[petsc-users] [beginner question] Different communicators in the two objects: Argument # 1 and 2 flag 3!
Niklas Fischer niklas at niklasfi.de
Tue Apr 22 04:29:30 CDT 2014
Hello,
I have attached a small test case for a problem I am experiencing. What
this dummy program does is it reads a vector and a matrix from a text
file and then solves Ax=b. The same data is available in two forms:
 - everything is in one file (matops.s.0 and vops.s.0)
 - the matrix and vector are split between processes (matops.0,
matops.1, vops.0, vops.1)
The serial version of the program works perfectly fine but unfortunately
errors occure, when running the parallel version:
make && mpirun -n 2 a.out matops vops
mpic++ -DPETSC_CLANGUAGE_CXX -isystem
/home/data/fischer/libs/petsc-3.4.3/arch-linux2-c-debug/include -isystem
/home/data/fischer/libs/petsc-3.4.3/include petsctest.cpp -Werror -Wall
-Wpedantic -std=c++11 -L
/home/data/fischer/libs/petsc-3.4.3/arch-linux2-c-debug/lib -lpetsc
/usr/bin/ld: warning: libmpi_cxx.so.0, needed by
/home/data/fischer/libs/petsc-3.4.3/arch-linux2-c-debug/lib/libpetsc.so,
may conflict with libmpi_cxx.so.1
/usr/bin/ld: warning: libmpi.so.0, needed by
may conflict with libmpi.so.1
librdmacm: couldn't read ABI version.
librdmacm: assuming: 4
CMA: unable to get RDMA device list
[[43019,1],0]: A high-performance Open MPI point-to-point messaging module
was unable to find any relevant network interfaces:
Module: OpenFabrics (openib)
  Host: dornroeschen.igpm.rwth-aachen.de
Another transport will be used instead, although this may result
Another transport will be used instead, although this may result in
lower performance.
Matrix size is 32x32
Vector size is 32
Vector size is 32
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Arguments must have same communicators!
[1]PETSC ERROR: Different communicators in the two objects: Argument # 1
and 2 flag 3!
[1]PETSC ERROR:
[1]PETSC ERROR: Petsc Release Version 3.4.0, May, 13, 2013
[1]PETSC ERROR: See docs/changes/index.html for recent updates.
[1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[1]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR:
[1]PETSC ERROR: petscwrap on a arch-linux2-c-debug named
dornroeschen.igpm.rwth-aachen.de by fischer Tue Apr 22 11:14:39 2014
[1]PETSC ERROR: Libraries linked from /usr/local/openmpi-4.8.1/lib
[1]PETSC ERROR: Configure run at Fri Jun  7 09:32:12 2013
[1]PETSC ERROR: Configure options --with-netcdf=1
--prefix=/usr/local/openmpi-4.8.1 --with-mpi=1 --with-shared-libraries=1
--with-hdf=1 --with-hdf-dir=/usr/local/openmpi-4.8.1
--with-netcdf-lib=/usr/local/openmpi-4.8.1/lib64/libnetcdf.so
--with-metis=1 --with-netcdf-include=/usr/local/openmpi-4.8.1/include
--with-metis-dir=/usr/local/openmpi-4.8.1 --COPTFLAGS=-O3
--CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --libdir=/usr/local/openmpi-4.8.1/lib64
[1]PETSC ERROR:
[1]PETSC ERROR: MatView() line 811 in
/local/petsc-3.4.0/src/mat/interface/matrix.c
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Arguments must have same communicators!
[0]PETSC ERROR: Different communicators in the two objects: Argument # 1
and 2 flag 3!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.4.0, May, 13, 2013
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: petscwrap on a arch-linux2-c-debug named
and 2 flag 3!
[1]PETSC ERROR:
[1]PETSC ERROR:
[1]PETSC ERROR:
[1]PETSC ERROR: main() line 108 in "unknowndirectory/"petsctest.cpp
[0]PETSC ERROR: Libraries linked from /usr/local/openmpi-4.8.1/lib
[0]PETSC ERROR: Configure run at Fri Jun  7 09:32:12 2013
[0]PETSC ERROR: Configure options --with-netcdf=1
[0]PETSC ERROR:
[0]PETSC ERROR: MatView() line 811 in
and 2 flag 3!
[0]PETSC ERROR:
[0]PETSC ERROR:
[0]PETSC ERROR:
[0]PETSC ERROR: main() line 108 in "unknowndirectory/"petsctest.cpp
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 80.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
PETSc KSPSolve done, residual norm: 30.4324, it took 10000
iterations.PETSc KSPSolve done, residual norm: 30.4324, it took 10000
iterations.--------------------------------------------------------------------------
mpirun has exited due to process rank 0 with PID 127153 on
node dornroeschen.igpm.rwth-aachen.de exiting improperly. There are two
reasons this could occur:
1. this process did not call "init" before exiting, but others in
the job did. This can cause a job to hang indefinitely while it waits
for all processes to call "init". By rule, if one process calls "init",
then ALL processes must call "init" prior to termination.
2. this process called "init", but exited without calling "finalize".
By rule, all processes that call "init" MUST call "finalize" prior to
exiting or it will be considered an "abnormal termination"
This may have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
[dornroeschen.igpm.rwth-aachen.de:127152] 1 more process has sent help
message help-mpi-btl-base.txt / btl:no-nics
[dornroeschen.igpm.rwth-aachen.de:127152] Set MCA parameter
"orte_base_help_aggregate" to 0 to see all help / error messages
message help-mpi-api.txt / mpi-abort
I would be glad to get some pointers as to where this problem comes from.
Kind regards,
Niklas Fischer
Type: application/gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140422/8953fdcb/attachment-0001.bin>
