[petsc-users] Assembling a finite element matrix in parallel
Sun Apr 27 19:48:08 CDT 2014
On Sun, Apr 27, 2014 at 7:22 PM, Justin Dong <jsd1 at rice.edu> wrote:
> Thanks for your help -- the matrix assembly is working correctly now.
> However, say I want to solve the linear problem in serial now. I have
> A_global and b_global created using MatCreateAIJ and VecCreateMPI, but want
> to solve A_global*x = b_global using PCLU. I have:
> KSPCreate(PETSC_COMM_SELF, &ksp);
> KSPSetOperators(ksp, A_global, A_global, DIFFERENT_NONZERO_PATTERN);
> KSPGetPC(ksp, &pc);
> PCSetType(pc, PCLU);
> KSPSetTolerances(ksp, 1.e-13, PETSC_DEFAULT, PETSC_DEFAULT, PETSC_DEFAULT);
> KSPSolve(ksp, b_global, b_global);
> Is there anyway to get this to work? I'd prefer using PCLU rightnow, and
> besides, the speed-up from assembling in parallel is already significant.
I recommend solving in parallel (on the same communicator as the matrix).
This is not too hard:
  1) Reconfigure using
$PETSC_DIR/$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
--download-superlu_dist
  2) Call KSPSetFromOptions(ksp) before solve
  3) Run with -pc_type lu -pc_factor_mat_solver_package superlu_dist
You can easily get your solution on one process if you want using
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecScatterCreateToZero.html
     Matt
> On Sun, Apr 27, 2014 at 9:11 AM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Sun, Apr 27, 2014 at 9:05 AM, Justin Dong <jsd1 at rice.edu> wrote:
>>> When I try to invoke MatCreateMPIAIJ, I'm getting this warning:
>>> *main.c:1842:2: **warning: **implicit declaration of function
>>> 'MatCreateMPIAIJ' is invalid in C99 [-Wimplicit-function-declaration]*
>>>         MatCreateMPIAIJ(PETSC_COMM_SELF, NLoc, NLoc, NLoc*nElems,
>>> NLoc*nElems, (ref+3)*NLoc,
>>> and this error:
>> The name was changed in the last release:
>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateAIJ.html
>>   Thanks,
>>       Matt
>>> Undefined symbols for architecture x86_64:
>>>   "_MatCreateMPIAIJ", referenced from:
>>>       _DG_SolveOil in main.o
>>> ld: symbol(s) not found for architecture x86_64
>>> clang: error: linker command failed with exit code 1 (use -v to see
>>> invocation)
>>> make: [main] Error 1 (ignored)
>>> /bin/rm -f -f main.o
>>> This is how I'm calling MatCreateMPIAIJ:
>>> MatCreateMPIAIJ(PETSC_COMM_WORLD, nlocal, nlocal, nlocal*nelements,
>>> nlocal*nelements, 3*nlocal,
>>>     PETSC_NULL, 3*nlocal, PETSC_NULL, &A_global);
>>> I'm able to run some simple MPI functions and use mpiexec, so I don't
>>> think it's an issue with MPI itself.
>>> Sincerely,
>>> Justin
>>> On Sun, Apr 27, 2014 at 8:35 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Sun, Apr 27, 2014 at 7:47 AM, Justin Dong <jsd1 at rice.edu> wrote:
>>>>> I think I've got the right idea on how to divide up the for loop:
>>>>>     MPI_Comm_size(MPI_COMM_WORLD,&numprocs);
>>>>>     MPI_Comm_rank(MPI_COMM_WORLD,&myid);
>>>>>     mystart = (nelements / numprocs) * myid;
>>>>>     if (nelements % numprocs > myid)
>>>>>     mystart += myid;
>>>>>     myend = mystart + (nelements / numprocs) + 1;
>>>>>     else
>>>>>     mystart += nelements % numprocs;
>>>>>      myend = mystart + (nelements / numprocs);
>>>> We have a function that does exactly this:
>>>> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Sys/PetscSplitOwnership.html
>>>>> But then, do I do this?
