[petsc-users] MATSOLVERSUPERLU_DIST not giving the correct solution
Wed Apr 30 05:32:00 CDT 2014
On Wed, Apr 30, 2014 at 3:02 AM, Justin Dong <jsd1 at rice.edu> wrote:
> I actually was able to solve my own problem...for some reason, I need to
> do
> PCSetType(pc, PCLU);
> PCFactorSetMatSolverPackage(pc, MATSOLVERSUPERLU_DIST);
> KSPSetTolerances(ksp, 1.e-15, PETSC_DEFAULT, PETSC_DEFAULT, PETSC_DEFAULT);
1) Before you do SetType(PCLU) the preconditioner has no type, so
FactorSetMatSolverPackage() has no effect
2) There is a larger issue here. Never ever ever ever code in this way.
Hardcoding a solver is crazy. The solver you
     use should depend on the equation, discretization, flow regime, and
architecture. Recompiling for all those is
     out of the question. You should just use
    KSPCreate()
    KSPSetOperators()
    KSPSetFromOptions()
    KSPSolve()
and then
   -pc_type lu -pc_factor_mat_solver_package superlu_dist
> instead of the ordering I initially had, though I'm not really clear on
> what the issue was. However, there seems to be some loss of accuracy as I
> increase the number of processes. Is this expected, or can I force a lower
> tolerance somehow? I am able to compare the solutions to a reference
> solution, and the error increases as I increase the processes. This is the
> solution in sequential:
Yes, this is unavoidable. However, just turn on the Krylov solver
  -ksp_type gmres -ksp_rtol 1.0e-10
and you can get whatever residual tolerance you want. To get a specific
error, you would need
a posteriori error estimation, which you could include in a custom
convergence criterion.
     Matt
> superlu_1process = [
> -6.8035811950925553e-06
> 1.6324030474375778e-04
> 5.4145340579614926e-02
> 1.6640521936281516e-04
> -1.7669374392923965e-04
> -2.8099208957838207e-04
> 5.3958133511222223e-02
> -5.4077899123806263e-02
> -5.3972905090366369e-02
> -1.9485020474821160e-04
> 5.4239813043824400e-02
> 4.4883984259948430e-04];
> superlu_2process = [
> -6.8035811950509821e-06
> 1.6324030474371623e-04
> 5.4145340579605655e-02
> 1.6640521936281687e-04
> -1.7669374392923807e-04
> -2.8099208957839834e-04
> 5.3958133511212911e-02
> -5.4077899123796964e-02
> -5.3972905090357078e-02
> -1.9485020474824480e-04
> 5.4239813043815172e-02
> 4.4883984259953320e-04];
> superlu_4process= [
> -6.8035811952565206e-06
> 1.6324030474386164e-04
> 5.4145340579691455e-02
> 1.6640521936278326e-04
> -1.7669374392921441e-04
> -2.8099208957829171e-04
> 5.3958133511299078e-02
> -5.4077899123883062e-02
> -5.3972905090443085e-02
> -1.9485020474806352e-04
> 5.4239813043900860e-02
> 4.4883984259921287e-04];
> This is some finite element solution and I can compute the error of the
> solution against an exact solution in the functional L2 norm:
> error with 1 process:    1.71340e-02 (accepted value)
> error with 2 processes: 2.65018e-02
> error with 3 processes: 3.00164e-02
> error with 4 processes: 3.14544e-02
> Is there a way to remedy this?
> On Wed, Apr 30, 2014 at 2:37 AM, Justin Dong <jsd1 at rice.edu> wrote:
>> Hi,
>> I'm trying to solve a linear system in parallel using SuperLU but for
>> some reason, it's not giving me the correct solution. I'm testing on a
>> small example so I can compare the sequential and parallel cases manually.
>> I'm absolutely sure that my routine for generating the matrix and
>> right-hand side in parallel is working correctly.
>> Running with 1 process and PCLU gives the correct solution. Running with
>> 2 processes and using SUPERLU_DIST does not give the correct solution (I
>> tried with 1 process too but according to the superlu documentation, I
>> would need SUPERLU for sequential?). This is the code for solving the
>> system:
>>         /* solve the system */
>> KSPCreate(PETSC_COMM_WORLD, &ksp);
>> KSPSetOperators(ksp, Aglobal, Aglobal, DIFFERENT_NONZERO_PATTERN);
>>  KSPSetType(ksp,KSPPREONLY);
>> KSPGetPC(ksp, &pc);
>> KSPSetTolerances(ksp, 1.e-13, PETSC_DEFAULT, PETSC_DEFAULT,
>> PETSC_DEFAULT);
>> KSPSolve(ksp, bglobal, bglobal);
>> Sincerely,
>> Justin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140430/2c3e7247/attachment.html>
