[petsc-users] Intel Internal compiler error: segmentation violation signal raised
TAY wee-beng zonexo at gmail.com
Mon Apr 7 05:16:50 CDT 2014
I encountered the error below when compiling my code using intel fortran:
/tmp/ifortlPEDlK.i90: catastrophic error: **Internal compiler error:
segmentation violation signal raised** Please report this error along
with the circumstances in which it occurred in a Software Problem
Report.  Note: File and line given may not be explicit cause of this error.
In the end, I realised that it is due to using *petsc.h90*:
module PETSc_solvers
use set_matrix
implicit none
contains
subroutine semi_momentum_simple_xyz(du,dv,dw)
*#include "finclude/petsc.h90"*
integer :: i,j,k,ijk,ierr,II !,ro...
If I use :
*#include "finclude/petsc.h"
or
*#include "finclude/petscdmda.h90"*
*#include "finclude/petscksp.h90"*
Then there is no problem.
May I know why this is happening?
Although I can now compile and build successfully, is this the right way
to go?
Thank you
Yours sincerely,
TAY wee-beng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140407/703da3cb/attachment.html>
