[petsc-users] Questions abt DM and DMDALocalToLocalBegin / End
Jed Brown jed at jedbrown.org
Sun Apr 6 10:04:54 CDT 2014
TAY wee-beng <zonexo at gmail.com> writes:
> On 6/4/2014 10:54 PM, Jed Brown wrote:
>> It is common for explicit methods to be implemented using only local
>> vectors.  I recommend using global vectors if you might want to use
>> implicit methods.
> Hi Jed,
> May I know what you mean by explicit or implicit mtds?
Explicit versus implicit time integration; like forward versus backward
Euler.  There are some abstraction corners that can be cut more easily
with explicit methods.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140406/76fc6d30/attachment.pgp>
