[petsc-users] [beginner question] Different communicators in the two objects: Argument # 1 and 2 flag 3!
Niklas Fischer niklas at niklasfi.de
Tue Apr 22 10:23:00 CDT 2014
I have tracked down the problem further and it basically boils down to
the following question: Is it possible to use MatSetValue(s) to set
values which are owned by other processes?
If I create a matrix with
     for(int i = 0; i < 4 * size; ++i){
       CHKERRXX(MatSetValue(A, i, i, rank+1, ADD_VALUES));
for n=m=4, on four processes, one would expect each entry to be 1 + 2 +
3 + 4 = 10, however, PETSc prints
    Matrix Object: 1 MPI processes
       type: mpiaij
    row 0: (0, 1)
    row 1: (1, 1)
    row 2: (2, 1)
    row 3: (3, 1)
    row 4: (4, 2)
    row 5: (5, 2)
    row 6: (6, 2)
    row 7: (7, 2)
    row 8: (8, 3)
    row 9: (9, 3)
    row 10: (10, 3)
    row 11: (11, 3)
    row 12: (12, 4)
    row 13: (13, 4)
    row 14: (14, 4)
    row 15: (15, 4)
which is exactly, what
    CHKERRXX(VecGetOwnershipRange(x, &ownership_start, &ownership_end));
    for(int i = ownership_start; i < ownership_end; ++i){
would give us.
Kind regards,
Niklas Fischer
Am 22.04.2014 14:59, schrieb Niklas Fischer:
> I should probably note that everything is fine if I run the serial
> version of this (with the exact same matrix + right hand side).
> PETSc KSPSolve done, residual norm: 3.13459e-13, it took 6 iterations.
> Am 22.04.2014 14:12, schrieb Niklas Fischer:
>> Am 22.04.2014 13:57, schrieb Matthew Knepley:
>>> On Tue, Apr 22, 2014 at 6:48 AM, Niklas Fischer <niklas at niklasfi.de
>>> <mailto:niklas at niklasfi.de>> wrote:
>>>     Am 22.04.2014 13:08, schrieb Jed Brown:
>>>         <mailto:niklas at niklasfi.de>> writes:
>>>             Hello,
>>>             I have attached a small test case for a problem I am
>>>             experiencing. What
>>>             this dummy program does is it reads a vector and a
>>>             matrix from a text
>>>             file and then solves Ax=b. The same data is available in
>>>             two forms:
>>>               - everything is in one file (matops.s.0 and vops.s.0)
>>>               - the matrix and vector are split between processes
>>>             (matops.0,
>>>             matops.1, vops.0, vops.1)
>>>             The serial version of the program works perfectly fine
>>>             but unfortunately
>>>             errors occure, when running the parallel version:
>>>             make && mpirun -n 2 a.out matops vops
>>>             mpic++ -DPETSC_CLANGUAGE_CXX -isystem
>>>             /home/data/fischer/libs/petsc-3.4.3/arch-linux2-c-debug/include
>>>             -isystem
>>>             /home/data/fischer/libs/petsc-3.4.3/include
>>>             petsctest.cpp -Werror -Wall
>>>             -Wpedantic -std=c++11 -L
>>>             /home/data/fischer/libs/petsc-3.4.3/arch-linux2-c-debug/lib
>>>             -lpetsc
>>>             /usr/bin/ld: warning: libmpi_cxx.so.0, needed by
>>>             /home/data/fischer/libs/petsc-3.4.3/arch-linux2-c-debug/lib/libpetsc.so,
>>>             may conflict with libmpi_cxx.so.1
>>>             /usr/bin/ld: warning: libmpi.so.0, needed by
>>>             may conflict with libmpi.so.1
>>>             librdmacm: couldn't read ABI version.
>>>             librdmacm: assuming: 4
>>>             CMA: unable to get RDMA device list
>>>             [[43019,1],0]: A high-performance Open MPI
>>>             point-to-point messaging module
>>>             was unable to find any relevant network interfaces:
>>>             Module: OpenFabrics (openib)
>>>                Host: dornroeschen.igpm.rwth-aachen.de
>>>             <http://dornroeschen.igpm.rwth-aachen.de>
>>>         It looks like your MPI is either broken or some of the code
>>>         linked into
>>>         your application was compiled with a different MPI or
>>>         different version.
>>>         Make sure you can compile and run simple MPI programs in
>>>         parallel.
>>>     Hello Jed,
>>>     thank you for your inputs. Unfortunately MPI does not seem to be
>>>     the issue here. The attachment contains a simple MPI hello world
>>>     program which runs flawlessly (I will append the output to this
>>>     mail) and I have not encountered any problems with other MPI
>>>     programs. My question still stands.
>>> This is a simple error. You created the matrix A using
>>> PETSC_COMM_WORLD, but you try to view it
>>> using PETSC_VIEWER_STDOUT_SELF. You need to use
>>> PETSC_VIEWER_STDOUT_WORLD in
>>> order to match.
>>>   Thanks,
>>>      Matt
>>>     Greetings,
>>>     Niklas Fischer
>>>     mpirun -np 2 ./mpitest
>>>     [[44086,1],0]: A high-performance Open MPI point-to-point
>>>     messaging module
>>>     Another transport will be used instead, although this may result in
>>>     lower performance.
>>>     Hello world from processor dornroeschen.igpm.rwth-aachen.de
>>>     <http://dornroeschen.igpm.rwth-aachen.de>, rank 0 out of 2
>>>     processors
>>>     <http://dornroeschen.igpm.rwth-aachen.de>, rank 1 out of 2
>>>     processors
>>>     [dornroeschen.igpm.rwth-aachen.de:128141
>>>     <http://dornroeschen.igpm.rwth-aachen.de:128141>] 1 more process
>>>     has sent help message help-mpi-btl-base.txt / btl:no-nics
>>>     <http://dornroeschen.igpm.rwth-aachen.de:128141>] Set MCA
>>>     parameter "orte_base_help_aggregate" to 0 to see all help /
>>>     error messages
>> Thank you, Matthew, this solves my viewing problem. Am I doing
>> something wrong when initializing the matrices as well? The matrix'
>> viewing output starts with "Matrix Object: 1 MPI processes" and the
>> Krylov solver does not converge.
>> Your help is really appreciated,
>> Niklas Fischer
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their experiments lead.
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140422/058748bf/attachment.html>
