[petsc-users] How to speed up geometric multigrid
Michele Rosso mrosso at uci.edu
Mon Sep 30 20:00:18 CDT 2013
Barry,
sorry again for the very late answer. I tried all the variations you
proposed: all of them converge very slow , except the last one (CG
instead of fgmres) diverges.
I attached the diagnostics for the two options that convergence: each of
the attached files starts with a list of the options I used for the run.
As you pointed out earlier, the residual I used to require was too
small, therefore I increased atol to e-9.
After some tests, I noticed that any further increase of the absolute
tolerance changes significantly the solution.
What would you suggest to try next?
Thank you very much,
Michele
On 09/24/2013 05:08 PM, Barry Smith wrote:
>   Thanks. The balance of work on the different levels and across processes looks ok. So it is is a matter of improving the convergence rate.
>   The initial residual norm is very small. Are you sure you need to decrease it to 10^-12 ????
>   Start with a really robust multigrid smoother use
> -pc_mg_type full -ksp_type fgmres -mg_levels_pc_type bjacobi -mg_levels_ksp_type gmres -mg_levels_ksp_max_it 3   PLUS -mg_coarse_pc_factor_mat_solver_package superlu_dist
> -mg_coarse_pc_type lu -pc_mg_galerkin -pc_mg_levels 5 -pc_mg_log -pc_type mg
>   run with the -log_summary and -pc_mg_log
> Now back off a little on the smoother and use -mg_levels_pc_type sor instead  how does that change the convergence and time.
> Back off even more an replace the -ksp_type fgmres with -ksp_type cg and the -mg_levels_ksp_type gmres with -mg_levels_ksp_type richardson   how does that change the convergence and the time?
>   There are some additional variants we can try based on the results from above.
>   Barry
> On Sep 24, 2013, at 4:29 PM, Michele Rosso <mrosso at uci.edu> wrote:
>> Barry,
>> I re-rerun the test case with the option -pc_mg_log as you suggested.
>> I attached the new output ("final_new.txt').
>> Thanks for your help.
>> Michele
>> On 09/23/2013 09:35 AM, Barry Smith wrote:
>>>    Run with the additional option -pc_mg_log and send us the log file.
>>>    Barry
>>> Maybe we should make this the default somehow.
>>> On Sep 23, 2013, at 10:55 AM, Michele Rosso <mrosso at uci.edu> wrote:
>>>> Hi,
>>>> I am successfully using PETSc to solve a 3D Poisson's equation with CG + MG .  Such equation arises from a projection algorithm for a multiphase incompressible flow simulation.
>>>> I set up the solver  as I was suggested to do in a previous thread (title: "GAMG speed") and run a test case (liquid droplet with surface tension falling under the effect of gravity in a quiescent fluid).
>>>> The solution of the Poisson Equation via multigrid is correct but it becomes progressively slower and slower as the simulation progresses (I am performing successive solves) due to an increase in the number of iterations.
>>>> Since the solution of the Poisson equation is mission-critical, I need to speed it up as much as I can.
>>>> Could you please help me out with this?
>>>> I run the test case with the following options:
>>>> -pc_type mg  -pc_mg_galerkin  -pc_mg_levels 5   -mg_levels_ksp_type richardson -mg_levels_ksp_max_it 1
>>>> -mg_coarse_pc_type lu   -mg_coarse_pc_factor_mat_solver_package superlu_dist
>>>> -log_summary -ksp_view  -ksp_monitor_true_residual  -options_left
>>>> Please find the diagnostic for the final solve in the attached file "final.txt'.
>>>> Thank you,
>>>> Michele
>>>> <final.txt>
>> <final_new.txt>
-mg_coarse_pc_factor_mat_solver_package superlu_dist -mg_coarse_pc_type lu -pc_mg_galerkin -pc_mg_levels 5 -pc_type mg
-log_summary  -pc_mg_log  -ksp_monitor_true_residual  -options_left
 0 KSP unpreconditioned resid norm 2.452212453860e-07 true resid norm 2.452212453860e-07 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.419822158980e-07 true resid norm 2.419822158980e-07 ||r(i)||/||b|| 9.867913994036e-01
  2 KSP unpreconditioned resid norm 1.667048646853e-07 true resid norm 1.667048646853e-07 ||r(i)||/||b|| 6.798141181563e-01
  3 KSP unpreconditioned resid norm 1.358535510529e-07 true resid norm 1.358535510529e-07 ||r(i)||/||b|| 5.540040009136e-01
  4 KSP unpreconditioned resid norm 1.354895642983e-07 true resid norm 1.354895642983e-07 ||r(i)||/||b|| 5.525196810946e-01
  5 KSP unpreconditioned resid norm 1.244851791906e-07 true resid norm 1.244851791906e-07 ||r(i)||/||b|| 5.076443478402e-01
  6 KSP unpreconditioned resid norm 1.173350897701e-07 true resid norm 1.173350897701e-07 ||r(i)||/||b|| 4.784866400357e-01
  7 KSP unpreconditioned resid norm 1.173017401976e-07 true resid norm 1.173017401976e-07 ||r(i)||/||b|| 4.783506421433e-01
  8 KSP unpreconditioned resid norm 1.105615956213e-07 true resid norm 1.105615956213e-07 ||r(i)||/||b|| 4.508646689531e-01
  9 KSP unpreconditioned resid norm 9.643586842608e-08 true resid norm 9.643586842608e-08 ||r(i)||/||b|| 3.932606584485e-01
 10 KSP unpreconditioned resid norm 9.612358457319e-08 true resid norm 9.612358457319e-08 ||r(i)||/||b|| 3.919871804821e-01
 11 KSP unpreconditioned resid norm 8.229327150626e-08 true resid norm 8.229327150626e-08 ||r(i)||/||b|| 3.355878540487e-01
 12 KSP unpreconditioned resid norm 7.938773453245e-08 true resid norm 7.938773453245e-08 ||r(i)||/||b|| 3.237392192812e-01
 13 KSP unpreconditioned resid norm 7.935125220727e-08 true resid norm 7.935125220727e-08 ||r(i)||/||b|| 3.235904461799e-01
 14 KSP unpreconditioned resid norm 7.335324537068e-08 true resid norm 7.335324537068e-08 ||r(i)||/||b|| 2.991308736533e-01
 15 KSP unpreconditioned resid norm 7.197373101672e-08 true resid norm 7.197373101672e-08 ||r(i)||/||b|| 2.935052829677e-01
 16 KSP unpreconditioned resid norm 7.016384861756e-08 true resid norm 7.016384861756e-08 ||r(i)||/||b|| 2.861246728729e-01
 17 KSP unpreconditioned resid norm 5.944871806930e-08 true resid norm 5.944871806929e-08 ||r(i)||/||b|| 2.424289052757e-01
 18 KSP unpreconditioned resid norm 5.922418197663e-08 true resid norm 5.922418197663e-08 ||r(i)||/||b|| 2.415132582962e-01
 19 KSP unpreconditioned resid norm 5.614577237297e-08 true resid norm 5.614577237297e-08 ||r(i)||/||b|| 2.289596575720e-01
 20 KSP unpreconditioned resid norm 5.543683039338e-08 true resid norm 5.543683039338e-08 ||r(i)||/||b|| 2.260686275616e-01
 21 KSP unpreconditioned resid norm 5.537009509960e-08 true resid norm 5.537009509960e-08 ||r(i)||/||b|| 2.257964843643e-01
 22 KSP unpreconditioned resid norm 5.440757674516e-08 true resid norm 5.440757674516e-08 ||r(i)||/||b|| 2.218713825529e-01
 23 KSP unpreconditioned resid norm 5.262955197017e-08 true resid norm 5.262955197017e-08 ||r(i)||/||b|| 2.146206862595e-01
 24 KSP unpreconditioned resid norm 5.185946887388e-08 true resid norm 5.185946887388e-08 ||r(i)||/||b|| 2.114803258267e-01
 25 KSP unpreconditioned resid norm 4.821365539193e-08 true resid norm 4.821365539193e-08 ||r(i)||/||b|| 1.966128804053e-01
 26 KSP unpreconditioned resid norm 4.809210785109e-08 true resid norm 4.809210785109e-08 ||r(i)||/||b|| 1.961172156001e-01
 27 KSP unpreconditioned resid norm 4.785689974287e-08 true resid norm 4.785689974287e-08 ||r(i)||/||b|| 1.951580486737e-01
 28 KSP unpreconditioned resid norm 4.699105156134e-08 true resid norm 4.699105156134e-08 ||r(i)||/||b|| 1.916271630028e-01
 29 KSP unpreconditioned resid norm 4.667740913574e-08 true resid norm 4.667740913574e-08 ||r(i)||/||b|| 1.903481448447e-01
 30 KSP unpreconditioned resid norm 4.495092087718e-08 true resid norm 4.495092087718e-08 ||r(i)||/||b|| 1.833076118931e-01
 31 KSP unpreconditioned resid norm 4.485095979916e-08 true resid norm 4.485095979916e-08 ||r(i)||/||b|| 1.828999756059e-01
 32 KSP unpreconditioned resid norm 4.433072229482e-08 true resid norm 4.433072229482e-08 ||r(i)||/||b|| 1.807784730276e-01
 33 KSP unpreconditioned resid norm 4.381505863646e-08 true resid norm 4.381505863646e-08 ||r(i)||/||b|| 1.786756223650e-01
 34 KSP unpreconditioned resid norm 4.367664103883e-08 true resid norm 4.367664103883e-08 ||r(i)||/||b|| 1.781111623101e-01
