[petsc-users] [petsc-maint] Iterative Solver Problem
Foad Hassaninejadfarahani umhassa5 at cc.umanitoba.ca
Mon Apr 28 14:42:35 CDT 2014
Hello;
I put all those commands. It does not work with
-ksp_monitor_singular_value and here is the output:
0 KSP preconditioned resid norm 2.622210477042e+04 true resid norm
1.860478790525e+07 ||r(i)||/||b|| 1.000000000000e+00
   0 KSP Residual norm 2.622210477042e+04 % max 1.000000000000e+00 min
1.000000000000e+00 max/min 1.000000000000e+00
   1 KSP preconditioned resid norm 5.998205227155e+03 true resid norm
4.223014979562e+06 ||r(i)||/||b|| 2.269853868300e-01
   1 KSP Residual norm 5.998205227155e+03 % max 8.773486916458e-01 min
8.773486916458e-01 max/min 1.000000000000e+00
   2 KSP preconditioned resid norm 1.879862239084e+03 true resid norm
3.444600162270e+06 ||r(i)||/||b|| 1.851458979169e-01
   2 KSP Residual norm 1.879862239084e+03 % max 1.229948994481e+00 min
7.933593275578e-01 max/min 1.550305078365e+00
   3 KSP preconditioned resid norm 8.529038157181e+02 true resid norm
1.311707893098e+06 ||r(i)||/||b|| 7.050378105779e-02
[3]PETSC ERROR:
[3]PETSC ERROR: Caught signal number 8 FPE: Floating Point
Exception,probably divide by zero
[3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[3]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[3]PETSC
ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to
find memory corruption errors
[3]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[3]PETSC ERROR: to get more information on the crash.
[3]PETSC ERROR: --------------------- Error Message
[3]PETSC ERROR: Signal received!
[3]PETSC ERROR:
[3]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29
13:45:54 CDT 2011
[3]PETSC ERROR: See docs/changes/index.html for recent updates.
[3]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[3]PETSC ERROR: See docs/index.html for manual pages.
[3]PETSC ERROR:
[3]PETSC ERROR:
/home/u14/umhassa5/mecfd/gas-code/TLEC2CCP/ctf/bin/Linux_p/ctf_Linux
on a arch-linu named mecfd02 by umhassa5 Mon Apr 28 14:39:08 2014
[3]PETSC ERROR: Libraries linked from
/home/mecfd/common/sw/petsc-3.2-p5-pgi/arch-linux2-c-opt/lib
[3]PETSC ERROR: Configure run at Sat Dec 31 07:53:05 2011
[3]PETSC ERROR: Configure options
--with-mpi-dir=/home/mecfd/common/openmpi-p
--PETSC_DIR=/home/mecfd/common/sw/petsc-3.2-p5-pgi --with-debugging=0
--with-shared-libraries=1 --download-f-blas-lapack=1
--download-superlu_dist=yes --download-parmetis=yes
--download-mumps=yes --download-scalapack=yes --download-spooles=yes
--download-blacs=yes --download-hypre=yes
[3]PETSC ERROR:
[3]PETSC ERROR: [0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 8 FPE: Floating Point
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC
[0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[0]PETSC ERROR: to get more information on the crash.
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received!
[7]PETSC ERROR:
[7]PETSC ERROR: Caught signal number 8 FPE: Floating Point
[7]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[7]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[7]PETSC
[7]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[7]PETSC ERROR: to get more information on the crash.
[7]PETSC ERROR: --------------------- Error Message
[7]PETSC ERROR: Signal received!
[7]PETSC ERROR:
[7]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29
13:45:54 CDT 2011
[7]PETSC ERROR: See docs/changes/index.html for recent updates.
[7]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[7]PETSC ERROR: See docs/index.html for manual pages.
