[petsc-users] Failed to compile the PETsc-dev with cuda, mpicc can not recognize c++ key word in thrust and cusp (Lei Shi)
Lei Shi leishi at ku.edu
Tue Apr 15 03:06:38 CDT 2014
Hi Christophe,
Thanks a lot. I add --with-clanguage=cxx option. It works well now. This
option is not on the manual for the compilation with gpu.
Sincerely Yours,
Lei Shi
On Fri, Apr 11, 2014 at 3:42 AM, Christophe Ortiz <
christophe.ortiz at ciemat.es> wrote:
> Hi,
> Maybe I'm wrong but I think the following options are missing if you want
> to use C++:
> --with-cxx=(g++ or icc....) --with-clanguage=cxx
> Christophe
>> Message: 2
>> Date: Fri, 11 Apr 2014 03:26:09 -0500
>> From: Lei Shi <stoneszone at gmail.com>
>> To: petsc-users at mcs.anl.gov
>> Subject: [petsc-users] Failed to compile the PETsc-dev with cuda,
>> Message-ID:
>>         <CAEV8=
>> V9JJr+8Np5JaOKqgrkS12KJ6TaO3V4wM9YPo-NG29EU-A at mail.gmail.com>
>> Content-Type: text/plain; charset="utf-8"
>> Hi guys,
>> I tried to compile petsc-dev with cuda5, but failed. I think the problem
>> is the PETsc-dev with cuda, mpicc can not recognize c++ key word in thrust
>> and cusp. Please help me out. here is my option file
>> configure_options = [
>>     '--with-shared-libraries=0',
>>     '--with-mpi-dir=/media/public/MPICH3/mpich-install/',
>>     '--with-cuda=1',
>>     '--with-cuda-dir=/usr/local/cuda',
>>     '--with-cudac=/usr/local/cuda/bin/nvcc',
>>     '--with-cuda-arch=sm_20',
>>     '--with-cusp-dir=/usr/local/cuda/include/cusp',
>>     '--with-thrust=1',
>>     '--with-cusp=1',
>>     '--with-debugging=0',
>>     '--with-precision=double',
>>     'COPTFLAGS=-O3',
>>     'CXXOPTFLAGS=-O3',
>>     'FOPTFLAGS=-O3',
>> and the error i got
>>              Configuring PETSc to compile on your system
>> TESTING: alternateConfigureLibrary from
>> PETSc.packages.petsc4py(config/PETSc/packages/petsc4py.py:65)
>>  Compilers:
>>   C Compiler:         /media/public/MPICH3/mpich-install/bin/mpicc  -Wall
>> -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O3
>>   CUDA Compiler:      /usr/local/cuda/bin/nvcc  -O -arch=sm_20
>>   C++ Compiler:       /media/public/MPICH3/mpich-install/bin/mpicxx  -Wall
>> Linkers:
>>   Static linker:   /usr/bin/ar cr
>>   Dynamic linker:   /usr/bin/ar
>> make:
>> MPI:
>>   Includes: -I/media/public/MPICH3/mpich-install/include
>> BLAS/LAPACK: -llapack -lblas
>> X:
>>   Library:  -lX11
>> pthread:
>>   Library:  -lpthread
>> valgrind:
>> cuda:
>>   Includes: -I/usr/local/cuda/include
>>   Library:  -Wl,-rpath,/usr/local/cuda/lib64 -L/usr/local/cuda/lib64
>> -lcufft -lcublas -lcudart -lcusparse
>>   Arch:     -arch=sm_20
>> cusp:
>>   Includes: -I/usr/local/cuda/include/cusp/
>> -I/usr/local/cuda/include/cusp/include
>> thrust:
>> sowing:
>> c2html:
>> PETSc:
>>   PETSC_ARCH: arch-cuda5-cg-opt
>>   PETSC_DIR: /home/leishi/work/development/3rd_party/petsc/petsc
>>   Clanguage: C
>>   Memory alignment: 16
>>   Scalar type: real
>>   Precision: double
>>   shared libraries: disabled
>> xxx=========================================================================xxx
>>  Configure stage complete. Now build PETSc libraries with (gnumake build):
>>    make PETSC_DIR=/home/leishi/work/development/3rd_party/petsc/petsc
>> PETSC_ARCH=arch-cuda5-cg-opt all
>> Using C/C++ compile: /media/public/MPICH3/mpich-install/bin/mpicc -c -Wall
>> -I/home/leishi/work/development/3rd_party/pet\
>> sc/petsc/include
>> -I/home/leishi/work/development/3rd_party/petsc/petsc/arch-cuda5-cg-opt/include
>> -I/usr/local/cuda/include -I/usr/local/cuda/include/cusp/
>> -I/usr/local/cuda/include/cus\
>> p/include -I/media/public/MPICH3/mpich-install/include
>> mpicc -show: gcc -I/media/public/MPICH3/mpich-install/include
>> -L/media/public/MPICH3/mpich-install/lib -lmpich -lopa -lmpl -lrt
>> -lpthread
>> Using CUDA compile: /usr/local/cuda/bin/nvcc -O -arch=sm_20  -c
>> --compiler-options=-Wall -Wwrite-strings -Wno-strict-aliasing
>> -Wno-unknown-pragmas -O3 -I/home/leishi/work/development/3\
>> rd_party/petsc/petsc/include
>> -I/usr/local/cuda\
>> /include/cusp/include -I/media/public/MPICH3/mpich-install/include
>> Using C/C++ linker: /media/public/MPICH3/mpich-install/bin/mpicc
>> Using C/C++ flags: -Wall -Wwrite-strings -Wno-strict-aliasing
>> Using libraries:
>> -L/home/leishi/work/development/3rd_party/petsc/petsc/arch-cuda5-cg-opt/lib
>>  -lpetsc -llapack -lblas -lX11 -lpthread -Wl,-rpath,/usr/local/cuda/lib64
>> -L/usr/local/cuda\
>> /lib64 -lcufft -lcublas -lcudart -lcusparse -lm
>> -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/x86_64-linux-gnu