 35 KSP unpreconditioned resid norm 4.341427566282e-08 true resid norm 4.341427566282e-08 ||r(i)||/||b|| 1.770412494010e-01
 36 KSP unpreconditioned resid norm 4.330641141605e-08 true resid norm 4.330641141605e-08 ||r(i)||/||b|| 1.766013843861e-01
 37 KSP unpreconditioned resid norm 4.318853001779e-08 true resid norm 4.318853001779e-08 ||r(i)||/||b|| 1.761206699273e-01
 38 KSP unpreconditioned resid norm 4.250324334124e-08 true resid norm 4.250324334124e-08 ||r(i)||/||b|| 1.733261050621e-01
 39 KSP unpreconditioned resid norm 4.232592940157e-08 true resid norm 4.232592940157e-08 ||r(i)||/||b|| 1.726030276656e-01
 40 KSP unpreconditioned resid norm 4.223089367169e-08 true resid norm 4.223089367169e-08 ||r(i)||/||b|| 1.722154767023e-01
 41 KSP unpreconditioned resid norm 4.186456912966e-08 true resid norm 4.186456912966e-08 ||r(i)||/||b|| 1.707216235027e-01
 42 KSP unpreconditioned resid norm 4.179398678087e-08 true resid norm 4.179398678087e-08 ||r(i)||/||b|| 1.704337922070e-01
 43 KSP unpreconditioned resid norm 4.167238168835e-08 true resid norm 4.167238168835e-08 ||r(i)||/||b|| 1.699378927089e-01
 44 KSP unpreconditioned resid norm 4.090901142391e-08 true resid norm 4.090901142391e-08 ||r(i)||/||b|| 1.668249068693e-01
 45 KSP unpreconditioned resid norm 3.975611201184e-08 true resid norm 3.975611201184e-08 ||r(i)||/||b|| 1.621234406067e-01
 46 KSP unpreconditioned resid norm 3.924101286981e-08 true resid norm 3.924101286981e-08 ||r(i)||/||b|| 1.600228920134e-01
 47 KSP unpreconditioned resid norm 3.521904644775e-08 true resid norm 3.521904644775e-08 ||r(i)||/||b|| 1.436215136756e-01
 48 KSP unpreconditioned resid norm 3.498324602837e-08 true resid norm 3.498324602837e-08 ||r(i)||/||b|| 1.426599313338e-01
 49 KSP unpreconditioned resid norm 3.459067870011e-08 true resid norm 3.459067870011e-08 ||r(i)||/||b|| 1.410590613617e-01
 50 KSP unpreconditioned resid norm 3.399462215977e-08 true resid norm 3.399462215977e-08 ||r(i)||/||b|| 1.386283725387e-01
 51 KSP unpreconditioned resid norm 3.399430398445e-08 true resid norm 3.399430398445e-08 ||r(i)||/||b|| 1.386270750356e-01
 52 KSP unpreconditioned resid norm 3.346869309028e-08 true resid norm 3.346869309028e-08 ||r(i)||/||b|| 1.364836600417e-01
 53 KSP unpreconditioned resid norm 3.138744643238e-08 true resid norm 3.138744643238e-08 ||r(i)||/||b|| 1.279964400432e-01
 54 KSP unpreconditioned resid norm 3.128257969232e-08 true resid norm 3.128257969232e-08 ||r(i)||/||b|| 1.275687987110e-01
 55 KSP unpreconditioned resid norm 2.821479391120e-08 true resid norm 2.821479391120e-08 ||r(i)||/||b|| 1.150585214050e-01
 56 KSP unpreconditioned resid norm 2.564797554339e-08 true resid norm 2.564797554339e-08 ||r(i)||/||b|| 1.045911642077e-01
 57 KSP unpreconditioned resid norm 2.504481002459e-08 true resid norm 2.504481002459e-08 ||r(i)||/||b|| 1.021314853253e-01
 58 KSP unpreconditioned resid norm 2.242451149879e-08 true resid norm 2.242451149879e-08 ||r(i)||/||b|| 9.144603871285e-02
 59 KSP unpreconditioned resid norm 2.093393512438e-08 true resid norm 2.093393512438e-08 ||r(i)||/||b|| 8.536754265081e-02
 60 KSP unpreconditioned resid norm 2.047371164412e-08 true resid norm 2.047371164412e-08 ||r(i)||/||b|| 8.349077426749e-02
 61 KSP unpreconditioned resid norm 2.017207880642e-08 true resid norm 2.017207880642e-08 ||r(i)||/||b|| 8.226073060948e-02
 62 KSP unpreconditioned resid norm 1.996642911112e-08 true resid norm 1.996642911112e-08 ||r(i)||/||b|| 8.142210141575e-02
 63 KSP unpreconditioned resid norm 1.949671274709e-08 true resid norm 1.949671274709e-08 ||r(i)||/||b|| 7.950662152618e-02
 64 KSP unpreconditioned resid norm 1.908868151489e-08 true resid norm 1.908868151489e-08 ||r(i)||/||b|| 7.784269052561e-02
 65 KSP unpreconditioned resid norm 1.835547412807e-08 true resid norm 1.835547412807e-08 ||r(i)||/||b|| 7.485270739562e-02
 66 KSP unpreconditioned resid norm 1.699752112694e-08 true resid norm 1.699752112694e-08 ||r(i)||/||b|| 6.931504283073e-02
 67 KSP unpreconditioned resid norm 1.699326819014e-08 true resid norm 1.699326819014e-08 ||r(i)||/||b|| 6.929769956673e-02
 68 KSP unpreconditioned resid norm 1.676964398385e-08 true resid norm 1.676964398385e-08 ||r(i)||/||b|| 6.838577121428e-02
 69 KSP unpreconditioned resid norm 1.668869881419e-08 true resid norm 1.668869881419e-08 ||r(i)||/||b|| 6.805568085228e-02
 70 KSP unpreconditioned resid norm 1.667200369803e-08 true resid norm 1.667200369803e-08 ||r(i)||/||b|| 6.798759900182e-02
 71 KSP unpreconditioned resid norm 1.656208779511e-08 true resid norm 1.656208779511e-08 ||r(i)||/||b|| 6.753936743546e-02
 72 KSP unpreconditioned resid norm 1.626050460200e-08 true resid norm 1.626050460200e-08 ||r(i)||/||b|| 6.630952622560e-02
 73 KSP unpreconditioned resid norm 1.624495256069e-08 true resid norm 1.624495256069e-08 ||r(i)||/||b|| 6.624610577731e-02
 74 KSP unpreconditioned resid norm 1.580439129234e-08 true resid norm 1.580439129234e-08 ||r(i)||/||b|| 6.444951891286e-02
 75 KSP unpreconditioned resid norm 1.528210351844e-08 true resid norm 1.528210351844e-08 ||r(i)||/||b|| 6.231965543763e-02
 76 KSP unpreconditioned resid norm 1.521637918567e-08 true resid norm 1.521637918567e-08 ||r(i)||/||b|| 6.205163488878e-02
 77 KSP unpreconditioned resid norm 1.510418394672e-08 true resid norm 1.510418394672e-08 ||r(i)||/||b|| 6.159410830387e-02
 78 KSP unpreconditioned resid norm 1.448733751222e-08 true resid norm 1.448733751222e-08 ||r(i)||/||b|| 5.907863933003e-02
 79 KSP unpreconditioned resid norm 1.440897586029e-08 true resid norm 1.440897586029e-08 ||r(i)||/||b|| 5.875908442440e-02
 80 KSP unpreconditioned resid norm 1.432288207531e-08 true resid norm 1.432288207531e-08 ||r(i)||/||b|| 5.840799826605e-02
 81 KSP unpreconditioned resid norm 1.397436573103e-08 true resid norm 1.397436573103e-08 ||r(i)||/||b|| 5.698676600810e-02
 82 KSP unpreconditioned resid norm 1.388657061475e-08 true resid norm 1.388657061475e-08 ||r(i)||/||b|| 5.662874190564e-02
 83 KSP unpreconditioned resid norm 1.359722455182e-08 true resid norm 1.359722455182e-08 ||r(i)||/||b|| 5.544880310191e-02
 84 KSP unpreconditioned resid norm 1.265365292676e-08 true resid norm 1.265365292676e-08 ||r(i)||/||b|| 5.160096510739e-02
 85 KSP unpreconditioned resid norm 1.259945408065e-08 true resid norm 1.259945408065e-08 ||r(i)||/||b|| 5.137994491795e-02
 86 KSP unpreconditioned resid norm 1.201823818499e-08 true resid norm 1.201823818499e-08 ||r(i)||/||b|| 4.900977550321e-02
 87 KSP unpreconditioned resid norm 1.189035093877e-08 true resid norm 1.189035093877e-08 ||r(i)||/||b|| 4.848825769583e-02
 88 KSP unpreconditioned resid norm 1.158499778932e-08 true resid norm 1.158499778932e-08 ||r(i)||/||b|| 4.724304279216e-02
 89 KSP unpreconditioned resid norm 1.133107493622e-08 true resid norm 1.133107493622e-08 ||r(i)||/||b|| 4.620755807019e-02
 90 KSP unpreconditioned resid norm 1.125101113680e-08 true resid norm 1.125101113680e-08 ||r(i)||/||b|| 4.588106189205e-02
 91 KSP unpreconditioned resid norm 1.117730224530e-08 true resid norm 1.117730224530e-08 ||r(i)||/||b|| 4.558048071123e-02
 92 KSP unpreconditioned resid norm 1.098216364313e-08 true resid norm 1.098216364313e-08 ||r(i)||/||b|| 4.478471523068e-02
 93 KSP unpreconditioned resid norm 1.081908478633e-08 true resid norm 1.081908478633e-08 ||r(i)||/||b|| 4.411968779173e-02
 94 KSP unpreconditioned resid norm 1.074175388349e-08 true resid norm 1.074175388349e-08 ||r(i)||/||b|| 4.380433622941e-02
 95 KSP unpreconditioned resid norm 1.044866647328e-08 true resid norm 1.044866647328e-08 ||r(i)||/||b|| 4.260914039822e-02
 96 KSP unpreconditioned resid norm 1.043552109077e-08 true resid norm 1.043552109077e-08 ||r(i)||/||b|| 4.255553418443e-02
 97 KSP unpreconditioned resid norm 9.830235360062e-09 true resid norm 9.830235360062e-09 ||r(i)||/||b|| 4.008720918363e-02
 98 KSP unpreconditioned resid norm 9.521119236860e-09 true resid norm 9.521119236860e-09 ||r(i)||/||b|| 3.882664906081e-02
