[petsc-users] libpetsc.so: undefined reference to `_gfortran_transfer_character_write at GFORTRAN_1.4'
Matteo Parsani parsani.matteo at gmail.com
Mon Apr 21 07:40:52 CDT 2014
Thanks Satish!
I am trying to fix the issue following your suggestions.
I will let you know.
Thanks
On Fri, Apr 18, 2014 at 12:21 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> detailed logs would have been useful.
> Mostlikely you have multiple version of libgfortran.so - and the wrong
> version got linked in.
> Or you have blas [or something else] compiled with a different version
> gfortran so its attempting to link with a different libgfortran.so]
> You can look at the link command, and look at all the .so files in the
> linkcommand - and do 'ldd libblas.so' etc on all the .so files in the
> link command to indentify the differences.
> And after you locate the multiple libgfortran.so files [perhaps with
> 'locate libgfortran.so'] - you can do the following to indentify the
> libgfortran library that you should be using.
> 'nm -Ao libgfortran.so |grep
> Or use --with-shared-libraries=0 and see if this problem goes away..
> Satish
> On Fri, 18 Apr 2014, Matteo Parsani wrote:
> > Dear PETSc Users and Developers,
> > I have compiled successfully PETSc 3.4 with gfortran 4.7.2.
> > However, when I compile my code, during the linking phase I get this
> error:
> /ump/fldmd/home/pmatteo/research/workspace/codes/ssdc/deps/petsc/lib/libpetsc.so:
> > undefined reference to `_gfortran_transfer_integer_write at GFORTRAN_1.4'
> > Any idea?
> > Is it related to the gcc compiler options?
> > Thank you,
Matteo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140421/ed6c4257/attachment.html>
