[petsc-users] Convergence_Eigenvalues_k=3
Fri Apr 25 07:57:37 CDT 2014
Tiny problem:
rows=384, cols=384
Huge condition number > 1.445175027567e+06
with ICC(0) preconditioner.  Normally one does not expect to see this on such a tiny problem.
Where is the matrix coming from? Discretization of some PDE? What kind of discretization? What PDE? Is it possible the matrix is singular? How big are the systems you want to solve? If smallish, say less than 1,000,000 unknowns you may just want to use a direct solver (assuming that works).
One cannot just black-box precondition any crazy matrix that comes along and expect it to converge quickly. One has to know where the matrix comes from to determine an appropriate preconditioner if possible.
  Barry
On Apr 25, 2014, at 7:33 AM, Oo <wumeng07maths at qq.com> wrote:
> Hi,
> Here is output when I used -ksp_view.
> KSP Object: 1 MPI processes
>   type: gmres
>     GMRES: restart=200, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>     GMRES: happy breakdown tolerance 1e-30
>   maximum iterations=200, initial guess is zero
>   tolerances:  relative=0.0001, absolute=0.0001, divergence=10000
>   left preconditioning
>   using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: icc
>     0 levels of fill
>     tolerance for zero pivot 2.22045e-14
>     using Manteuffel shift [POSITIVE_DEFINITE]
>     matrix ordering: natural
>     factor fill ratio given 1, needed 1
>       Factored matrix follows:
>         Matrix Object:         1 MPI processes
>           type: seqsbaij
>           rows=384, cols=384
>           package used to perform factorization: petsc
>           total: nonzeros=2560, allocated nonzeros=2560
>           total number of mallocs used during MatSetValues calls =0
>               block size is 1
>   linear system matrix = precond matrix:
>     type: seqaij
>     rows=384, cols=384
>     total: nonzeros=4736, allocated nonzeros=147456
>       using I-node routines: found 96 nodes, limit used is 5
> Thanks,
> Meng
> ------------------ Original ------------------
> From:  "Matthew Knepley";<knepley at gmail.com>;
> Send time: Friday, Apr 25, 2014 6:22 PM
> To: "Oo "<wumeng07maths at qq.com>;
> Cc: "Barry Smith"<bsmith at mcs.anl.gov>; "petsc-users"<petsc-users at mcs.anl.gov>;
> Subject:  Re: [petsc-users] Convergence_Eigenvalues_k=3
> On Fri, Apr 25, 2014 at 4:13 AM, Oo <wumeng07maths at qq.com> wrote:
> Hi,
> What I can do for solving this linear system?
> I am guessing that you are using the default GMRES/ILU. Run with -ksp_view to confirm.
> We would have to know something about the linear system to suggest improvements.
>     Matt
> At this moment,
> I use the common line "/Users/wumeng/MyWork/BuildMSplineTools/bin/msplinePDE_PFEM_2 -ksp_gmres_restart 200 -ksp_max_it 200 -ksp_monitor_true_residual -ksp_monitor_singular_value"
> The following are the output:
>   0 KSP preconditioned resid norm 7.463734841673e+00 true resid norm 7.520241011357e-02 ||r(i)||/||b|| 1.000000000000e+00
>   0 KSP Residual norm 7.463734841673e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
>   1 KSP preconditioned resid norm 3.449001344285e-03 true resid norm 7.834435231711e-05 ||r(i)||/||b|| 1.041779807307e-03
>   1 KSP Residual norm 3.449001344285e-03 % max 9.999991695261e-01 min 9.999991695261e-01 max/min 1.000000000000e+00
>   2 KSP preconditioned resid norm 1.811463883605e-05 true resid norm 3.597611565181e-07 ||r(i)||/||b|| 4.783904611232e-06
>   2 KSP Residual norm 1.811463883605e-05 % max 1.000686014764e+00 min 9.991339510077e-01 max/min 1.001553409084e+00
>   0 KSP preconditioned resid norm 9.374463936067e+00 true resid norm 9.058107112571e-02 ||r(i)||/||b|| 1.000000000000e+00
>   0 KSP Residual norm 9.374463936067e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
>   1 KSP preconditioned resid norm 2.595582184655e-01 true resid norm 6.637387889158e-03 ||r(i)||/||b|| 7.327566131280e-02
>   1 KSP Residual norm 2.595582184655e-01 % max 9.933440157684e-01 min 9.933440157684e-01 max/min 1.000000000000e+00
>   2 KSP preconditioned resid norm 6.351429855766e-03 true resid norm 1.844857600919e-04 ||r(i)||/||b|| 2.036692189651e-03
>   2 KSP Residual norm 6.351429855766e-03 % max 1.000795215571e+00 min 8.099278726624e-01 max/min 1.235659679523e+00
>   3 KSP preconditioned resid norm 1.883016084950e-04 true resid norm 3.876682412610e-06 ||r(i)||/||b|| 4.279793078656e-05
>   3 KSP Residual norm 1.883016084950e-04 % max 1.184638644500e+00 min 8.086172954187e-01 max/min 1.465017692809e+00
>   0 KSP preconditioned resid norm 1.414935390756e+03 true resid norm 1.787617427503e+01 ||r(i)||/||b|| 1.000000000000e+00
>   0 KSP Residual norm 1.414935390756e+03 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
>   1 KSP preconditioned resid norm 1.384179962960e+03 true resid norm 1.802958083039e+01 ||r(i)||/||b|| 1.008581621157e+00
>   1 KSP Residual norm 1.384179962960e+03 % max 1.895999321723e+01 min 1.895999321723e+01 max/min 1.000000000000e+00
>   2 KSP preconditioned resid norm 1.382373771674e+03 true resid norm 1.813982830244e+01 ||r(i)||/||b|| 1.014748906749e+00
>   2 KSP Residual norm 1.382373771674e+03 % max 3.551645921348e+01 min 6.051184451182e+00 max/min 5.869340044086e+00
>   3 KSP preconditioned resid norm 1.332723893134e+03 true resid norm 1.774590608681e+01 ||r(i)||/||b|| 9.927127479173e-01
>   3 KSP Residual norm 1.332723893134e+03 % max 5.076435191911e+01 min 4.941060752900e+00 max/min 1.027397849527e+01
>   4 KSP preconditioned resid norm 1.093788576095e+03 true resid norm 1.717433802192e+01 ||r(i)||/||b|| 9.607390125925e-01
>   4 KSP Residual norm 1.093788576095e+03 % max 6.610818819562e+01 min 1.960683367943e+00 max/min 3.371691180560e+01
>   5 KSP preconditioned resid norm 1.077330470806e+03 true resid norm 1.750861653688e+01 ||r(i)||/||b|| 9.794386800837e-01
>   5 KSP Residual norm 1.077330470806e+03 % max 7.296006568006e+01 min 1.721275741199e+00 max/min 4.238720382432e+01
>   6 KSP preconditioned resid norm 1.021951470305e+03 true resid norm 1.587225289158e+01 ||r(i)||/||b|| 8.878998742895e-01
>   6 KSP Residual norm 1.021951470305e+03 % max 7.313469782749e+01 min 1.113708844536e+00 max/min 6.566769958438e+01
>   7 KSP preconditioned resid norm 8.968401331418e+02 true resid norm 1.532116106999e+01 ||r(i)||/||b|| 8.570715878170e-01
>   7 KSP Residual norm 8.968401331418e+02 % max 7.385099946342e+01 min 1.112940159952e+00 max/min 6.635666689088e+01
>   8 KSP preconditioned resid norm 8.540750681178e+02 true resid norm 1.665367409583e+01 ||r(i)||/||b|| 9.316128741873e-01
>   8 KSP Residual norm 8.540750681178e+02 % max 9.333712052307e+01 min 9.984044777583e-01 max/min 9.348627996205e+01
>   9 KSP preconditioned resid norm 8.540461721597e+02 true resid norm 1.669107313551e+01 ||r(i)||/||b|| 9.337049907166e-01
>   9 KSP Residual norm 8.540461721597e+02 % max 9.673114572055e+01 min 9.309725017804e-01 max/min 1.039033328434e+02
>  10 KSP preconditioned resid norm 8.540453927813e+02 true resid norm 1.668902252063e+01 ||r(i)||/||b|| 9.335902785387e-01
>  10 KSP Residual norm 8.540453927813e+02 % max 9.685490817256e+01 min 8.452348922200e-01 max/min 1.145893396783e+02
>  11 KSP preconditioned resid norm 7.927564518868e+02 true resid norm 1.671721115974e+01 ||r(i)||/||b|| 9.351671617505e-01
>  11 KSP Residual norm 7.927564518868e+02 % max 1.076430910935e+02 min 8.433341413962e-01 max/min 1.276399066629e+02
>  12 KSP preconditioned resid norm 4.831253651357e+02 true resid norm 2.683431434549e+01 ||r(i)||/||b|| 1.501121768709e+00
>  12 KSP Residual norm 4.831253651357e+02 % max 1.079017603981e+02 min 8.354112427301e-01 max/min 1.291600530124e+02
>  13 KSP preconditioned resid norm 4.093462051807e+02 true resid norm 1.923302214627e+01 ||r(i)||/||b|| 1.075902586894e+00
>  13 KSP Residual norm 4.093462051807e+02 % max 1.088474472678e+02 min 6.034301796734e-01 max/min 1.803811790233e+02
>  14 KSP preconditioned resid norm 3.809274390266e+02 true resid norm 2.118308925475e+01 ||r(i)||/||b|| 1.184990083943e+00
>  14 KSP Residual norm 3.809274390266e+02 % max 1.104675729761e+02 min 6.010582938812e-01 max/min 1.837884513045e+02
>  15 KSP preconditioned resid norm 2.408316705377e+02 true resid norm 1.238065951026e+01 ||r(i)||/||b|| 6.925788101960e-01
>  15 KSP Residual norm 2.408316705377e+02 % max 1.215487322437e+02 min 5.131416858605e-01 max/min 2.368716781211e+02
>  16 KSP preconditioned resid norm 1.979802937570e+02 true resid norm 9.481184679187e+00 ||r(i)||/||b|| 5.303810834083e-01
>  16 KSP Residual norm 1.979802937570e+02 % max 1.246827043503e+02 min 4.780929228356e-01 max/min 2.607917799970e+02
>  17 KSP preconditioned resid norm 1.853329360151e+02 true resid norm 9.049630342765e+00 ||r(i)||/||b|| 5.062397694011e-01
>  17 KSP Residual norm 1.853329360151e+02 % max 1.252018074901e+02 min 4.612413672912e-01 max/min 2.714453133841e+02
>  18 KSP preconditioned resid norm 1.853299943955e+02 true resid norm 9.047741838474e+00 ||r(i)||/||b|| 5.061341257515e-01
>  18 KSP Residual norm 1.853299943955e+02 % max 1.256988083109e+02 min 4.556318323953e-01 max/min 2.758780211867e+02
>  19 KSP preconditioned resid norm 1.730151601343e+02 true resid norm 9.854026387827e+00 ||r(i)||/||b|| 5.512379906472e-01
>  19 KSP Residual norm 1.730151601343e+02 % max 1.279580192729e+02 min 3.287110716087e-01 max/min 3.892720091436e+02
>  20 KSP preconditioned resid norm 1.429145143492e+02 true resid norm 8.228490997826e+00 ||r(i)||/||b|| 4.603049215804e-01
>  20 KSP Residual norm 1.429145143492e+02 % max 1.321397322884e+02 min 2.823235578054e-01 max/min 4.680435926621e+02
>  21 KSP preconditioned resid norm 1.345382626439e+02 true resid norm 8.176256473861e+00 ||r(i)||/||b|| 4.573829024078e-01
>  21 KSP Residual norm 1.345382626439e+02 % max 1.332774949926e+02 min 2.425224324298e-01 max/min 5.495470817166e+02
>  22 KSP preconditioned resid norm 1.301499631466e+02 true resid norm 8.487706077838e+00 ||r(i)||/||b|| 4.748055119207e-01
>  22 KSP Residual norm 1.301499631466e+02 % max 1.334143594976e+02 min 2.077893364534e-01 max/min 6.420654773469e+02
>  23 KSP preconditioned resid norm 1.260084835452e+02 true resid norm 8.288260183397e+00 ||r(i)||/||b|| 4.636484325941e-01
>  23 KSP Residual norm 1.260084835452e+02 % max 1.342473982017e+02 min 2.010966692943e-01 max/min 6.675764381023e+02
>  24 KSP preconditioned resid norm 1.255711443195e+02 true resid norm 8.117619099395e+00 ||r(i)||/||b|| 4.541027053386e-01
>  24 KSP Residual norm 1.255711443195e+02 % max 1.342478258493e+02 min 1.586270065907e-01 max/min 8.463112854147e+02
>  25 KSP preconditioned resid norm 1.064125166220e+02 true resid norm 8.683750469293e+00 ||r(i)||/||b|| 4.857723098741e-01
>  25 KSP Residual norm 1.064125166220e+02 % max 1.343100269972e+02 min 1.586061159091e-01 max/min 8.468149303534e+02
>  26 KSP preconditioned resid norm 9.497012777512e+01 true resid norm 7.776308733811e+00 ||r(i)||/||b|| 4.350096734441e-01
>  26 KSP Residual norm 9.497012777512e+01 % max 1.346211743671e+02 min 1.408944545921e-01 max/min 9.554753219835e+02
>  27 KSP preconditioned resid norm 9.449347291209e+01 true resid norm 8.027397390699e+00 ||r(i)||/||b|| 4.490556685785e-01
>  27 KSP Residual norm 9.449347291209e+01 % max 1.353601106604e+02 min 1.302056396509e-01 max/min 1.039587156311e+03
>  28 KSP preconditioned resid norm 7.708808620337e+01 true resid norm 8.253756419882e+00 ||r(i)||/||b|| 4.617182789167e-01
>  28 KSP Residual norm 7.708808620337e+01 % max 1.354170803310e+02 min 1.300840147004e-01 max/min 1.040997086712e+03
>  29 KSP preconditioned resid norm 6.883976717639e+01 true resid norm 7.200274893950e+00 ||r(i)||/||b|| 4.027861209659e-01
>  29 KSP Residual norm 6.883976717639e+01 % max 1.359172085675e+02 min 1.060952954746e-01 max/min 1.281086102446e+03
>  30 KSP preconditioned resid norm 6.671786230822e+01 true resid norm 6.613746362850e+00 ||r(i)||/||b|| 3.699754914612e-01
>  30 KSP Residual norm 6.671786230822e+01 % max 1.361448012233e+02 min 8.135160167393e-02 max/min 1.673535596373e+03
>  31 KSP preconditioned resid norm 5.753308015718e+01 true resid norm 7.287752888130e+00 ||r(i)||/||b|| 4.076796732906e-01
>  31 KSP Residual norm 5.753308015718e+01 % max 1.363247397022e+02 min 6.837262871767e-02 max/min 1.993849618759e+03
>  32 KSP preconditioned resid norm 5.188554631220e+01 true resid norm 7.000101427370e+00 ||r(i)||/||b|| 3.915883409767e-01
>  32 KSP Residual norm 5.188554631220e+01 % max 1.365417051351e+02 min 6.421828602757e-02 max/min 2.126212229901e+03
>  33 KSP preconditioned resid norm 4.949709579590e+01 true resid norm 6.374314702607e+00 ||r(i)||/||b|| 3.565815931606e-01
>  33 KSP Residual norm 4.949709579590e+01 % max 1.366317667622e+02 min 6.421330753944e-02 max/min 2.127779614503e+03
>  34 KSP preconditioned resid norm 4.403827792460e+01 true resid norm 6.147327125810e+00 ||r(i)||/||b|| 3.438838216294e-01
>  34 KSP Residual norm 4.403827792460e+01 % max 1.370253126927e+02 min 6.368216512224e-02 max/min 2.151706249775e+03
>  35 KSP preconditioned resid norm 4.140066382940e+01 true resid norm 5.886089041852e+00 ||r(i)||/||b|| 3.292700636777e-01
>  35 KSP Residual norm 4.140066382940e+01 % max 1.390943209074e+02 min 6.114512372501e-02 max/min 2.274822789352e+03
>  36 KSP preconditioned resid norm 3.745028333544e+01 true resid norm 5.122854489971e+00 ||r(i)||/||b|| 2.865744320432e-01
>  36 KSP Residual norm 3.745028333544e+01 % max 1.396462040364e+02 min 5.993486381149e-02 max/min 2.329966152515e+03
>  37 KSP preconditioned resid norm 3.492028700266e+01 true resid norm 4.982433448736e+00 ||r(i)||/||b|| 2.787192254942e-01
>  37 KSP Residual norm 3.492028700266e+01 % max 1.418761690073e+02 min 5.972847536278e-02 max/min 2.375352261139e+03
>  38 KSP preconditioned resid norm 3.068024157121e+01 true resid norm 4.394664243655e+00 ||r(i)||/||b|| 2.458391922143e-01
>  38 KSP Residual norm 3.068024157121e+01 % max 1.419282962644e+02 min 5.955136512602e-02 max/min 2.383292070032e+03
>  39 KSP preconditioned resid norm 2.614836504484e+01 true resid norm 3.671741082517e+00 ||r(i)||/||b|| 2.053985951371e-01
>  39 KSP Residual norm 2.614836504484e+01 % max 1.424590886621e+02 min 5.534838135054e-02 max/min 2.573861876102e+03
>  40 KSP preconditioned resid norm 2.598742703782e+01 true resid norm 3.707086113835e+00 ||r(i)||/||b|| 2.073758096559e-01
>  40 KSP Residual norm 2.598742703782e+01 % max 1.428352406023e+02 min 5.401263258718e-02 max/min 2.644478407376e+03
>  41 KSP preconditioned resid norm 2.271029765350e+01 true resid norm 2.912150121100e+00 ||r(i)||/||b|| 1.629067873414e-01
>  41 KSP Residual norm 2.271029765350e+01 % max 1.446928584608e+02 min 5.373910075949e-02 max/min 2.692506134562e+03
>  42 KSP preconditioned resid norm 1.795836259709e+01 true resid norm 2.316834528159e+00 ||r(i)||/||b|| 1.296046062493e-01
>  42 KSP Residual norm 1.795836259709e+01 % max 1.449375360478e+02 min 5.251640030193e-02 max/min 2.759852831011e+03
>  43 KSP preconditioned resid norm 1.795769958691e+01 true resid norm 2.311558013062e+00 ||r(i)||/||b|| 1.293094359844e-01
>  43 KSP Residual norm 1.795769958691e+01 % max 1.449864885595e+02 min 4.685673226983e-02 max/min 3.094250954688e+03
>  44 KSP preconditioned resid norm 1.688955122733e+01 true resid norm 2.370951018341e+00 ||r(i)||/||b|| 1.326319033292e-01
>  44 KSP Residual norm 1.688955122733e+01 % max 1.450141764818e+02 min 4.554223489616e-02 max/min 3.184169086398e+03
>  45 KSP preconditioned resid norm 1.526531678793e+01 true resid norm 1.947726448658e+00 ||r(i)||/||b|| 1.089565596470e-01
>  45 KSP Residual norm 1.526531678793e+01 % max 1.460128059490e+02 min 4.478596884382e-02 max/min 3.260235509433e+03
>  46 KSP preconditioned resid norm 1.519131456699e+01 true resid norm 1.914601584750e+00 ||r(i)||/||b|| 1.071035421390e-01
>  46 KSP Residual norm 1.519131456699e+01 % max 1.467440844081e+02 min 4.068627190104e-02 max/min 3.606722305867e+03
>  47 KSP preconditioned resid norm 1.396606833105e+01 true resid norm 1.916085501806e+00 ||r(i)||/||b|| 1.071865530245e-01
>  47 KSP Residual norm 1.396606833105e+01 % max 1.472676539618e+02 min 4.068014642358e-02 max/min 3.620135788804e+03
>  48 KSP preconditioned resid norm 1.128785630240e+01 true resid norm 1.818072605558e+00 ||r(i)||/||b|| 1.017036742642e-01
>  48 KSP Residual norm 1.128785630240e+01 % max 1.476343971960e+02 min 4.003858518052e-02 max/min 3.687303048557e+03
>  49 KSP preconditioned resid norm 9.686331225178e+00 true resid norm 1.520702063515e+00 ||r(i)||/||b|| 8.506865284031e-02
>  49 KSP Residual norm 9.686331225178e+00 % max 1.478478861627e+02 min 3.802148926353e-02 max/min 3.888534852961e+03
>  50 KSP preconditioned resid norm 9.646313260413e+00 true resid norm 1.596152870343e+00 ||r(i)||/||b|| 8.928939972200e-02
>  50 KSP Residual norm 9.646313260413e+00 % max 1.479986700685e+02 min 3.796210121957e-02 max/min 3.898590049388e+03
>  51 KSP preconditioned resid norm 9.270552344731e+00 true resid norm 1.442564661256e+00 ||r(i)||/||b|| 8.069761678656e-02
>  51 KSP Residual norm 9.270552344731e+00 % max 1.482179613835e+02 min 3.763123640547e-02 max/min 3.938694965706e+03
>  52 KSP preconditioned resid norm 8.025547426875e+00 true resid norm 1.151158202903e+00 ||r(i)||/||b|| 6.439622847661e-02
>  52 KSP Residual norm 8.025547426875e+00 % max 1.482612345232e+02 min 3.498901666812e-02 max/min 4.237364997409e+03
>  53 KSP preconditioned resid norm 7.830903379041e+00 true resid norm 1.083539895672e+00 ||r(i)||/||b|| 6.061363460667e-02
>  53 KSP Residual norm 7.830903379041e+00 % max 1.496916293673e+02 min 3.180425422032e-02 max/min 4.706654283743e+03
>  54 KSP preconditioned resid norm 7.818451528162e+00 true resid norm 1.101275786636e+00 ||r(i)||/||b|| 6.160578710481e-02
>  54 KSP Residual norm 7.818451528162e+00 % max 1.497547864750e+02 min 2.963830547627e-02 max/min 5.052744550289e+03