>>>> Yes.
>>>>>  for (k = mystart+1; k < myend; ++k)
>>>>>     get_index(k,ie,je); /* ie and je are arrays that indicate where to
>>>>> place A_local */
>>>>>     compute_local_matrix(A_local,...);
>>>>>     MatSetValues(A_global, nlocal, ie, nlocal, je, A_local,
>>>>> ADD_VALUES);
>>>>> The indices are global indices and I'm doing
>>>>> MatCreateSeqAIJ(PETSC_COMM_WORLD, nglobal, nglobal, 3*nlocal,
>>>> This should be MatCreateMPIAIJ() for parallel execution.
>>>>    Matt
>>>> to create the matrix. Running the program seems to give me multiple
>>>>> errors, but mainly
>>>>> [3]PETSC ERROR: Object is in wrong state!
>>>>> [3]PETSC ERROR: Mat object's type is not set: Argument # 1!
>>>>> On Sun, Apr 27, 2014 at 6:54 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Sun, Apr 27, 2014 at 6:25 AM, Justin Dong <jsd1 at rice.edu> wrote:
>>>>>>> Hi Matt,
>>>>>>> For option 1), that would be using MPI and not any special functions
>>>>>>> in PETSc? I ask since I've never done parallel programming before. I tried
>>>>>>> using OpenMP to parallelize that for loop but it resulted in some errors
>>>>>>> and I didn't investigate further, but I'm assuming it's because each
>>>>>>> process wasn't communicating properly with the others during MatSetValues?
>>>>>> Yes, using MPI, so each process owns a set of elements that it loops
>>>>>> over. The Mat object manages the global
>>>>>> values as long as you use global indices for the (row, column). There
>>>>>> are of course many refinements for this,
>>>>>> but I think the thing to do is get something working fast, and then
>>>>>> optimize it.
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> Sincerely,
>>>>>>> Justin
>>>>>>> On Sun, Apr 27, 2014 at 5:57 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>>> On Sun, Apr 27, 2014 at 4:14 AM, Justin Dong <jsd1 at rice.edu> wrote:
>>>>>>>>> Hi all,
>>>>>>>>> I'm currently coding a finite element problem in PETSc. I'm
>>>>>>>>> computing all of the matrices by myself and would prefer to do it that way.
>>>>>>>>> I want to parallelize the assembly of the global matrices. This is a
>>>>>>>>> simplified version of the assembly routine (pseudocode):
>>>>>>>>> for (k = 0; k < nelements; ++k)
>>>>>>>>> where to place A_local */
>>>>>>>>> ADD_VALUES);
>>>>>>>>> This is for DG finite elements and I know the matrix easily be
>>>>>>>>> assembled in parallel. Even on my laptop, this would allow me to
>>>>>>>>> significantly speed up my code. The only problem is, I'm not sure how to do
>>>>>>>>> this in PETSc. I'd assume I need to use MatCreateMPIAIJ instead of
>>>>>>>>> MatCreateSeqAIJ, but wasn't able to find any using tutorials on how I might
>>>>>>>>> do this.
>>>>>>>> 1) If you just split this loop across processes, it would work
>>>>>>>> immediately. However, that can be non-optimal in terms
>>>>>>>>      of communication.
>>>>>>>> 2) PETSc matrices are distributed by contiguous blocks of rows (see
>>>>>>>> manual section on matrices), so you would like
>>>>>>>>     those row blocks to correspond roughly to your element blocks.
>>>>>>>> 3) You will also have to preallocate, but that should be the same
>>>>>>>> as you do now for the sequential case, except you
>>>>>>>>      check whether a column is inside the diagonal block.
>>>>>>>>   Thanks,
>>>>>>>>       Matt
>>>>>>>>> Sincerely,
>>>>>>>>> Justin
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140427/cf398294/attachment-0001.html>