 99 KSP unpreconditioned resid norm 9.520911974750e-09 true resid norm 9.520911974750e-09 ||r(i)||/||b|| 3.882580385628e-02
100 KSP unpreconditioned resid norm 9.376716676094e-09 true resid norm 9.376716676094e-09 ||r(i)||/||b|| 3.823778262496e-02
101 KSP unpreconditioned resid norm 9.206346340775e-09 true resid norm 9.206346340775e-09 ||r(i)||/||b|| 3.754302090050e-02
102 KSP unpreconditioned resid norm 9.147193139051e-09 true resid norm 9.147193139051e-09 ||r(i)||/||b|| 3.730179709613e-02
103 KSP unpreconditioned resid norm 9.056811926003e-09 true resid norm 9.056811926003e-09 ||r(i)||/||b|| 3.693322702013e-02
104 KSP unpreconditioned resid norm 8.936944824040e-09 true resid norm 8.936944824040e-09 ||r(i)||/||b|| 3.644441496075e-02
105 KSP unpreconditioned resid norm 8.934739148676e-09 true resid norm 8.934739148676e-09 ||r(i)||/||b|| 3.643542032669e-02
106 KSP unpreconditioned resid norm 8.850749678925e-09 true resid norm 8.850749678925e-09 ||r(i)||/||b|| 3.609291546086e-02
107 KSP unpreconditioned resid norm 8.679435160414e-09 true resid norm 8.679435160414e-09 ||r(i)||/||b|| 3.539430340446e-02
108 KSP unpreconditioned resid norm 8.657752776426e-09 true resid norm 8.657752776426e-09 ||r(i)||/||b|| 3.530588372470e-02
109 KSP unpreconditioned resid norm 8.514323923495e-09 true resid norm 8.514323923495e-09 ||r(i)||/||b|| 3.472098802080e-02
110 KSP unpreconditioned resid norm 8.281813089698e-09 true resid norm 8.281813089698e-09 ||r(i)||/||b|| 3.377282044490e-02
111 KSP unpreconditioned resid norm 8.256092263525e-09 true resid norm 8.256092263525e-09 ||r(i)||/||b|| 3.366793219946e-02
112 KSP unpreconditioned resid norm 8.249978289270e-09 true resid norm 8.249978289270e-09 ||r(i)||/||b|| 3.364299971759e-02
113 KSP unpreconditioned resid norm 8.018171173819e-09 true resid norm 8.018171173819e-09 ||r(i)||/||b|| 3.269770186998e-02
114 KSP unpreconditioned resid norm 7.989855578933e-09 true resid norm 7.989855578933e-09 ||r(i)||/||b|| 3.258223228724e-02
115 KSP unpreconditioned resid norm 7.459893032882e-09 true resid norm 7.459893032882e-09 ||r(i)||/||b|| 3.042107147420e-02
116 KSP unpreconditioned resid norm 7.202291666167e-09 true resid norm 7.202291666167e-09 ||r(i)||/||b|| 2.937058595730e-02
117 KSP unpreconditioned resid norm 7.170313473198e-09 true resid norm 7.170313473198e-09 ||r(i)||/||b|| 2.924018048236e-02
118 KSP unpreconditioned resid norm 6.972218265192e-09 true resid norm 6.972218265192e-09 ||r(i)||/||b|| 2.843235811080e-02
119 KSP unpreconditioned resid norm 6.635512376660e-09 true resid norm 6.635512376660e-09 ||r(i)||/||b|| 2.705928830193e-02
120 KSP unpreconditioned resid norm 6.549929915762e-09 true resid norm 6.549929915762e-09 ||r(i)||/||b|| 2.671028729770e-02
121 KSP unpreconditioned resid norm 6.470318250528e-09 true resid norm 6.470318250528e-09 ||r(i)||/||b|| 2.638563490020e-02
122 KSP unpreconditioned resid norm 6.241392498551e-09 true resid norm 6.241392498551e-09 ||r(i)||/||b|| 2.545208710903e-02
123 KSP unpreconditioned resid norm 6.128754651656e-09 true resid norm 6.128754651656e-09 ||r(i)||/||b|| 2.499275559101e-02
124 KSP unpreconditioned resid norm 6.110276397128e-09 true resid norm 6.110276397128e-09 ||r(i)||/||b|| 2.491740219127e-02
125 KSP unpreconditioned resid norm 5.954851894569e-09 true resid norm 5.954851894569e-09 ||r(i)||/||b|| 2.428358882688e-02
126 KSP unpreconditioned resid norm 5.797967509678e-09 true resid norm 5.797967509678e-09 ||r(i)||/||b|| 2.364382213519e-02
127 KSP unpreconditioned resid norm 5.767558700754e-09 true resid norm 5.767558700754e-09 ||r(i)||/||b|| 2.351981653007e-02
128 KSP unpreconditioned resid norm 5.639121572750e-09 true resid norm 5.639121572750e-09 ||r(i)||/||b|| 2.299605633220e-02
129 KSP unpreconditioned resid norm 5.624366897720e-09 true resid norm 5.624366897720e-09 ||r(i)||/||b|| 2.293588750381e-02
130 KSP unpreconditioned resid norm 5.608499860222e-09 true resid norm 5.608499860222e-09 ||r(i)||/||b|| 2.287118251681e-02
131 KSP unpreconditioned resid norm 5.303626608640e-09 true resid norm 5.303626608640e-09 ||r(i)||/||b|| 2.162792461269e-02
132 KSP unpreconditioned resid norm 5.207681722116e-09 true resid norm 5.207681722116e-09 ||r(i)||/||b|| 2.123666615394e-02
133 KSP unpreconditioned resid norm 5.201502631855e-09 true resid norm 5.201502631855e-09 ||r(i)||/||b|| 2.121146813224e-02
134 KSP unpreconditioned resid norm 5.131488055171e-09 true resid norm 5.131488055171e-09 ||r(i)||/||b|| 2.092595218286e-02
135 KSP unpreconditioned resid norm 4.975360345852e-09 true resid norm 4.975360345852e-09 ||r(i)||/||b|| 2.028927117640e-02
136 KSP unpreconditioned resid norm 4.952631636049e-09 true resid norm 4.952631636048e-09 ||r(i)||/||b|| 2.019658463218e-02
137 KSP unpreconditioned resid norm 4.910518190967e-09 true resid norm 4.910518190967e-09 ||r(i)||/||b|| 2.002484810497e-02
138 KSP unpreconditioned resid norm 4.828869410474e-09 true resid norm 4.828869410474e-09 ||r(i)||/||b|| 1.969188845311e-02
139 KSP unpreconditioned resid norm 4.828706549393e-09 true resid norm 4.828706549393e-09 ||r(i)||/||b|| 1.969122431375e-02
140 KSP unpreconditioned resid norm 4.786379052905e-09 true resid norm 4.786379052905e-09 ||r(i)||/||b|| 1.951861489558e-02
141 KSP unpreconditioned resid norm 4.681977202199e-09 true resid norm 4.681977202199e-09 ||r(i)||/||b|| 1.909286935897e-02
142 KSP unpreconditioned resid norm 4.662789271598e-09 true resid norm 4.662789271598e-09 ||r(i)||/||b|| 1.901462193562e-02
143 KSP unpreconditioned resid norm 4.522398642038e-09 true resid norm 4.522398642038e-09 ||r(i)||/||b|| 1.844211595500e-02
144 KSP unpreconditioned resid norm 4.274697680856e-09 true resid norm 4.274697680855e-09 ||r(i)||/||b|| 1.743200379774e-02
145 KSP unpreconditioned resid norm 4.265555182135e-09 true resid norm 4.265555182135e-09 ||r(i)||/||b|| 1.739472114425e-02
146 KSP unpreconditioned resid norm 4.207412975160e-09 true resid norm 4.207412975160e-09 ||r(i)||/||b|| 1.715762012601e-02
147 KSP unpreconditioned resid norm 4.154016179231e-09 true resid norm 4.154016179231e-09 ||r(i)||/||b|| 1.693987065718e-02
148 KSP unpreconditioned resid norm 4.131742489350e-09 true resid norm 4.131742489350e-09 ||r(i)||/||b|| 1.684903966149e-02
149 KSP unpreconditioned resid norm 4.043172138715e-09 true resid norm 4.043172138715e-09 ||r(i)||/||b|| 1.648785419204e-02
150 KSP unpreconditioned resid norm 3.939168395943e-09 true resid norm 3.939168395943e-09 ||r(i)||/||b|| 1.606373211971e-02
151 KSP unpreconditioned resid norm 3.857606362584e-09 true resid norm 3.857606362584e-09 ||r(i)||/||b|| 1.573112621833e-02
152 KSP unpreconditioned resid norm 3.793151011702e-09 true resid norm 3.793151011702e-09 ||r(i)||/||b|| 1.546828051432e-02
153 KSP unpreconditioned resid norm 3.771214716922e-09 true resid norm 3.771214716922e-09 ||r(i)||/||b|| 1.537882539902e-02
154 KSP unpreconditioned resid norm 3.744927773353e-09 true resid norm 3.744927773353e-09 ||r(i)||/||b|| 1.527162855509e-02
155 KSP unpreconditioned resid norm 3.699554989589e-09 true resid norm 3.699554989589e-09 ||r(i)||/||b|| 1.508660060740e-02
156 KSP unpreconditioned resid norm 3.699553806166e-09 true resid norm 3.699553806166e-09 ||r(i)||/||b|| 1.508659578146e-02
157 KSP unpreconditioned resid norm 3.578721024518e-09 true resid norm 3.578721024518e-09 ||r(i)||/||b|| 1.459384572851e-02
158 KSP unpreconditioned resid norm 3.468771260320e-09 true resid norm 3.468771260320e-09 ||r(i)||/||b|| 1.414547607757e-02
159 KSP unpreconditioned resid norm 3.467025485554e-09 true resid norm 3.467025485554e-09 ||r(i)||/||b|| 1.413835689520e-02
160 KSP unpreconditioned resid norm 3.400003173641e-09 true resid norm 3.400003173641e-09 ||r(i)||/||b|| 1.386504325222e-02
161 KSP unpreconditioned resid norm 3.357061147998e-09 true resid norm 3.357061147998e-09 ||r(i)||/||b|| 1.368992781483e-02
162 KSP unpreconditioned resid norm 3.356049647642e-09 true resid norm 3.356049647642e-09 ||r(i)||/||b|| 1.368580296686e-02
