[petsc-users] Compiling program with program files dependencies (SLEPC )
Steve Ndengue steve.ndengue at gmail.com
Thu Apr 24 19:36:16 CDT 2014
Thank you for the quick reply.
It partly solved the problem; the PETSC and SLEPC files are now included
in the compilation.
However the Warning are now error messages!
/pgm_hatom_offaxis_cyl.F90:880:0: error: invalid preprocessing directive
#INCLUDE//
//pgm_hatom_offaxis_cyl.F90:887:0: error: invalid preprocessing
directive #IF//
//pgm_hatom_offaxis_cyl.F90:890:0: error: invalid preprocessing
directive #ELSE//
//pgm_hatom_offaxis_cyl.F90:893:0: error: invalid preprocessing
directive #ENDIF/
And the corresponding code lines are:
*#INCLUDE <finclude/slepcepsdef.h>**
**        USE slepceps**
** IMPLICIT NONE**
**#IF DEFINED(PETSC_USE_FORTRAN_DATATYPES)**
**TYPE(Mat)                                          A**
**TYPE(EPS)                                          solver**
**#ELSE**
**Mat                                                A**
**EPS                                                solver**
**#ENDIF*
Sincerely.
On 04/24/2014 07:25 PM, Satish Balay wrote:
> On Thu, 24 Apr 2014, Steve Ndengue wrote:
>> Dear all,
>> I am having trouble compiling a code with some dependencies that shall call
>> SLEPC.
>> The compilation however goes perfectly for the various tutorials and tests in
>> the package.
>> A sample makefile looks like:
>> /default: code//
>> //routines: Rout1.o Rout2.o Rout3.o Module1.o//
>> //code: PgmPrincipal//
>> //sources=Rout1.f Rout2.f Rout3.f Module1.f90//
> Its best to rename your sourcefiles .F/.F90 [and not .f/.f90
> [this enables using default targets from petsc makefiles - and its
> the correct notation for preprocessing - which is required by petsc/slepc]
>> //objets=Rout1.o Rout2.o Rout3.o Module1.o Pgm//Principal//.o//
>> //%.o: %.f//
>> //        -${FLINKER} -c $<//
> And you shouldn't need to create the above .o.f target.
> Satish
>> //Module1_mod.mod Module1.o: //Module1//.f90//
>> //        -${FLINKER} -c //Module1//.f90//
>> //include ${SLEPC_DIR}/conf/slepc_common//
>> //Pgm//Principal//: ${objets} chkopts//
>> //        -${FLINKER} -o $@ ${objets} ${SLEPC_LIB}//
>> //.PHONY: clean//
>> //        ${RM} *.o *.mod Pgm//Principal//
>> The code exits with Warning and error messages of the type:
>> *Warning: Pgm**Principal**.f90:880: Illegal preprocessor directive**
>> **Warning: Pgm**Principal**.f90:889: Illegal preprocessor directive**
>> **Warning: Pgm**Principal**.f90:892: Illegal preprocessor directive**
>> **Warning: Pgm**Principal**.f90:895: Illegal preprocessor directive*
>> and
>> *USE slepceps**
>> **                    1**
>> **Fatal Error: Can't open module file 'slepceps.mod' for reading at (1): No
>> such file or directory
>> *I do not get these errors with the tests and errors files.
>> Sincerely,
Steve
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140424/762394b7/attachment.html>
