[petsc-users] valgrind error messages with PETSc V3.5.1
Mon Aug 4 23:55:07 CDT 2014
   Randy,
   Thanks, this is now fixed in master, maint, and next and will be fixed in the next patch release.
   Barry
On Aug 4, 2014, at 5:14 PM, Randall Mackie <rlmackie862 at gmail.com> wrote:
> Barry,
> Yes, that fixes the problem.
> Thanks, Randy
> On Aug 4, 2014, at 1:49 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  Randall,
>>   If you replace the PetscStrncpy(b,a,n+1);  with PetscStrncpy(b,a,n);
>> #define FIXCHAR(a,n,b) \
>> if (a == PETSC_NULL_CHARACTER_Fortran) { \
>>   b = a = 0; \
>> } else { \
>>   while((n > 0) && (a[n-1] == ' ')) n--; \
>>   *ierr = PetscMalloc((n+1)*sizeof(char),&b); \
>>   if (*ierr) return; \
>>   *ierr = PetscStrncpy(b,a,n+1); \
>>   b[n] = 0; \
>> in include/petsc-private/fortranimpl.h and recompile the PETSc libraries does the problem go away?
>> Let me know and I’ll fix the code.
>>  Thanks
>>  Barry
>> On Aug 2, 2014, at 2:20 PM, Randall Mackie <rlmackie862 at gmail.com> wrote:
>>> The attached small program, basically a call to PetscPrintf, gives the following valgrind errors:
>>> [rmackie ~/tst_petsc_problem] ./cmd_test
>>> ==24812== Invalid read of size 1
>>> ==24812==    at 0x4C2E500: __GI_strncpy (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
>>> ==24812==    by 0x4EF5B4D: PetscStrncpy (str.c:335)
>>> ==24812==    by 0x4F334E0: petscprintf_ (zmprintf.c:54)
>>> ==24812==    by 0x400F28: MAIN__ (test.F90:11)
>>> ==24812==    by 0x400F9A: main (test.F90:16)
>>> ==24812==  Address 0x8cef9bb is 0 bytes after a block of size 11 alloc'd
>>> ==24812==    at 0x4C2AB80: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
>>> ==24812==    by 0x6828BB4: ??? (in /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0)
>>> ==24812==    by 0x68FBC97: _gfortran_string_trim (in /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0)
>>> ==24812==    by 0x400EFD: MAIN__ (test.F90:11)
>>> ==24812==
>>> The program was compiled with PETSc V3.5.1 and --download-mpich.
>>> The same program compiled with V3.4.4 and --download-mpich does not give these errors.
>>> It seems like an innocuous error, and I can certainly create a suppression file for it, but I thought I'd report it anyway.
>>> I get the same error on 2 different systems and I've tried 3 different gfortran versions, all with the same result.
>>> Program, configure commands, etc, attached.
>>> Randy M.
>>> <makefile><test.F90><valgrind_out.txt><cmd_configure><cmd_test>
