> I debugged with valgrind and received the following message:
> ==19424== Invalid read of size 8
> ==19424==    at 0x54089E4: VecRestoreArray_Nest (vecnest.c:746)
> ==19424==    by 0x53F5F6F: VecRestoreArray (rvector.c:1666)
> ==19424==    by 0x54BE874: VecMedian (projection.c:855)
> ==19424==    by 0x6247B74: TaoSolve_SSILS (ssils.c:59)
> ==19424==    by 0x620739E: TaoSolve (taosolver.c:188)
> ==19424==    by 0x40491C: main (main.cpp:265)
> ==19424==  Address 0x0 is not stack'd, malloc'd or (recently) free'd
> It looks like the bug relates to the nested vector. Could you please give me
> a hint to locate the bug? Thanks.
> Khai