[7]PETSC ERROR:
[7]PETSC ERROR:
[7]PETSC ERROR: Libraries linked from
[7]PETSC ERROR: Configure run at Sat Dec 31 07:53:05 2011
[7]PETSC ERROR: Configure options
[7]PETSC ERROR:
[7]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
User provided function() line 0 in unknown directory unknown file
[1]PETSC ERROR:
[1]PETSC ERROR: Caught signal number 8 FPE: Floating Point
[1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[1]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[1]PETSC
[1]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[1]PETSC ERROR: to get more information on the crash.
[1]PETSC ERROR: --------------------- Error Message
[2]PETSC ERROR:
[2]PETSC ERROR: [4]PETSC ERROR:
[4]PETSC ERROR: Caught signal number 8 FPE: Floating Point
[4]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[4]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[4]PETSC
[4]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[4]PETSC ERROR: to get more information on the crash.
[4]PETSC ERROR: --------------------- Error Message
[4]PETSC ERROR: Signal received!
[4]PETSC ERROR:
[4]PETSC ERROR: [5]PETSC ERROR:
[5]PETSC ERROR: Caught signal number 8 FPE: Floating Point
[5]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[5]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[5]PETSC
[5]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[5]PETSC ERROR: to get more information on the crash.
[6]PETSC ERROR:
[6]PETSC ERROR: Caught signal number 8 FPE: Floating Point
[6]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[6]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[6]PETSC
[6]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[6]PETSC ERROR: to get more information on the crash.
[6]PETSC ERROR: --------------------- Error Message
[6]PETSC ERROR: Signal received!
[6]PETSC ERROR:
[6]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29
13:45:54 CDT 2011
[6]PETSC ERROR: See docs/changes/index.html for recent updates.
[6]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[6]PETSC ERROR: See docs/index.html for manual pages.
[6]PETSC ERROR:
[6]PETSC ERROR:
[6]PETSC ERROR: Libraries linked from
[6]PETSC ERROR: Configure run at Sat Dec 31 07:53:05 2011
[6]PETSC ERROR: Configure options
[6]PETSC ERROR:
[6]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29
13:45:54 CDT 2011
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR:
[0]PETSC ERROR: Libraries linked from
[0]PETSC ERROR: Configure run at Sat Dec 31 07:53:05 2011
[0]PETSC ERROR: Configure options
[0]PETSC ERROR:
[0]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
[1]PETSC ERROR: Signal received!
[1]PETSC ERROR:
[1]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29
13:45:54 CDT 2011
[1]PETSC ERROR: See docs/changes/index.html for recent updates.
[1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[1]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR:
[1]PETSC ERROR:
[1]PETSC ERROR: Libraries linked from
[1]PETSC ERROR: Configure run at Sat Dec 31 07:53:05 2011
[1]PETSC ERROR: Configure options
[1]PETSC ERROR:
[1]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
Caught signal number 8 FPE: Floating Point Exception,probably divide by zero
[2]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[2]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[2]PETSC
[2]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[2]PETSC ERROR: to get more information on the crash.
[2]PETSC ERROR: --------------------- Error Message
[2]PETSC ERROR: Signal received!
[2]PETSC ERROR:
[2]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29
13:45:54 CDT 2011
Petsc Release Version 3.2.0, Patch 5, Sat Oct 29 13:45:54 CDT 2011
[4]PETSC ERROR: See docs/changes/index.html for recent updates.
[4]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[4]PETSC ERROR: See docs/index.html for manual pages.
[4]PETSC ERROR:
[4]PETSC ERROR:
[4]PETSC ERROR: Libraries linked from
[4]PETSC ERROR: Configure run at Sat Dec 31 07:53:05 2011
[4]PETSC ERROR: Configure options
[4]PETSC ERROR:
[4]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
[5]PETSC ERROR: --------------------- Error Message
[5]PETSC ERROR: Signal received!
[5]PETSC ERROR:
[5]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29
13:45:54 CDT 2011
[5]PETSC ERROR: See docs/changes/index.html for recent updates.
[5]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[5]PETSC ERROR: See docs/index.html for manual pages.