163 KSP unpreconditioned resid norm 3.284283436860e-09 true resid norm 3.284283436860e-09 ||r(i)||/||b|| 1.339314394105e-02
164 KSP unpreconditioned resid norm 3.236517913866e-09 true resid norm 3.236517913866e-09 ||r(i)||/||b|| 1.319835852220e-02
165 KSP unpreconditioned resid norm 3.226209835937e-09 true resid norm 3.226209835937e-09 ||r(i)||/||b|| 1.315632269487e-02
166 KSP unpreconditioned resid norm 3.153468551104e-09 true resid norm 3.153468551104e-09 ||r(i)||/||b|| 1.285968736575e-02
167 KSP unpreconditioned resid norm 3.090746655863e-09 true resid norm 3.090746655863e-09 ||r(i)||/||b|| 1.260391060733e-02
168 KSP unpreconditioned resid norm 3.066178249083e-09 true resid norm 3.066178249083e-09 ||r(i)||/||b|| 1.250372187065e-02
169 KSP unpreconditioned resid norm 3.030296737504e-09 true resid norm 3.030296737504e-09 ||r(i)||/||b|| 1.235739885724e-02
170 KSP unpreconditioned resid norm 2.920555814502e-09 true resid norm 2.920555814502e-09 ||r(i)||/||b|| 1.190988085027e-02
171 KSP unpreconditioned resid norm 2.919920023392e-09 true resid norm 2.919920023392e-09 ||r(i)||/||b|| 1.190728812585e-02
172 KSP unpreconditioned resid norm 2.899203585400e-09 true resid norm 2.899203585400e-09 ||r(i)||/||b|| 1.182280752565e-02
173 KSP unpreconditioned resid norm 2.853525738559e-09 true resid norm 2.853525738559e-09 ||r(i)||/||b|| 1.163653554596e-02
174 KSP unpreconditioned resid norm 2.848599432980e-09 true resid norm 2.848599432980e-09 ||r(i)||/||b|| 1.161644631767e-02
175 KSP unpreconditioned resid norm 2.670567714904e-09 true resid norm 2.670567714905e-09 ||r(i)||/||b|| 1.089044185670e-02
176 KSP unpreconditioned resid norm 2.574460860036e-09 true resid norm 2.574460860036e-09 ||r(i)||/||b|| 1.049852289912e-02
177 KSP unpreconditioned resid norm 2.566251090751e-09 true resid norm 2.566251090751e-09 ||r(i)||/||b|| 1.046504386972e-02
178 KSP unpreconditioned resid norm 2.521090771205e-09 true resid norm 2.521090771205e-09 ||r(i)||/||b|| 1.028088234050e-02
179 KSP unpreconditioned resid norm 2.483916357622e-09 true resid norm 2.483916357622e-09 ||r(i)||/||b|| 1.012928693724e-02
180 KSP unpreconditioned resid norm 2.421953972199e-09 true resid norm 2.421953972199e-09 ||r(i)||/||b|| 9.876607421949e-03
181 KSP unpreconditioned resid norm 2.373332058238e-09 true resid norm 2.373332058238e-09 ||r(i)||/||b|| 9.678329683472e-03
182 KSP unpreconditioned resid norm 2.362195619604e-09 true resid norm 2.362195619604e-09 ||r(i)||/||b|| 9.632915842531e-03
183 KSP unpreconditioned resid norm 2.321212697334e-09 true resid norm 2.321212697334e-09 ||r(i)||/||b|| 9.465789530918e-03
184 KSP unpreconditioned resid norm 2.269721903308e-09 true resid norm 2.269721903308e-09 ||r(i)||/||b|| 9.255812642721e-03
185 KSP unpreconditioned resid norm 2.179999635151e-09 true resid norm 2.179999635151e-09 ||r(i)||/||b|| 8.889929711103e-03
186 KSP unpreconditioned resid norm 2.048752349177e-09 true resid norm 2.048752349178e-09 ||r(i)||/||b|| 8.354709829290e-03
187 KSP unpreconditioned resid norm 2.046743929968e-09 true resid norm 2.046743929968e-09 ||r(i)||/||b|| 8.346519595991e-03
188 KSP unpreconditioned resid norm 2.036272520522e-09 true resid norm 2.036272520522e-09 ||r(i)||/||b|| 8.303817710886e-03
189 KSP unpreconditioned resid norm 1.994115099266e-09 true resid norm 1.994115099266e-09 ||r(i)||/||b|| 8.131901851029e-03
190 KSP unpreconditioned resid norm 1.977275642988e-09 true resid norm 1.977275642988e-09 ||r(i)||/||b|| 8.063231388764e-03
191 KSP unpreconditioned resid norm 1.955324293191e-09 true resid norm 1.955324293191e-09 ||r(i)||/||b|| 7.973714879855e-03
192 KSP unpreconditioned resid norm 1.935585651100e-09 true resid norm 1.935585651100e-09 ||r(i)||/||b|| 7.893221682537e-03
193 KSP unpreconditioned resid norm 1.934506635159e-09 true resid norm 1.934506635159e-09 ||r(i)||/||b|| 7.888821509382e-03
194 KSP unpreconditioned resid norm 1.922907675017e-09 true resid norm 1.922907675017e-09 ||r(i)||/||b|| 7.841521528814e-03
195 KSP unpreconditioned resid norm 1.824598688118e-09 true resid norm 1.824598688118e-09 ||r(i)||/||b|| 7.440622386716e-03
196 KSP unpreconditioned resid norm 1.817944587173e-09 true resid norm 1.817944587173e-09 ||r(i)||/||b|| 7.413487295162e-03
197 KSP unpreconditioned resid norm 1.807090795128e-09 true resid norm 1.807090795128e-09 ||r(i)||/||b|| 7.369226072902e-03
198 KSP unpreconditioned resid norm 1.753669753179e-09 true resid norm 1.753669753179e-09 ||r(i)||/||b|| 7.151377730010e-03
199 KSP unpreconditioned resid norm 1.710838452332e-09 true resid norm 1.710838452332e-09 ||r(i)||/||b|| 6.976713822811e-03
200 KSP unpreconditioned resid norm 1.710770440488e-09 true resid norm 1.710770440488e-09 ||r(i)||/||b|| 6.976436473905e-03
201 KSP unpreconditioned resid norm 1.670865227850e-09 true resid norm 1.670865227850e-09 ||r(i)||/||b|| 6.813705008389e-03
202 KSP unpreconditioned resid norm 1.665513805615e-09 true resid norm 1.665513805615e-09 ||r(i)||/||b|| 6.791882175596e-03
203 KSP unpreconditioned resid norm 1.639873964672e-09 true resid norm 1.639873964672e-09 ||r(i)||/||b|| 6.687324183885e-03
204 KSP unpreconditioned resid norm 1.589069902779e-09 true resid norm 1.589069902779e-09 ||r(i)||/||b|| 6.480147755050e-03
205 KSP unpreconditioned resid norm 1.588252119589e-09 true resid norm 1.588252119589e-09 ||r(i)||/||b|| 6.476812876016e-03
206 KSP unpreconditioned resid norm 1.567411584020e-09 true resid norm 1.567411584020e-09 ||r(i)||/||b|| 6.391826212090e-03
207 KSP unpreconditioned resid norm 1.495962924807e-09 true resid norm 1.495962924807e-09 ||r(i)||/||b|| 6.100462145733e-03
208 KSP unpreconditioned resid norm 1.495926920942e-09 true resid norm 1.495926920942e-09 ||r(i)||/||b|| 6.100315323768e-03
209 KSP unpreconditioned resid norm 1.407870398173e-09 true resid norm 1.407870398173e-09 ||r(i)||/||b|| 5.741225218707e-03
210 KSP unpreconditioned resid norm 1.396979823489e-09 true resid norm 1.396979823489e-09 ||r(i)||/||b|| 5.696813998679e-03
211 KSP unpreconditioned resid norm 1.385830225181e-09 true resid norm 1.385830225181e-09 ||r(i)||/||b|| 5.651346493244e-03
212 KSP unpreconditioned resid norm 1.330892709317e-09 true resid norm 1.330892709317e-09 ||r(i)||/||b|| 5.427314045413e-03
213 KSP unpreconditioned resid norm 1.328397746461e-09 true resid norm 1.328397746461e-09 ||r(i)||/||b|| 5.417139711405e-03
214 KSP unpreconditioned resid norm 1.306080253239e-09 true resid norm 1.306080253239e-09 ||r(i)||/||b|| 5.326130087883e-03
215 KSP unpreconditioned resid norm 1.240539718062e-09 true resid norm 1.240539718062e-09 ||r(i)||/||b|| 5.058859056478e-03
216 KSP unpreconditioned resid norm 1.240539252753e-09 true resid norm 1.240539252753e-09 ||r(i)||/||b|| 5.058857158970e-03
217 KSP unpreconditioned resid norm 1.196342468783e-09 true resid norm 1.196342468783e-09 ||r(i)||/||b|| 4.878624879746e-03
218 KSP unpreconditioned resid norm 1.183315169922e-09 true resid norm 1.183315169922e-09 ||r(i)||/||b|| 4.825500205169e-03
219 KSP unpreconditioned resid norm 1.183257111912e-09 true resid norm 1.183257111912e-09 ||r(i)||/||b|| 4.825263447502e-03
220 KSP unpreconditioned resid norm 1.158502689777e-09 true resid norm 1.158502689777e-09 ||r(i)||/||b|| 4.724316149496e-03
221 KSP unpreconditioned resid norm 1.141467176795e-09 true resid norm 1.141467176795e-09 ||r(i)||/||b|| 4.654846177776e-03
222 KSP unpreconditioned resid norm 1.125380759183e-09 true resid norm 1.125380759183e-09 ||r(i)||/||b|| 4.589246569608e-03
223 KSP unpreconditioned resid norm 1.049751865544e-09 true resid norm 1.049751865544e-09 ||r(i)||/||b|| 4.280835715890e-03
224 KSP unpreconditioned resid norm 1.038873206649e-09 true resid norm 1.038873206649e-09 ||r(i)||/||b|| 4.236473087857e-03
225 KSP unpreconditioned resid norm 1.037106322062e-09 true resid norm 1.037106322062e-09 ||r(i)||/||b|| 4.229267820694e-03
226 KSP unpreconditioned resid norm 1.023165629117e-09 true resid norm 1.023165629117e-09 ||r(i)||/||b|| 4.172418370629e-03
