[petsc-users] KSP breakdown in specific cluster (update)
Wed Apr 23 05:00:48 CDT 2014
On Wed, Apr 23, 2014 at 5:55 AM, TAY wee-beng <zonexo at gmail.com> wrote:
> Hi,
> Just to update that I managed to compare the values by reducing the
> problem size to hundred plus values. The matrix and vector are almost the
> same compared to my win7 output.
Run in the debugger and get a stack trace,
   Matt
> Also tried valgrind but it aborts almost immediately:
> valgrind --leak-check=yes ./a.out
> ==17603== Memcheck, a memory error detector.
> ==17603== Copyright (C) 2002-2006, and GNU GPL'd, by Julian Seward et al.
> ==17603== Using LibVEX rev 1658, a library for dynamic binary translation.
> ==17603== Copyright (C) 2004-2006, and GNU GPL'd, by OpenWorks LLP.
> ==17603== Using valgrind-3.2.1, a dynamic binary instrumentation framework.
> ==17603== Copyright (C) 2000-2006, and GNU GPL'd, by Julian Seward et al.
> ==17603== For more details, rerun with: -v
> ==17603==
> --17603-- DWARF2 CFI reader: unhandled CFI instruction 0:10
> vex amd64->IR: unhandled instruction bytes: 0xF 0xAE 0x85 0xF0
> ==17603== valgrind: Unrecognised instruction at address 0x5DD0F0E.
> ==17603== Your program just tried to execute an instruction that Valgrind
> ==17603== did not recognise.  There are two possible reasons for this.
> ==17603== 1. Your program has a bug and erroneously jumped to a non-code
> ==17603==    location.  If you are running Memcheck and you just saw a
> ==17603==    warning about a bad jump, it's probably your program's fault.
> ==17603== 2. The instruction is legitimate but Valgrind doesn't handle it,
> ==17603==    i.e. it's Valgrind's fault.  If you think this is the case or
> ==17603==    you are not sure, please let us know and we'll try to fix it.
> ==17603== Either way, Valgrind will now raise a SIGILL signal which will
> ==17603== probably kill your program.
> forrtl: severe (168): Program Exception - illegal instruction
> Image              PC                Routine Line        Source
> libifcore.so.5     0000000005DD0F0E  Unknown Unknown  Unknown
> libifcore.so.5     0000000005DD0DC7  Unknown Unknown  Unknown
> a.out              0000000001CB4CBB  Unknown Unknown  Unknown
> a.out              00000000004093DC  Unknown Unknown  Unknown
> libc.so.6          000000369141D974  Unknown Unknown  Unknown
> a.out              00000000004092E9  Unknown Unknown  Unknown
> ==17603==
> ==17603== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 5 from 1)
> ==17603== malloc/free: in use at exit: 239 bytes in 8 blocks.
> ==17603== malloc/free: 31 allocs, 23 frees, 31,388 bytes allocated.
> ==17603== For counts of detected errors, rerun with: -v
> ==17603== searching for pointers to 8 not-freed blocks.
> ==17603== checked 2,340,280 bytes.
> ==17603==
> ==17603== LEAK SUMMARY:
> ==17603==    definitely lost: 0 bytes in 0 blocks.
> ==17603==      possibly lost: 0 bytes in 0 blocks.
> ==17603==    still reachable: 239 bytes in 8 blocks.
> ==17603==         suppressed: 0 bytes in 0 blocks.
> ==17603== Reachable blocks (those to which a pointer was found) are not
> shown.
> ==17603== To see them, rerun with: --show-reachable=yes
> Thank you
> Yours sincerely,
> TAY wee-beng
> On 23/4/2014 5:18 PM, TAY wee-beng wrote:
>> Hi,
>> My code was found to be giving error answer in one of the cluster, even
>> on single processor. No error msg was given. It used to be working fine.
>> I run the debug version and it gives the error msg:
>> [0]PETSC ERROR: ------------------------------
>> [0]PETSC ERROR: Caught signal number 8 FPE: Floating Point
>> Exception,probably divide by zero
>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
>> documentation/faq.html#valgrind[0]PETSC ERROR: or try http://valgrind.orgon GNU/linux and Apple Mac OS X to find memory corruption errors
>> [0]PETSC ERROR: likely location of problem given in stack below
>> [0]PETSC ERROR: ---------------------  Stack Frames
>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>> available,
>> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
>> [0]PETSC ERROR:       is given.
>> [0]PETSC ERROR: [0] VecDot_Seq line 62 src/vec/vec/impls/seq/bvec1.c
>> [0]PETSC ERROR: [0] VecDot_MPI line 14 src/vec/vec/impls/mpi/pbvec.c
>> [0]PETSC ERROR: [0] VecDot line 118 src/vec/vec/interface/rvector.c
>> [0]PETSC ERROR: [0] KSPSolve_BCGS line 39 src/ksp/ksp/impls/bcgs/bcgs.c
>> [0]PETSC ERROR: [0] KSPSolve line 356 src/ksp/ksp/interface/itfunc.c
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Signal received!
>> It happens after KSPSolve. There was no problem on other cluster. So how
>> should I debug to find the error?
>> I tried to compare the input matrix and vector between different cluster
>> but there are too many values.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140423/74d170b5/attachment.html>