[5]PETSC ERROR:
[5]PETSC ERROR:
[5]PETSC ERROR: Libraries linked from
[5]PETSC ERROR: Configure run at Sat Dec 31 07:53:05 2011
[5]PETSC ERROR: Configure options
[5]PETSC ERROR:
[5]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
MPI_ABORT was invoked on rank 4 in communicator MPI_COMM_WORLD
with errorcode 59.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[2]PETSC ERROR: See docs/changes/index.html for recent updates.
[2]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[2]PETSC ERROR: See docs/index.html for manual pages.
[2]PETSC ERROR:
[2]PETSC ERROR:
[2]PETSC ERROR: Libraries linked from
[2]PETSC ERROR: Configure run at Sat Dec 31 07:53:05 2011
[2]PETSC ERROR: Configure options
[2]PETSC ERROR:
[2]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
mpiexec has exited due to process rank 3 with PID 19683 on
node mecfd02 exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpiexec (as reported here).
With Best Regards;
Foad
Quoting Barry Smith <bsmith at mcs.anl.gov>:
>   Please run with the additional options -ksp_max_it 500
> -ksp_gmres_restart 500 -ksp_monitor_true_residual
> -ksp_monitor_singular_value and send back all the output (that would
> include the 500 residual norms as it tries to converge.)
>   Barry
> On Apr 28, 2014, at 1:21 PM, Foad Hassaninejadfarahani
> <umhassa5 at cc.umanitoba.ca> wrote:
>> Hello Again;
>> I used -ksp_rtol 1.e-12 and it took way way longer to get the
>> result for one iteration and it did not converge:
>> Linear solve did not converge due to DIVERGED_ITS iterations 10000
>> KSP Object: 8 MPI processes
>>  type: gmres
>>    GMRES: restart=300, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>>    GMRES: happy breakdown tolerance 1e-30
>>  maximum iterations=10000, initial guess is zero
>>  tolerances:  relative=1e-12, absolute=1e-50, divergence=10000
>>  left preconditioning
>>  using PRECONDITIONED norm type for convergence test
>> PC Object: 8 MPI processes
>>  type: asm
>>    Additive Schwarz: total subdomain blocks = 8, amount of overlap = 1
>>    Additive Schwarz: restriction/interpolation type - RESTRICT
>>    Local solve is same for all blocks, in the following KSP and PC objects:
>>  KSP Object:  (sub_)   1 MPI processes
>>    type: preonly
>>    tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>    using NONE norm type for convergence test
>>  PC Object:  (sub_)   1 MPI processes
>>    type: lu
>>      LU: out-of-place factorization
>>      tolerance for zero pivot 1e-12
>>      matrix ordering: nd
>>      factor fill ratio given 5, needed 3.70575
>>        Factored matrix follows:
>>          Matrix Object:           1 MPI processes
>>            type: seqaij
>>            rows=5630, cols=5630
>>            package used to perform factorization: petsc
>>            total: nonzeros=877150, allocated nonzeros=877150
>>            total number of mallocs used during MatSetValues calls =0
>>              using I-node routines: found 1126 nodes, limit used is 5
>>    linear system matrix = precond matrix:
>>      type: seqaij
>>      total: nonzeros=236700, allocated nonzeros=236700
>>  Matrix Object:   8 MPI processes
>>    type: mpiaij
>>    rows=41000, cols=41000
>>    total: nonzeros=1817800, allocated nonzeros=2555700
>>    total number of mallocs used during MatSetValues calls =121180
>>      using I-node (on process 0) routines: found 1025 nodes, limit used is 5
>> Well, let me clear everything. I am solving the whole system (air
>> and water) coupled at once. Although originally the system is not
>> linear, but I linearized the equations, so I have some lagged
>> terms. In addition the interface (between two phases) location is
>> wrong at the beginning and should be corrected in each iteration
>> after getting the solution. Therefore, I solve the whole domain,
>> move the interface and again solve the whole domain. This should
>> continue until the interface movement becomes from the order of
>> 1E-12.
