[petsc-users] trying to solve a lot of ksp problems quickly
Francis Poulin fpoulin at uwaterloo.ca
Wed Aug 6 18:50:38 CDT 2014
Hello,
I am trying to figure out a faster way of doing in petsc4py and thought I would ask to see how this should be done in petsc.  If I can figure that out then I think I can figure out how to translate it but I am having issues with the basic algorithm I should be using.
I am solving a linear system of ODEs of the form
B du/dt = A u
using Crank-Nicholson.  So the update equation can be written as
(B - dt/2*A)*u^(n+1) = (B + dt/2*A)*u^n
or, if you don't mind using the backslash operator,
u^(n+1) = (B - dt/2*A)\(B + dt/2*A)*u^n
The integration is faster of course after I build the matrix
C = (B - dt/2*A)\(B + dt/2*A)
however building this is very slow and I am not sure how to build it efficiently.  At the moment the majority of my code is just doing that.
In petsc4py I do the following:
(you can find the full code at https://github.com/francispoulin/qg_1L_ts/blob/master/qg_1L_ts.py)
        AeT = PETSc.Mat().createAIJ([Ny-1,Ny-1])
        AeT.setUp(); AeT.assemble()
        ksp = PETSc.KSP().create(PETSc.COMM_WORLD)
        ksp.setOperators(B-dto2*A)
        ksp.setTolerances(1e-16)
        pc = ksp.getPC()
        pc.setType('none')
        ksp.setFromOptions()
        btemp = B+dto2*A
        btemp.assemble()
        bcol = PETSc.Vec().createMPI(Ny-1)
        xcol = PETSc.Vec().createMPI(Ny-1)
        bcol.setUp(); xcol.setUp()
        sc,ec = bcol.getOwnershipRange()
        for i in range(0,Ny-1):
            bcol[sc:ec] = btemp[sc:ec,i]
            bcol.assemble(); xcol.assemble()
            ksp.solve(bcol,xcol)
            AeT[sc:ec,i] = xcol[sc:ec]
       AeT.assemble()
We are building the matrix one row at a time and, as accurate as that maybe, it is very slow.  Is there perhaps a fast way of doing this kind of operation in petsc?
Sorry for the bother but any advice would be greatly appreciated.
Cheers, Francis
Francis Poulin
Associate Professor
Associate Chair, Undergraduate Studies
Department of Applied Mathematics
University of Waterloo
email:           fpoulin at uwaterloo.ca
Web:            https://uwaterloo.ca/poulin-research-group/
Telephone:  +1 519 888 4567 x32637
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140806/219fce01/attachment-0001.html>