227 KSP unpreconditioned resid norm 1.012513033752e-09 true resid norm 1.012513033752e-09 ||r(i)||/||b|| 4.128977618385e-03
228 KSP unpreconditioned resid norm 1.011709961023e-09 true resid norm 1.011709961023e-09 ||r(i)||/||b|| 4.125702727880e-03
229 KSP unpreconditioned resid norm 1.000890151107e-09 true resid norm 1.000890151107e-09 ||r(i)||/||b|| 4.081580083044e-03
230 KSP unpreconditioned resid norm 9.932322546904e-10 true resid norm 9.932322546904e-10 ||r(i)||/||b|| 4.050351563654e-03
231 KSP unpreconditioned resid norm 9.815667443562e-10 true resid norm 9.815667443562e-10 ||r(i)||/||b|| 4.002780194722e-03
232 KSP unpreconditioned resid norm 9.700314124060e-10 true resid norm 9.700314124060e-10 ||r(i)||/||b|| 3.955739686743e-03
233 KSP unpreconditioned resid norm 9.574610866687e-10 true resid norm 9.574610866687e-10 ||r(i)||/||b|| 3.904478525755e-03
234 KSP unpreconditioned resid norm 9.280928856868e-10 true resid norm 9.280928856868e-10 ||r(i)||/||b|| 3.784716467881e-03
235 KSP unpreconditioned resid norm 9.010773908713e-10 true resid norm 9.010773908713e-10 ||r(i)||/||b|| 3.674548628333e-03
236 KSP unpreconditioned resid norm 8.803465259674e-10 true resid norm 8.803465259674e-10 ||r(i)||/||b|| 3.590009195906e-03
237 KSP unpreconditioned resid norm 8.798665240877e-10 true resid norm 8.798665240877e-10 ||r(i)||/||b|| 3.588051772197e-03
238 KSP unpreconditioned resid norm 8.400926267700e-10 true resid norm 8.400926267700e-10 ||r(i)||/||b|| 3.425855804001e-03
239 KSP unpreconditioned resid norm 8.373642559707e-10 true resid norm 8.373642559707e-10 ||r(i)||/||b|| 3.414729644051e-03
240 KSP unpreconditioned resid norm 7.987805643411e-10 true resid norm 7.987805643411e-10 ||r(i)||/||b|| 3.257387275249e-03
241 KSP unpreconditioned resid norm 7.781091552377e-10 true resid norm 7.781091552377e-10 ||r(i)||/||b|| 3.173090300609e-03
242 KSP unpreconditioned resid norm 7.781050658407e-10 true resid norm 7.781050658407e-10 ||r(i)||/||b|| 3.173073624252e-03
243 KSP unpreconditioned resid norm 7.445999948358e-10 true resid norm 7.445999948358e-10 ||r(i)||/||b|| 3.036441616890e-03
244 KSP unpreconditioned resid norm 7.441159890920e-10 true resid norm 7.441159890920e-10 ||r(i)||/||b|| 3.034467865623e-03
245 KSP unpreconditioned resid norm 7.163771304103e-10 true resid norm 7.163771304103e-10 ||r(i)||/||b|| 2.921350184331e-03
246 KSP unpreconditioned resid norm 7.085036867050e-10 true resid norm 7.085036867050e-10 ||r(i)||/||b|| 2.889242673854e-03
247 KSP unpreconditioned resid norm 7.083620085774e-10 true resid norm 7.083620085774e-10 ||r(i)||/||b|| 2.888664917521e-03
248 KSP unpreconditioned resid norm 6.947432439294e-10 true resid norm 6.947432439294e-10 ||r(i)||/||b|| 2.833128274982e-03
249 KSP unpreconditioned resid norm 6.823952950716e-10 true resid norm 6.823952950716e-10 ||r(i)||/||b|| 2.782773955810e-03
250 KSP unpreconditioned resid norm 6.796826154377e-10 true resid norm 6.796826154377e-10 ||r(i)||/||b|| 2.771711783649e-03
251 KSP unpreconditioned resid norm 6.718040441435e-10 true resid norm 6.718040441435e-10 ||r(i)||/||b|| 2.739583363121e-03
252 KSP unpreconditioned resid norm 6.686245721995e-10 true resid norm 6.686245721995e-10 ||r(i)||/||b|| 2.726617635217e-03
253 KSP unpreconditioned resid norm 6.683255976770e-10 true resid norm 6.683255976770e-10 ||r(i)||/||b|| 2.725398432036e-03
254 KSP unpreconditioned resid norm 6.424717983573e-10 true resid norm 6.424717983573e-10 ||r(i)||/||b|| 2.619967928741e-03
255 KSP unpreconditioned resid norm 6.249393762433e-10 true resid norm 6.249393762433e-10 ||r(i)||/||b|| 2.548471586381e-03
256 KSP unpreconditioned resid norm 6.241944596833e-10 true resid norm 6.241944596833e-10 ||r(i)||/||b|| 2.545433853827e-03
257 KSP unpreconditioned resid norm 6.187343723218e-10 true resid norm 6.187343723218e-10 ||r(i)||/||b|| 2.523167890073e-03
258 KSP unpreconditioned resid norm 6.070150446634e-10 true resid norm 6.070150446634e-10 ||r(i)||/||b|| 2.475377056779e-03
259 KSP unpreconditioned resid norm 6.050327025112e-10 true resid norm 6.050327025112e-10 ||r(i)||/||b|| 2.467293164419e-03
260 KSP unpreconditioned resid norm 5.863857468676e-10 true resid norm 5.863857468677e-10 ||r(i)||/||b|| 2.391251809950e-03
261 KSP unpreconditioned resid norm 5.800609942453e-10 true resid norm 5.800609942453e-10 ||r(i)||/||b|| 2.365459784417e-03
262 KSP unpreconditioned resid norm 5.635375866246e-10 true resid norm 5.635375866246e-10 ||r(i)||/||b|| 2.298078152802e-03
263 KSP unpreconditioned resid norm 5.425626596200e-10 true resid norm 5.425626596200e-10 ||r(i)||/||b|| 2.212543447310e-03
264 KSP unpreconditioned resid norm 5.351709834533e-10 true resid norm 5.351709834533e-10 ||r(i)||/||b|| 2.182400560811e-03
265 KSP unpreconditioned resid norm 5.350898708340e-10 true resid norm 5.350898708340e-10 ||r(i)||/||b|| 2.182069787598e-03
266 KSP unpreconditioned resid norm 5.132862441853e-10 true resid norm 5.132862441853e-10 ||r(i)||/||b|| 2.093155686316e-03
267 KSP unpreconditioned resid norm 5.124896691838e-10 true resid norm 5.124896691838e-10 ||r(i)||/||b|| 2.089907293216e-03
268 KSP unpreconditioned resid norm 5.037801763816e-10 true resid norm 5.037801763816e-10 ||r(i)||/||b|| 2.054390416248e-03
269 KSP unpreconditioned resid norm 4.925535549039e-10 true resid norm 4.925535549040e-10 ||r(i)||/||b|| 2.008608814169e-03
270 KSP unpreconditioned resid norm 4.898675799887e-10 true resid norm 4.898675799887e-10 ||r(i)||/||b|| 1.997655542518e-03
271 KSP unpreconditioned resid norm 4.875059607231e-10 true resid norm 4.875059607231e-10 ||r(i)||/||b|| 1.988024977019e-03
272 KSP unpreconditioned resid norm 4.837449656585e-10 true resid norm 4.837449656585e-10 ||r(i)||/||b|| 1.972687826852e-03
273 KSP unpreconditioned resid norm 4.720657497394e-10 true resid norm 4.720657497394e-10 ||r(i)||/||b|| 1.925060567229e-03
274 KSP unpreconditioned resid norm 4.715724551130e-10 true resid norm 4.715724551130e-10 ||r(i)||/||b|| 1.923048936362e-03
275 KSP unpreconditioned resid norm 4.556552568181e-10 true resid norm 4.556552568181e-10 ||r(i)||/||b|| 1.858139396123e-03
276 KSP unpreconditioned resid norm 4.546658619224e-10 true resid norm 4.546658619224e-10 ||r(i)||/||b|| 1.854104693118e-03
277 KSP unpreconditioned resid norm 4.492436702595e-10 true resid norm 4.492436702595e-10 ||r(i)||/||b|| 1.831993266131e-03
278 KSP unpreconditioned resid norm 4.374310091973e-10 true resid norm 4.374310091973e-10 ||r(i)||/||b|| 1.783821823874e-03
279 KSP unpreconditioned resid norm 4.303070397063e-10 true resid norm 4.303070397063e-10 ||r(i)||/||b|| 1.754770631839e-03
280 KSP unpreconditioned resid norm 4.302972725838e-10 true resid norm 4.302972725838e-10 ||r(i)||/||b|| 1.754730802001e-03
281 KSP unpreconditioned resid norm 4.125645901087e-10 true resid norm 4.125645901087e-10 ||r(i)||/||b|| 1.682417807883e-03
282 KSP unpreconditioned resid norm 4.103036443391e-10 true resid norm 4.103036443391e-10 ||r(i)||/||b|| 1.673197783875e-03
283 KSP unpreconditioned resid norm 3.929667750546e-10 true resid norm 3.929667750546e-10 ||r(i)||/||b|| 1.602498896195e-03
284 KSP unpreconditioned resid norm 3.873776455578e-10 true resid norm 3.873776455578e-10 ||r(i)||/||b|| 1.579706705053e-03
285 KSP unpreconditioned resid norm 3.872816271266e-10 true resid norm 3.872816271266e-10 ||r(i)||/||b|| 1.579315146683e-03
286 KSP unpreconditioned resid norm 3.830696799350e-10 true resid norm 3.830696799350e-10 ||r(i)||/||b|| 1.562139036248e-03
287 KSP unpreconditioned resid norm 3.696542291520e-10 true resid norm 3.696542291520e-10 ||r(i)||/||b|| 1.507431497504e-03
288 KSP unpreconditioned resid norm 3.641272853703e-10 true resid norm 3.641272853703e-10 ||r(i)||/||b|| 1.484892896605e-03
289 KSP unpreconditioned resid norm 3.635260937116e-10 true resid norm 3.635260937116e-10 ||r(i)||/||b|| 1.482441267025e-03
290 KSP unpreconditioned resid norm 3.587436182869e-10 true resid norm 3.587436182869e-10 ||r(i)||/||b|| 1.462938570931e-03
291 KSP unpreconditioned resid norm 3.584310825884e-10 true resid norm 3.584310825884e-10 ||r(i)||/||b|| 1.461664065951e-03