>> My problem is after getting the converged solution. Restarting from
>> the converged solution, if I use Superlu, it gives me back the
>> converged solution and stops after one iteration. But, if I use any
>> iterative solver, it does not give me back the converged solution
>> and starts moving the interface cause the wrong solution ask for
>> new interface location. This leads to oscillation for ever and for
>> some cases divergence.
>> With Best Regards;
>> Foad
>>> On Apr 28, 2014, at 12:59 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> First try a much tighter tolerance on the linear solver. Use
>>>> -ksp_rtol 1.e-12
>>>> I don?t fully understand. Is the coupled system nonlinear? Are
>>>> you solving a nonlinear system, how are you doing that since you
>>>> seem to be only solving a single linear system? Does the linear
>>>> system involve all unknowns in the fluid and air?
>>>> Barry
>>>> On Apr 28, 2014, at 11:19 AM, Foad Hassaninejadfarahani
>>>>> Hello PETSc team;
>>>>> The PETSc setup in my code is working now. I have issues with
>>>>> using the iterative solver instead of direct solver.
>>>>> I am solving a 2D, two-phase flow. Two fluids (air and water)
>>>>> flow into a channel and there is interaction between two phases.
>>>>> I am solving for the velocities in x and y directions, pressure
>>>>> and two scalars. They are all coupled together. I am looking for
>>>>> the steady-state solution. Since there is interface between the
>>>>> phases which needs updating, there are many iterations to reach
>>>>> the steady-state solution. "A" is a nine-banded non-symmetric
>>>>> matrix and each node has five unknowns. I am storing the
>>>>> non-zero coefficients and their locations in three separate
>>>>> vectors.
>>>>> I started using the direct solver. Superlu works fine and gives
>>>>> me good results compared to the previous works. However it is
>>>>> not cheap and applicable for fine grids. But, the iterative
>>>>> solver did not work and here is what I did:
>>>>> I got the converged solution by using Superlu. After that I
>>>>> restarted from the converged solution and did one iteration
>>>>> using  -pc_type lu -pc_factor_mat_solver_package superlu_dist
>>>>> -log_summary. Again, it gave me the same converged solution.
>>>>> After that I started from the converged solution once more and
>>>>> this time I tried different combinations of iterative solvers
>>>>> and preconditions like the followings:
>>>>> -ksp_type gmres -ksp_gmres_restart 300 -pc_type asm -sub_pc_type
>>>>> lu ksp_monitor_true_residual -ksp_converged_reason -ksp_view
>>>>> -log_summary
>>>>> and here is the report:
>>>>> Linear solve converged due to CONVERGED_RTOL iterations 41
>>>>> type: gmres
>>>>> tolerances:  relative=1e-06, absolute=1e-50, divergence=10000
>>>>> type: asm
>>>>>  type: preonly
>>>>>  type: lu
>>>>>    matrix ordering: nd
>>>>>          type: seqaij
>>>>>    type: seqaij
>>>>>  type: mpiaij
>>>>> used is 5
>>>>> But, the results are far from the converged solution. For
>>>>> example two reference nodes for the pressure are compared:
>>>>> Based on Superlu
>>>>> Channel Inlet pressure (MIXTURE):      0.38890D-01
>>>>> Channel Inlet pressure (LIQUID):       0.38416D-01
>>>>> Based on Gmres
