[petsc-users] Variable and function reference problem in Windows & Linux
Jed Brown jed at jedbrown.org
Thu Aug 7 11:27:08 CDT 2014
Danyang Su <danyang.su at gmail.com> writes:
> Hi All,
> I have the codes first developed on Windows OS, it works fine. Now the
> codes have been ported to Linux, there are some compiling errors
> regarding some variable and function definition, as shown below.
> 1. DMDA_BOUNDARY_NONE & DM_BOUNDARY_NONE
> I should use DMDA_BOUNDARY_NONE on windows and DM_BOUNDARY_NONE on
> linux, otherwise, there will be like undefined type.
Looks like you upgraded PETSc.
  * DMDABoundaryType has become DMBoundaryType, and all the enumeration
    values have also been renamed.
  http://www.mcs.anl.gov/petsc/documentation/changes/35.html
> 2. DMDAGetGlobalIndicesF90
> This function works fine on Windows but results into undefined reference
> on Linux.
  * DMDAGetGlobalIndices(DM,PetscInt*,const PetscInt*[]) and
    DMDARestoreGlobalIndices(DM,PetscInt*,const PetscInt*[]) are
    removed, use DMGetLocalToGlobalMapping() to get this information
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140807/2c3e6f06/attachment.pgp>