>  55 KSP preconditioned resid norm 6.716190950888e+00 true resid norm 1.068051260258e+00 ||r(i)||/||b|| 5.974719444025e-02
>  55 KSP Residual norm 6.716190950888e+00 % max 1.509985715255e+02 min 2.913583319816e-02 max/min 5.182572624524e+03
>  56 KSP preconditioned resid norm 6.435651273713e+00 true resid norm 9.738533937643e-01 ||r(i)||/||b|| 5.447772989798e-02
>  56 KSP Residual norm 6.435651273713e+00 % max 1.513751779517e+02 min 2.849133088254e-02 max/min 5.313025866562e+03
>  57 KSP preconditioned resid norm 6.427111085122e+00 true resid norm 9.515491605865e-01 ||r(i)||/||b|| 5.323002259581e-02
>  57 KSP Residual norm 6.427111085122e+00 % max 1.514217018182e+02 min 2.805206411012e-02 max/min 5.397880926830e+03
>  58 KSP preconditioned resid norm 6.330738649886e+00 true resid norm 9.488038114070e-01 ||r(i)||/||b|| 5.307644671670e-02
>  58 KSP Residual norm 6.330738649886e+00 % max 1.514492565938e+02 min 2.542367477260e-02 max/min 5.957016754989e+03
>  59 KSP preconditioned resid norm 5.861133560095e+00 true resid norm 9.281566562924e-01 ||r(i)||/||b|| 5.192143699275e-02
>  59 KSP Residual norm 5.861133560095e+00 % max 1.522146406650e+02 min 2.316380798762e-02 max/min 6.571227008373e+03
>  60 KSP preconditioned resid norm 5.523892064332e+00 true resid norm 8.250464923972e-01 ||r(i)||/||b|| 4.615341513814e-02
>  60 KSP Residual norm 5.523892064332e+00 % max 1.522274643717e+02 min 2.316038063761e-02 max/min 6.572753131893e+03
>  61 KSP preconditioned resid norm 5.345610652504e+00 true resid norm 7.967455833060e-01 ||r(i)||/||b|| 4.457025150056e-02
>  61 KSP Residual norm 5.345610652504e+00 % max 1.527689509969e+02 min 2.278107359995e-02 max/min 6.705959239659e+03
>  62 KSP preconditioned resid norm 4.883527474160e+00 true resid norm 6.939057385062e-01 ||r(i)||/||b|| 3.881735139915e-02
>  62 KSP Residual norm 4.883527474160e+00 % max 1.527847370492e+02 min 2.215885299007e-02 max/min 6.894974984387e+03
>  63 KSP preconditioned resid norm 3.982941325093e+00 true resid norm 6.883730294386e-01 ||r(i)||/||b|| 3.850784954587e-02
>  63 KSP Residual norm 3.982941325093e+00 % max 1.528029462870e+02 min 2.036330717837e-02 max/min 7.503837414449e+03
>  64 KSP preconditioned resid norm 3.768777539791e+00 true resid norm 6.576940275451e-01 ||r(i)||/||b|| 3.679165449085e-02
>  64 KSP Residual norm 3.768777539791e+00 % max 1.534842011203e+02 min 2.015613298342e-02 max/min 7.614764262895e+03
>  65 KSP preconditioned resid norm 3.754783611569e+00 true resid norm 6.240730525064e-01 ||r(i)||/||b|| 3.491088433716e-02
>  65 KSP Residual norm 3.754783611569e+00 % max 1.536539871370e+02 min 2.002205183069e-02 max/min 7.674237807208e+03
>  66 KSP preconditioned resid norm 3.242712853326e+00 true resid norm 5.919043028914e-01 ||r(i)||/||b|| 3.311135222698e-02
>  66 KSP Residual norm 3.242712853326e+00 % max 1.536763506920e+02 min 1.853540050760e-02 max/min 8.290964666717e+03
>  67 KSP preconditioned resid norm 2.639460944665e+00 true resid norm 5.172526166420e-01 ||r(i)||/||b|| 2.893530845493e-02
>  67 KSP Residual norm 2.639460944665e+00 % max 1.536900244470e+02 min 1.819164547837e-02 max/min 8.448384981431e+03
>  68 KSP preconditioned resid norm 2.332848633723e+00 true resid norm 4.860086486067e-01 ||r(i)||/||b|| 2.718750897868e-02
>  68 KSP Residual norm 2.332848633723e+00 % max 1.537025056230e+02 min 1.794260313013e-02 max/min 8.566343718814e+03
>  69 KSP preconditioned resid norm 2.210456807969e+00 true resid norm 5.392952883712e-01 ||r(i)||/||b|| 3.016838391000e-02
>  69 KSP Residual norm 2.210456807969e+00 % max 1.537288460363e+02 min 1.753831098488e-02 max/min 8.765316464556e+03
>  70 KSP preconditioned resid norm 2.193036145802e+00 true resid norm 5.031209038994e-01 ||r(i)||/||b|| 2.814477505974e-02
>  70 KSP Residual norm 2.193036145802e+00 % max 1.541461506421e+02 min 1.700508158735e-02 max/min 9.064711030659e+03
>  71 KSP preconditioned resid norm 1.938788470922e+00 true resid norm 3.360317906409e-01 ||r(i)||/||b|| 1.879774640094e-02
>  71 KSP Residual norm 1.938788470922e+00 % max 1.545641242905e+02 min 1.655870257931e-02 max/min 9.334313696993e+03
>  72 KSP preconditioned resid norm 1.450214827437e+00 true resid norm 2.879267785157e-01 ||r(i)||/||b|| 1.610673369402e-02
>  72 KSP Residual norm 1.450214827437e+00 % max 1.549625503409e+02 min 1.648921859604e-02 max/min 9.397810420079e+03
>  73 KSP preconditioned resid norm 1.110389920050e+00 true resid norm 2.664130281817e-01 ||r(i)||/||b|| 1.490324630331e-02
>  73 KSP Residual norm 1.110389920050e+00 % max 1.553700778851e+02 min 1.637230817799e-02 max/min 9.489809023627e+03
>  74 KSP preconditioned resid norm 8.588797630056e-01 true resid norm 2.680334659775e-01 ||r(i)||/||b|| 1.499389421102e-02
>  74 KSP Residual norm 8.588797630056e-01 % max 1.560105458550e+02 min 1.627972447765e-02 max/min 9.583119546597e+03
>  75 KSP preconditioned resid norm 6.037657330005e-01 true resid norm 2.938298885198e-01 ||r(i)||/||b|| 1.643695591681e-02
>  75 KSP Residual norm 6.037657330005e-01 % max 1.568417947105e+02 min 1.617453208191e-02 max/min 9.696836601902e+03
>  76 KSP preconditioned resid norm 4.778003132962e-01 true resid norm 3.104440343355e-01 ||r(i)||/||b|| 1.736635756394e-02
>  76 KSP Residual norm 4.778003132962e-01 % max 1.582399629678e+02 min 1.614387326366e-02 max/min 9.801858598824e+03
>  77 KSP preconditioned resid norm 4.523141317161e-01 true resid norm 3.278599563956e-01 ||r(i)||/||b|| 1.834061087967e-02
>  77 KSP Residual norm 4.523141317161e-01 % max 1.610754319747e+02 min 1.614204788287e-02 max/min 9.978624344533e+03
>  78 KSP preconditioned resid norm 4.522674526201e-01 true resid norm 3.287567680693e-01 ||r(i)||/||b|| 1.839077886640e-02
>  78 KSP Residual norm 4.522674526201e-01 % max 1.611450941232e+02 min 1.596556934579e-02 max/min 1.009328829014e+04
>  79 KSP preconditioned resid norm 4.452139421181e-01 true resid norm 3.198810083892e-01 ||r(i)||/||b|| 1.789426548812e-02
>  79 KSP Residual norm 4.452139421181e-01 % max 1.619065061486e+02 min 1.456184518464e-02 max/min 1.111854329555e+04
>  80 KSP preconditioned resid norm 4.217533807980e-01 true resid norm 2.940346905843e-01 ||r(i)||/||b|| 1.644841262233e-02
>  80 KSP Residual norm 4.217533807980e-01 % max 1.620409915505e+02 min 1.154094228288e-02 max/min 1.404053391644e+04
>  81 KSP preconditioned resid norm 3.815105809981e-01 true resid norm 2.630686686818e-01 ||r(i)||/||b|| 1.471616155865e-02
>  81 KSP Residual norm 3.815105809981e-01 % max 1.643140061303e+02 min 9.352799654900e-03 max/min 1.756843000953e+04
>  82 KSP preconditioned resid norm 3.257333222641e-01 true resid norm 2.350339902943e-01 ||r(i)||/||b|| 1.314789096807e-02
>  82 KSP Residual norm 3.257333222641e-01 % max 1.661730623934e+02 min 7.309343891643e-03 max/min 2.273433359502e+04
>  83 KSP preconditioned resid norm 2.653029571859e-01 true resid norm 1.993496448136e-01 ||r(i)||/||b|| 1.115169508568e-02
>  83 KSP Residual norm 2.653029571859e-01 % max 1.672909675648e+02 min 5.727931297058e-03 max/min 2.920617564857e+04
>  84 KSP preconditioned resid norm 2.125985080811e-01 true resid norm 1.651488251908e-01 ||r(i)||/||b|| 9.238488205020e-03
>  84 KSP Residual norm 2.125985080811e-01 % max 1.677205536916e+02 min 4.904920732181e-03 max/min 3.419434540321e+04
>  85 KSP preconditioned resid norm 1.823170233996e-01 true resid norm 1.538640960567e-01 ||r(i)||/||b|| 8.607216157635e-03
>  85 KSP Residual norm 1.823170233996e-01 % max 1.684045979154e+02 min 4.411887233900e-03 max/min 3.817064874674e+04
>  86 KSP preconditioned resid norm 1.568093845918e-01 true resid norm 1.468517035130e-01 ||r(i)||/||b|| 8.214940246925e-03
>  86 KSP Residual norm 1.568093845918e-01 % max 1.707938893954e+02 min 3.835536173319e-03 max/min 4.452933870980e+04
>  87 KSP preconditioned resid norm 1.416153038224e-01 true resid norm 1.326462010194e-01 ||r(i)||/||b|| 7.420279024951e-03
>  87 KSP Residual norm 1.416153038224e-01 % max 1.708004671154e+02 min 3.204409749322e-03 max/min 5.330169375233e+04
>  88 KSP preconditioned resid norm 1.298764107063e-01 true resid norm 1.273603812747e-01 ||r(i)||/||b|| 7.124588254468e-03
>  88 KSP Residual norm 1.298764107063e-01 % max 1.708079667291e+02 min 2.881989285724e-03 max/min 5.926738436372e+04
>  89 KSP preconditioned resid norm 1.226436579597e-01 true resid norm 1.269051556519e-01 ||r(i)||/||b|| 7.099122759682e-03
>  89 KSP Residual norm 1.226436579597e-01 % max 1.708200970069e+02 min 2.600538747361e-03 max/min 6.568642639154e+04
>  90 KSP preconditioned resid norm 1.131214284449e-01 true resid norm 1.236585929815e-01 ||r(i)||/||b|| 6.917508806917e-03
>  90 KSP Residual norm 1.131214284449e-01 % max 1.708228433345e+02 min 2.097699611380e-03 max/min 8.143341516003e+04
>  91 KSP preconditioned resid norm 1.097877127886e-01 true resid norm 1.208660430826e-01 ||r(i)||/||b|| 6.761292501577e-03
>  91 KSP Residual norm 1.097877127886e-01 % max 1.734053778533e+02 min 1.669096618002e-03 max/min 1.038917555659e+05
>  92 KSP preconditioned resid norm 1.087819681706e-01 true resid norm 1.220967287438e-01 ||r(i)||/||b|| 6.830137526368e-03
>  92 KSP Residual norm 1.087819681706e-01 % max 1.735898650322e+02 min 1.410331102754e-03 max/min 1.230844761867e+05
>  93 KSP preconditioned resid norm 1.082792743495e-01 true resid norm 1.231464976286e-01 ||r(i)||/||b|| 6.888861997758e-03
>  93 KSP Residual norm 1.082792743495e-01 % max 1.744253420547e+02 min 1.160377474118e-03 max/min 1.503177594750e+05
>  94 KSP preconditioned resid norm 1.082786837568e-01 true resid norm 1.231972007582e-01 ||r(i)||/||b|| 6.891698350150e-03
>  94 KSP Residual norm 1.082786837568e-01 % max 1.744405973598e+02 min 9.020124135986e-04 max/min 1.933904619603e+05
>  95 KSP preconditioned resid norm 1.076120024876e-01 true resid norm 1.193390416348e-01 ||r(i)||/||b|| 6.675871458778e-03
>  95 KSP Residual norm 1.076120024876e-01 % max 1.744577996139e+02 min 6.759449987513e-04 max/min 2.580946673712e+05
>  96 KSP preconditioned resid norm 1.051338654734e-01 true resid norm 1.113305708771e-01 ||r(i)||/||b|| 6.227874553259e-03
>  96 KSP Residual norm 1.051338654734e-01 % max 1.754402425643e+02 min 5.544787352320e-04 max/min 3.164057184102e+05
>  97 KSP preconditioned resid norm 9.747169190114e-02 true resid norm 9.349805869502e-02 ||r(i)||/||b|| 5.230317027375e-03
>  97 KSP Residual norm 9.747169190114e-02 % max 1.756210909470e+02 min 4.482270392115e-04 max/min 3.918127992813e+05
>  98 KSP preconditioned resid norm 8.842962288098e-02 true resid norm 7.385511932515e-02 ||r(i)||/||b|| 4.131483514810e-03
>  98 KSP Residual norm 8.842962288098e-02 % max 1.757463096622e+02 min 3.987817611456e-04 max/min 4.407079931572e+05
>  99 KSP preconditioned resid norm 7.588962343124e-02 true resid norm 4.759948399141e-02 ||r(i)||/||b|| 2.662733270502e-03
>  99 KSP Residual norm 7.588962343124e-02 % max 1.758800802719e+02 min 3.549508940132e-04 max/min 4.955053874730e+05
> 100 KSP preconditioned resid norm 5.762080294705e-02 true resid norm 2.979101328333e-02 ||r(i)||/||b|| 1.666520633833e-03
> 100 KSP Residual norm 5.762080294705e-02 % max 1.767054165485e+02 min 3.399974141580e-04 max/min 5.197257661094e+05
> 101 KSP preconditioned resid norm 4.010101211334e-02 true resid norm 1.618156300742e-02 ||r(i)||/||b|| 9.052028000211e-04
> 101 KSP Residual norm 4.010101211334e-02 % max 1.780221758963e+02 min 3.330380731227e-04 max/min 5.345400128792e+05
> 102 KSP preconditioned resid norm 2.613215615582e-02 true resid norm 8.507285387866e-03 ||r(i)||/||b|| 4.759007859835e-04
> 102 KSP Residual norm 2.613215615582e-02 % max 1.780247903707e+02 min 3.267877108360e-04 max/min 5.447719864228e+05
> 103 KSP preconditioned resid norm 1.756896108812e-02 true resid norm 4.899136161981e-03 ||r(i)||/||b|| 2.740595435358e-04
> 103 KSP Residual norm 1.756896108812e-02 % max 1.780337300599e+02 min 3.237486252629e-04 max/min 5.499134704135e+05
> 104 KSP preconditioned resid norm 1.142112016905e-02 true resid norm 3.312246267926e-03 ||r(i)||/||b|| 1.852883182367e-04
> 104 KSP Residual norm 1.142112016905e-02 % max 1.805569604942e+02 min 3.232308817378e-04 max/min 5.586005876774e+05
> 105 KSP preconditioned resid norm 7.345608733466e-03 true resid norm 1.880672268508e-03 ||r(i)||/||b|| 1.052055232609e-04
> 105 KSP Residual norm 7.345608733466e-03 % max 1.817568861663e+02 min 3.229958821968e-04 max/min 5.627219917794e+05
> 106 KSP preconditioned resid norm 4.810582452316e-03 true resid norm 1.418216565286e-03 ||r(i)||/||b|| 7.933557502107e-05
> 106 KSP Residual norm 4.810582452316e-03 % max 1.845797149153e+02 min 3.220343456392e-04 max/min 5.731677922395e+05
> 107 KSP preconditioned resid norm 3.114068270187e-03 true resid norm 1.177898700463e-03 ||r(i)||/||b|| 6.589210209864e-05
> 107 KSP Residual norm 3.114068270187e-03 % max 1.850561815508e+02 min 3.216059660171e-04 max/min 5.754127755856e+05
> 108 KSP preconditioned resid norm 2.293796939903e-03 true resid norm 1.090384984298e-03 ||r(i)||/||b|| 6.099655147246e-05
> 108 KSP Residual norm 2.293796939903e-03 % max 1.887275970943e+02 min 3.204019028106e-04 max/min 5.890339459248e+05
> 109 KSP preconditioned resid norm 1.897140553486e-03 true resid norm 1.085409353133e-03 ||r(i)||/||b|| 6.071821276936e-05
> 109 KSP Residual norm 1.897140553486e-03 % max 1.900700995337e+02 min 3.201092729524e-04 max/min 5.937663029274e+05
> 110 KSP preconditioned resid norm 1.638607873536e-03 true resid norm 1.080912735078e-03 ||r(i)||/||b|| 6.046667024205e-05
> 110 KSP Residual norm 1.638607873536e-03 % max 1.941847763082e+02 min 3.201003961856e-04 max/min 6.066371008040e+05
> 111 KSP preconditioned resid norm 1.445734513987e-03 true resid norm 1.072337220355e-03 ||r(i)||/||b|| 5.998695268109e-05
> 111 KSP Residual norm 1.445734513987e-03 % max 1.968706347099e+02 min 3.200841174449e-04 max/min 6.150590547303e+05
> 112 KSP preconditioned resid norm 1.309787940098e-03 true resid norm 1.071880522659e-03 ||r(i)||/||b|| 5.996140483796e-05
> 112 KSP Residual norm 1.309787940098e-03 % max 2.005995546657e+02 min 3.200727858161e-04 max/min 6.267310547950e+05
> 113 KSP preconditioned resid norm 1.203600185791e-03 true resid norm 1.068704252153e-03 ||r(i)||/||b|| 5.978372305568e-05
> 113 KSP Residual norm 1.203600185791e-03 % max 2.044005133646e+02 min 3.200669375682e-04 max/min 6.386180182109e+05
> 114 KSP preconditioned resid norm 1.120060134211e-03 true resid norm 1.067737533794e-03 ||r(i)||/||b|| 5.972964446230e-05
> 114 KSP Residual norm 1.120060134211e-03 % max 2.080860182134e+02 min 3.200663739818e-04 max/min 6.501339569812e+05
> 115 KSP preconditioned resid norm 1.051559355475e-03 true resid norm 1.066440021011e-03 ||r(i)||/||b|| 5.965706110284e-05
> 115 KSP Residual norm 1.051559355475e-03 % max 2.120208487134e+02 min 3.200660278464e-04 max/min 6.624284687130e+05
> 116 KSP preconditioned resid norm 9.943175666627e-04 true resid norm 1.065634036988e-03 ||r(i)||/||b|| 5.961197404955e-05
> 116 KSP Residual norm 9.943175666627e-04 % max 2.158491989548e+02 min 3.200660249513e-04 max/min 6.743896012946e+05
> 117 KSP preconditioned resid norm 9.454894909455e-04 true resid norm 1.064909725825e-03 ||r(i)||/||b|| 5.957145580713e-05
> 117 KSP Residual norm 9.454894909455e-04 % max 2.197604049280e+02 min 3.200659829252e-04 max/min 6.866096887885e+05
> 118 KSP preconditioned resid norm 9.032188050175e-04 true resid norm 1.064337854187e-03 ||r(i)||/||b|| 5.953946508976e-05
> 118 KSP Residual norm 9.032188050175e-04 % max 2.236450290076e+02 min 3.200659636119e-04 max/min 6.987466786029e+05
> 119 KSP preconditioned resid norm 8.661523005930e-04 true resid norm 1.063851383334e-03 ||r(i)||/||b|| 5.951225172494e-05
> 119 KSP Residual norm 8.661523005930e-04 % max 2.275386631435e+02 min 3.200659439058e-04 max/min 7.109118213789e+05
> 120 KSP preconditioned resid norm 8.333044554060e-04 true resid norm 1.063440179004e-03 ||r(i)||/||b|| 5.948924879800e-05
> 120 KSP Residual norm 8.333044554060e-04 % max 2.314181044639e+02 min 3.200659279880e-04 max/min 7.230326136825e+05
> 121 KSP preconditioned resid norm 8.039309218182e-04 true resid norm 1.063085844171e-03 ||r(i)||/||b|| 5.946942717246e-05
> 121 KSP Residual norm 8.039309218182e-04 % max 2.352840091878e+02 min 3.200659140872e-04 max/min 7.351111094065e+05
> 122 KSP preconditioned resid norm 7.774595735272e-04 true resid norm 1.062777951335e-03 ||r(i)||/||b|| 5.945220352987e-05
> 122 KSP Residual norm 7.774595735272e-04 % max 2.391301402333e+02 min 3.200659020264e-04 max/min 7.471278218621e+05
> 123 KSP preconditioned resid norm 7.534419441080e-04 true resid norm 1.062507774643e-03 ||r(i)||/||b|| 5.943708974281e-05
> 123 KSP Residual norm 7.534419441080e-04 % max 2.429535997478e+02 min 3.200658914252e-04 max/min 7.590736978126e+05
> 124 KSP preconditioned resid norm 7.315209774625e-04 true resid norm 1.062268823392e-03 ||r(i)||/||b|| 5.942372271877e-05
> 124 KSP Residual norm 7.315209774625e-04 % max 2.467514538222e+02 min 3.200658820413e-04 max/min 7.709395710924e+05
> 125 KSP preconditioned resid norm 7.114083600074e-04 true resid norm 1.062055971251e-03 ||r(i)||/||b|| 5.941181568889e-05
> 125 KSP Residual norm 7.114083600074e-04 % max 2.505215705167e+02 min 3.200658736748e-04 max/min 7.827187811071e+05
> 126 KSP preconditioned resid norm 6.928683961266e-04 true resid norm 1.061865165985e-03 ||r(i)||/||b|| 5.940114196966e-05
> 126 KSP Residual norm 6.928683961266e-04 % max 2.542622648377e+02 min 3.200658661692e-04 max/min 7.944060636045e+05
> 127 KSP preconditioned resid norm 6.757062709768e-04 true resid norm 1.061693150669e-03 ||r(i)||/||b|| 5.939151936730e-05
> 127 KSP Residual norm 6.757062709768e-04 % max 2.579722822206e+02 min 3.200658593982e-04 max/min 8.059974990947e+05
> 128 KSP preconditioned resid norm 6.597593638309e-04 true resid norm 1.061537280201e-03 ||r(i)||/||b|| 5.938279991397e-05
> 128 KSP Residual norm 6.597593638309e-04 % max 2.616507118184e+02 min 3.200658532588e-04 max/min 8.174902419435e+05