292 KSP unpreconditioned resid norm 3.573721244021e-10 true resid norm 3.573721244021e-10 ||r(i)||/||b|| 1.457345687318e-03
293 KSP unpreconditioned resid norm 3.468100005226e-10 true resid norm 3.468100005226e-10 ||r(i)||/||b|| 1.414273873280e-03
294 KSP unpreconditioned resid norm 3.457583459976e-10 true resid norm 3.457583459976e-10 ||r(i)||/||b|| 1.409985278613e-03
295 KSP unpreconditioned resid norm 3.387076173157e-10 true resid norm 3.387076173157e-10 ||r(i)||/||b|| 1.381232758942e-03
296 KSP unpreconditioned resid norm 3.324320252350e-10 true resid norm 3.324320252350e-10 ||r(i)||/||b|| 1.355641207643e-03
297 KSP unpreconditioned resid norm 3.320316935344e-10 true resid norm 3.320316935344e-10 ||r(i)||/||b|| 1.354008674949e-03
298 KSP unpreconditioned resid norm 3.199433868021e-10 true resid norm 3.199433868021e-10 ||r(i)||/||b|| 1.304713163407e-03
299 KSP unpreconditioned resid norm 3.186963397244e-10 true resid norm 3.186963397244e-10 ||r(i)||/||b|| 1.299627767662e-03
300 KSP unpreconditioned resid norm 3.038254414015e-10 true resid norm 3.038254414015e-10 ||r(i)||/||b|| 1.238984986489e-03
301 KSP unpreconditioned resid norm 2.957613786677e-10 true resid norm 2.957613786677e-10 ||r(i)||/||b|| 1.206100141128e-03
302 KSP unpreconditioned resid norm 2.948798167727e-10 true resid norm 2.948798167727e-10 ||r(i)||/||b|| 1.202505175718e-03
303 KSP unpreconditioned resid norm 2.871808272344e-10 true resid norm 2.871808272344e-10 ||r(i)||/||b|| 1.171109080627e-03
304 KSP unpreconditioned resid norm 2.833844512083e-10 true resid norm 2.833844512083e-10 ||r(i)||/||b|| 1.155627648665e-03
305 KSP unpreconditioned resid norm 2.774102056635e-10 true resid norm 2.774102056635e-10 ||r(i)||/||b|| 1.131264973501e-03
306 KSP unpreconditioned resid norm 2.700213061379e-10 true resid norm 2.700213061379e-10 ||r(i)||/||b|| 1.101133410006e-03
307 KSP unpreconditioned resid norm 2.695724613761e-10 true resid norm 2.695724613761e-10 ||r(i)||/||b|| 1.099303043469e-03
308 KSP unpreconditioned resid norm 2.664577097467e-10 true resid norm 2.664577097467e-10 ||r(i)||/||b|| 1.086601241778e-03
309 KSP unpreconditioned resid norm 2.551357253957e-10 true resid norm 2.551357253957e-10 ||r(i)||/||b|| 1.040430754660e-03
310 KSP unpreconditioned resid norm 2.551346590051e-10 true resid norm 2.551346590051e-10 ||r(i)||/||b|| 1.040426405972e-03
311 KSP unpreconditioned resid norm 2.519231006984e-10 true resid norm 2.519231006984e-10 ||r(i)||/||b|| 1.027329831482e-03
312 KSP unpreconditioned resid norm 2.493737722590e-10 true resid norm 2.493737722590e-10 ||r(i)||/||b|| 1.016933797340e-03
313 KSP unpreconditioned resid norm 2.481881884201e-10 true resid norm 2.481881884201e-10 ||r(i)||/||b|| 1.012099045617e-03
314 KSP unpreconditioned resid norm 2.442954977149e-10 true resid norm 2.442954977149e-10 ||r(i)||/||b|| 9.962248471999e-04
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./hit on a interlagos-64idx-pgi-opt named nid24651 with 128 processors, by Unknown Mon Sep 30 12:07:56 2013
Using Petsc Release Version 3.4.2, Jul, 02, 2013
                         Max       Max/Min        Avg      Total
Time (sec):           5.495e+01      1.00032   5.494e+01
Objects:              2.012e+03      1.00000   2.012e+03
Flops:                7.393e+09      1.00000   7.393e+09  9.463e+11
Flops/sec:            1.346e+08      1.00032   1.346e+08  1.723e+10
MPI Messages:         2.139e+05      1.00000   2.139e+05  2.738e+07
MPI Message Lengths:  4.189e+08      1.00000   1.958e+03  5.361e+10
MPI Reductions:       6.444e+03      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.9671e+01  35.8%  3.8477e+11  40.7%  8.837e+05   3.2%  5.137e+02       26.2%  6.429e+03  99.8%
 1:        MG Apply: 3.5264e+01  64.2%  5.6152e+11  59.3%  2.649e+07  96.8%  1.445e+03       73.8%  1.400e+01   0.2%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %f - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %f %M %L %R  %T %f %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecMDot              784 1.0 2.3676e+00 1.4 6.93e+08 1.0 0.0e+00 0.0e+00 7.8e+02  4  9  0  0 12  10 23  0  0 12 37453
VecNorm             1690 1.0 7.5013e-01 3.6 1.11e+08 1.0 0.0e+00 0.0e+00 1.7e+03  1  1  0  0 26   3  4  0  0 26 18899
VecScale             838 1.0 4.0263e-02 1.1 2.75e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 87296
VecCopy              852 1.0 1.2544e-01 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               942 1.0 1.3346e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecAXPY              818 1.0 1.3729e-01 1.4 5.36e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  2  0  0  0 49979
VecAYPX              818 1.0 1.1893e-01 1.9 2.68e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 28849
VecWAXPY              20 1.0 5.6469e-03 1.9 6.55e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 14855
VecMAXPY            1602 1.0 3.4485e+00 1.2 1.40e+09 1.0 0.0e+00 0.0e+00 0.0e+00  6 19  0  0  0  16 46  0  0  0 51877
VecScatterBegin     1694 1.0 2.3263e-01 1.3 0.00e+00 0.0 8.5e+05 1.6e+04 0.0e+00  0  0  3 26  0   1  0 96 99  0     0
VecScatterEnd       1694 1.0 1.1359e+00 3.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   3  0  0  0  0     0
MatMult             1622 1.0 5.9099e+00 1.1 6.91e+08 1.0 8.3e+05 1.6e+04 0.0e+00 10  9  3 25  0  28 23 94 97  0 14965
MatMultTranspose       4 1.0 2.2697e-03 1.1 2.53e+05 1.0 1.5e+03 9.9e+02 0.0e+00  0  0  0  0  0   0  0  0  0  0 14252
MatLUFactorSym         1 1.0 5.1498e-04 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         1 1.0 1.3133e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
MatAssemblyBegin      51 1.0 1.6192e-01 5.5 0.00e+00 0.0 0.0e+00 0.0e+00 8.6e+01  0  0  0  0  1   1  0  0  0  1     0
MatAssemblyEnd        51 1.0 1.6754e-01 1.2 0.00e+00 0.0 1.2e+04 1.1e+03 7.2e+01  0  0  0  0  1   1  0  1  0  1     0
MatGetRowIJ            1 1.0 4.0531e-06 4.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 1.5974e-05 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatPtAP                4 1.0 2.1024e-01 1.0 5.11e+06 1.0 2.5e+04 6.0e+03 1.0e+02  0  0  0  0  2   1  0  3  1  2  3108
MatPtAPSymbolic        4 1.0 1.4685e-01 1.1 0.00e+00 0.0 1.5e+04 7.8e+03 6.0e+01  0  0  0  0  1   1  0  2  1  1     0
MatPtAPNumeric         4 1.0 7.1755e-02 1.1 5.11e+06 1.0 9.7e+03 3.1e+03 4.0e+01  0  0  0  0  1   0  0  1  0  1  9107
MatGetLocalMat         4 1.0 1.9876e-02 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          4 1.0 2.8243e-02 3.0 0.00e+00 0.0 1.1e+04 8.4e+03 8.0e+00  0  0  0  0  0   0  0  1  1  0     0
MatGetSymTrans         8 1.0 9.5758e-03 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog       784 1.0 3.7788e+00 1.2 1.39e+09 1.0 0.0e+00 0.0e+00 7.8e+02  6 19  0  0 12  18 46  0  0 12 46933
KSPSetUp               6 1.0 2.6372e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 3.6e+01  0  0  0  0  1   0  0  0  0  1     0
Warning -- total time of even greater than time of entire stage -- something is wrong with the timer
KSPSolve              34 1.0 4.8017e+01 1.0 7.39e+09 1.0 2.7e+07 1.9e+03 6.2e+03 87100100 99 96 2442463096379 97 19707
PCSetUp                1 1.0 4.2120e-01 1.0 5.36e+06 1.0 3.4e+04 4.6e+03 3.1e+02  1  0  0  0  5   2  0  4  1  5  1628
PCApply              784 1.0 3.5575e+01 1.0 4.39e+09 1.0 2.6e+07 1.5e+03 1.4e+01 64 59 97 74  0 1791462998281  0 15784
MGSetup Level 0        1 1.0 1.3333e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  0   1  0  0  0  0     0
MGSetup Level 1        1 1.0 2.0680e-03 7.6 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  0   0  0  0  0  0     0
MGSetup Level 2        1 1.0 3.9411e-04 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  0   0  0  0  0  0     0
MGSetup Level 3        1 1.0 2.9707e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  0   0  0  0  0  0     0
MGSetup Level 4        1 1.0 1.7860e-03 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  0   0  0  0  0  0     0