>>>>> Channel Inlet pressure (MIXTURE):     -0.87214D+00
>>>>> Channel Inlet pressure (LIQUID):      -0.87301D+00
>>>>> I also tried this:
>>>>> -ksp_type gcr -pc_type asm -ksp_diagonal_scale
>>>>> -ksp_diagonal_scale_fix -ksp_monitor_true_residual
>>>>> -ksp_converged_reason -ksp_view -log_summary
>>>>> 0 KSP unpreconditioned resid norm 2.248340888101e+05 true resid
>>>>> norm 2.248340888101e+05 ||r(i)||/||b|| 1.000000000000e+00
>>>>> 1 KSP unpreconditioned resid norm 4.900010460179e+04 true resid
>>>>> norm 4.900010460179e+04 ||r(i)||/||b|| 2.179389471637e-01
>>>>> 2 KSP unpreconditioned resid norm 4.267761572746e+04 true resid
>>>>> norm 4.267761572746e+04 ||r(i)||/||b|| 1.898182608933e-01
>>>>> 3 KSP unpreconditioned resid norm 2.041242251471e+03 true resid
>>>>> norm 2.041242251471e+03 ||r(i)||/||b|| 9.078882398457e-03
>>>>> 4 KSP unpreconditioned resid norm 1.852885420564e+03 true resid
>>>>> norm 1.852885420564e+03 ||r(i)||/||b|| 8.241123178296e-03
>>>>> 5 KSP unpreconditioned resid norm 1.748965594395e+02 true resid
>>>>> norm 1.748965594395e+02 ||r(i)||/||b|| 7.778916460804e-04
>>>>> 6 KSP unpreconditioned resid norm 5.664539353996e+01 true resid
>>>>> norm 5.664539353996e+01 ||r(i)||/||b|| 2.519430831852e-04
>>>>> 7 KSP unpreconditioned resid norm 3.607535692806e+01 true resid
>>>>> norm 3.607535692806e+01 ||r(i)||/||b|| 1.604532351788e-04
>>>>> 8 KSP unpreconditioned resid norm 1.041501303366e+01 true resid
>>>>> norm 1.041501303366e+01 ||r(i)||/||b|| 4.632310468924e-05
>>>>> 9 KSP unpreconditioned resid norm 3.089920380322e+00 true resid
>>>>> norm 3.089920380322e+00 ||r(i)||/||b|| 1.374311340720e-05
>>>>> 10 KSP unpreconditioned resid norm 1.456883209806e+00 true resid
>>>>> norm 1.456883209806e+00 ||r(i)||/||b|| 6.479814593583e-06
>>>>> 11 KSP unpreconditioned resid norm 5.566902714391e-01 true resid
>>>>> norm 5.566902714391e-01 ||r(i)||/||b|| 2.476004748147e-06
>>>>> 12 KSP unpreconditioned resid norm 2.403913756663e-01 true resid
>>>>> norm 2.403913756663e-01 ||r(i)||/||b|| 1.069194520006e-06
>>>>> 13 KSP unpreconditioned resid norm 1.650435118839e-01 true resid
>>>>> norm 1.650435118839e-01 ||r(i)||/||b|| 7.340680088032e-07
>>>>> Linear solve converged due to CONVERGED_RTOL iterations 13
>>>>> type: gcr
>>>>>  GCR: restart = 30
>>>>>  GCR: restarts performed = 1
>>>>> right preconditioning
>>>>> diagonally scaled system
>>>>> using UNPRECONDITIONED norm type for convergence test
>>>>> type: asm
>>>>>  type: preonly
>>>>>  type: ilu
>>>>>    ILU: out-of-place factorization
>>>>>    0 levels of fill
>>>>>    using diagonal shift to prevent zero pivot
>>>>>    matrix ordering: natural
>>>>>    factor fill ratio given 1, needed 1
>>>>>          type: seqaij
>>>>>    type: seqaij
>>>>>  type: mpiaij
>>>>> used is 5
>>>>> Channel Inlet pressure (MIXTURE):      -0.90733D+00
>>>>> Channel Inlet pressure (LIQUID):      -0.10118D+01
>>>>> As you may see these are complete different results which are
>>>>> not close to the converged solution.
>>>>> Since, I want to have fine grids I need to use iterative solver.
>>>>> I wonder if I am missing something or using wrong
>>>>> solver/precondition/option. I would appreciate if you could help
>>>>> me (like always).
>>>>> With Best Regards;
>>>>> Foad