> 129 KSP preconditioned resid norm 6.448907155810e-04 true resid norm 1.061395383620e-03 ||r(i)||/||b|| 5.937486216514e-05
> 129 KSP Residual norm 6.448907155810e-04 % max 2.652969302909e+02 min 3.200658476664e-04 max/min 8.288823447585e+05
> 130 KSP preconditioned resid norm 6.309840465804e-04 true resid norm 1.061265662452e-03 ||r(i)||/||b|| 5.936760551361e-05
> 130 KSP Residual norm 6.309840465804e-04 % max 2.689105505574e+02 min 3.200658425513e-04 max/min 8.401725982813e+05
> 131 KSP preconditioned resid norm 6.179399078869e-04 true resid norm 1.061146614178e-03 ||r(i)||/||b|| 5.936094590780e-05
> 131 KSP Residual norm 6.179399078869e-04 % max 2.724913796166e+02 min 3.200658378548e-04 max/min 8.513603996069e+05
> 132 KSP preconditioned resid norm 6.056726732840e-04 true resid norm 1.061036973709e-03 ||r(i)||/||b|| 5.935481257818e-05
> 132 KSP Residual norm 6.056726732840e-04 % max 2.760393830832e+02 min 3.200658335276e-04 max/min 8.624456413884e+05
> 133 KSP preconditioned resid norm 5.941081632891e-04 true resid norm 1.060935668299e-03 ||r(i)||/||b|| 5.934914551493e-05
> 133 KSP Residual norm 5.941081632891e-04 % max 2.795546556158e+02 min 3.200658295276e-04 max/min 8.734286194450e+05
> 134 KSP preconditioned resid norm 5.831817499918e-04 true resid norm 1.060841782314e-03 ||r(i)||/||b|| 5.934389349718e-05
> 134 KSP Residual norm 5.831817499918e-04 % max 2.830373962684e+02 min 3.200658258193e-04 max/min 8.843099557533e+05
> 135 KSP preconditioned resid norm 5.728368317981e-04 true resid norm 1.060754529477e-03 ||r(i)||/||b|| 5.933901254021e-05
> 135 KSP Residual norm 5.728368317981e-04 % max 2.864878879810e+02 min 3.200658223718e-04 max/min 8.950905343719e+05
> 136 KSP preconditioned resid norm 5.630235956754e-04 true resid norm 1.060673230868e-03 ||r(i)||/||b|| 5.933446466506e-05
> 136 KSP Residual norm 5.630235956754e-04 % max 2.899064805338e+02 min 3.200658191584e-04 max/min 9.057714481857e+05
> 137 KSP preconditioned resid norm 5.536980049705e-04 true resid norm 1.060597297101e-03 ||r(i)||/||b|| 5.933021690118e-05
> 137 KSP Residual norm 5.536980049705e-04 % max 2.932935763968e+02 min 3.200658161562e-04 max/min 9.163539546933e+05
> 138 KSP preconditioned resid norm 5.448209657758e-04 true resid norm 1.060526214124e-03 ||r(i)||/||b|| 5.932624049239e-05
> 138 KSP Residual norm 5.448209657758e-04 % max 2.966496189942e+02 min 3.200658133448e-04 max/min 9.268394393456e+05
> 139 KSP preconditioned resid norm 5.363576357737e-04 true resid norm 1.060459531517e-03 ||r(i)||/||b|| 5.932251024194e-05
> 139 KSP Residual norm 5.363576357737e-04 % max 2.999750829834e+02 min 3.200658107070e-04 max/min 9.372293851716e+05
> 140 KSP preconditioned resid norm 5.282768476492e-04 true resid norm 1.060396852955e-03 ||r(i)||/||b|| 5.931900397932e-05
> 140 KSP Residual norm 5.282768476492e-04 % max 3.032704662136e+02 min 3.200658082268e-04 max/min 9.475253476584e+05
> 141 KSP preconditioned resid norm 5.205506252810e-04 true resid norm 1.060337828321e-03 ||r(i)||/||b|| 5.931570211878e-05
> 141 KSP Residual norm 5.205506252810e-04 % max 3.065362830844e+02 min 3.200658058907e-04 max/min 9.577289339963e+05
> 142 KSP preconditioned resid norm 5.131537755696e-04 true resid norm 1.060282147141e-03 ||r(i)||/||b|| 5.931258729233e-05
> 142 KSP Residual norm 5.131537755696e-04 % max 3.097730590695e+02 min 3.200658036863e-04 max/min 9.678417859756e+05
> 143 KSP preconditioned resid norm 5.060635423123e-04 true resid norm 1.060229533174e-03 ||r(i)||/||b|| 5.930964404698e-05
> 143 KSP Residual norm 5.060635423123e-04 % max 3.129813262144e+02 min 3.200658016030e-04 max/min 9.778655659143e+05
> 144 KSP preconditioned resid norm 4.992593112791e-04 true resid norm 1.060179739774e-03 ||r(i)||/||b|| 5.930685858524e-05
> 144 KSP Residual norm 4.992593112791e-04 % max 3.161616194433e+02 min 3.200657996311e-04 max/min 9.878019451242e+05
> 145 KSP preconditioned resid norm 4.927223577718e-04 true resid norm 1.060132546053e-03 ||r(i)||/||b|| 5.930421855048e-05
> 145 KSP Residual norm 4.927223577718e-04 % max 3.193144735429e+02 min 3.200657977617e-04 max/min 9.976525944849e+05
> 146 KSP preconditioned resid norm 4.864356296191e-04 true resid norm 1.060087753599e-03 ||r(i)||/||b|| 5.930171284355e-05
> 146 KSP Residual norm 4.864356296191e-04 % max 3.224404207086e+02 min 3.200657959872e-04 max/min 1.007419176779e+06
> 147 KSP preconditioned resid norm 4.803835598739e-04 true resid norm 1.060045183705e-03 ||r(i)||/||b|| 5.929933146747e-05
> 147 KSP Residual norm 4.803835598739e-04 % max 3.255399885620e+02 min 3.200657943002e-04 max/min 1.017103340498e+06
> 148 KSP preconditioned resid norm 4.745519045267e-04 true resid norm 1.060004674955e-03 ||r(i)||/||b|| 5.929706539253e-05
> 148 KSP Residual norm 4.745519045267e-04 % max 3.286136985587e+02 min 3.200657926948e-04 max/min 1.026706714866e+06
> 149 KSP preconditioned resid norm 4.689276013781e-04 true resid norm 1.059966081181e-03 ||r(i)||/||b|| 5.929490644211e-05
> 149 KSP Residual norm 4.689276013781e-04 % max 3.316620647237e+02 min 3.200657911651e-04 max/min 1.036230905891e+06
> 150 KSP preconditioned resid norm 4.634986468865e-04 true resid norm 1.059929269736e-03 ||r(i)||/||b|| 5.929284719586e-05
> 150 KSP Residual norm 4.634986468865e-04 % max 3.346855926588e+02 min 3.200657897058e-04 max/min 1.045677493263e+06
> 151 KSP preconditioned resid norm 4.582539883466e-04 true resid norm 1.059894119959e-03 ||r(i)||/||b|| 5.929088090393e-05
> 151 KSP Residual norm 4.582539883466e-04 % max 3.376847787762e+02 min 3.200657883122e-04 max/min 1.055048027960e+06
> 152 KSP preconditioned resid norm 4.531834291922e-04 true resid norm 1.059860521790e-03 ||r(i)||/||b|| 5.928900140955e-05
> 152 KSP Residual norm 4.531834291922e-04 % max 3.406601097208e+02 min 3.200657869798e-04 max/min 1.064344030443e+06
> 153 KSP preconditioned resid norm 4.482775455769e-04 true resid norm 1.059828374748e-03 ||r(i)||/||b|| 5.928720309181e-05
> 153 KSP Residual norm 4.482775455769e-04 % max 3.436120619489e+02 min 3.200657857049e-04 max/min 1.073566989337e+06
> 154 KSP preconditioned resid norm 4.435276126791e-04 true resid norm 1.059797586777e-03 ||r(i)||/||b|| 5.928548080094e-05
> 154 KSP Residual norm 4.435276126791e-04 % max 3.465411014367e+02 min 3.200657844837e-04 max/min 1.082718360526e+06
> 155 KSP preconditioned resid norm 4.389255394186e-04 true resid norm 1.059768073502e-03 ||r(i)||/||b|| 5.928382981713e-05
> 155 KSP Residual norm 4.389255394186e-04 % max 3.494476834965e+02 min 3.200657833130e-04 max/min 1.091799566575e+06
> 156 KSP preconditioned resid norm 4.344638104739e-04 true resid norm 1.059739757336e-03 ||r(i)||/||b|| 5.928224580001e-05
> 156 KSP Residual norm 4.344638104739e-04 % max 3.523322526810e+02 min 3.200657821896e-04 max/min 1.100811996430e+06
> 157 KSP preconditioned resid norm 4.301354346542e-04 true resid norm 1.059712566921e-03 ||r(i)||/||b|| 5.928072475785e-05
> 157 KSP Residual norm 4.301354346542e-04 % max 3.551952427605e+02 min 3.200657811108e-04 max/min 1.109757005350e+06
> 158 KSP preconditioned resid norm 4.259338988194e-04 true resid norm 1.059686436414e-03 ||r(i)||/||b|| 5.927926300733e-05
> 158 KSP Residual norm 4.259338988194e-04 % max 3.580370767604e+02 min 3.200657800738e-04 max/min 1.118635915023e+06
> 159 KSP preconditioned resid norm 4.218531266563e-04 true resid norm 1.059661305045e-03 ||r(i)||/||b|| 5.927785714894e-05
> 159 KSP Residual norm 4.218531266563e-04 % max 3.608581670458e+02 min 3.200657790764e-04 max/min 1.127450013829e+06
> 160 KSP preconditioned resid norm 4.178874417186e-04 true resid norm 1.059637116561e-03 ||r(i)||/||b|| 5.927650403596e-05
> 160 KSP Residual norm 4.178874417186e-04 % max 3.636589154466e+02 min 3.200657781164e-04 max/min 1.136200557232e+06
> 161 KSP preconditioned resid norm 4.140315342180e-04 true resid norm 1.059613818894e-03 ||r(i)||/||b|| 5.927520075559e-05
> 161 KSP Residual norm 4.140315342180e-04 % max 3.664397134134e+02 min 3.200657771916e-04 max/min 1.144888768267e+06
> 162 KSP preconditioned resid norm 4.102804311252e-04 true resid norm 1.059591363713e-03 ||r(i)||/||b|| 5.927394460419e-05
> 162 KSP Residual norm 4.102804311252e-04 % max 3.692009421979e+02 min 3.200657763002e-04 max/min 1.153515838106e+06
> 163 KSP preconditioned resid norm 4.066294691985e-04 true resid norm 1.059569706138e-03 ||r(i)||/||b|| 5.927273307117e-05
> 163 KSP Residual norm 4.066294691985e-04 % max 3.719429730532e+02 min 3.200657754405e-04 max/min 1.162082926678e+06
> 164 KSP preconditioned resid norm 4.030742706055e-04 true resid norm 1.059548804412e-03 ||r(i)||/||b|| 5.927156382068e-05
> 164 KSP Residual norm 4.030742706055e-04 % max 3.746661674483e+02 min 3.200657746106e-04 max/min 1.170591163345e+06
> 165 KSP preconditioned resid norm 3.996107208498e-04 true resid norm 1.059528619651e-03 ||r(i)||/||b|| 5.927043467745e-05
> 165 KSP Residual norm 3.996107208498e-04 % max 3.773708772938e+02 min 3.200657738091e-04 max/min 1.179041647605e+06
> 166 KSP preconditioned resid norm 3.962349487489e-04 true resid norm 1.059509115572e-03 ||r(i)||/||b|| 5.926934361186e-05
> 166 KSP Residual norm 3.962349487489e-04 % max 3.800574451754e+02 min 3.200657730346e-04 max/min 1.187435449820e+06
> 167 KSP preconditioned resid norm 3.929433082418e-04 true resid norm 1.059490258328e-03 ||r(i)||/||b|| 5.926828873043e-05
> 167 KSP Residual norm 3.929433082418e-04 % max 3.827262045917e+02 min 3.200657722858e-04 max/min 1.195773611962e+06
> 168 KSP preconditioned resid norm 3.897323618319e-04 true resid norm 1.059472016256e-03 ||r(i)||/||b|| 5.926726826196e-05
> 168 KSP Residual norm 3.897323618319e-04 % max 3.853774801959e+02 min 3.200657715611e-04 max/min 1.204057148368e+06
> 169 KSP preconditioned resid norm 3.865988654946e-04 true resid norm 1.059454359751e-03 ||r(i)||/||b|| 5.926628055033e-05
> 169 KSP Residual norm 3.865988654946e-04 % max 3.880115880375e+02 min 3.200657708600e-04 max/min 1.212287046487e+06
> 170 KSP preconditioned resid norm 3.835397548978e-04 true resid norm 1.059437261066e-03 ||r(i)||/||b|| 5.926532404338e-05
> 170 KSP Residual norm 3.835397548978e-04 % max 3.906288358040e+02 min 3.200657701808e-04 max/min 1.220464267652e+06
> 171 KSP preconditioned resid norm 3.805521328045e-04 true resid norm 1.059420694153e-03 ||r(i)||/||b|| 5.926439728400e-05
> 171 KSP Residual norm 3.805521328045e-04 % max 3.932295230610e+02 min 3.200657695227e-04 max/min 1.228589747812e+06
> 172 KSP preconditioned resid norm 3.776332575372e-04 true resid norm 1.059404634604e-03 ||r(i)||/||b|| 5.926349890668e-05
> 172 KSP Residual norm 3.776332575372e-04 % max 3.958139414889e+02 min 3.200657688847e-04 max/min 1.236664398283e+06
> 173 KSP preconditioned resid norm 3.747805324013e-04 true resid norm 1.059389059461e-03 ||r(i)||/||b|| 5.926262762725e-05
> 173 KSP Residual norm 3.747805324013e-04 % max 3.983823751168e+02 min 3.200657682658e-04 max/min 1.244689106477e+06
> 174 KSP preconditioned resid norm 3.719914959745e-04 true resid norm 1.059373947132e-03 ||r(i)||/||b|| 5.926178223783e-05
> 174 KSP Residual norm 3.719914959745e-04 % max 4.009351005517e+02 min 3.200657676654e-04 max/min 1.252664736614e+06
> 175 KSP preconditioned resid norm 3.692638131792e-04 true resid norm 1.059359277291e-03 ||r(i)||/||b|| 5.926096160129e-05
> 175 KSP Residual norm 3.692638131792e-04 % max 4.034723872035e+02 min 3.200657670824e-04 max/min 1.260592130428e+06
> 176 KSP preconditioned resid norm 3.665952670646e-04 true resid norm 1.059345030772e-03 ||r(i)||/||b|| 5.926016464562e-05
> 176 KSP Residual norm 3.665952670646e-04 % max 4.059944975044e+02 min 3.200657665165e-04 max/min 1.268472107852e+06
> 177 KSP preconditioned resid norm 3.639837512333e-04 true resid norm 1.059331189535e-03 ||r(i)||/||b|| 5.925939036157e-05
> 177 KSP Residual norm 3.639837512333e-04 % max 4.085016871234e+02 min 3.200657659664e-04 max/min 1.276305467690e+06
> 178 KSP preconditioned resid norm 3.614272628526e-04 true resid norm 1.059317736504e-03 ||r(i)||/||b|| 5.925863779385e-05
> 178 KSP Residual norm 3.614272628526e-04 % max 4.109942051749e+02 min 3.200657654318e-04 max/min 1.284092988266e+06
> 179 KSP preconditioned resid norm 3.589238961979e-04 true resid norm 1.059304655605e-03 ||r(i)||/||b|| 5.925790604337e-05
> 179 KSP Residual norm 3.589238961979e-04 % max 4.134722944217e+02 min 3.200657649118e-04 max/min 1.291835428058e+06
> 180 KSP preconditioned resid norm 3.564718366825e-04 true resid norm 1.059291931579e-03 ||r(i)||/||b|| 5.925719425653e-05
> 180 KSP Residual norm 3.564718366825e-04 % max 4.159361914728e+02 min 3.200657644063e-04 max/min 1.299533526319e+06
> 181 KSP preconditioned resid norm 3.540693553287e-04 true resid norm 1.059279550018e-03 ||r(i)||/||b|| 5.925650162730e-05
> 181 KSP Residual norm 3.540693553287e-04 % max 4.183861269743e+02 min 3.200657639142e-04 max/min 1.307188003670e+06
> 182 KSP preconditioned resid norm 3.517148036444e-04 true resid norm 1.059267497309e-03 ||r(i)||/||b|| 5.925582739414e-05
> 182 KSP Residual norm 3.517148036444e-04 % max 4.208223257952e+02 min 3.200657634351e-04 max/min 1.314799562686e+06
> 183 KSP preconditioned resid norm 3.494066088688e-04 true resid norm 1.059255760488e-03 ||r(i)||/||b|| 5.925517083190e-05
> 183 KSP Residual norm 3.494066088688e-04 % max 4.232450072075e+02 min 3.200657629684e-04 max/min 1.322368888450e+06
> 184 KSP preconditioned resid norm 3.471432695577e-04 true resid norm 1.059244327320e-03 ||r(i)||/||b|| 5.925453125615e-05
> 184 KSP Residual norm 3.471432695577e-04 % max 4.256543850606e+02 min 3.200657625139e-04 max/min 1.329896649105e+06
> 185 KSP preconditioned resid norm 3.449233514781e-04 true resid norm 1.059233186159e-03 ||r(i)||/||b|| 5.925390801536e-05
> 185 KSP Residual norm 3.449233514781e-04 % max 4.280506679492e+02 min 3.200657620711e-04 max/min 1.337383496377e+06
> 186 KSP preconditioned resid norm 3.427454837895e-04 true resid norm 1.059222325963e-03 ||r(i)||/||b|| 5.925330049183e-05
> 186 KSP Residual norm 3.427454837895e-04 % max 4.304340593770e+02 min 3.200657616393e-04 max/min 1.344830066085e+06
> 187 KSP preconditioned resid norm 3.406083554860e-04 true resid norm 1.059211736238e-03 ||r(i)||/||b|| 5.925270809861e-05
> 187 KSP Residual norm 3.406083554860e-04 % max 4.328047579144e+02 min 3.200657612184e-04 max/min 1.352236978635e+06
> 188 KSP preconditioned resid norm 3.385107120797e-04 true resid norm 1.059201407008e-03 ||r(i)||/||b|| 5.925213027752e-05
> 188 KSP Residual norm 3.385107120797e-04 % max 4.351629573503e+02 min 3.200657608077e-04 max/min 1.359604839494e+06
> 189 KSP preconditioned resid norm 3.364513525062e-04 true resid norm 1.059191328770e-03 ||r(i)||/||b|| 5.925156649705e-05
> 189 KSP Residual norm 3.364513525062e-04 % max 4.375088468402e+02 min 3.200657604069e-04 max/min 1.366934239651e+06
> 190 KSP preconditioned resid norm 3.344291262348e-04 true resid norm 1.059181492481e-03 ||r(i)||/||b|| 5.925101625132e-05
> 190 KSP Residual norm 3.344291262348e-04 % max 4.398426110478e+02 min 3.200657600159e-04 max/min 1.374225756063e+06
> 191 KSP preconditioned resid norm 3.324429305670e-04 true resid norm 1.059171889545e-03 ||r(i)||/||b|| 5.925047905943e-05
> 191 KSP Residual norm 3.324429305670e-04 % max 4.421644302826e+02 min 3.200657596338e-04 max/min 1.381479952084e+06
> 192 KSP preconditioned resid norm 3.304917081101e-04 true resid norm 1.059162511741e-03 ||r(i)||/||b|| 5.924995446149e-05
> 192 KSP Residual norm 3.304917081101e-04 % max 4.444744806328e+02 min 3.200657592613e-04 max/min 1.388697377872e+06
> 193 KSP preconditioned resid norm 3.285744444114e-04 true resid norm 1.059153351271e-03 ||r(i)||/||b|| 5.924944202127e-05
> 193 KSP Residual norm 3.285744444114e-04 % max 4.467729340931e+02 min 3.200657588967e-04 max/min 1.395878570808e+06
> 194 KSP preconditioned resid norm 3.266901657422e-04 true resid norm 1.059144400627e-03 ||r(i)||/||b|| 5.924894131886e-05
> 194 KSP Residual norm 3.266901657422e-04 % max 4.490599586887e+02 min 3.200657585410e-04 max/min 1.403024055856e+06
> 195 KSP preconditioned resid norm 3.248379370193e-04 true resid norm 1.059135652724e-03 ||r(i)||/||b|| 5.924845195782e-05
> 195 KSP Residual norm 3.248379370193e-04 % max 4.513357185943e+02 min 3.200657581935e-04 max/min 1.410134345960e+06
> 196 KSP preconditioned resid norm 3.230168598555e-04 true resid norm 1.059127100716e-03 ||r(i)||/||b|| 5.924797355524e-05
> 196 KSP Residual norm 3.230168598555e-04 % max 4.536003742498e+02 min 3.200657578528e-04 max/min 1.417209942397e+06
> 197 KSP preconditioned resid norm 3.212260707284e-04 true resid norm 1.059118738110e-03 ||r(i)||/||b|| 5.924750574787e-05
> 197 KSP Residual norm 3.212260707284e-04 % max 4.558540824713e+02 min 3.200657575203e-04 max/min 1.424251335110e+06
> 198 KSP preconditioned resid norm 3.194647392600e-04 true resid norm 1.059110558683e-03 ||r(i)||/||b|| 5.924704818760e-05
> 198 KSP Residual norm 3.194647392600e-04 % max 4.580969965587e+02 min 3.200657571950e-04 max/min 1.431259003067e+06
> 199 KSP preconditioned resid norm 3.177320665985e-04 true resid norm 1.059102556481e-03 ||r(i)||/||b|| 5.924660054140e-05
> 199 KSP Residual norm 3.177320665985e-04 % max 4.603292663993e+02 min 3.200657568766e-04 max/min 1.438233414569e+06
> 200 KSP preconditioned resid norm 3.160272838961e-04 true resid norm 1.059094725800e-03 ||r(i)||/||b|| 5.924616249011e-05
> 200 KSP Residual norm 3.160272838961e-04 % max 4.625510385677e+02 min 3.200657565653e-04 max/min 1.445175027567e+06
> Thanks,
> Meng
> From:  "Barry Smith";<bsmith at mcs.anl.gov>;
> Send time: Friday, Apr 25, 2014 6:54 AM
> Cc: "Dave May"<dave.mayhem23 at gmail.com>; "petsc-users"<petsc-users at mcs.anl.gov>;
>   Run the bad case again with -ksp_gmres_restart 200 -ksp_max_it 200 and send the output
> On Apr 24, 2014, at 5:46 PM, Oo <wumeng07maths at qq.com> wrote:
> > Thanks,
> > The following is the output at the beginning.