--- Event Stage 1: MG Apply
VecCopy             8624 1.0 2.4634e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet             50176 1.0 3.2026e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAXPY            15680 1.0 3.5027e-01 1.4 1.34e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  2  0  0  0   1  3  0  0  0 48993
VecAYPX            18816 1.0 4.3705e-01 1.2 9.64e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  2  0  0  0 28229
VecScatterBegin    40768 1.0 1.3572e+00 1.8 0.00e+00 0.0 2.6e+07 1.5e+03 0.0e+00  2  0 97 74  0   3  0100100  0     0
VecScatterEnd      40768 1.0 3.4473e+00 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   7  0  0  0  0     0
MatMult            21952 1.0 1.5737e+01 1.1 2.19e+09 1.0 1.9e+07 1.8e+03 0.0e+00 27 30 70 66  0  43 50 73 89  0 17850
MatMultAdd          7840 1.0 1.7853e+00 1.2 2.26e+08 1.0 3.0e+06 5.3e+02 0.0e+00  3  3 11  3  0   4  5 11  4  0 16221
MatMultTranspose   10976 1.0 4.0456e+00 1.3 4.24e+08 1.0 4.2e+06 6.6e+02 0.0e+00  6  6 15  5  0  10 10 16  7  0 13427
MatSolve           19600 1.0 1.3496e+01 1.1 1.31e+09 1.0 0.0e+00 0.0e+00 0.0e+00 24 18  0  0  0  37 30  0  0  0 12419
MatLUFactorNum         4 1.0 1.0570e-02 1.2 1.86e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 22564
MatILUFactorSym        4 1.0 5.1000e-02 3.9 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0 29     0
MatGetRowIJ            4 1.0 9.7752e-0610.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         4 1.0 5.0209e-0244.6 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  0   0  0  0  0 71     0
KSPSetUp               4 1.0 4.2915e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve           19600 1.0 2.3593e+01 1.0 2.79e+09 1.0 1.0e+07 2.1e+03 1.4e+01 42 38 38 40  0  65 63 39 54100 15111
PCSetUp                4 1.0 7.3869e-02 1.8 1.86e+06 1.0 0.0e+00 0.0e+00 1.4e+01  0  0  0  0  0   0  0  0  0100  3229
PCSetUpOnBlocks    15680 1.0 8.8366e-02 1.7 1.86e+06 1.0 0.0e+00 0.0e+00 1.4e+01  0  0  0  0  0   0  0  0  0100  2699
PCApply            19600 1.0 1.4283e+01 1.1 1.31e+09 1.0 0.0e+00 0.0e+00 0.0e+00 25 18  0  0  0  39 30  0  0  0 11734
MGSmooth Level 0    3920 1.0 6.4374e+00 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 11  0  0  0  0  17  0  0  0  0     0
MGSmooth Level 1    6272 1.0 5.7907e-01 1.1 2.36e+07 1.0 4.0e+06 1.9e+02 5.0e+00  1  0 15  1  0   2  1 15  2 36  5214
MGResid Level 1     3136 1.0 7.1739e-01 5.5 1.08e+07 1.0 3.2e+06 1.9e+02 0.0e+00  1  0 12  1  0   1  0 12  2  0  1934
MGInterp Level 1    7840 1.0 5.6076e-01 4.3 3.34e+06 1.0 3.0e+06 6.4e+01 0.0e+00  0  0 11  0  0   1  0 11  0  0   762
MGSmooth Level 2    4704 1.0 1.0847e+00 1.2 1.80e+08 1.0 3.2e+06 6.4e+02 3.0e+00  2  2 12  4  0   3  4 12  5 21 21185
MGResid Level 2     2352 1.0 9.1275e-01 2.8 6.50e+07 1.0 2.4e+06 6.4e+02 0.0e+00  1  1  9  3  0   1  1  9  4  0  9119
MGInterp Level 2    6272 1.0 7.0760e-01 3.4 2.13e+07 1.0 2.4e+06 2.1e+02 0.0e+00  1  0  9  1  0   1  0  9  1  0  3848
MGSmooth Level 3    3136 1.0 6.2875e+00 1.1 1.12e+09 1.0 2.4e+06 2.3e+03 3.0e+00 11 15  9 10  0  17 25  9 14 21 22740
MGResid Level 3     1568 1.0 1.9152e+00 1.2 3.47e+08 1.0 1.6e+06 2.3e+03 0.0e+00  3  5  6  7  0   5  8  6  9  0 23179
MGInterp Level 3    4704 1.0 1.4607e+00 1.9 1.27e+08 1.0 1.8e+06 7.7e+02 0.0e+00  2  2  7  3  0   3  3  7  4  0 11116
MGSmooth Level 4    1568 1.0 1.0432e+01 1.1 1.47e+09 1.0 8.0e+05 1.6e+04 3.0e+00 18 20  3 25  0  29 33  3 33 21 17976
MGResid Level 4      784 1.0 2.9461e+00 1.1 3.60e+08 1.0 4.0e+05 1.6e+04 0.0e+00  5  5  1 12  0   8  8  2 17  0 15626
MGInterp Level 4    3136 1.0 5.2866e+00 1.1 6.68e+08 1.0 1.2e+06 2.9e+03 0.0e+00  9  9  4  7  0  14 15  5  9  0 16172
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Vector  1843           1843    474947688     0
      Vector Scatter    19             19        22572     0
              Matrix    38             42     19508928     0
   Matrix Null Space     1              1          652     0
    Distributed Mesh     5              5       830792     0
     Bipartite Graph    10             10         8560     0
           Index Set    47             59       844496     0
   IS L to G Mapping     5              5       405756     0
       Krylov Solver    11             11        32800     0
     DMKSP interface     3              3         2088     0
      Preconditioner    11             11        11864     0
              Viewer     1              0            0     0
              Matrix     4              0            0     0
           Index Set    14              2         1792     0
Average time to get PetscTime(): 1.90735e-07
Average time for MPI_Barrier(): 1.52111e-05
Average time for zero size MPI_Send(): 2.83681e-06
#PETSc Option Table entries:
-ksp_type fgmres
-log_summary
-options_left
-pc_mg_galerkin
-pc_mg_levels 5
-pc_mg_log
-pc_mg_type full
-pc_type mg
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 8
Configure run at: Wed Aug 28 23:25:43 2013
Configure options: --known-level1-dcache-size=16384 --known-level1-dcache-linesize=64 --known-level1-dcache-assoc=4 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=0 --known-mpi-c-double-complex=0 --with-batch="1 " --known-mpi-shared="0 " --known-memcmp-ok  --with-blas-lapack-lib="-L/opt/acml/5.3.0/pgi64/lib  -lacml" --COPTFLAGS="-O3 -fastsse" --FOPTFLAGS="-O3 -fastsse" --CXXOPTFLAGS="-O3 -fastsse" --with-x="0 " --with-debugging="0 " --with-clib-autodetect="0 " --with-cxxlib-autodetect="0 " --with-fortranlib-autodetect="0 " --with-shared-libraries=0 --with-dynamic-loading=0 --with-mpi-compilers="1 " --known-mpi-shared-libraries=0 --with-64-bit-indices --download-blacs="1 " --download-scalapack="1 " --download-superlu_dist="1 " --download-metis="1 " --download-parmetis="1 " --with-cc=cc --with-cxx=CC --with-fc=ftn PETSC_ARCH=interlagos-64idx-pgi-opt
Libraries compiled on Wed Aug 28 23:25:43 2013 on h2ologin3
Machine characteristics: Linux-2.6.32.59-0.7-default-x86_64-with-SuSE-11-x86_64
Using PETSc directory: /mnt/a/u/sciteam/mrosso/LIBS/petsc-3.4.2
Using PETSc arch: interlagos-64idx-pgi-opt
Using C compiler: cc  -O3 -fastsse  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: ftn  -O3 -fastsse   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.4.2/interlagos-64idx-pgi-opt/include -I/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.4.2/include -I/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.4.2/include -I/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.4.2/interlagos-64idx-pgi-opt/include -I/opt/cray/udreg/2.3.2-1.0402.7311.2.1.gem/include -I/opt/cray/ugni/5.0-1.0402.7128.7.6.gem/include -I/opt/cray/pmi/4.0.1-1.0000.9421.73.3.gem/include -I/opt/cray/dmapp/4.0.1-1.0402.7439.5.1.gem/include -I/opt/cray/gni-headers/2.1-1.0402.7082.6.2.gem/include -I/opt/cray/xpmem/0.1-2.0402.44035.2.1.gem/include -I/opt/cray/rca/1.0.0-2.0402.42153.2.106.gem/include -I/opt/cray-hss-devel/7.0.0/include -I/opt/cray/krca/1.0.0-2.0402.42157.2.94.gem/include -I/opt/cray/mpt/6.0.1/gni/mpich2-pgi/121/include -I/opt/acml/5.3.0/pgi64_fma4/include -I/opt/cray/libsci/12.1.01/pgi/121/interlagos/include -I/opt/fftw/3.3.0.3/interlagos/include -I/usr/include/alps -I/opt/pgi/13.6.0/linux86-64/13.6/include -I/opt/cray/xe-sysroot/4.2.24/usr/include
Using C linker: cc
Using Fortran linker: ftn
Using libraries: -Wl,-rpath,/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.4.2/interlagos-64idx-pgi-opt/lib -L/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.4.2/interlagos-64idx-pgi-opt/lib -lpetsc -Wl,-rpath,/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.4.2/interlagos-64idx-pgi-opt/lib -L/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.4.2/interlagos-64idx-pgi-opt/lib -lsuperlu_dist_3.3 -L/opt/acml/5.3.0/pgi64/lib -lacml -lpthread -lparmetis -lmetis -ldl
-ksp_type fgmres
-log_summary
-options_left
-pc_mg_galerkin
-pc_mg_levels 5
-pc_mg_log
-pc_mg_type full
-pc_type mg
There are no unused options.