>> -L/lib/x86_64-linux-gnu -L/usr/\
>> lib/gcc/x86_64-linux-gnu/4.8 -lmpichcxx -lstdc++ -ldl -lmpich -lopa -lmpl
>> -lrt -lpthread -lgcc_s -ldl
>> Using mpiexec: /media/public/MPICH3/mpich-install/bin/mpiexec
>> Building PETSc using GNU Make with 18 build threads
>> make[2]: Entering directory
>> `/home/leishi/work/development/3rd_party/petsc/petsc'
>> Use "/usr/bin/make V=1" to see the verbose compile lines.
>>           CC arch-cuda5-cg-opt/obj/src/sys/utils/arch.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/utils/fhost.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/utils/fuser.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/utils/memc.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/utils/mpiu.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/utils/psleep.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/utils/sortd.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/utils/sorti.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/utils/str.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/utils/sortip.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/utils/pbarrier.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/utils/pdisplay.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/utils/ctable.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/utils/psplit.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/utils/select.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/utils/mpimesg.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/utils/sseenabled.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/utils/mpitr.o
>> In file included from /usr/local/cuda/include/cusp/detail/config.h:24:0,
>>                  from /usr/local/cuda/include/cusp/complex.h:63,
>>                  from
>> /home/leishi/work/development/3rd_party/petsc/petsc/include/petscmath.h:145,
>>                  from
>> /home/leishi/work/development/3rd_party/petsc/petsc/include/petscsys.h:366,
>>                  from
>> /home/leishi/work/development/3rd_party/petsc/petsc/include/petsc-private/petscimpl.h:8,
>>                  from
>> /home/leishi/work/development/3rd_party/petsc/petsc/src/sys/objects/options.c:14:
>> /usr/local/cuda/include/thrust/version.h:69:1: error: unknown type name
>> ?namespace?
>> /usr/local/cuda/include/thrust/version.h:70:1: error: expected ?=?, ?,?,
>> ?;?, ?asm? or ?__attribute__? before ?{? token
>> /home/leishi/work/development/3rd_party/petsc/petsc/include/petscmath.h:145:0,
>>                  from
>>                  from
>>                  from
>> /usr/local/cuda/include/cusp/complex.h:70:19: fatal error: complex: No
>> such
>> file or directory
>> compilation terminated.
>>           CC arch-cuda5-cg-opt/obj/src/sys/objects/state.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/objects/aoptions.o
>>           CC arch-cuda5-cg-opt/obj/src/sys/objects/subcomm.o
>>                  from
>>                  from
>>                  from
>> /home/leishi/work/development/3rd_party/petsc/petsc/src/sys/objects/init.c:10:
>> /usr/local/cuda/include/thrust/version.h:69:1: error:* unknown type name
>> ?namespace? *
>>                  from
>>                  from
>> such
>> file or directory
>> make: *** [all] Error 1
>> Sincerely Yours,
>> Lei Shi
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <
>> http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140411/4831a810/attachment.html
>> petsc-users mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
>> End of petsc-users Digest, Vol 64, Issue 26
>> Confidencialidad:
>> Este mensaje y sus ficheros adjuntos se dirige exclusivamente a su
>> destinatario y puede contener información privilegiada o confidencial. Si
>> no es vd. el destinatario indicado, queda notificado de que la utilización,
>> divulgación y/o copia sin autorización está prohibida en virtud de la
>> legislación vigente. Si ha recibido este mensaje por error, le rogamos que
>> nos lo comunique inmediatamente respondiendo al mensaje y proceda a su
>> destrucción.
>> Disclaimer:
>> This message and its attached files is intended exclusively for its
>> recipients and may contain confidential information. If you received this
>> e-mail in error you are hereby notified that any dissemination, copy or
>> disclosure of this communication is strictly prohibited and may be
>> unlawful. In this case, please notify us by a reply and delete this email
>> and its contents immediately.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140415/46cf90b3/attachment-0001.html>