> > When solving the linear system:
> > Output:
> > +00 max/min 7.343521316293e+01
> > 9636 KSP preconditioned resid norm 1.080641720588e+00 true resid norm 1.594064989678e-01 ||r(i)||/||b|| 8.917260288210e-03
> > 9636 KSP Residual norm 1.080641720588e+00 % max 9.802496207537e+01 min 1.168945135768e+00 max/min 8.385762434515e+01
> > 9637 KSP preconditioned resid norm 1.080641720588e+00 true resid norm 1.594064987918e-01 ||r(i)||/||b|| 8.917260278361e-03
> > 9637 KSP Residual norm 1.080641720588e+00 % max 1.122401280488e+02 min 1.141681830513e+00 max/min 9.831121512938e+01
> > 9638 KSP preconditioned resid norm 1.080641720588e+00 true resid norm 1.594064986859e-01 ||r(i)||/||b|| 8.917260272440e-03
> > 9638 KSP Residual norm 1.080641720588e+00 % max 1.134941067042e+02 min 1.090790142559e+00 max/min 1.040476094127e+02
> > 9639 KSP preconditioned resid norm 1.080641720588e+00 true resid norm 1.594064442988e-01 ||r(i)||/||b|| 8.917257230005e-03
> > 9639 KSP Residual norm 1.080641720588e+00 % max 1.139914662925e+02 min 4.119649156568e-01 max/min 2.767018791170e+02
> > 9640 KSP preconditioned resid norm 1.080641720586e+00 true resid norm 1.594063809183e-01 ||r(i)||/||b|| 8.917253684473e-03
> > 9640 KSP Residual norm 1.080641720586e+00 % max 1.140011421526e+02 min 2.894486589274e-01 max/min 3.938561766878e+02
> > 9641 KSP preconditioned resid norm 1.080641720586e+00 true resid norm 1.594063839202e-01 ||r(i)||/||b|| 8.917253852403e-03
> > 9641 KSP Residual norm 1.080641720586e+00 % max 1.140392299942e+02 min 2.880532973299e-01 max/min 3.958962839563e+02
> > 9642 KSP preconditioned resid norm 1.080641720586e+00 true resid norm 1.594064091676e-01 ||r(i)||/||b|| 8.917255264750e-03
> > 9642 KSP Residual norm 1.080641720586e+00 % max 1.140392728591e+02 min 2.501717295613e-01 max/min 4.558439639005e+02
> > 9643 KSP preconditioned resid norm 1.080641720583e+00 true resid norm 1.594064099334e-01 ||r(i)||/||b|| 8.917255307591e-03
> > 9643 KSP Residual norm 1.080641720583e+00 % max 1.141360429432e+02 min 2.500714638111e-01 max/min 4.564137035220e+02
> > 9644 KSP preconditioned resid norm 1.080641720582e+00 true resid norm 1.594064169337e-01 ||r(i)||/||b|| 8.917255699186e-03
> > 9644 KSP Residual norm 1.080641720582e+00 % max 1.141719168213e+02 min 2.470526471293e-01 max/min 4.621359784969e+02
> > 9645 KSP preconditioned resid norm 1.080641720554e+00 true resid norm 1.594064833602e-01 ||r(i)||/||b|| 8.917259415111e-03
> > 9645 KSP Residual norm 1.080641720554e+00 % max 1.141770017757e+02 min 2.461729098264e-01 max/min 4.638081495493e+02
> > 9646 KSP preconditioned resid norm 1.080641720550e+00 true resid norm 1.594066163854e-01 ||r(i)||/||b|| 8.917266856592e-03
> > 9646 KSP Residual norm 1.080641720550e+00 % max 1.150251695783e+02 min 1.817293289064e-01 max/min 6.329477485583e+02
> > 9647 KSP preconditioned resid norm 1.080641720425e+00 true resid norm 1.594070759575e-01 ||r(i)||/||b|| 8.917292565231e-03
> > 9647 KSP Residual norm 1.080641720425e+00 % max 1.153670774825e+02 min 1.757825842976e-01 max/min 6.563055034347e+02
> > 9648 KSP preconditioned resid norm 1.080641720405e+00 true resid norm 1.594072309986e-01 ||r(i)||/||b|| 8.917301238287e-03
> > 9648 KSP Residual norm 1.080641720405e+00 % max 1.154419449950e+02 min 1.682003217110e-01 max/min 6.863360534671e+02
> > 9649 KSP preconditioned resid norm 1.080641719971e+00 true resid norm 1.594088666650e-01 ||r(i)||/||b|| 8.917392738093e-03
> > 9649 KSP Residual norm 1.080641719971e+00 % max 1.154420890958e+02 min 1.254364806923e-01 max/min 9.203230867027e+02
> > 9650 KSP preconditioned resid norm 1.080641719766e+00 true resid norm 1.594089470619e-01 ||r(i)||/||b|| 8.917397235527e-03
> > 9650 KSP Residual norm 1.080641719766e+00 % max 1.155791388935e+02 min 1.115280748954e-01 max/min 1.036323266603e+03
> > 9651 KSP preconditioned resid norm 1.080641719668e+00 true resid norm 1.594099325489e-01 ||r(i)||/||b|| 8.917452364041e-03
> > 9651 KSP Residual norm 1.080641719668e+00 % max 1.156952656131e+02 min 9.753165869338e-02 max/min 1.186232933624e+03
> > 9652 KSP preconditioned resid norm 1.080641719560e+00 true resid norm 1.594104650490e-01 ||r(i)||/||b|| 8.917482152303e-03
> > 9652 KSP Residual norm 1.080641719560e+00 % max 1.157175173166e+02 min 8.164906465197e-02 max/min 1.417254659437e+03
> > 9653 KSP preconditioned resid norm 1.080641719545e+00 true resid norm 1.594102433389e-01 ||r(i)||/||b|| 8.917469749751e-03
> > 9653 KSP Residual norm 1.080641719545e+00 % max 1.157284977956e+02 min 8.043379142473e-02 max/min 1.438804459490e+03
> > 9654 KSP preconditioned resid norm 1.080641719502e+00 true resid norm 1.594103748106e-01 ||r(i)||/||b|| 8.917477104328e-03
> > 9654 KSP Residual norm 1.080641719502e+00 % max 1.158252103352e+02 min 8.042977537341e-02 max/min 1.440078749412e+03
> > 9655 KSP preconditioned resid norm 1.080641719500e+00 true resid norm 1.594103839160e-01 ||r(i)||/||b|| 8.917477613692e-03
> > 9655 KSP Residual norm 1.080641719500e+00 % max 1.158319413225e+02 min 7.912584859399e-02 max/min 1.463895090931e+03
> > 9656 KSP preconditioned resid norm 1.080641719298e+00 true resid norm 1.594103559180e-01 ||r(i)||/||b|| 8.917476047469e-03
> > 9656 KSP Residual norm 1.080641719298e+00 % max 1.164752277567e+02 min 7.459488142962e-02 max/min 1.561437266532e+03
> > 9657 KSP preconditioned resid norm 1.080641719265e+00 true resid norm 1.594102184171e-01 ||r(i)||/||b|| 8.917468355617e-03
> > 9657 KSP Residual norm 1.080641719265e+00 % max 1.166579038733e+02 min 7.458594814570e-02 max/min 1.564073485335e+03
> > 9658 KSP preconditioned resid norm 1.080641717458e+00 true resid norm 1.594091333285e-01 ||r(i)||/||b|| 8.917407655346e-03
> > 9658 KSP Residual norm 1.080641717458e+00 % max 1.166903646829e+02 min 6.207842503132e-02 max/min 1.879724954749e+03
> > 9659 KSP preconditioned resid norm 1.080641710951e+00 true resid norm 1.594084758922e-01 ||r(i)||/||b|| 8.917370878110e-03
> > 9659 KSP Residual norm 1.080641710951e+00 % max 1.166911765130e+02 min 4.511759655558e-02 max/min 2.586378384966e+03
> > 9660 KSP preconditioned resid norm 1.080641710473e+00 true resid norm 1.594073892570e-01 ||r(i)||/||b|| 8.917310091324e-03
> > 9660 KSP Residual norm 1.080641710473e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
> > 9661 KSP preconditioned resid norm 1.080641710473e+00 true resid norm 1.594073892624e-01 ||r(i)||/||b|| 8.917310091626e-03
> > 9661 KSP Residual norm 1.080641710473e+00 % max 3.063497860835e+01 min 3.063497860835e+01 max/min 1.000000000000e+00
> > 9662 KSP preconditioned resid norm 1.080641710473e+00 true resid norm 1.594073892715e-01 ||r(i)||/||b|| 8.917310092135e-03
> > 9662 KSP Residual norm 1.080641710473e+00 % max 3.066567116490e+01 min 3.845920135843e+00 max/min 7.973559013643e+00
> > 9663 KSP preconditioned resid norm 1.080641710473e+00 true resid norm 1.594073893803e-01 ||r(i)||/||b|| 8.917310098220e-03
> > 9663 KSP Residual norm 1.080641710473e+00 % max 3.713314039929e+01 min 1.336313376350e+00 max/min 2.778774878443e+01
> > 9664 KSP preconditioned resid norm 1.080641710473e+00 true resid norm 1.594073893840e-01 ||r(i)||/||b|| 8.917310098430e-03
> > 9664 KSP Residual norm 1.080641710473e+00 % max 4.496286107838e+01 min 1.226793755688e+00 max/min 3.665070911057e+01
> > 9665 KSP preconditioned resid norm 1.080641710473e+00 true resid norm 1.594073893901e-01 ||r(i)||/||b|| 8.917310098770e-03
> > 9665 KSP Residual norm 1.080641710473e+00 % max 8.684753794468e+01 min 1.183106109633e+00 max/min 7.340638108242e+01
> > 9666 KSP preconditioned resid norm 1.080641710473e+00 true resid norm 1.594073897030e-01 ||r(i)||/||b|| 8.917310116272e-03
> > 9666 KSP Residual norm 1.080641710473e+00 % max 9.802657279239e+01 min 1.168685545918e+00 max/min 8.387762913199e+01
> > 9667 KSP preconditioned resid norm 1.080641710473e+00 true resid norm 1.594073898787e-01 ||r(i)||/||b|| 8.917310126104e-03
> > 9667 KSP Residual norm 1.080641710473e+00 % max 1.123342619847e+02 min 1.141262650540e+00 max/min 9.842980661068e+01
> > 9668 KSP preconditioned resid norm 1.080641710473e+00 true resid norm 1.594073899832e-01 ||r(i)||/||b|| 8.917310131950e-03
> > 9668 KSP Residual norm 1.080641710473e+00 % max 1.134978630027e+02 min 1.090790451862e+00 max/min 1.040510235573e+02
> > 9669 KSP preconditioned resid norm 1.080641710472e+00 true resid norm 1.594074437274e-01 ||r(i)||/||b|| 8.917313138421e-03
> > 9669 KSP Residual norm 1.080641710472e+00 % max 1.139911467053e+02 min 4.122424185123e-01 max/min 2.765148407498e+02
> > 9670 KSP preconditioned resid norm 1.080641710471e+00 true resid norm 1.594075064381e-01 ||r(i)||/||b|| 8.917316646478e-03
> > 9670 KSP Residual norm 1.080641710471e+00 % max 1.140007007543e+02 min 2.895766957825e-01 max/min 3.936805081855e+02
> > 9671 KSP preconditioned resid norm 1.080641710471e+00 true resid norm 1.594075034738e-01 ||r(i)||/||b|| 8.917316480653e-03
> > 9671 KSP Residual norm 1.080641710471e+00 % max 1.140387089437e+02 min 2.881955202443e-01 max/min 3.956991033277e+02
> > 9672 KSP preconditioned resid norm 1.080641710470e+00 true resid norm 1.594074784660e-01 ||r(i)||/||b|| 8.917315081711e-03
> > 9672 KSP Residual norm 1.080641710470e+00 % max 1.140387584514e+02 min 2.501644562253e-01 max/min 4.558551609294e+02
> > 9673 KSP preconditioned resid norm 1.080641710468e+00 true resid norm 1.594074777329e-01 ||r(i)||/||b|| 8.917315040700e-03
> > 9673 KSP Residual norm 1.080641710468e+00 % max 1.141359894823e+02 min 2.500652210717e-01 max/min 4.564248838488e+02
> > 9674 KSP preconditioned resid norm 1.080641710467e+00 true resid norm 1.594074707419e-01 ||r(i)||/||b|| 8.917314649619e-03
> > 9674 KSP Residual norm 1.080641710467e+00 % max 1.141719424825e+02 min 2.470352404045e-01 max/min 4.621686456374e+02
> > 9675 KSP preconditioned resid norm 1.080641710439e+00 true resid norm 1.594074050132e-01 ||r(i)||/||b|| 8.917310972734e-03
> > 9675 KSP Residual norm 1.080641710439e+00 % max 1.141769957478e+02 min 2.461583334135e-01 max/min 4.638355897383e+02
> > 9676 KSP preconditioned resid norm 1.080641710435e+00 true resid norm 1.594072732317e-01 ||r(i)||/||b|| 8.917303600825e-03
> > 9676 KSP Residual norm 1.080641710435e+00 % max 1.150247840524e+02 min 1.817432478135e-01 max/min 6.328971526384e+02
> > 9677 KSP preconditioned resid norm 1.080641710313e+00 true resid norm 1.594068192028e-01 ||r(i)||/||b|| 8.917278202275e-03
> > 9677 KSP Residual norm 1.080641710313e+00 % max 1.153658698688e+02 min 1.758229849082e-01 max/min 6.561478291873e+02
> > 9678 KSP preconditioned resid norm 1.080641710294e+00 true resid norm 1.594066656020e-01 ||r(i)||/||b|| 8.917269609788e-03
> > 9678 KSP Residual norm 1.080641710294e+00 % max 1.154409214869e+02 min 1.682261493961e-01 max/min 6.862245964808e+02
> > 9679 KSP preconditioned resid norm 1.080641709867e+00 true resid norm 1.594050456081e-01 ||r(i)||/||b|| 8.917178986714e-03
> > 9679 KSP Residual norm 1.080641709867e+00 % max 1.154410567101e+02 min 1.254614849745e-01 max/min 9.201314390116e+02
> > 9680 KSP preconditioned resid norm 1.080641709664e+00 true resid norm 1.594049650069e-01 ||r(i)||/||b|| 8.917174477851e-03
> > 9680 KSP Residual norm 1.080641709664e+00 % max 1.155780217907e+02 min 1.115227545913e-01 max/min 1.036362688622e+03
> > 9681 KSP preconditioned resid norm 1.080641709568e+00 true resid norm 1.594039822189e-01 ||r(i)||/||b|| 8.917119500317e-03
> > 9681 KSP Residual norm 1.080641709568e+00 % max 1.156949294099e+02 min 9.748012982669e-02 max/min 1.186856538000e+03
> > 9682 KSP preconditioned resid norm 1.080641709462e+00 true resid norm 1.594034585197e-01 ||r(i)||/||b|| 8.917090204385e-03
> > 9682 KSP Residual norm 1.080641709462e+00 % max 1.157178049396e+02 min 8.161660044005e-02 max/min 1.417821917547e+03
> > 9683 KSP preconditioned resid norm 1.080641709447e+00 true resid norm 1.594036816693e-01 ||r(i)||/||b|| 8.917102687458e-03
> > 9683 KSP Residual norm 1.080641709447e+00 % max 1.157298376396e+02 min 8.041659530019e-02 max/min 1.439128791856e+03
> > 9684 KSP preconditioned resid norm 1.080641709407e+00 true resid norm 1.594035571975e-01 ||r(i)||/||b|| 8.917095724454e-03
> > 9684 KSP Residual norm 1.080641709407e+00 % max 1.158244705264e+02 min 8.041209608100e-02 max/min 1.440386162919e+03
> > 9685 KSP preconditioned resid norm 1.080641709405e+00 true resid norm 1.594035489927e-01 ||r(i)||/||b|| 8.917095265477e-03
> > 9685 KSP Residual norm 1.080641709405e+00 % max 1.158301451854e+02 min 7.912026880308e-02 max/min 1.463975627707e+03
> > 9686 KSP preconditioned resid norm 1.080641709207e+00 true resid norm 1.594035774591e-01 ||r(i)||/||b|| 8.917096857899e-03
> > 9686 KSP Residual norm 1.080641709207e+00 % max 1.164678839370e+02 min 7.460755571674e-02 max/min 1.561073577845e+03
> > 9687 KSP preconditioned resid norm 1.080641709174e+00 true resid norm 1.594037147171e-01 ||r(i)||/||b|| 8.917104536162e-03
> > 9687 KSP Residual norm 1.080641709174e+00 % max 1.166488052404e+02 min 7.459794478802e-02 max/min 1.563699986264e+03
> > 9688 KSP preconditioned resid norm 1.080641707398e+00 true resid norm 1.594047860513e-01 ||r(i)||/||b|| 8.917164467006e-03
> > 9688 KSP Residual norm 1.080641707398e+00 % max 1.166807852257e+02 min 6.210503072987e-02 max/min 1.878765437428e+03
> > 9689 KSP preconditioned resid norm 1.080641701010e+00 true resid norm 1.594054414016e-01 ||r(i)||/||b|| 8.917201127549e-03
> > 9689 KSP Residual norm 1.080641701010e+00 % max 1.166815140099e+02 min 4.513527468187e-02 max/min 2.585151299782e+03
> > 9690 KSP preconditioned resid norm 1.080641700548e+00 true resid norm 1.594065078534e-01 ||r(i)||/||b|| 8.917260785273e-03
> > 9690 KSP Residual norm 1.080641700548e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
> > 9691 KSP preconditioned resid norm 1.080641700548e+00 true resid norm 1.594065078481e-01 ||r(i)||/||b|| 8.917260784977e-03
> > 9691 KSP Residual norm 1.080641700548e+00 % max 3.063462923862e+01 min 3.063462923862e+01 max/min 1.000000000000e+00
> > 9692 KSP preconditioned resid norm 1.080641700548e+00 true resid norm 1.594065078391e-01 ||r(i)||/||b|| 8.917260784472e-03
> > 9692 KSP Residual norm 1.080641700548e+00 % max 3.066527639129e+01 min 3.844401168431e+00 max/min 7.976606771193e+00
> > 9693 KSP preconditioned resid norm 1.080641700548e+00 true resid norm 1.594065077314e-01 ||r(i)||/||b|| 8.917260778448e-03
> > 9693 KSP Residual norm 1.080641700548e+00 % max 3.714560719346e+01 min 1.336559823443e+00 max/min 2.779195255007e+01
> > 9694 KSP preconditioned resid norm 1.080641700548e+00 true resid norm 1.594065077277e-01 ||r(i)||/||b|| 8.917260778237e-03
> > 9694 KSP Residual norm 1.080641700548e+00 % max 4.500980776068e+01 min 1.226798344943e+00 max/min 3.668883965014e+01
> > 9695 KSP preconditioned resid norm 1.080641700548e+00 true resid norm 1.594065077215e-01 ||r(i)||/||b|| 8.917260777894e-03
> > 9695 KSP Residual norm 1.080641700548e+00 % max 8.688252795875e+01 min 1.183121330492e+00 max/min 7.343501103356e+01
> > 9696 KSP preconditioned resid norm 1.080641700548e+00 true resid norm 1.594065074170e-01 ||r(i)||/||b|| 8.917260760857e-03
> > 9696 KSP Residual norm 1.080641700548e+00 % max 9.802496799855e+01 min 1.168942571066e+00 max/min 8.385781339895e+01
> > 9697 KSP preconditioned resid norm 1.080641700548e+00 true resid norm 1.594065072444e-01 ||r(i)||/||b|| 8.917260751202e-03
> > 9697 KSP Residual norm 1.080641700548e+00 % max 1.122410641497e+02 min 1.141677885656e+00 max/min 9.831237475989e+01
> > 9698 KSP preconditioned resid norm 1.080641700548e+00 true resid norm 1.594065071406e-01 ||r(i)||/||b|| 8.917260745398e-03
> > 9698 KSP Residual norm 1.080641700548e+00 % max 1.134941426413e+02 min 1.090790153651e+00 max/min 1.040476413006e+02
> > 9699 KSP preconditioned resid norm 1.080641700547e+00 true resid norm 1.594064538413e-01 ||r(i)||/||b|| 8.917257763815e-03
> > 9699 KSP Residual norm 1.080641700547e+00 % max 1.139914632588e+02 min 4.119681054781e-01 max/min 2.766997292824e+02
> > 9700 KSP preconditioned resid norm 1.080641700546e+00 true resid norm 1.594063917269e-01 ||r(i)||/||b|| 8.917254289111e-03
> > 9700 KSP Residual norm 1.080641700546e+00 % max 1.140011377578e+02 min 2.894500209686e-01 max/min 3.938543081679e+02
> > 9701 KSP preconditioned resid norm 1.080641700546e+00 true resid norm 1.594063946692e-01 ||r(i)||/||b|| 8.917254453705e-03
> > 9701 KSP Residual norm 1.080641700546e+00 % max 1.140392249545e+02 min 2.880548133071e-01 max/min 3.958941829341e+02
> > 9702 KSP preconditioned resid norm 1.080641700546e+00 true resid norm 1.594064194159e-01 ||r(i)||/||b|| 8.917255838042e-03
> > 9702 KSP Residual norm 1.080641700546e+00 % max 1.140392678944e+02 min 2.501716607446e-01 max/min 4.558440694479e+02
> > 9703 KSP preconditioned resid norm 1.080641700543e+00 true resid norm 1.594064201661e-01 ||r(i)||/||b|| 8.917255880013e-03
> > 9703 KSP Residual norm 1.080641700543e+00 % max 1.141360426034e+02 min 2.500714053220e-01 max/min 4.564138089137e+02
> > 9704 KSP preconditioned resid norm 1.080641700542e+00 true resid norm 1.594064270279e-01 ||r(i)||/||b|| 8.917256263859e-03
> > 9704 KSP Residual norm 1.080641700542e+00 % max 1.141719170495e+02 min 2.470524869868e-01 max/min 4.621362789824e+02
> > 9705 KSP preconditioned resid norm 1.080641700515e+00 true resid norm 1.594064921269e-01 ||r(i)||/||b|| 8.917259905523e-03
> > 9705 KSP Residual norm 1.080641700515e+00 % max 1.141770017414e+02 min 2.461727640845e-01 max/min 4.638084239987e+02
> > 9706 KSP preconditioned resid norm 1.080641700511e+00 true resid norm 1.594066225181e-01 ||r(i)||/||b|| 8.917267199657e-03
> > 9706 KSP Residual norm 1.080641700511e+00 % max 1.150251667711e+02 min 1.817294170466e-01 max/min 6.329474261263e+02
> > 9707 KSP preconditioned resid norm 1.080641700391e+00 true resid norm 1.594070728983e-01 ||r(i)||/||b|| 8.917292394097e-03
> > 9707 KSP Residual norm 1.080641700391e+00 % max 1.153670687494e+02 min 1.757829178698e-01 max/min 6.563042083238e+02
> > 9708 KSP preconditioned resid norm 1.080641700372e+00 true resid norm 1.594072248425e-01 ||r(i)||/||b|| 8.917300893916e-03
> > 9708 KSP Residual norm 1.080641700372e+00 % max 1.154419380718e+02 min 1.682005223292e-01 max/min 6.863351936912e+02
> > 9709 KSP preconditioned resid norm 1.080641699955e+00 true resid norm 1.594088278507e-01 ||r(i)||/||b|| 8.917390566803e-03
> > 9709 KSP Residual norm 1.080641699955e+00 % max 1.154420821193e+02 min 1.254367014624e-01 max/min 9.203214113045e+02
> > 9710 KSP preconditioned resid norm 1.080641699758e+00 true resid norm 1.594089066545e-01 ||r(i)||/||b|| 8.917394975116e-03
