[petsc-users] SNES failed with reason -3
Que Cat quecat001 at gmail.com
Wed Apr 16 11:38:37 CDT 2014
Hi Jed and Peter,
Please see the attached file for the output. Thank you for your help.
Que
On Wed, Apr 16, 2014 at 10:05 AM, Jed Brown <jed at jedbrown.org> wrote:
> Que Cat <quecat001 at gmail.com> writes:
> > Dear Petsc-Users,
> > I call the nonliner solver snes in my code and it said that "SNES Failed!
> > Reason -3". I testes with "-pc_type lu" and it passed. I have checked the
> > hand-coded Jacobian, ant it looks fine. Could you suggest any possible
> > sources of the errors?
> Run with -snes_converged_reason -ksp_converged_reason
> -ksp_monitor_true_residual -snes_view and send the output.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140416/69b0f3a1/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140416/69b0f3a1/attachment-0001.obj>
