[petsc-users] Interior eigenvalues with slepc and shell matrix
John Travers jtravs at gmail.com
Thu Aug 7 09:43:47 CDT 2014
On 07 Aug 2014, at 14:31, Jose E. Roman <jroman at dsic.upv.es> wrote:
> El 07/08/2014, a las 14:05, John Travers escribió:
>> On 07 Aug 2014, at 13:30, Jose E. Roman <jroman at dsic.upv.es> wrote:
>>> -st_type precond
>> I tried that and got:
>> [0]PETSC ERROR: No support for this operation for this object type
>> [0]PETSC ERROR: EPSGD only works with KSPPREONLY
>> So I set:
>> -st_ksp_type preonly
>> and get:
>> [0]PETSC ERROR: ST does not have apply
>> My full command line is currently:
>> -eps_nev 1 -eps_tol 1e-10 -eps_type gd -st_type precond -st_ksp_type preonly
>> I also tried
>> -st_matmode shell
>> But it made no difference.
>> Really, thank you very much for your patience. I’m trying to educate myself
>> about slepc (which is awesome BTW, so thank you), but there are a huge
>> number of options!
> These options work well with SLEPc's ex1.c, so you must have something different in your source code. Send the code excerpt that sets EPS/ST options.
> Jose
Yes, of course you were correct. I was doing something strange with the ST object. It now works. Thanks again for your help!
John