> > 9710 KSP Residual norm 1.080641699758e+00 % max 1.155791306030e+02 min 1.115278858784e-01 max/min 1.036324948623e+03
> > 9711 KSP preconditioned resid norm 1.080641699664e+00 true resid norm 1.594098725388e-01 ||r(i)||/||b|| 8.917449007053e-03
> > 9711 KSP Residual norm 1.080641699664e+00 % max 1.156952614563e+02 min 9.753133694719e-02 max/min 1.186236804269e+03
> > 9712 KSP preconditioned resid norm 1.080641699560e+00 true resid norm 1.594103943811e-01 ||r(i)||/||b|| 8.917478199111e-03
> > 9712 KSP Residual norm 1.080641699560e+00 % max 1.157175157006e+02 min 8.164872572382e-02 max/min 1.417260522743e+03
> > 9713 KSP preconditioned resid norm 1.080641699546e+00 true resid norm 1.594101771105e-01 ||r(i)||/||b|| 8.917466044914e-03
> > 9713 KSP Residual norm 1.080641699546e+00 % max 1.157285025175e+02 min 8.043358651149e-02 max/min 1.438808183705e+03
> > 9714 KSP preconditioned resid norm 1.080641699505e+00 true resid norm 1.594103059104e-01 ||r(i)||/||b|| 8.917473250025e-03
> > 9714 KSP Residual norm 1.080641699505e+00 % max 1.158251990486e+02 min 8.042956633721e-02 max/min 1.440082351843e+03
> > 9715 KSP preconditioned resid norm 1.080641699503e+00 true resid norm 1.594103148215e-01 ||r(i)||/||b|| 8.917473748516e-03
> > 9715 KSP Residual norm 1.080641699503e+00 % max 1.158319218998e+02 min 7.912575668150e-02 max/min 1.463896545925e+03
> > 9716 KSP preconditioned resid norm 1.080641699309e+00 true resid norm 1.594102873744e-01 ||r(i)||/||b|| 8.917472213115e-03
> > 9716 KSP Residual norm 1.080641699309e+00 % max 1.164751648212e+02 min 7.459498920670e-02 max/min 1.561434166824e+03
> > 9717 KSP preconditioned resid norm 1.080641699277e+00 true resid norm 1.594101525703e-01 ||r(i)||/||b|| 8.917464672122e-03
> > 9717 KSP Residual norm 1.080641699277e+00 % max 1.166578264103e+02 min 7.458604738274e-02 max/min 1.564070365758e+03
> > 9718 KSP preconditioned resid norm 1.080641697541e+00 true resid norm 1.594090891807e-01 ||r(i)||/||b|| 8.917405185702e-03
> > 9718 KSP Residual norm 1.080641697541e+00 % max 1.166902828397e+02 min 6.207863457218e-02 max/min 1.879717291527e+03
> > 9719 KSP preconditioned resid norm 1.080641691292e+00 true resid norm 1.594084448306e-01 ||r(i)||/||b|| 8.917369140517e-03
> > 9719 KSP Residual norm 1.080641691292e+00 % max 1.166910940162e+02 min 4.511779816158e-02 max/min 2.586364999424e+03
> > 9720 KSP preconditioned resid norm 1.080641690833e+00 true resid norm 1.594073798840e-01 ||r(i)||/||b|| 8.917309566993e-03
> > 9720 KSP Residual norm 1.080641690833e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
> > 9721 KSP preconditioned resid norm 1.080641690833e+00 true resid norm 1.594073798892e-01 ||r(i)||/||b|| 8.917309567288e-03
> > 9721 KSP Residual norm 1.080641690833e+00 % max 3.063497720423e+01 min 3.063497720423e+01 max/min 1.000000000000e+00
> > 9722 KSP preconditioned resid norm 1.080641690833e+00 true resid norm 1.594073798982e-01 ||r(i)||/||b|| 8.917309567787e-03
> > 9722 KSP Residual norm 1.080641690833e+00 % max 3.066566915002e+01 min 3.845904218039e+00 max/min 7.973591491484e+00
> > 9723 KSP preconditioned resid norm 1.080641690833e+00 true resid norm 1.594073800048e-01 ||r(i)||/||b|| 8.917309573750e-03
> > 9723 KSP Residual norm 1.080641690833e+00 % max 3.713330064708e+01 min 1.336316867286e+00 max/min 2.778779611043e+01
> > 9724 KSP preconditioned resid norm 1.080641690833e+00 true resid norm 1.594073800084e-01 ||r(i)||/||b|| 8.917309573955e-03
> > 9724 KSP Residual norm 1.080641690833e+00 % max 4.496345800250e+01 min 1.226793989785e+00 max/min 3.665118868930e+01
> > 9725 KSP preconditioned resid norm 1.080641690833e+00 true resid norm 1.594073800144e-01 ||r(i)||/||b|| 8.917309574290e-03
> > 9725 KSP Residual norm 1.080641690833e+00 % max 8.684799302076e+01 min 1.183106260116e+00 max/min 7.340675639080e+01
> > 9726 KSP preconditioned resid norm 1.080641690833e+00 true resid norm 1.594073803210e-01 ||r(i)||/||b|| 8.917309591441e-03
> > 9726 KSP Residual norm 1.080641690833e+00 % max 9.802654643741e+01 min 1.168688159857e+00 max/min 8.387741897664e+01
> > 9727 KSP preconditioned resid norm 1.080641690833e+00 true resid norm 1.594073804933e-01 ||r(i)||/||b|| 8.917309601077e-03
> > 9727 KSP Residual norm 1.080641690833e+00 % max 1.123333202151e+02 min 1.141267080659e+00 max/min 9.842859933384e+01
> > 9728 KSP preconditioned resid norm 1.080641690833e+00 true resid norm 1.594073805957e-01 ||r(i)||/||b|| 8.917309606809e-03
> > 9728 KSP Residual norm 1.080641690833e+00 % max 1.134978238790e+02 min 1.090790456842e+00 max/min 1.040509872149e+02
> > 9729 KSP preconditioned resid norm 1.080641690832e+00 true resid norm 1.594074332665e-01 ||r(i)||/||b|| 8.917312553232e-03
> > 9729 KSP Residual norm 1.080641690832e+00 % max 1.139911500486e+02 min 4.122400558994e-01 max/min 2.765164336102e+02
> > 9730 KSP preconditioned resid norm 1.080641690831e+00 true resid norm 1.594074947247e-01 ||r(i)||/||b|| 8.917315991226e-03
> > 9730 KSP Residual norm 1.080641690831e+00 % max 1.140007051733e+02 min 2.895754967285e-01 max/min 3.936821535706e+02
> > 9731 KSP preconditioned resid norm 1.080641690831e+00 true resid norm 1.594074918191e-01 ||r(i)||/||b|| 8.917315828690e-03
> > 9731 KSP Residual norm 1.080641690831e+00 % max 1.140387143094e+02 min 2.881941911453e-01 max/min 3.957009468380e+02
> > 9732 KSP preconditioned resid norm 1.080641690830e+00 true resid norm 1.594074673079e-01 ||r(i)||/||b|| 8.917314457521e-03
> > 9732 KSP Residual norm 1.080641690830e+00 % max 1.140387637599e+02 min 2.501645326450e-01 max/min 4.558550428958e+02
> > 9733 KSP preconditioned resid norm 1.080641690828e+00 true resid norm 1.594074665892e-01 ||r(i)||/||b|| 8.917314417314e-03
> > 9733 KSP Residual norm 1.080641690828e+00 % max 1.141359902062e+02 min 2.500652873669e-01 max/min 4.564247657404e+02
> > 9734 KSP preconditioned resid norm 1.080641690827e+00 true resid norm 1.594074597377e-01 ||r(i)||/||b|| 8.917314034043e-03
> > 9734 KSP Residual norm 1.080641690827e+00 % max 1.141719421992e+02 min 2.470354276866e-01 max/min 4.621682941123e+02
> > 9735 KSP preconditioned resid norm 1.080641690800e+00 true resid norm 1.594073953224e-01 ||r(i)||/||b|| 8.917310430625e-03
> > 9735 KSP Residual norm 1.080641690800e+00 % max 1.141769958343e+02 min 2.461584786890e-01 max/min 4.638353163473e+02
> > 9736 KSP preconditioned resid norm 1.080641690797e+00 true resid norm 1.594072661531e-01 ||r(i)||/||b|| 8.917303204847e-03
> > 9736 KSP Residual norm 1.080641690797e+00 % max 1.150247889475e+02 min 1.817430598855e-01 max/min 6.328978340080e+02
> > 9737 KSP preconditioned resid norm 1.080641690679e+00 true resid norm 1.594068211899e-01 ||r(i)||/||b|| 8.917278313432e-03
> > 9737 KSP Residual norm 1.080641690679e+00 % max 1.153658852526e+02 min 1.758225138542e-01 max/min 6.561496745986e+02
> > 9738 KSP preconditioned resid norm 1.080641690661e+00 true resid norm 1.594066706603e-01 ||r(i)||/||b|| 8.917269892752e-03
> > 9738 KSP Residual norm 1.080641690661e+00 % max 1.154409350014e+02 min 1.682258367468e-01 max/min 6.862259521714e+02
> > 9739 KSP preconditioned resid norm 1.080641690251e+00 true resid norm 1.594050830368e-01 ||r(i)||/||b|| 8.917181080485e-03
> > 9739 KSP Residual norm 1.080641690251e+00 % max 1.154410703479e+02 min 1.254612102469e-01 max/min 9.201335625627e+02
> > 9740 KSP preconditioned resid norm 1.080641690057e+00 true resid norm 1.594050040532e-01 ||r(i)||/||b|| 8.917176662114e-03
> > 9740 KSP Residual norm 1.080641690057e+00 % max 1.155780358111e+02 min 1.115226752201e-01 max/min 1.036363551923e+03
> > 9741 KSP preconditioned resid norm 1.080641689964e+00 true resid norm 1.594040409622e-01 ||r(i)||/||b|| 8.917122786435e-03
> > 9741 KSP Residual norm 1.080641689964e+00 % max 1.156949319460e+02 min 9.748084084270e-02 max/min 1.186847907198e+03
> > 9742 KSP preconditioned resid norm 1.080641689862e+00 true resid norm 1.594035276798e-01 ||r(i)||/||b|| 8.917094073223e-03
> > 9742 KSP Residual norm 1.080641689862e+00 % max 1.157177974822e+02 min 8.161690928512e-02 max/min 1.417816461022e+03
> > 9743 KSP preconditioned resid norm 1.080641689848e+00 true resid norm 1.594037462881e-01 ||r(i)||/||b|| 8.917106302257e-03
> > 9743 KSP Residual norm 1.080641689848e+00 % max 1.157298152734e+02 min 8.041673363017e-02 max/min 1.439126038190e+03
> > 9744 KSP preconditioned resid norm 1.080641689809e+00 true resid norm 1.594036242374e-01 ||r(i)||/||b|| 8.917099474695e-03
> > 9744 KSP Residual norm 1.080641689809e+00 % max 1.158244737331e+02 min 8.041224000025e-02 max/min 1.440383624841e+03
> > 9745 KSP preconditioned resid norm 1.080641689808e+00 true resid norm 1.594036161930e-01 ||r(i)||/||b|| 8.917099024685e-03
> > 9745 KSP Residual norm 1.080641689808e+00 % max 1.158301611517e+02 min 7.912028815054e-02 max/min 1.463975471516e+03
> > 9746 KSP preconditioned resid norm 1.080641689617e+00 true resid norm 1.594036440841e-01 ||r(i)||/||b|| 8.917100584928e-03
> > 9746 KSP Residual norm 1.080641689617e+00 % max 1.164679674294e+02 min 7.460741052548e-02 max/min 1.561077734894e+03
> > 9747 KSP preconditioned resid norm 1.080641689585e+00 true resid norm 1.594037786262e-01 ||r(i)||/||b|| 8.917108111263e-03
> > 9747 KSP Residual norm 1.080641689585e+00 % max 1.166489093034e+02 min 7.459780450955e-02 max/min 1.563704321734e+03
> > 9748 KSP preconditioned resid norm 1.080641687880e+00 true resid norm 1.594048285858e-01 ||r(i)||/||b|| 8.917166846404e-03
> > 9748 KSP Residual norm 1.080641687880e+00 % max 1.166808944816e+02 min 6.210471238399e-02 max/min 1.878776827114e+03
> > 9749 KSP preconditioned resid norm 1.080641681745e+00 true resid norm 1.594054707973e-01 ||r(i)||/||b|| 8.917202771956e-03
> > 9749 KSP Residual norm 1.080641681745e+00 % max 1.166816242497e+02 min 4.513512286802e-02 max/min 2.585162437485e+03
> > 9750 KSP preconditioned resid norm 1.080641681302e+00 true resid norm 1.594065161384e-01 ||r(i)||/||b|| 8.917261248737e-03
> > 9750 KSP Residual norm 1.080641681302e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
> > 9751 KSP preconditioned resid norm 1.080641681302e+00 true resid norm 1.594065161332e-01 ||r(i)||/||b|| 8.917261248446e-03
> > 9751 KSP Residual norm 1.080641681302e+00 % max 3.063463477969e+01 min 3.063463477969e+01 max/min 1.000000000000e+00
> > 9752 KSP preconditioned resid norm 1.080641681302e+00 true resid norm 1.594065161243e-01 ||r(i)||/||b|| 8.917261247951e-03
> > 9752 KSP Residual norm 1.080641681302e+00 % max 3.066528223339e+01 min 3.844415595957e+00 max/min 7.976578355796e+00
> > 9753 KSP preconditioned resid norm 1.080641681302e+00 true resid norm 1.594065160188e-01 ||r(i)||/||b|| 8.917261242049e-03
> > 9753 KSP Residual norm 1.080641681302e+00 % max 3.714551741771e+01 min 1.336558367241e+00 max/min 2.779191566050e+01
> > 9754 KSP preconditioned resid norm 1.080641681302e+00 true resid norm 1.594065160151e-01 ||r(i)||/||b|| 8.917261241840e-03
> > 9754 KSP Residual norm 1.080641681302e+00 % max 4.500946346995e+01 min 1.226798482639e+00 max/min 3.668855489054e+01
> > 9755 KSP preconditioned resid norm 1.080641681302e+00 true resid norm 1.594065160091e-01 ||r(i)||/||b|| 8.917261241506e-03
> > 9755 KSP Residual norm 1.080641681302e+00 % max 8.688228012809e+01 min 1.183121177118e+00 max/min 7.343481108144e+01
> > 9756 KSP preconditioned resid norm 1.080641681302e+00 true resid norm 1.594065157105e-01 ||r(i)||/||b|| 8.917261224803e-03
> > 9756 KSP Residual norm 1.080641681302e+00 % max 9.802497401249e+01 min 1.168940055038e+00 max/min 8.385799903943e+01
> > 9757 KSP preconditioned resid norm 1.080641681302e+00 true resid norm 1.594065155414e-01 ||r(i)||/||b|| 8.917261215340e-03
> > 9757 KSP Residual norm 1.080641681302e+00 % max 1.122419823631e+02 min 1.141674012007e+00 max/min 9.831351259875e+01
> > 9758 KSP preconditioned resid norm 1.080641681302e+00 true resid norm 1.594065154397e-01 ||r(i)||/||b|| 8.917261209650e-03
> > 9758 KSP Residual norm 1.080641681302e+00 % max 1.134941779165e+02 min 1.090790164362e+00 max/min 1.040476726180e+02
> > 9759 KSP preconditioned resid norm 1.080641681301e+00 true resid norm 1.594064632071e-01 ||r(i)||/||b|| 8.917258287741e-03
> > 9759 KSP Residual norm 1.080641681301e+00 % max 1.139914602803e+02 min 4.119712251563e-01 max/min 2.766976267263e+02
> > 9760 KSP preconditioned resid norm 1.080641681300e+00 true resid norm 1.594064023343e-01 ||r(i)||/||b|| 8.917254882493e-03
> > 9760 KSP Residual norm 1.080641681300e+00 % max 1.140011334474e+02 min 2.894513550128e-01 max/min 3.938524780524e+02
> > 9761 KSP preconditioned resid norm 1.080641681299e+00 true resid norm 1.594064052181e-01 ||r(i)||/||b|| 8.917255043816e-03
> > 9761 KSP Residual norm 1.080641681299e+00 % max 1.140392200085e+02 min 2.880562980628e-01 max/min 3.958921251693e+02
> > 9762 KSP preconditioned resid norm 1.080641681299e+00 true resid norm 1.594064294735e-01 ||r(i)||/||b|| 8.917256400669e-03
> > 9762 KSP Residual norm 1.080641681299e+00 % max 1.140392630219e+02 min 2.501715931763e-01 max/min 4.558441730892e+02
> > 9763 KSP preconditioned resid norm 1.080641681297e+00 true resid norm 1.594064302085e-01 ||r(i)||/||b|| 8.917256441789e-03
> > 9763 KSP Residual norm 1.080641681297e+00 % max 1.141360422663e+02 min 2.500713478839e-01 max/min 4.564139123977e+02
> > 9764 KSP preconditioned resid norm 1.080641681296e+00 true resid norm 1.594064369343e-01 ||r(i)||/||b|| 8.917256818032e-03
> > 9764 KSP Residual norm 1.080641681296e+00 % max 1.141719172739e+02 min 2.470523296471e-01 max/min 4.621365742109e+02
> > 9765 KSP preconditioned resid norm 1.080641681269e+00 true resid norm 1.594065007316e-01 ||r(i)||/||b|| 8.917260386877e-03
> > 9765 KSP Residual norm 1.080641681269e+00 % max 1.141770017074e+02 min 2.461726211496e-01 max/min 4.638086931610e+02
> > 9766 KSP preconditioned resid norm 1.080641681266e+00 true resid norm 1.594066285385e-01 ||r(i)||/||b|| 8.917267536440e-03
> > 9766 KSP Residual norm 1.080641681266e+00 % max 1.150251639969e+02 min 1.817295045513e-01 max/min 6.329471060897e+02
> > 9767 KSP preconditioned resid norm 1.080641681150e+00 true resid norm 1.594070699054e-01 ||r(i)||/||b|| 8.917292226672e-03
> > 9767 KSP Residual norm 1.080641681150e+00 % max 1.153670601170e+02 min 1.757832464778e-01 max/min 6.563029323251e+02
> > 9768 KSP preconditioned resid norm 1.080641681133e+00 true resid norm 1.594072188128e-01 ||r(i)||/||b|| 8.917300556609e-03
> > 9768 KSP Residual norm 1.080641681133e+00 % max 1.154419312149e+02 min 1.682007202940e-01 max/min 6.863343451393e+02
> > 9769 KSP preconditioned resid norm 1.080641680732e+00 true resid norm 1.594087897943e-01 ||r(i)||/||b|| 8.917388437917e-03
> > 9769 KSP Residual norm 1.080641680732e+00 % max 1.154420752094e+02 min 1.254369186538e-01 max/min 9.203197627011e+02
> > 9770 KSP preconditioned resid norm 1.080641680543e+00 true resid norm 1.594088670353e-01 ||r(i)||/||b|| 8.917392758804e-03
> > 9770 KSP Residual norm 1.080641680543e+00 % max 1.155791224140e+02 min 1.115277033208e-01 max/min 1.036326571538e+03
> > 9771 KSP preconditioned resid norm 1.080641680452e+00 true resid norm 1.594098136932e-01 ||r(i)||/||b|| 8.917445715209e-03
> > 9771 KSP Residual norm 1.080641680452e+00 % max 1.156952573953e+02 min 9.753101753312e-02 max/min 1.186240647556e+03
> > 9772 KSP preconditioned resid norm 1.080641680352e+00 true resid norm 1.594103250846e-01 ||r(i)||/||b|| 8.917474322641e-03
> > 9772 KSP Residual norm 1.080641680352e+00 % max 1.157175142052e+02 min 8.164839358709e-02 max/min 1.417266269688e+03
> > 9773 KSP preconditioned resid norm 1.080641680339e+00 true resid norm 1.594101121664e-01 ||r(i)||/||b|| 8.917462411912e-03
> > 9773 KSP Residual norm 1.080641680339e+00 % max 1.157285073186e+02 min 8.043338619163e-02 max/min 1.438811826757e+03
> > 9774 KSP preconditioned resid norm 1.080641680299e+00 true resid norm 1.594102383476e-01 ||r(i)||/||b|| 8.917469470538e-03
> > 9774 KSP Residual norm 1.080641680299e+00 % max 1.158251880541e+02 min 8.042936196082e-02 max/min 1.440085874492e+03
> > 9775 KSP preconditioned resid norm 1.080641680298e+00 true resid norm 1.594102470687e-01 ||r(i)||/||b|| 8.917469958400e-03
> > 9775 KSP Residual norm 1.080641680298e+00 % max 1.158319028736e+02 min 7.912566724984e-02 max/min 1.463897960037e+03
> > 9776 KSP preconditioned resid norm 1.080641680112e+00 true resid norm 1.594102201623e-01 ||r(i)||/||b|| 8.917468453243e-03
> > 9776 KSP Residual norm 1.080641680112e+00 % max 1.164751028861e+02 min 7.459509526345e-02 max/min 1.561431116546e+03
> > 9777 KSP preconditioned resid norm 1.080641680081e+00 true resid norm 1.594100880055e-01 ||r(i)||/||b|| 8.917461060344e-03
> > 9777 KSP Residual norm 1.080641680081e+00 % max 1.166577501679e+02 min 7.458614509876e-02 max/min 1.564067294448e+03
> > 9778 KSP preconditioned resid norm 1.080641678414e+00 true resid norm 1.594090458938e-01 ||r(i)||/||b|| 8.917402764217e-03
> > 9778 KSP Residual norm 1.080641678414e+00 % max 1.166902022924e+02 min 6.207884124039e-02 max/min 1.879709736213e+03
> > 9779 KSP preconditioned resid norm 1.080641672412e+00 true resid norm 1.594084143785e-01 ||r(i)||/||b|| 8.917367437011e-03
> > 9779 KSP Residual norm 1.080641672412e+00 % max 1.166910128239e+02 min 4.511799534103e-02 max/min 2.586351896663e+03
> > 9780 KSP preconditioned resid norm 1.080641671971e+00 true resid norm 1.594073707031e-01 ||r(i)||/||b|| 8.917309053412e-03
> > 9780 KSP Residual norm 1.080641671971e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
> > 9781 KSP preconditioned resid norm 1.080641671971e+00 true resid norm 1.594073707083e-01 ||r(i)||/||b|| 8.917309053702e-03
> > 9781 KSP Residual norm 1.080641671971e+00 % max 3.063497578379e+01 min 3.063497578379e+01 max/min 1.000000000000e+00
> > 9782 KSP preconditioned resid norm 1.080641671971e+00 true resid norm 1.594073707170e-01 ||r(i)||/||b|| 8.917309054190e-03
> > 9782 KSP Residual norm 1.080641671971e+00 % max 3.066566713389e+01 min 3.845888622043e+00 max/min 7.973623302070e+00
> > 9783 KSP preconditioned resid norm 1.080641671971e+00 true resid norm 1.594073708215e-01 ||r(i)||/||b|| 8.917309060034e-03
> > 9783 KSP Residual norm 1.080641671971e+00 % max 3.713345706068e+01 min 1.336320269525e+00 max/min 2.778784241137e+01
> > 9784 KSP preconditioned resid norm 1.080641671971e+00 true resid norm 1.594073708251e-01 ||r(i)||/||b|| 8.917309060235e-03
> > 9784 KSP Residual norm 1.080641671971e+00 % max 4.496404075363e+01 min 1.226794215442e+00 max/min 3.665165696713e+01
> > 9785 KSP preconditioned resid norm 1.080641671971e+00 true resid norm 1.594073708309e-01 ||r(i)||/||b|| 8.917309060564e-03
