[petsc-users] MUMPS error -13 info
Hong Zhang hzhang at mcs.anl.gov
Fri Apr 18 09:31:01 CDT 2014
Gong Ding,
The reported bug is fixed in petsc-release
https://bitbucket.org/petsc/petsc/commits/151787a63101f3b7c1ee9a4abd20e4c3fe8caf18?at=maint
Thanks for your contribution!
Hong
On Sun, Apr 13, 2014 at 2:42 AM, Gong Ding <gdiso at ustc.edu> wrote:
> Dear Sir,
> I see an error:
> Transient compute from 0 ps step 0.2 ps to 3000 ps
> t = 0.2 ps, dt = 0.2 ps
>   process particle generation....................ok
>   Gummel electron equation CONVERGED_ATOL, residual 5.41824e-12, its 4
>   Gummel hole equation CONVERGED_ATOL, residual 4.6721e-13, its 4
> --------------------- Error Message ------------------------------------
> Fatal Error:Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory 990883164 megabytes
>  at line 721 in /tmp/build/rhel6-64/build.petsc.3.4.4.859b2b9/src/src/mat/impls/aij/mpi/mumps/mumps.c
> which reported that MUMPS requires 990883164 megabytes of memory.
> The memory requirement is too huge so I takes a look at the reason.
> The code in petsc is listed below:
> if (mumps->id.INFOG(1) < 0) {
>  if (mumps->id.INFO(1) == -13)
> SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"Error reported by MUMPS in numerical factorization phase: Cannot allocate required memory %d megabytes\n",mumps->id.INFO(2));
> However, the mumps user's guide said
> –13 An error occurred in a Fortran ALLOCATE statement. The size that the package requested is
> available in INFO(2). If INFO(2) is negative, then the size that the package requested is obtained
> by multiplying the absolute value of INFO(2) by 1 million.
> It is clear that 990883164 megabytes should be 990883164 bytes here. Hope this bug can be fixed.
> Regards,
> Gong Ding
