[petsc-users] Intel Internal compiler error: segmentation violation signal raised
TAY wee-beng zonexo at gmail.com
Wed Apr 9 20:01:47 CDT 2014
Hi all,
Thank you for the gfortran options. I will try them out!
Yours sincerely,
TAY wee-beng
On 8/4/2014 8:33 PM, Jed Brown wrote:
> TAY wee-beng <zonexo at gmail.com> writes:
>> Thanks for the advice. It took me a while to compile and build
>> successfully with gfortran due to the stricter rules and entirely
>> different options.
> Writing portable standards-compliant code pays off.
>> But the most problematic thing was that most clusters I work with use
>> old versions of gcc/gfortran. With the gcc/gfortran tied to the MPI, it
>> seems that I can't just update myself to use the new version, or can I?
> They often have modules to access more recent versions.  You can also
> request it.  Paying to upgrade commercial compilers while leaving open
> source compilers at an old version is not good machine maintenance.
>> Also, can anyone recommend options to get optimized results in gfortran?
>> I'm using :
>> -fno-signed-zeros  -fno-trapping-math -ffast-math -march=native
>> -funroll-loops -ffree-line-length-none -O3
> I usually use this, with or without -ffast-math depending on requirements:
>    -O3 -march=native -ftree-vectorize