> > 9785 KSP Residual norm 1.080641671971e+00 % max 8.684843710054e+01 min 1.183106407741e+00 max/min 7.340712258198e+01
> > 9786 KSP preconditioned resid norm 1.080641671971e+00 true resid norm 1.594073711314e-01 ||r(i)||/||b|| 8.917309077372e-03
> > 9786 KSP Residual norm 1.080641671971e+00 % max 9.802652080694e+01 min 1.168690722569e+00 max/min 8.387721311884e+01
> > 9787 KSP preconditioned resid norm 1.080641671971e+00 true resid norm 1.594073713003e-01 ||r(i)||/||b|| 8.917309086817e-03
> > 9787 KSP Residual norm 1.080641671971e+00 % max 1.123323967807e+02 min 1.141271419633e+00 max/min 9.842741599265e+01
> > 9788 KSP preconditioned resid norm 1.080641671971e+00 true resid norm 1.594073714007e-01 ||r(i)||/||b|| 8.917309092435e-03
> > 9788 KSP Residual norm 1.080641671971e+00 % max 1.134977855491e+02 min 1.090790461557e+00 max/min 1.040509516255e+02
> > 9789 KSP preconditioned resid norm 1.080641671970e+00 true resid norm 1.594074230188e-01 ||r(i)||/||b|| 8.917311979972e-03
> > 9789 KSP Residual norm 1.080641671970e+00 % max 1.139911533240e+02 min 4.122377311421e-01 max/min 2.765180009315e+02
> > 9790 KSP preconditioned resid norm 1.080641671969e+00 true resid norm 1.594074832488e-01 ||r(i)||/||b|| 8.917315349259e-03
> > 9790 KSP Residual norm 1.080641671969e+00 % max 1.140007095063e+02 min 2.895743194700e-01 max/min 3.936837690403e+02
> > 9791 KSP preconditioned resid norm 1.080641671969e+00 true resid norm 1.594074804009e-01 ||r(i)||/||b|| 8.917315189946e-03
> > 9791 KSP Residual norm 1.080641671969e+00 % max 1.140387195674e+02 min 2.881928861513e-01 max/min 3.957027568944e+02
> > 9792 KSP preconditioned resid norm 1.080641671968e+00 true resid norm 1.594074563767e-01 ||r(i)||/||b|| 8.917313846024e-03
> > 9792 KSP Residual norm 1.080641671968e+00 % max 1.140387689617e+02 min 2.501646075030e-01 max/min 4.558549272813e+02
> > 9793 KSP preconditioned resid norm 1.080641671966e+00 true resid norm 1.594074556720e-01 ||r(i)||/||b|| 8.917313806607e-03
> > 9793 KSP Residual norm 1.080641671966e+00 % max 1.141359909124e+02 min 2.500653522913e-01 max/min 4.564246500628e+02
> > 9794 KSP preconditioned resid norm 1.080641671965e+00 true resid norm 1.594074489575e-01 ||r(i)||/||b|| 8.917313430994e-03
> > 9794 KSP Residual norm 1.080641671965e+00 % max 1.141719419220e+02 min 2.470356110582e-01 max/min 4.621679499282e+02
> > 9795 KSP preconditioned resid norm 1.080641671939e+00 true resid norm 1.594073858301e-01 ||r(i)||/||b|| 8.917309899620e-03
> > 9795 KSP Residual norm 1.080641671939e+00 % max 1.141769959186e+02 min 2.461586211459e-01 max/min 4.638350482589e+02
> > 9796 KSP preconditioned resid norm 1.080641671936e+00 true resid norm 1.594072592237e-01 ||r(i)||/||b|| 8.917302817214e-03
> > 9796 KSP Residual norm 1.080641671936e+00 % max 1.150247937261e+02 min 1.817428765765e-01 max/min 6.328984986528e+02
> > 9797 KSP preconditioned resid norm 1.080641671823e+00 true resid norm 1.594068231505e-01 ||r(i)||/||b|| 8.917278423111e-03
> > 9797 KSP Residual norm 1.080641671823e+00 % max 1.153659002697e+02 min 1.758220533048e-01 max/min 6.561514787326e+02
> > 9798 KSP preconditioned resid norm 1.080641671805e+00 true resid norm 1.594066756326e-01 ||r(i)||/||b|| 8.917270170903e-03
> > 9798 KSP Residual norm 1.080641671805e+00 % max 1.154409481864e+02 min 1.682255312531e-01 max/min 6.862272767188e+02
> > 9799 KSP preconditioned resid norm 1.080641671412e+00 true resid norm 1.594051197519e-01 ||r(i)||/||b|| 8.917183134347e-03
> > 9799 KSP Residual norm 1.080641671412e+00 % max 1.154410836529e+02 min 1.254609413083e-01 max/min 9.201356410140e+02
> > 9800 KSP preconditioned resid norm 1.080641671225e+00 true resid norm 1.594050423544e-01 ||r(i)||/||b|| 8.917178804700e-03
> > 9800 KSP Residual norm 1.080641671225e+00 % max 1.155780495006e+02 min 1.115226000164e-01 max/min 1.036364373532e+03
> > 9801 KSP preconditioned resid norm 1.080641671136e+00 true resid norm 1.594040985764e-01 ||r(i)||/||b|| 8.917126009400e-03
> > 9801 KSP Residual norm 1.080641671136e+00 % max 1.156949344498e+02 min 9.748153395641e-02 max/min 1.186839494150e+03
> > 9802 KSP preconditioned resid norm 1.080641671038e+00 true resid norm 1.594035955111e-01 ||r(i)||/||b|| 8.917097867731e-03
> > 9802 KSP Residual norm 1.080641671038e+00 % max 1.157177902650e+02 min 8.161721244731e-02 max/min 1.417811106202e+03
> > 9803 KSP preconditioned resid norm 1.080641671024e+00 true resid norm 1.594038096704e-01 ||r(i)||/||b|| 8.917109847884e-03
> > 9803 KSP Residual norm 1.080641671024e+00 % max 1.157297935320e+02 min 8.041686995864e-02 max/min 1.439123328121e+03
> > 9804 KSP preconditioned resid norm 1.080641670988e+00 true resid norm 1.594036899968e-01 ||r(i)||/||b|| 8.917103153299e-03
> > 9804 KSP Residual norm 1.080641670988e+00 % max 1.158244769690e+02 min 8.041238179269e-02 max/min 1.440381125230e+03
> > 9805 KSP preconditioned resid norm 1.080641670986e+00 true resid norm 1.594036821095e-01 ||r(i)||/||b|| 8.917102712083e-03
> > 9805 KSP Residual norm 1.080641670986e+00 % max 1.158301768585e+02 min 7.912030787936e-02 max/min 1.463975304989e+03
> > 9806 KSP preconditioned resid norm 1.080641670803e+00 true resid norm 1.594037094369e-01 ||r(i)||/||b|| 8.917104240783e-03
> > 9806 KSP Residual norm 1.080641670803e+00 % max 1.164680491000e+02 min 7.460726855236e-02 max/min 1.561081800203e+03
> > 9807 KSP preconditioned resid norm 1.080641670773e+00 true resid norm 1.594038413140e-01 ||r(i)||/||b|| 8.917111618039e-03
> > 9807 KSP Residual norm 1.080641670773e+00 % max 1.166490110820e+02 min 7.459766739249e-02 max/min 1.563708560326e+03
> > 9808 KSP preconditioned resid norm 1.080641669134e+00 true resid norm 1.594048703119e-01 ||r(i)||/||b|| 8.917169180576e-03
> > 9808 KSP Residual norm 1.080641669134e+00 % max 1.166810013448e+02 min 6.210440124755e-02 max/min 1.878787960288e+03
> > 9809 KSP preconditioned resid norm 1.080641663243e+00 true resid norm 1.594054996410e-01 ||r(i)||/||b|| 8.917204385483e-03
> > 9809 KSP Residual norm 1.080641663243e+00 % max 1.166817320749e+02 min 4.513497352470e-02 max/min 2.585173380262e+03
> > 9810 KSP preconditioned resid norm 1.080641662817e+00 true resid norm 1.594065242705e-01 ||r(i)||/||b|| 8.917261703653e-03
> > 9810 KSP Residual norm 1.080641662817e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
> > 9811 KSP preconditioned resid norm 1.080641662817e+00 true resid norm 1.594065242654e-01 ||r(i)||/||b|| 8.917261703367e-03
> > 9811 KSP Residual norm 1.080641662817e+00 % max 3.063464017134e+01 min 3.063464017134e+01 max/min 1.000000000000e+00
> > 9812 KSP preconditioned resid norm 1.080641662817e+00 true resid norm 1.594065242568e-01 ||r(i)||/||b|| 8.917261702882e-03
> > 9812 KSP Residual norm 1.080641662817e+00 % max 3.066528792324e+01 min 3.844429757599e+00 max/min 7.976550452671e+00
> > 9813 KSP preconditioned resid norm 1.080641662817e+00 true resid norm 1.594065241534e-01 ||r(i)||/||b|| 8.917261697099e-03
> > 9813 KSP Residual norm 1.080641662817e+00 % max 3.714542869717e+01 min 1.336556919260e+00 max/min 2.779187938941e+01
> > 9814 KSP preconditioned resid norm 1.080641662817e+00 true resid norm 1.594065241497e-01 ||r(i)||/||b|| 8.917261696894e-03
> > 9814 KSP Residual norm 1.080641662817e+00 % max 4.500912339640e+01 min 1.226798613987e+00 max/min 3.668827375841e+01
> > 9815 KSP preconditioned resid norm 1.080641662817e+00 true resid norm 1.594065241439e-01 ||r(i)||/||b|| 8.917261696565e-03
> > 9815 KSP Residual norm 1.080641662817e+00 % max 8.688203511576e+01 min 1.183121026759e+00 max/min 7.343461332421e+01
> > 9816 KSP preconditioned resid norm 1.080641662817e+00 true resid norm 1.594065238512e-01 ||r(i)||/||b|| 8.917261680193e-03
> > 9816 KSP Residual norm 1.080641662817e+00 % max 9.802498010891e+01 min 1.168937586878e+00 max/min 8.385818131719e+01
> > 9817 KSP preconditioned resid norm 1.080641662817e+00 true resid norm 1.594065236853e-01 ||r(i)||/||b|| 8.917261670916e-03
> > 9817 KSP Residual norm 1.080641662817e+00 % max 1.122428829897e+02 min 1.141670208530e+00 max/min 9.831462899798e+01
> > 9818 KSP preconditioned resid norm 1.080641662817e+00 true resid norm 1.594065235856e-01 ||r(i)||/||b|| 8.917261665338e-03
> > 9818 KSP Residual norm 1.080641662817e+00 % max 1.134942125400e+02 min 1.090790174709e+00 max/min 1.040477033727e+02
> > 9819 KSP preconditioned resid norm 1.080641662816e+00 true resid norm 1.594064723991e-01 ||r(i)||/||b|| 8.917258801942e-03
> > 9819 KSP Residual norm 1.080641662816e+00 % max 1.139914573562e+02 min 4.119742762810e-01 max/min 2.766955703769e+02
> > 9820 KSP preconditioned resid norm 1.080641662815e+00 true resid norm 1.594064127438e-01 ||r(i)||/||b|| 8.917255464802e-03
> > 9820 KSP Residual norm 1.080641662815e+00 % max 1.140011292201e+02 min 2.894526616195e-01 max/min 3.938506855740e+02
> > 9821 KSP preconditioned resid norm 1.080641662815e+00 true resid norm 1.594064155702e-01 ||r(i)||/||b|| 8.917255622914e-03
> > 9821 KSP Residual norm 1.080641662815e+00 % max 1.140392151549e+02 min 2.880577522236e-01 max/min 3.958901097943e+02
> > 9822 KSP preconditioned resid norm 1.080641662815e+00 true resid norm 1.594064393436e-01 ||r(i)||/||b|| 8.917256952808e-03
> > 9822 KSP Residual norm 1.080641662815e+00 % max 1.140392582401e+02 min 2.501715268375e-01 max/min 4.558442748531e+02
> > 9823 KSP preconditioned resid norm 1.080641662812e+00 true resid norm 1.594064400637e-01 ||r(i)||/||b|| 8.917256993092e-03
> > 9823 KSP Residual norm 1.080641662812e+00 % max 1.141360419319e+02 min 2.500712914815e-01 max/min 4.564140140028e+02
> > 9824 KSP preconditioned resid norm 1.080641662811e+00 true resid norm 1.594064466562e-01 ||r(i)||/||b|| 8.917257361878e-03
> > 9824 KSP Residual norm 1.080641662811e+00 % max 1.141719174947e+02 min 2.470521750742e-01 max/min 4.621368642491e+02
> > 9825 KSP preconditioned resid norm 1.080641662786e+00 true resid norm 1.594065091771e-01 ||r(i)||/||b|| 8.917260859317e-03
> > 9825 KSP Residual norm 1.080641662786e+00 % max 1.141770016737e+02 min 2.461724809746e-01 max/min 4.638089571251e+02
> > 9826 KSP preconditioned resid norm 1.080641662783e+00 true resid norm 1.594066344484e-01 ||r(i)||/||b|| 8.917267867042e-03
> > 9826 KSP Residual norm 1.080641662783e+00 % max 1.150251612560e+02 min 1.817295914017e-01 max/min 6.329467885162e+02
> > 9827 KSP preconditioned resid norm 1.080641662672e+00 true resid norm 1.594070669773e-01 ||r(i)||/||b|| 8.917292062876e-03
> > 9827 KSP Residual norm 1.080641662672e+00 % max 1.153670515865e+02 min 1.757835701538e-01 max/min 6.563016753248e+02
> > 9828 KSP preconditioned resid norm 1.080641662655e+00 true resid norm 1.594072129068e-01 ||r(i)||/||b|| 8.917300226227e-03
> > 9828 KSP Residual norm 1.080641662655e+00 % max 1.154419244262e+02 min 1.682009156098e-01 max/min 6.863335078032e+02
> > 9829 KSP preconditioned resid norm 1.080641662270e+00 true resid norm 1.594087524825e-01 ||r(i)||/||b|| 8.917386350680e-03
> > 9829 KSP Residual norm 1.080641662270e+00 % max 1.154420683680e+02 min 1.254371322814e-01 max/min 9.203181407961e+02
> > 9830 KSP preconditioned resid norm 1.080641662088e+00 true resid norm 1.594088281904e-01 ||r(i)||/||b|| 8.917390585807e-03
> > 9830 KSP Residual norm 1.080641662088e+00 % max 1.155791143272e+02 min 1.115275270000e-01 max/min 1.036328137421e+03
> > 9831 KSP preconditioned resid norm 1.080641662001e+00 true resid norm 1.594097559916e-01 ||r(i)||/||b|| 8.917442487360e-03
> > 9831 KSP Residual norm 1.080641662001e+00 % max 1.156952534277e+02 min 9.753070058662e-02 max/min 1.186244461814e+03
> > 9832 KSP preconditioned resid norm 1.080641661905e+00 true resid norm 1.594102571355e-01 ||r(i)||/||b|| 8.917470521541e-03
> > 9832 KSP Residual norm 1.080641661905e+00 % max 1.157175128244e+02 min 8.164806814555e-02 max/min 1.417271901866e+03
> > 9833 KSP preconditioned resid norm 1.080641661892e+00 true resid norm 1.594100484838e-01 ||r(i)||/||b|| 8.917458849484e-03
> > 9833 KSP Residual norm 1.080641661892e+00 % max 1.157285121903e+02 min 8.043319039381e-02 max/min 1.438815389813e+03
> > 9834 KSP preconditioned resid norm 1.080641661854e+00 true resid norm 1.594101720988e-01 ||r(i)||/||b|| 8.917465764556e-03
> > 9834 KSP Residual norm 1.080641661854e+00 % max 1.158251773437e+02 min 8.042916217223e-02 max/min 1.440089318544e+03
> > 9835 KSP preconditioned resid norm 1.080641661853e+00 true resid norm 1.594101806342e-01 ||r(i)||/||b|| 8.917466242026e-03
> > 9835 KSP Residual norm 1.080641661853e+00 % max 1.158318842362e+02 min 7.912558026309e-02 max/min 1.463899333832e+03
> > 9836 KSP preconditioned resid norm 1.080641661674e+00 true resid norm 1.594101542582e-01 ||r(i)||/||b|| 8.917464766544e-03
> > 9836 KSP Residual norm 1.080641661674e+00 % max 1.164750419425e+02 min 7.459519966941e-02 max/min 1.561428114124e+03
> > 9837 KSP preconditioned resid norm 1.080641661644e+00 true resid norm 1.594100247000e-01 ||r(i)||/||b|| 8.917457519010e-03
> > 9837 KSP Residual norm 1.080641661644e+00 % max 1.166576751361e+02 min 7.458624135723e-02 max/min 1.564064269942e+03
> > 9838 KSP preconditioned resid norm 1.080641660043e+00 true resid norm 1.594090034525e-01 ||r(i)||/||b|| 8.917400390036e-03
> > 9838 KSP Residual norm 1.080641660043e+00 % max 1.166901230302e+02 min 6.207904511461e-02 max/min 1.879702286251e+03
> > 9839 KSP preconditioned resid norm 1.080641654279e+00 true resid norm 1.594083845247e-01 ||r(i)||/||b|| 8.917365766976e-03
> > 9839 KSP Residual norm 1.080641654279e+00 % max 1.166909329256e+02 min 4.511818825181e-02 max/min 2.586339067391e+03
> > 9840 KSP preconditioned resid norm 1.080641653856e+00 true resid norm 1.594073617105e-01 ||r(i)||/||b|| 8.917308550363e-03
> > 9840 KSP Residual norm 1.080641653856e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
> > 9841 KSP preconditioned resid norm 1.080641653856e+00 true resid norm 1.594073617156e-01 ||r(i)||/||b|| 8.917308550646e-03
> > 9841 KSP Residual norm 1.080641653856e+00 % max 3.063497434930e+01 min 3.063497434930e+01 max/min 1.000000000000e+00
> > 9842 KSP preconditioned resid norm 1.080641653856e+00 true resid norm 1.594073617242e-01 ||r(i)||/||b|| 8.917308551127e-03
> > 9842 KSP Residual norm 1.080641653856e+00 % max 3.066566511835e+01 min 3.845873341758e+00 max/min 7.973654458505e+00
> > 9843 KSP preconditioned resid norm 1.080641653856e+00 true resid norm 1.594073618265e-01 ||r(i)||/||b|| 8.917308556853e-03
> > 9843 KSP Residual norm 1.080641653856e+00 % max 3.713360973998e+01 min 1.336323585560e+00 max/min 2.778788771015e+01
> > 9844 KSP preconditioned resid norm 1.080641653856e+00 true resid norm 1.594073618300e-01 ||r(i)||/||b|| 8.917308557050e-03
> > 9844 KSP Residual norm 1.080641653856e+00 % max 4.496460969624e+01 min 1.226794432981e+00 max/min 3.665211423154e+01
> > 9845 KSP preconditioned resid norm 1.080641653856e+00 true resid norm 1.594073618358e-01 ||r(i)||/||b|| 8.917308557372e-03
> > 9845 KSP Residual norm 1.080641653856e+00 % max 8.684887047460e+01 min 1.183106552555e+00 max/min 7.340747989862e+01
> > 9846 KSP preconditioned resid norm 1.080641653856e+00 true resid norm 1.594073621302e-01 ||r(i)||/||b|| 8.917308573843e-03
> > 9846 KSP Residual norm 1.080641653856e+00 % max 9.802649587879e+01 min 1.168693234980e+00 max/min 8.387701147298e+01
> > 9847 KSP preconditioned resid norm 1.080641653856e+00 true resid norm 1.594073622957e-01 ||r(i)||/||b|| 8.917308583099e-03
> > 9847 KSP Residual norm 1.080641653856e+00 % max 1.123314913547e+02 min 1.141275669292e+00 max/min 9.842625614229e+01
> > 9848 KSP preconditioned resid norm 1.080641653856e+00 true resid norm 1.594073623942e-01 ||r(i)||/||b|| 8.917308588608e-03
> > 9848 KSP Residual norm 1.080641653856e+00 % max 1.134977479974e+02 min 1.090790466016e+00 max/min 1.040509167741e+02
> > 9849 KSP preconditioned resid norm 1.080641653855e+00 true resid norm 1.594074129801e-01 ||r(i)||/||b|| 8.917311418404e-03
> > 9849 KSP Residual norm 1.080641653855e+00 % max 1.139911565327e+02 min 4.122354439173e-01 max/min 2.765195429329e+02
> > 9850 KSP preconditioned resid norm 1.080641653854e+00 true resid norm 1.594074720057e-01 ||r(i)||/||b|| 8.917314720319e-03
> > 9850 KSP Residual norm 1.080641653854e+00 % max 1.140007137546e+02 min 2.895731636857e-01 max/min 3.936853550364e+02
> > 9851 KSP preconditioned resid norm 1.080641653854e+00 true resid norm 1.594074692144e-01 ||r(i)||/||b|| 8.917314564169e-03
> > 9851 KSP Residual norm 1.080641653854e+00 % max 1.140387247200e+02 min 2.881916049088e-01 max/min 3.957045339889e+02
> > 9852 KSP preconditioned resid norm 1.080641653853e+00 true resid norm 1.594074456679e-01 ||r(i)||/||b|| 8.917313246972e-03
> > 9852 KSP Residual norm 1.080641653853e+00 % max 1.140387740588e+02 min 2.501646808296e-01 max/min 4.558548140395e+02
> > 9853 KSP preconditioned resid norm 1.080641653851e+00 true resid norm 1.594074449772e-01 ||r(i)||/||b|| 8.917313208332e-03
> > 9853 KSP Residual norm 1.080641653851e+00 % max 1.141359916013e+02 min 2.500654158720e-01 max/min 4.564245367688e+02
> > 9854 KSP preconditioned resid norm 1.080641653850e+00 true resid norm 1.594074383969e-01 ||r(i)||/||b|| 8.917312840228e-03
> > 9854 KSP Residual norm 1.080641653850e+00 % max 1.141719416509e+02 min 2.470357905993e-01 max/min 4.621676129356e+02
> > 9855 KSP preconditioned resid norm 1.080641653826e+00 true resid norm 1.594073765323e-01 ||r(i)||/||b|| 8.917309379499e-03
> > 9855 KSP Residual norm 1.080641653826e+00 % max 1.141769960009e+02 min 2.461587608334e-01 max/min 4.638347853812e+02
> > 9856 KSP preconditioned resid norm 1.080641653822e+00 true resid norm 1.594072524403e-01 ||r(i)||/||b|| 8.917302437746e-03
> > 9856 KSP Residual norm 1.080641653822e+00 % max 1.150247983913e+02 min 1.817426977612e-01 max/min 6.328991470261e+02
> > 9857 KSP preconditioned resid norm 1.080641653714e+00 true resid norm 1.594068250847e-01 ||r(i)||/||b|| 8.917278531310e-03
> > 9857 KSP Residual norm 1.080641653714e+00 % max 1.153659149296e+02 min 1.758216030104e-01 max/min 6.561532425728e+02
> > 9858 KSP preconditioned resid norm 1.080641653697e+00 true resid norm 1.594066805198e-01 ||r(i)||/||b|| 8.917270444298e-03
> > 9858 KSP Residual norm 1.080641653697e+00 % max 1.154409610504e+02 min 1.682252327368e-01 max/min 6.862285709010e+02
> > 9859 KSP preconditioned resid norm 1.080641653319e+00 true resid norm 1.594051557657e-01 ||r(i)||/||b|| 8.917185148971e-03
> > 9859 KSP Residual norm 1.080641653319e+00 % max 1.154410966341e+02 min 1.254606780252e-01 max/min 9.201376754146e+02
> > 9860 KSP preconditioned resid norm 1.080641653140e+00 true resid norm 1.594050799233e-01 ||r(i)||/||b|| 8.917180906316e-03
