[petsc-users] Intel Internal compiler error: segmentation violation signal raised
Mon Apr 7 11:40:12 CDT 2014
How about just including petsc.h90 so you get everything.
     Matt
On Mon, Apr 7, 2014 at 5:19 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>  Sorry I realised that
> *#include "finclude/petscdmda.h90"*
> *#include "finclude/petscksp.h90"*
> also gave errors:
> */home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(10):
> error #5082: Syntax error, found ',' when expecting one of: ( % [ : . = =>*
> *          PetscInt, pointer :: array(:)*
> error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: )
> */home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(11):
> error #5082: Syntax error, found IDENTIFIER 'N' when expecting one of: ( %
> *          PetscInt  n*
> */home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(12):
> error #5082: Syntax error, found IDENTIFIER 'IERR' when expecting one of: (
> *          PetscErrorCode ierr*
> */home/wtay/Lib/petsc-3.4.4_shared_rel/include/finclude/ftn-custom/petscdmda.h90(13):
> error #5082: Syntax error, found IDENTIFIER 'V' when expecting one of: ( %
> Thank you
> Yours sincerely,
> TAY wee-beng
> On 7/4/2014 6:16 PM, TAY wee-beng wrote:
> Hi,
> I encountered the error below when compiling my code using intel fortran:
> /tmp/ifortlPEDlK.i90: catastrophic error: **Internal compiler error:
> segmentation violation signal raised** Please report this error along with
> the circumstances in which it occurred in a Software Problem Report.  Note:
> File and line given may not be explicit cause of this error.
> In the end, I realised that it is due to using *petsc.h90*:
> module PETSc_solvers
> use set_matrix
> implicit none
> contains
> subroutine semi_momentum_simple_xyz(du,dv,dw)
> *#include "finclude/petsc.h90"*
> integer :: i,j,k,ijk,ierr,II !,ro...
> If I use :
> *#include "finclude/petsc.h" or *
> Then there is no problem.
> May I know why this is happening?
> Although I can now compile and build successfully, is this the right way
> to go?
> Thank you
> Yours sincerely,
> TAY wee-beng
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140407/063eda87/attachment.html>
