[petsc-users] Trying to write Fortran version of ksp/ex34.c
Thu Apr 3 08:56:10 CDT 2014
On Thu, Apr 3, 2014 at 8:43 AM, Åsmund Ervik <asmund.ervik at ntnu.no> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Dear PETSc users,
> I'm trying to write a Poisson solver in Fortran using the
> KSPSetComputeOperators etc. framework. When debugging this, I ended up
> modifying ksp/ex22.f so that it matches ksp/ex34.c. The difference
> between these is that ex34.c has a non-constant RHS and Neumann BCs,
> which is closer to what I want.
If it has Neumann conditions, then it has a null space. Have you included
this in
your solver? That can cause a residual offset.
  Matt
> Now, when I run these two programs I get the following:
> ./ex22f_mod
>    Residual, L2 norm         1.007312
>    Error, sup norm         0.020941
>    Error, L1 norm        10.687882
>    Error, L2 norm         0.340425
> ./ex34
>    Residual, L2 norm 1.07124e-05
>    Error, sup norm 0.0209405
>    Error, L1 norm 0.00618512
>    Error, L2 norm 0.000197005
> but when I MatView/VecView the matrix and RHS for each example (write
> them to file), there is no difference. I have attached ex22f_mod.F90,
> any suggestions on what the error is?
> Once this example works, you can of course include it with PETSc.
> Regards,
> Åsmund
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v2.0.22 (GNU/Linux)
> Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
> iQEcBAEBAgAGBQJTPWWZAAoJED+FDAHgGz19aNYIANyq9k3a5kHzTlAdybkZCYDw
> yKtDE5l/4iWYmNL49FH8AocHVcRivLaeJG5CGKqySFtZUXOlC9DM7rn4UmuQecni
> dgIQuTk0Ym+OJccHyT5xxnebpFVNrIOTpInfQaDW6dTyeL1svAMeHqslKaGepySL
> q/cODbgNDYgl6uumB+POMZevtlM6HPhl/1m7HofcHC9upvTRjSPqP1cg+kg+/8m2
> Fdie/X7PCBfShrAys94kNXNcwtbO7taauphkQGMfyl0gUd+lFATG6zrEZdDqSFlV
> c44GFFbxW/SRIDBXdOeX9/cy75KW5do1Sildwb6R4H/i7t6/hCJUJuss7FHjmLc=
> =tV3N
> -----END PGP SIGNATURE-----
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140403/7e4b99e4/attachment.html>