> > 9860 KSP Residual norm 1.080641653140e+00 % max 1.155780628675e+02 min 1.115225287992e-01 max/min 1.036365155202e+03
> > 9861 KSP preconditioned resid norm 1.080641653054e+00 true resid norm 1.594041550812e-01 ||r(i)||/||b|| 8.917129170295e-03
> > 9861 KSP Residual norm 1.080641653054e+00 % max 1.156949369211e+02 min 9.748220965886e-02 max/min 1.186831292869e+03
> > 9862 KSP preconditioned resid norm 1.080641652960e+00 true resid norm 1.594036620365e-01 ||r(i)||/||b|| 8.917101589189e-03
> > 9862 KSP Residual norm 1.080641652960e+00 % max 1.157177832797e+02 min 8.161751000999e-02 max/min 1.417805851533e+03
> > 9863 KSP preconditioned resid norm 1.080641652947e+00 true resid norm 1.594038718371e-01 ||r(i)||/||b|| 8.917113325517e-03
> > 9863 KSP Residual norm 1.080641652947e+00 % max 1.157297723960e+02 min 8.041700428565e-02 max/min 1.439120661408e+03
> > 9864 KSP preconditioned resid norm 1.080641652912e+00 true resid norm 1.594037544972e-01 ||r(i)||/||b|| 8.917106761475e-03
> > 9864 KSP Residual norm 1.080641652912e+00 % max 1.158244802295e+02 min 8.041252146115e-02 max/min 1.440378663980e+03
> > 9865 KSP preconditioned resid norm 1.080641652910e+00 true resid norm 1.594037467642e-01 ||r(i)||/||b|| 8.917106328887e-03
> > 9865 KSP Residual norm 1.080641652910e+00 % max 1.158301923080e+02 min 7.912032794006e-02 max/min 1.463975129069e+03
> > 9866 KSP preconditioned resid norm 1.080641652734e+00 true resid norm 1.594037735388e-01 ||r(i)||/||b|| 8.917107826673e-03
> > 9866 KSP Residual norm 1.080641652734e+00 % max 1.164681289889e+02 min 7.460712971447e-02 max/min 1.561085776047e+03
> > 9867 KSP preconditioned resid norm 1.080641652705e+00 true resid norm 1.594039028009e-01 ||r(i)||/||b|| 8.917115057644e-03
> > 9867 KSP Residual norm 1.080641652705e+00 % max 1.166491106270e+02 min 7.459753335320e-02 max/min 1.563712704477e+03
> > 9868 KSP preconditioned resid norm 1.080641651132e+00 true resid norm 1.594049112430e-01 ||r(i)||/||b|| 8.917171470279e-03
> > 9868 KSP Residual norm 1.080641651132e+00 % max 1.166811058685e+02 min 6.210409714784e-02 max/min 1.878798843026e+03
> > 9869 KSP preconditioned resid norm 1.080641645474e+00 true resid norm 1.594055279416e-01 ||r(i)||/||b|| 8.917205968634e-03
> > 9869 KSP Residual norm 1.080641645474e+00 % max 1.166818375393e+02 min 4.513482662958e-02 max/min 2.585184130582e+03
> > 9870 KSP preconditioned resid norm 1.080641645065e+00 true resid norm 1.594065322524e-01 ||r(i)||/||b|| 8.917262150160e-03
> > 9870 KSP Residual norm 1.080641645065e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
> > 9871 KSP preconditioned resid norm 1.080641645065e+00 true resid norm 1.594065322474e-01 ||r(i)||/||b|| 8.917262149880e-03
> > 9871 KSP Residual norm 1.080641645065e+00 % max 3.063464541814e+01 min 3.063464541814e+01 max/min 1.000000000000e+00
> > 9872 KSP preconditioned resid norm 1.080641645065e+00 true resid norm 1.594065322389e-01 ||r(i)||/||b|| 8.917262149406e-03
> > 9872 KSP Residual norm 1.080641645065e+00 % max 3.066529346532e+01 min 3.844443657370e+00 max/min 7.976523054651e+00
> > 9873 KSP preconditioned resid norm 1.080641645065e+00 true resid norm 1.594065321376e-01 ||r(i)||/||b|| 8.917262143737e-03
> > 9873 KSP Residual norm 1.080641645065e+00 % max 3.714534104643e+01 min 1.336555480314e+00 max/min 2.779184373079e+01
> > 9874 KSP preconditioned resid norm 1.080641645065e+00 true resid norm 1.594065321340e-01 ||r(i)||/||b|| 8.917262143537e-03
> > 9874 KSP Residual norm 1.080641645065e+00 % max 4.500878758461e+01 min 1.226798739269e+00 max/min 3.668799628162e+01
> > 9875 KSP preconditioned resid norm 1.080641645065e+00 true resid norm 1.594065321283e-01 ||r(i)||/||b|| 8.917262143216e-03
> > 9875 KSP Residual norm 1.080641645065e+00 % max 8.688179296761e+01 min 1.183120879361e+00 max/min 7.343441780400e+01
> > 9876 KSP preconditioned resid norm 1.080641645065e+00 true resid norm 1.594065318413e-01 ||r(i)||/||b|| 8.917262127165e-03
> > 9876 KSP Residual norm 1.080641645065e+00 % max 9.802498627683e+01 min 1.168935165788e+00 max/min 8.385836028017e+01
> > 9877 KSP preconditioned resid norm 1.080641645065e+00 true resid norm 1.594065316788e-01 ||r(i)||/||b|| 8.917262118072e-03
> > 9877 KSP Residual norm 1.080641645065e+00 % max 1.122437663284e+02 min 1.141666474192e+00 max/min 9.831572430803e+01
> > 9878 KSP preconditioned resid norm 1.080641645065e+00 true resid norm 1.594065315811e-01 ||r(i)||/||b|| 8.917262112605e-03
> > 9878 KSP Residual norm 1.080641645065e+00 % max 1.134942465219e+02 min 1.090790184702e+00 max/min 1.040477335730e+02
> > 9879 KSP preconditioned resid norm 1.080641645064e+00 true resid norm 1.594064814200e-01 ||r(i)||/||b|| 8.917259306578e-03
> > 9879 KSP Residual norm 1.080641645064e+00 % max 1.139914544856e+02 min 4.119772603942e-01 max/min 2.766935591945e+02
> > 9880 KSP preconditioned resid norm 1.080641645063e+00 true resid norm 1.594064229585e-01 ||r(i)||/||b|| 8.917256036220e-03
> > 9880 KSP Residual norm 1.080641645063e+00 % max 1.140011250742e+02 min 2.894539413393e-01 max/min 3.938489299774e+02
> > 9881 KSP preconditioned resid norm 1.080641645063e+00 true resid norm 1.594064257287e-01 ||r(i)||/||b|| 8.917256191184e-03
> > 9881 KSP Residual norm 1.080641645063e+00 % max 1.140392103921e+02 min 2.880591764056e-01 max/min 3.958881359556e+02
> > 9882 KSP preconditioned resid norm 1.080641645063e+00 true resid norm 1.594064490294e-01 ||r(i)||/||b|| 8.917257494633e-03
> > 9882 KSP Residual norm 1.080641645063e+00 % max 1.140392535477e+02 min 2.501714617108e-01 max/min 4.558443747654e+02
> > 9883 KSP preconditioned resid norm 1.080641645061e+00 true resid norm 1.594064497349e-01 ||r(i)||/||b|| 8.917257534101e-03
> > 9883 KSP Residual norm 1.080641645061e+00 % max 1.141360416004e+02 min 2.500712361002e-01 max/min 4.564141137554e+02
> > 9884 KSP preconditioned resid norm 1.080641645059e+00 true resid norm 1.594064561966e-01 ||r(i)||/||b|| 8.917257895569e-03
> > 9884 KSP Residual norm 1.080641645059e+00 % max 1.141719177119e+02 min 2.470520232306e-01 max/min 4.621371491678e+02
> > 9885 KSP preconditioned resid norm 1.080641645035e+00 true resid norm 1.594065174658e-01 ||r(i)||/||b|| 8.917261322993e-03
> > 9885 KSP Residual norm 1.080641645035e+00 % max 1.141770016402e+02 min 2.461723435101e-01 max/min 4.638092159834e+02
> > 9886 KSP preconditioned resid norm 1.080641645032e+00 true resid norm 1.594066402497e-01 ||r(i)||/||b|| 8.917268191569e-03
> > 9886 KSP Residual norm 1.080641645032e+00 % max 1.150251585488e+02 min 1.817296775460e-01 max/min 6.329464735865e+02
> > 9887 KSP preconditioned resid norm 1.080641644925e+00 true resid norm 1.594070641129e-01 ||r(i)||/||b|| 8.917291902641e-03
> > 9887 KSP Residual norm 1.080641644925e+00 % max 1.153670431587e+02 min 1.757838889123e-01 max/min 6.563004372733e+02
> > 9888 KSP preconditioned resid norm 1.080641644909e+00 true resid norm 1.594072071224e-01 ||r(i)||/||b|| 8.917299902647e-03
> > 9888 KSP Residual norm 1.080641644909e+00 % max 1.154419177071e+02 min 1.682011082589e-01 max/min 6.863326817642e+02
> > 9889 KSP preconditioned resid norm 1.080641644540e+00 true resid norm 1.594087159021e-01 ||r(i)||/||b|| 8.917384304358e-03
> > 9889 KSP Residual norm 1.080641644540e+00 % max 1.154420615965e+02 min 1.254373423966e-01 max/min 9.203165452239e+02
> > 9890 KSP preconditioned resid norm 1.080641644365e+00 true resid norm 1.594087901062e-01 ||r(i)||/||b|| 8.917388455364e-03
> > 9890 KSP Residual norm 1.080641644365e+00 % max 1.155791063432e+02 min 1.115273566807e-01 max/min 1.036329648465e+03
> > 9891 KSP preconditioned resid norm 1.080641644282e+00 true resid norm 1.594096994140e-01 ||r(i)||/||b|| 8.917439322388e-03
> > 9891 KSP Residual norm 1.080641644282e+00 % max 1.156952495514e+02 min 9.753038620512e-02 max/min 1.186248245835e+03
> > 9892 KSP preconditioned resid norm 1.080641644189e+00 true resid norm 1.594101905102e-01 ||r(i)||/||b|| 8.917466794493e-03
> > 9892 KSP Residual norm 1.080641644189e+00 % max 1.157175115527e+02 min 8.164774923625e-02 max/min 1.417277422037e+03
> > 9893 KSP preconditioned resid norm 1.080641644177e+00 true resid norm 1.594099860409e-01 ||r(i)||/||b|| 8.917455356405e-03
> > 9893 KSP Residual norm 1.080641644177e+00 % max 1.157285171248e+02 min 8.043299897298e-02 max/min 1.438818875368e+03
> > 9894 KSP preconditioned resid norm 1.080641644141e+00 true resid norm 1.594101071411e-01 ||r(i)||/||b|| 8.917462130798e-03
> > 9894 KSP Residual norm 1.080641644141e+00 % max 1.158251669093e+02 min 8.042896682578e-02 max/min 1.440092686509e+03
> > 9895 KSP preconditioned resid norm 1.080641644139e+00 true resid norm 1.594101154949e-01 ||r(i)||/||b|| 8.917462598110e-03
> > 9895 KSP Residual norm 1.080641644139e+00 % max 1.158318659802e+02 min 7.912549560750e-02 max/min 1.463900669321e+03
> > 9896 KSP preconditioned resid norm 1.080641643967e+00 true resid norm 1.594100896394e-01 ||r(i)||/||b|| 8.917461151744e-03
> > 9896 KSP Residual norm 1.080641643967e+00 % max 1.164749819823e+02 min 7.459530237415e-02 max/min 1.561425160502e+03
> > 9897 KSP preconditioned resid norm 1.080641643939e+00 true resid norm 1.594099626317e-01 ||r(i)||/||b|| 8.917454046886e-03
> > 9897 KSP Residual norm 1.080641643939e+00 % max 1.166576013049e+02 min 7.458633610448e-02 max/min 1.564061293230e+03
> > 9898 KSP preconditioned resid norm 1.080641642401e+00 true resid norm 1.594089618420e-01 ||r(i)||/||b|| 8.917398062328e-03
> > 9898 KSP Residual norm 1.080641642401e+00 % max 1.166900450421e+02 min 6.207924609942e-02 max/min 1.879694944349e+03
> > 9899 KSP preconditioned resid norm 1.080641636866e+00 true resid norm 1.594083552587e-01 ||r(i)||/||b|| 8.917364129827e-03
> > 9899 KSP Residual norm 1.080641636866e+00 % max 1.166908543099e+02 min 4.511837692126e-02 max/min 2.586326509785e+03
> > 9900 KSP preconditioned resid norm 1.080641636459e+00 true resid norm 1.594073529026e-01 ||r(i)||/||b|| 8.917308057647e-03
> > 9900 KSP Residual norm 1.080641636459e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
> > 9901 KSP preconditioned resid norm 1.080641636459e+00 true resid norm 1.594073529076e-01 ||r(i)||/||b|| 8.917308057926e-03
> > 9901 KSP Residual norm 1.080641636459e+00 % max 3.063497290246e+01 min 3.063497290246e+01 max/min 1.000000000000e+00
> > 9902 KSP preconditioned resid norm 1.080641636459e+00 true resid norm 1.594073529160e-01 ||r(i)||/||b|| 8.917308058394e-03
> > 9902 KSP Residual norm 1.080641636459e+00 % max 3.066566310477e+01 min 3.845858371013e+00 max/min 7.973684973919e+00
> > 9903 KSP preconditioned resid norm 1.080641636459e+00 true resid norm 1.594073530163e-01 ||r(i)||/||b|| 8.917308064007e-03
> > 9903 KSP Residual norm 1.080641636459e+00 % max 3.713375877488e+01 min 1.336326817614e+00 max/min 2.778793202787e+01
> > 9904 KSP preconditioned resid norm 1.080641636459e+00 true resid norm 1.594073530198e-01 ||r(i)||/||b|| 8.917308064200e-03
> > 9904 KSP Residual norm 1.080641636459e+00 % max 4.496516516046e+01 min 1.226794642680e+00 max/min 3.665256074336e+01
> > 9905 KSP preconditioned resid norm 1.080641636459e+00 true resid norm 1.594073530254e-01 ||r(i)||/||b|| 8.917308064515e-03
> > 9905 KSP Residual norm 1.080641636459e+00 % max 8.684929340512e+01 min 1.183106694605e+00 max/min 7.340782855945e+01
> > 9906 KSP preconditioned resid norm 1.080641636459e+00 true resid norm 1.594073533139e-01 ||r(i)||/||b|| 8.917308080655e-03
> > 9906 KSP Residual norm 1.080641636459e+00 % max 9.802647163348e+01 min 1.168695697992e+00 max/min 8.387681395754e+01
> > 9907 KSP preconditioned resid norm 1.080641636459e+00 true resid norm 1.594073534761e-01 ||r(i)||/||b|| 8.917308089727e-03
> > 9907 KSP Residual norm 1.080641636459e+00 % max 1.123306036185e+02 min 1.141279831413e+00 max/min 9.842511934993e+01
> > 9908 KSP preconditioned resid norm 1.080641636459e+00 true resid norm 1.594073535726e-01 ||r(i)||/||b|| 8.917308095124e-03
> > 9908 KSP Residual norm 1.080641636459e+00 % max 1.134977112090e+02 min 1.090790470231e+00 max/min 1.040508826457e+02
> > 9909 KSP preconditioned resid norm 1.080641636458e+00 true resid norm 1.594074031465e-01 ||r(i)||/||b|| 8.917310868307e-03
> > 9909 KSP Residual norm 1.080641636458e+00 % max 1.139911596762e+02 min 4.122331938771e-01 max/min 2.765210598500e+02
> > 9910 KSP preconditioned resid norm 1.080641636457e+00 true resid norm 1.594074609911e-01 ||r(i)||/||b|| 8.917314104156e-03
> > 9910 KSP Residual norm 1.080641636457e+00 % max 1.140007179199e+02 min 2.895720290537e-01 max/min 3.936869120007e+02
> > 9911 KSP preconditioned resid norm 1.080641636457e+00 true resid norm 1.594074582552e-01 ||r(i)||/||b|| 8.917313951111e-03
> > 9911 KSP Residual norm 1.080641636457e+00 % max 1.140387297689e+02 min 2.881903470643e-01 max/min 3.957062786128e+02
> > 9912 KSP preconditioned resid norm 1.080641636457e+00 true resid norm 1.594074351775e-01 ||r(i)||/||b|| 8.917312660133e-03
> > 9912 KSP Residual norm 1.080641636457e+00 % max 1.140387790534e+02 min 2.501647526543e-01 max/min 4.558547031242e+02
> > 9913 KSP preconditioned resid norm 1.080641636455e+00 true resid norm 1.594074345003e-01 ||r(i)||/||b|| 8.917312622252e-03
> > 9913 KSP Residual norm 1.080641636455e+00 % max 1.141359922733e+02 min 2.500654781355e-01 max/min 4.564244258117e+02
> > 9914 KSP preconditioned resid norm 1.080641636454e+00 true resid norm 1.594074280517e-01 ||r(i)||/||b|| 8.917312261516e-03
> > 9914 KSP Residual norm 1.080641636454e+00 % max 1.141719413857e+02 min 2.470359663864e-01 max/min 4.621672829905e+02
> > 9915 KSP preconditioned resid norm 1.080641636430e+00 true resid norm 1.594073674253e-01 ||r(i)||/||b|| 8.917308870053e-03
> > 9915 KSP Residual norm 1.080641636430e+00 % max 1.141769960812e+02 min 2.461588977988e-01 max/min 4.638345276249e+02
> > 9916 KSP preconditioned resid norm 1.080641636427e+00 true resid norm 1.594072457998e-01 ||r(i)||/||b|| 8.917302066275e-03
> > 9916 KSP Residual norm 1.080641636427e+00 % max 1.150248029458e+02 min 1.817425233097e-01 max/min 6.328997795954e+02
> > 9917 KSP preconditioned resid norm 1.080641636323e+00 true resid norm 1.594068269925e-01 ||r(i)||/||b|| 8.917278638033e-03
> > 9917 KSP Residual norm 1.080641636323e+00 % max 1.153659292411e+02 min 1.758211627252e-01 max/min 6.561549670868e+02
> > 9918 KSP preconditioned resid norm 1.080641636306e+00 true resid norm 1.594066853231e-01 ||r(i)||/||b|| 8.917270712996e-03
> > 9918 KSP Residual norm 1.080641636306e+00 % max 1.154409736018e+02 min 1.682249410195e-01 max/min 6.862298354942e+02
> > 9919 KSP preconditioned resid norm 1.080641635944e+00 true resid norm 1.594051910900e-01 ||r(i)||/||b|| 8.917187125026e-03
> > 9919 KSP Residual norm 1.080641635944e+00 % max 1.154411092996e+02 min 1.254604202789e-01 max/min 9.201396667011e+02
> > 9920 KSP preconditioned resid norm 1.080641635771e+00 true resid norm 1.594051167722e-01 ||r(i)||/||b|| 8.917182967656e-03
> > 9920 KSP Residual norm 1.080641635771e+00 % max 1.155780759198e+02 min 1.115224613869e-01 max/min 1.036365898694e+03
> > 9921 KSP preconditioned resid norm 1.080641635689e+00 true resid norm 1.594042104954e-01 ||r(i)||/||b|| 8.917132270191e-03
> > 9921 KSP Residual norm 1.080641635689e+00 % max 1.156949393598e+02 min 9.748286841768e-02 max/min 1.186823297649e+03
> > 9922 KSP preconditioned resid norm 1.080641635599e+00 true resid norm 1.594037272785e-01 ||r(i)||/||b|| 8.917105238852e-03
> > 9922 KSP Residual norm 1.080641635599e+00 % max 1.157177765183e+02 min 8.161780203814e-02 max/min 1.417800695787e+03
> > 9923 KSP preconditioned resid norm 1.080641635586e+00 true resid norm 1.594039328090e-01 ||r(i)||/||b|| 8.917116736308e-03
> > 9923 KSP Residual norm 1.080641635586e+00 % max 1.157297518468e+02 min 8.041713659406e-02 max/min 1.439118038125e+03
> > 9924 KSP preconditioned resid norm 1.080641635552e+00 true resid norm 1.594038177599e-01 ||r(i)||/||b|| 8.917110300416e-03
> > 9924 KSP Residual norm 1.080641635552e+00 % max 1.158244835100e+02 min 8.041265899129e-02 max/min 1.440376241290e+03
> > 9925 KSP preconditioned resid norm 1.080641635551e+00 true resid norm 1.594038101782e-01 ||r(i)||/||b|| 8.917109876291e-03
> > 9925 KSP Residual norm 1.080641635551e+00 % max 1.158302075022e+02 min 7.912034826741e-02 max/min 1.463974944988e+03
> > 9926 KSP preconditioned resid norm 1.080641635382e+00 true resid norm 1.594038364112e-01 ||r(i)||/||b|| 8.917111343775e-03
> > 9926 KSP Residual norm 1.080641635382e+00 % max 1.164682071358e+02 min 7.460699390243e-02 max/min 1.561089665242e+03
> > 9927 KSP preconditioned resid norm 1.080641635354e+00 true resid norm 1.594039631076e-01 ||r(i)||/||b|| 8.917118431221e-03
> > 9927 KSP Residual norm 1.080641635354e+00 % max 1.166492079885e+02 min 7.459740228247e-02 max/min 1.563716757144e+03
> > 9928 KSP preconditioned resid norm 1.080641633843e+00 true resid norm 1.594049513925e-01 ||r(i)||/||b|| 8.917173716256e-03
> > 9928 KSP Residual norm 1.080641633843e+00 % max 1.166812081048e+02 min 6.210379986959e-02 max/min 1.878809482669e+03
> > 9929 KSP preconditioned resid norm 1.080641628410e+00 true resid norm 1.594055557080e-01 ||r(i)||/||b|| 8.917207521894e-03
> > 9929 KSP Residual norm 1.080641628410e+00 % max 1.166819406955e+02 min 4.513468212670e-02 max/min 2.585194692807e+03
> > 9930 KSP preconditioned resid norm 1.080641628017e+00 true resid norm 1.594065400862e-01 ||r(i)||/||b|| 8.917262588389e-03
> > 9930 KSP Residual norm 1.080641628017e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
> > 9931 KSP preconditioned resid norm 1.080641628017e+00 true resid norm 1.594065400814e-01 ||r(i)||/||b|| 8.917262588116e-03
> > 9931 KSP Residual norm 1.080641628017e+00 % max 3.063465052437e+01 min 3.063465052437e+01 max/min 1.000000000000e+00
> > 9932 KSP preconditioned resid norm 1.080641628017e+00 true resid norm 1.594065400730e-01 ||r(i)||/||b|| 8.917262587648e-03
> > 9932 KSP Residual norm 1.080641628017e+00 % max 3.066529886382e+01 min 3.844457299464e+00 max/min 7.976496154112e+00
> > 9933 KSP preconditioned resid norm 1.080641628017e+00 true resid norm 1.594065399737e-01 ||r(i)||/||b|| 8.917262582094e-03
> > 9933 KSP Residual norm 1.080641628017e+00 % max 3.714525447417e+01 min 1.336554051053e+00 max/min 2.779180867762e+01
> > 9934 KSP preconditioned resid norm 1.080641628017e+00 true resid norm 1.594065399702e-01 ||r(i)||/||b|| 8.917262581897e-03
> > 9934 KSP Residual norm 1.080641628017e+00 % max 4.500845605790e+01 min 1.226798858744e+00 max/min 3.668772247146e+01
> > 9935 KSP preconditioned resid norm 1.080641628017e+00 true resid norm 1.594065399646e-01 ||r(i)||/||b|| 8.917262581583e-03
> > 9935 KSP Residual norm 1.080641628017e+00 % max 8.688155371236e+01 min 1.183120734870e+00 max/min 7.343422454843e+01
> > 9936 KSP preconditioned resid norm 1.080641628017e+00 true resid norm 1.594065396833e-01 ||r(i)||/||b|| 8.917262565850e-03
> > 9936 KSP Residual norm 1.080641628017e+00 % max 9.802499250688e+01 min 1.168932790974e+00 max/min 8.385853597724e+01
> > 9937 KSP preconditioned resid norm 1.080641628017e+00 true resid norm 1.594065395240e-01 ||r(i)||/||b|| 8.917262556936e-03
> > 9937 KSP Residual norm 1.080641628017e+00 % max 1.122446326752e+02 min 1.141662807959e+00 max/min 9.831679887675e+01
> > 9938 KSP preconditioned resid norm 1.080641628017e+00 true resid norm 1.594065394282e-01 ||r(i)||/||b|| 8.917262551579e-03
> > 9938 KSP Residual norm 1.080641628017e+00 % max 1.134942798726e+02 min 1.090790194356e+00 max/min 1.040477632269e+02
> > 9939 KSP preconditioned resid norm 1.080641628016e+00 true resid norm 1.594064902727e-01 ||r(i)||/||b|| 8.917259801801e-03
> > 9939 KSP Residual norm 1.080641628016e+00 % max 1.139914516679e+02 min 4.119801790176e-01 max/min 2.766915921531e+02
> > 9940 KSP preconditioned resid norm 1.080641628015e+00 true resid norm 1.594064329818e-01 ||r(i)||/||b|| 8.917256596927e-03
> > 9940 KSP Residual norm 1.080641628015e+00 % max 1.140011210085e+02 min 2.894551947128e-01 max/min 3.938472105212e+02
> > 9941 KSP preconditioned resid norm 1.080641628015e+00 true resid norm 1.594064356968e-01 ||r(i)||/||b|| 8.917256748803e-03
> > 9941 KSP Residual norm 1.080641628015e+00 % max 1.140392057187e+02 min 2.880605712140e-01 max/min 3.958862028153e+02
> > 9942 KSP preconditioned resid norm 1.080641628014e+00 true resid norm 1.594064585337e-01 ||r(i)||/||b|| 8.917258026309e-03
> > 9942 KSP Residual norm 1.080641628014e+00 % max 1.140392489431e+02 min 2.501713977769e-01 max/min 4.558444728556e+02
> > 9943 KSP preconditioned resid norm 1.080641628013e+00 true resid norm 1.594064592249e-01 ||r(i)||/||b|| 8.917258064976e-03
> > 9943 KSP Residual norm 1.080641628013e+00 % max 1.141360412719e+02 min 2.500711817244e-01 max/min 4.564142116850e+02
> > 9944 KSP preconditioned resid norm 1.080641628011e+00 true resid norm 1.594064655583e-01 ||r(i)||/||b|| 8.917258419265e-03
> > 9944 KSP Residual norm 1.080641628011e+00 % max 1.141719179255e+02 min 2.470518740808e-01 max/min 4.621374290332e+02
> > 9945 KSP preconditioned resid norm 1.080641627988e+00 true resid norm 1.594065256003e-01 ||r(i)||/||b|| 8.917261778039e-03
> > 9945 KSP Residual norm 1.080641627988e+00 % max 1.141770016071e+02 min 2.461722087102e-01 max/min 4.638094698230e+02
> > 9946 KSP preconditioned resid norm 1.080641627985e+00 true resid norm 1.594066459440e-01 ||r(i)||/||b|| 8.917268510113e-03
> > 9946 KSP Residual norm 1.080641627985e+00 % max 1.150251558754e+02 min 1.817297629761e-01 max/min 6.329461613313e+02
> > 9947 KSP preconditioned resid norm 1.080641627883e+00 true resid norm 1.594070613108e-01 ||r(i)||/||b|| 8.917291745887e-03
> > 9947 KSP Residual norm 1.080641627883e+00 % max 1.153670348347e+02 min 1.757842027946e-01 max/min 6.562992180216e+02
> > 9948 KSP preconditioned resid norm 1.080641627867e+00 true resid norm 1.594072014571e-01 ||r(i)||/||b|| 8.917299585729e-03
> > 9948 KSP Residual norm 1.080641627867e+00 % max 1.154419110590e+02 min 1.682012982555e-01 max/min 6.863318669729e+02
> > 9949 KSP preconditioned resid norm 1.080641627512e+00 true resid norm 1.594086800399e-01 ||r(i)||/||b|| 8.917382298211e-03
> > 9949 KSP Residual norm 1.080641627512e+00 % max 1.154420548965e+02 min 1.254375490145e-01 max/min 9.203149758861e+02
> > 9950 KSP preconditioned resid norm 1.080641627344e+00 true resid norm 1.594087527690e-01 ||r(i)||/||b|| 8.917386366706e-03
> > 9950 KSP Residual norm 1.080641627344e+00 % max 1.155790984624e+02 min 1.115271921586e-01 max/min 1.036331106570e+03
> > 9951 KSP preconditioned resid norm 1.080641627264e+00 true resid norm 1.594096439404e-01 ||r(i)||/||b|| 8.917436219173e-03
> > 9951 KSP Residual norm 1.080641627264e+00 % max 1.156952457641e+02 min 9.753007450777e-02 max/min 1.186251998145e+03
> > 9952 KSP preconditioned resid norm 1.080641627176e+00 true resid norm 1.594101251850e-01 ||r(i)||/||b|| 8.917463140178e-03
> > 9952 KSP Residual norm 1.080641627176e+00 % max 1.157175103847e+02 min 8.164743677427e-02 max/min 1.417282831604e+03
> > 9953 KSP preconditioned resid norm 1.080641627164e+00 true resid norm 1.594099248157e-01 ||r(i)||/||b|| 8.917451931444e-03
> > 9953 KSP Residual norm 1.080641627164e+00 % max 1.157285221143e+02 min 8.043281187160e-02 max/min 1.438822284357e+03
> > 9954 KSP preconditioned resid norm 1.080641627129e+00 true resid norm 1.594100434515e-01 ||r(i)||/||b|| 8.917458567979e-03
> > 9954 KSP Residual norm 1.080641627129e+00 % max 1.158251567433e+02 min 8.042877586324e-02 max/min 1.440095979333e+03
> > 9955 KSP preconditioned resid norm 1.080641627127e+00 true resid norm 1.594100516277e-01 ||r(i)||/||b|| 8.917459025356e-03
> > 9955 KSP Residual norm 1.080641627127e+00 % max 1.158318480981e+02 min 7.912541326160e-02 max/min 1.463901966807e+03
> > 9956 KSP preconditioned resid norm 1.080641626963e+00 true resid norm 1.594100262829e-01 ||r(i)||/||b|| 8.917457607557e-03
> > 9956 KSP Residual norm 1.080641626963e+00 % max 1.164749229958e+02 min 7.459540346436e-02 max/min 1.561422253738e+03
> > 9957 KSP preconditioned resid norm 1.080641626935e+00 true resid norm 1.594099017783e-01 ||r(i)||/||b|| 8.917450642725e-03
> > 9957 KSP Residual norm 1.080641626935e+00 % max 1.166575286636e+02 min 7.458642942097e-02 max/min 1.564058362483e+03
> > 9958 KSP preconditioned resid norm 1.080641625459e+00 true resid norm 1.594089210473e-01 ||r(i)||/||b|| 8.917395780257e-03
> > 9958 KSP Residual norm 1.080641625459e+00 % max 1.166899683166e+02 min 6.207944430169e-02 max/min 1.879687707085e+03
> > 9959 KSP preconditioned resid norm 1.080641620143e+00 true resid norm 1.594083265698e-01 ||r(i)||/||b|| 8.917362524958e-03
> > 9959 KSP Residual norm 1.080641620143e+00 % max 1.166907769657e+02 min 4.511856151865e-02 max/min 2.586314213883e+03
> > 9960 KSP preconditioned resid norm 1.080641619752e+00 true resid norm 1.594073442756e-01 ||r(i)||/||b|| 8.917307575050e-03
> > 9960 KSP Residual norm 1.080641619752e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
> > 9961 KSP preconditioned resid norm 1.080641619752e+00 true resid norm 1.594073442805e-01 ||r(i)||/||b|| 8.917307575322e-03
> > 9961 KSP Residual norm 1.080641619752e+00 % max 3.063497144523e+01 min 3.063497144523e+01 max/min 1.000000000000e+00
> > 9962 KSP preconditioned resid norm 1.080641619752e+00 true resid norm 1.594073442888e-01 ||r(i)||/||b|| 8.917307575783e-03
> > 9962 KSP Residual norm 1.080641619752e+00 % max 3.066566109468e+01 min 3.845843703829e+00 max/min 7.973714861098e+00
> > 9963 KSP preconditioned resid norm 1.080641619752e+00 true resid norm 1.594073443871e-01 ||r(i)||/||b|| 8.917307581283e-03
> > 9963 KSP Residual norm 1.080641619752e+00 % max 3.713390425813e+01 min 1.336329967989e+00 max/min 2.778797538606e+01
> > 9964 KSP preconditioned resid norm 1.080641619752e+00 true resid norm 1.594073443904e-01 ||r(i)||/||b|| 8.917307581472e-03
> > 9964 KSP Residual norm 1.080641619752e+00 % max 4.496570748601e+01 min 1.226794844829e+00 max/min 3.665299677086e+01
> > 9965 KSP preconditioned resid norm 1.080641619752e+00 true resid norm 1.594073443960e-01 ||r(i)||/||b|| 8.917307581781e-03
> > 9965 KSP Residual norm 1.080641619752e+00 % max 8.684970616180e+01 min 1.183106833938e+00 max/min 7.340816878957e+01
> > 9966 KSP preconditioned resid norm 1.080641619752e+00 true resid norm 1.594073446787e-01 ||r(i)||/||b|| 8.917307597597e-03
> > 9966 KSP Residual norm 1.080641619752e+00 % max 9.802644805035e+01 min 1.168698112506e+00 max/min 8.387662049028e+01
> > 9967 KSP preconditioned resid norm 1.080641619752e+00 true resid norm 1.594073448376e-01 ||r(i)||/||b|| 8.917307606488e-03
> > 9967 KSP Residual norm 1.080641619752e+00 % max 1.123297332549e+02 min 1.141283907756e+00 max/min 9.842400518531e+01
> > 9968 KSP preconditioned resid norm 1.080641619752e+00 true resid norm 1.594073449323e-01 ||r(i)||/||b|| 8.917307611782e-03
> > 9968 KSP Residual norm 1.080641619752e+00 % max 1.134976751689e+02 min 1.090790474217e+00 max/min 1.040508492250e+02
> > 9969 KSP preconditioned resid norm 1.080641619751e+00 true resid norm 1.594073935137e-01 ||r(i)||/||b|| 8.917310329444e-03
> > 9969 KSP Residual norm 1.080641619751e+00 % max 1.139911627557e+02 min 4.122309806702e-01 max/min 2.765225519207e+02
> > 9970 KSP preconditioned resid norm 1.080641619750e+00 true resid norm 1.594074502003e-01 ||r(i)||/||b|| 8.917313500516e-03
> > 9970 KSP Residual norm 1.080641619750e+00 % max 1.140007220037e+02 min 2.895709152543e-01 max/min 3.936884403725e+02
> > 9971 KSP preconditioned resid norm 1.080641619750e+00 true resid norm 1.594074475189e-01 ||r(i)||/||b|| 8.917313350515e-03
> > 9971 KSP Residual norm 1.080641619750e+00 % max 1.140387347164e+02 min 2.881891122657e-01 max/min 3.957079912555e+02
> > 9972 KSP preconditioned resid norm 1.080641619750e+00 true resid norm 1.594074249007e-01 ||r(i)||/||b|| 8.917312085247e-03
> > 9972 KSP Residual norm 1.080641619750e+00 % max 1.140387839472e+02 min 2.501648230072e-01 max/min 4.558545944886e+02
> > 9973 KSP preconditioned resid norm 1.080641619748e+00 true resid norm 1.594074242369e-01 ||r(i)||/||b|| 8.917312048114e-03
> > 9973 KSP Residual norm 1.080641619748e+00 % max 1.141359929290e+02 min 2.500655391090e-01 max/min 4.564243171438e+02
> > 9974 KSP preconditioned resid norm 1.080641619747e+00 true resid norm 1.594074179174e-01 ||r(i)||/||b|| 8.917311694599e-03
> > 9974 KSP Residual norm 1.080641619747e+00 % max 1.141719411262e+02 min 2.470361384981e-01 max/min 4.621669599450e+02
> > 9975 KSP preconditioned resid norm 1.080641619724e+00 true resid norm 1.594073585052e-01 ||r(i)||/||b|| 8.917308371056e-03
> > 9975 KSP Residual norm 1.080641619724e+00 % max 1.141769961595e+02 min 2.461590320913e-01 max/min 4.638342748974e+02
> > 9976 KSP preconditioned resid norm 1.080641619721e+00 true resid norm 1.594072392992e-01 ||r(i)||/||b|| 8.917301702630e-03
> > 9976 KSP Residual norm 1.080641619721e+00 % max 1.150248073926e+02 min 1.817423531140e-01 max/min 6.329003967526e+02
> > 9977 KSP preconditioned resid norm 1.080641619621e+00 true resid norm 1.594068288737e-01 ||r(i)||/||b|| 8.917278743269e-03
> > 9977 KSP Residual norm 1.080641619621e+00 % max 1.153659432133e+02 min 1.758207322277e-01 max/min 6.561566531518e+02
> > 9978 KSP preconditioned resid norm 1.080641619605e+00 true resid norm 1.594066900433e-01 ||r(i)||/||b|| 8.917270977044e-03
> > 9978 KSP Residual norm 1.080641619605e+00 % max 1.154409858489e+02 min 1.682246559484e-01 max/min 6.862310711714e+02
> > 9979 KSP preconditioned resid norm 1.080641619257e+00 true resid norm 1.594052257365e-01 ||r(i)||/||b|| 8.917189063164e-03
> > 9979 KSP Residual norm 1.080641619257e+00 % max 1.154411216580e+02 min 1.254601679658e-01 max/min 9.201416157000e+02
> > 9980 KSP preconditioned resid norm 1.080641619092e+00 true resid norm 1.594051529133e-01 ||r(i)||/||b|| 8.917184989407e-03
> > 9980 KSP Residual norm 1.080641619092e+00 % max 1.155780886655e+02 min 1.115223976110e-01 max/min 1.036366605645e+03
> > 9981 KSP preconditioned resid norm 1.080641619012e+00 true resid norm 1.594042648383e-01 ||r(i)||/||b|| 8.917135310152e-03
> > 9981 KSP Residual norm 1.080641619012e+00 % max 1.156949417657e+02 min 9.748351070064e-02 max/min 1.186815502788e+03
> > 9982 KSP preconditioned resid norm 1.080641618926e+00 true resid norm 1.594037912594e-01 ||r(i)||/||b|| 8.917108817969e-03
> > 9982 KSP Residual norm 1.080641618926e+00 % max 1.157177699729e+02 min 8.161808862755e-02 max/min 1.417795637202e+03
> > 9983 KSP preconditioned resid norm 1.080641618914e+00 true resid norm 1.594039926066e-01 ||r(i)||/||b|| 8.917120081407e-03
> > 9983 KSP Residual norm 1.080641618914e+00 % max 1.157297318664e+02 min 8.041726690542e-02 max/min 1.439115457660e+03
> > 9984 KSP preconditioned resid norm 1.080641618881e+00 true resid norm 1.594038798061e-01 ||r(i)||/||b|| 8.917113771305e-03
> > 9984 KSP Residual norm 1.080641618881e+00 % max 1.158244868066e+02 min 8.041279440761e-02 max/min 1.440373856671e+03
> > 9985 KSP preconditioned resid norm 1.080641618880e+00 true resid norm 1.594038723728e-01 ||r(i)||/||b|| 8.917113355483e-03
> > 9985 KSP Residual norm 1.080641618880e+00 % max 1.158302224434e+02 min 7.912036884330e-02 max/min 1.463974753110e+03
> > 9986 KSP preconditioned resid norm 1.080641618717e+00 true resid norm 1.594038980749e-01 ||r(i)||/||b|| 8.917114793267e-03
> > 9986 KSP Residual norm 1.080641618717e+00 % max 1.164682835790e+02 min 7.460686106511e-02 max/min 1.561093469371e+03
> > 9987 KSP preconditioned resid norm 1.080641618691e+00 true resid norm 1.594040222541e-01 ||r(i)||/||b|| 8.917121739901e-03
> > 9987 KSP Residual norm 1.080641618691e+00 % max 1.166493032152e+02 min 7.459727412837e-02 max/min 1.563720720069e+03
> > 9988 KSP preconditioned resid norm 1.080641617240e+00 true resid norm 1.594049907736e-01 ||r(i)||/||b|| 8.917175919248e-03
> > 9988 KSP Residual norm 1.080641617240e+00 % max 1.166813081045e+02 min 6.210350927266e-02 max/min 1.878819884271e+03
> > 9989 KSP preconditioned resid norm 1.080641612022e+00 true resid norm 1.594055829488e-01 ||r(i)||/||b|| 8.917209045757e-03
> > 9989 KSP Residual norm 1.080641612022e+00 % max 1.166820415947e+02 min 4.513453999933e-02 max/min 2.585205069033e+03
> > 9990 KSP preconditioned resid norm 1.080641611645e+00 true resid norm 1.594065477745e-01 ||r(i)||/||b|| 8.917263018470e-03
> > 9990 KSP Residual norm 1.080641611645e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
> > 9991 KSP preconditioned resid norm 1.080641611645e+00 true resid norm 1.594065477696e-01 ||r(i)||/||b|| 8.917263018201e-03
> > 9991 KSP Residual norm 1.080641611645e+00 % max 3.063465549435e+01 min 3.063465549435e+01 max/min 1.000000000000e+00
> > 9992 KSP preconditioned resid norm 1.080641611645e+00 true resid norm 1.594065477615e-01 ||r(i)||/||b|| 8.917263017744e-03
> > 9992 KSP Residual norm 1.080641611645e+00 % max 3.066530412302e+01 min 3.844470687795e+00 max/min 7.976469744031e+00
> > 9993 KSP preconditioned resid norm 1.080641611645e+00 true resid norm 1.594065476642e-01 ||r(i)||/||b|| 8.917263012302e-03
> > 9993 KSP Residual norm 1.080641611645e+00 % max 3.714516899070e+01 min 1.336552632161e+00 max/min 2.779177422339e+01
> > 9994 KSP preconditioned resid norm 1.080641611645e+00 true resid norm 1.594065476608e-01 ||r(i)||/||b|| 8.917263012110e-03
> > 9994 KSP Residual norm 1.080641611645e+00 % max 4.500812884571e+01 min 1.226798972667e+00 max/min 3.668745234425e+01
> > 9995 KSP preconditioned resid norm 1.080641611645e+00 true resid norm 1.594065476552e-01 ||r(i)||/||b|| 8.917263011801e-03
> > 9995 KSP Residual norm 1.080641611645e+00 % max 8.688131738345e+01 min 1.183120593233e+00 max/min 7.343403358914e+01
> > 9996 KSP preconditioned resid norm 1.080641611645e+00 true resid norm 1.594065473796e-01 ||r(i)||/||b|| 8.917262996379e-03
> > 9996 KSP Residual norm 1.080641611645e+00 % max 9.802499878957e+01 min 1.168930461656e+00 max/min 8.385870845619e+01
> > 9997 KSP preconditioned resid norm 1.080641611645e+00 true resid norm 1.594065472234e-01 ||r(i)||/||b|| 8.917262987642e-03
> > 9997 KSP Residual norm 1.080641611645e+00 % max 1.122454823211e+02 min 1.141659208813e+00 max/min 9.831785304632e+01
> > 9998 KSP preconditioned resid norm 1.080641611645e+00 true resid norm 1.594065471295e-01 ||r(i)||/||b|| 8.917262982389e-03
> > 9998 KSP Residual norm 1.080641611645e+00 % max 1.134943126018e+02 min 1.090790203681e+00 max/min 1.040477923425e+02
> > 9999 KSP preconditioned resid norm 1.080641611644e+00 true resid norm 1.594064989598e-01 ||r(i)||/||b|| 8.917260287762e-03
> > 9999 KSP Residual norm 1.080641611644e+00 % max 1.139914489020e+02 min 4.119830336343e-01 max/min 2.766896682528e+02
> > 10000 KSP preconditioned resid norm 1.080641611643e+00 true resid norm 1.594064428168e-01 ||r(i)||/||b|| 8.917257147097e-03
> > 10000 KSP Residual norm 1.080641611643e+00 % max 1.140011170215e+02 min 2.894564222709e-01 max/min 3.938455264772e+02
> > Then the number of iteration >10000
> > The Programme stop with convergenceReason=-3
> > Best,
> > Meng
> > ------------------ Original ------------------
> > From:  "Barry Smith";<bsmith at mcs.anl.gov>;
> > Send time: Friday, Apr 25, 2014 6:27 AM
> > To: "Oo "<wumeng07maths at qq.com>;
> > Cc: "Dave May"<dave.mayhem23 at gmail.com>; "petsc-users"<petsc-users at mcs.anl.gov>;
> > Subject:  Re: [petsc-users] Convergence_Eigenvalues_k=3
> > On Apr 24, 2014, at 5:24 PM, Oo <wumeng07maths at qq.com> wrote:
> > > Configure PETSC again?
> >    No, the command line when you run the program.
> > Barry
> > > From:  "Dave May";<dave.mayhem23 at gmail.com>;
> > > Send time: Friday, Apr 25, 2014 6:20 AM
> > > Cc: "Barry Smith"<bsmith at mcs.anl.gov>; "Matthew Knepley"<knepley at gmail.com>; "petsc-users"<petsc-users at mcs.anl.gov>;
> > > On the command line
> > > On 25 April 2014 00:11, Oo <wumeng07maths at qq.com> wrote:
> > > Where should I put "-ksp_monitor_true_residual -ksp_monitor_singular_value " ?
> > > Thanks,
> > > Meng
> > > Date:  Apr 25, 2014
> > > To:  "Matthew Knepley"<knepley at gmail.com>;
> > > Cc:  "Oo "<wumeng07maths at qq.com>; "petsc-users"<petsc-users at mcs.anl.gov>;
> > >    There are also a great deal of “bogus” numbers that have no meaning and many zeros. Most of these are not the eigenvalues of anything.
> > >    Run the two cases with -ksp_monitor_true_residual -ksp_monitor_singular_value and send the output
> > >   Barry
> > > On Apr 24, 2014, at 4:53 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > > > On Thu, Apr 24, 2014 at 12:57 PM, Oo <wumeng07maths at qq.com> wrote:
> > > > Hi,
> > > > For analysis the convergence of linear solver,
> > > > I meet a problem.
> > > > One is the list of Eigenvalues whose linear system which has a convergence solution.
> > > > The other is the list of Eigenvalues whose linear system whose solution does not converge (convergenceReason=-3).
> > > > These are just lists of numbers. It does not tell us anything about the computation. What is the problem you are having?
> > > >   Matt
> > > > Do you know what kind of method can be used to obtain a convergence solution for our non-convergence case?
> > > > Thanks,
> > > > Meng
> > > > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > > > -- Norbert Wiener
> -- Norbert Wiener