-pc_mg_type full -ksp_type fgmres -mg_levels_pc_type sor -mg_levels_ksp_type gmres
-mg_levels_ksp_max_it 3 -mg_coarse_pc_factor_mat_solver_package superlu_dist -mg_coarse_pc_type lu
-pc_mg_galerkin -pc_mg_levels 5 -pc_type mg -log_summary  -pc_mg_log  -ksp_monitor_true_residual  -options_left
9979 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9980 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9981 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9982 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9983 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9984 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9985 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9986 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9987 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9988 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9989 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9990 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9991 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9992 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9993 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9994 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9995 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9996 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9997 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9998 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
9999 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
10000 KSP unpreconditioned resid norm 1.205238163959e-08 true resid norm 1.205238163959e-08 ||r(i)||/||b|| 6.439485962882e-02
./hit on a interlagos-64idx-pgi-opt named nid00193 with 128 processors, by Unknown Mon Sep 30 12:37:25 2013
Time (sec):           1.632e+03      1.00002   1.632e+03
Objects:              4.184e+05      1.00000   4.184e+05
Flops:                2.514e+11      1.00000   2.514e+11  3.218e+13
Flops/sec:            1.540e+08      1.00002   1.540e+08  1.972e+10
MPI Messages:         7.101e+06      1.00000   7.101e+06  9.089e+08
MPI Message Lengths:  1.378e+10      1.00000   1.941e+03  1.764e+12
MPI Reductions:       9.168e+05      1.00000
 0:      Main Stage: 4.6064e+02  28.2%  1.3696e+13  42.6%  2.736e+07   3.0%  4.928e+02       25.4%  1.864e+05  20.3%
 1:        MG Apply: 1.1712e+03  71.8%  1.8482e+13  57.4%  8.816e+08  97.0%  1.448e+03       74.6%  7.305e+05  79.7%
Phase summary info:
VecMDot            26088 1.0 7.9541e+01 1.2 2.57e+10 1.0 0.0e+00 0.0e+00 2.6e+04  4 10  0  0  3  15 24  0  0 14 41427
VecNorm            53560 1.0 2.3821e+01 2.7 3.51e+09 1.0 0.0e+00 0.0e+00 5.4e+04  1  1  0  0  6   4  3  0  0 29 18861
VecScale           27094 1.0 1.2548e+00 1.1 8.88e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 90567
VecCopy            26466 1.0 3.6450e+00 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecSet             26866 1.0 3.6354e+00 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecAXPY            26277 1.0 3.9569e+00 1.3 1.72e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  2  0  0  0 55707
VecAYPX            26277 1.0 3.4483e+00 1.5 8.61e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  1  0  0  0 31962
VecWAXPY             819 1.0 2.3387e-01 1.9 2.68e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 14688
VecMAXPY           52365 1.0 1.2676e+02 1.2 5.16e+10 1.0 0.0e+00 0.0e+00 0.0e+00  7 21  0  0  0  26 48  0  0  0 52096
VecScatterBegin    53566 1.0 7.2821e+00 1.3 0.00e+00 0.0 2.7e+07 1.6e+04 0.0e+00  0  0  3 25  0   1  0100100  0     0
VecScatterEnd      53566 1.0 3.9626e+01 3.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   5  0  0  0  0     0
MatMult            53184 1.0 1.8661e+02 1.2 2.27e+10 1.0 2.7e+07 1.6e+04 0.0e+00 11  9  3 25  0  38 21100100  0 15540
MatMultTranspose       4 1.0 2.2471e-03 1.1 2.53e+05 1.0 1.5e+03 9.9e+02 0.0e+00  0  0  0  0  0   0  0  0  0  0 14396
MatLUFactorSym         1 1.0 4.9806e-04 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         1 1.0 1.2223e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin     206 1.0 6.9716e-0111.8 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+02  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd       206 1.0 7.1718e-01 1.2 0.00e+00 0.0 1.2e+04 1.1e+03 7.2e+01  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            1 1.0 5.0068e-06 5.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 1.9073e-05 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatPtAP                4 1.0 2.0369e-01 1.0 5.11e+06 1.0 2.5e+04 6.0e+03 1.0e+02  0  0  0  0  0   0  0  0  0  0  3208
MatPtAPSymbolic        4 1.0 1.4161e-01 1.1 0.00e+00 0.0 1.5e+04 7.8e+03 6.0e+01  0  0  0  0  0   0  0  0  0  0     0
MatPtAPNumeric         4 1.0 7.0208e-02 1.1 5.11e+06 1.0 9.7e+03 3.1e+03 4.0e+01  0  0  0  0  0   0  0  0  0  0  9307
MatGetLocalMat         4 1.0 1.8704e-02 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          4 1.0 2.6713e-02 2.8 0.00e+00 0.0 1.1e+04 8.4e+03 8.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSymTrans         8 1.0 9.3246e-03 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog     26088 1.0 1.3317e+02 1.1 5.15e+10 1.0 0.0e+00 0.0e+00 2.6e+04  8 20  0  0  3  27 48  0  0 14 49486
KSPSetUp               6 1.0 2.7412e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 3.6e+01  0  0  0  0  0   0  0  0  0  0     0
KSPSolve             189 1.0 1.5818e+03 1.0 2.51e+11 1.0 9.1e+08 1.9e+03 9.2e+05 97100100100100 3432353321393491 20342
PCSetUp                1 1.0 4.0787e-01 1.0 5.36e+06 1.0 3.4e+04 4.6e+03 3.0e+02  0  0  0  0  0   0  0  0  0  0  1681
PCApply            26088 1.0 1.1782e+03 1.0 1.44e+11 1.0 8.8e+08 1.5e+03 7.3e+05 72 57 97 75 80 2541353222294392 15686
MGSetup Level 0        1 1.0 1.2428e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  0   0  0  0  0  0     0
MGSetup Level 1        1 1.0 1.9360e-0319.3 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0     0
MGSetup Level 2        1 1.0 2.7823e-04 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0     0
MGSetup Level 3        1 1.0 1.4997e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0     0
MGSetup Level 4        1 1.0 1.6689e-03 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScale          365232 1.0 1.5631e+00 1.3 7.00e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 57287
VecCopy           130440 1.0 1.0518e-01 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet           1147872 1.0 2.7147e+00 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAYPX           260880 1.0 4.9379e+00 1.2 1.12e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 28911
VecScatterBegin  1356576 1.0 7.7021e+01 1.9 0.00e+00 0.0 8.8e+08 1.5e+03 0.0e+00  3  0 97 75  0   5  0100100  0     0
VecScatterEnd    1356576 1.0 1.1642e+02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  6  0  0  0  0   8  0  0  0  0     0
MatMult           365232 1.0 2.0117e+02 1.1 3.05e+10 1.0 2.9e+08 1.5e+03 0.0e+00 12 12 32 26  0  16 21 33 34  0 19428
MatMultAdd        260880 1.0 6.2891e+01 1.2 7.53e+09 1.0 1.0e+08 5.3e+02 0.0e+00  3  3 11  3  0   5  5 11  4  0 15322
MatMultTranspose  365232 1.0 1.3004e+02 1.2 1.41e+10 1.0 1.4e+08 6.6e+02 0.0e+00  7  6 15  5  0  10 10 16  7  0 13900
MatSolve          130440 1.0 2.2788e+02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 13  0  0  0  0  18  0  0  0  0     0
MatSOR            521760 1.0 5.7865e+02 1.1 9.11e+10 1.0 3.5e+08 2.1e+03 7.3e+05 35 36 38 41 80  48 63 39 54100 20149
KSPSolve          652200 1.0 7.9658e+02 1.0 9.11e+10 1.0 3.5e+08 2.1e+03 7.3e+05 48 36 38 41 80  67 63 39 54100 14637
PCApply           130440 1.0 2.2803e+02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 13  0  0  0  0  18  0  0  0  0     0
MGSmooth Level 0  130440 1.0 2.3022e+02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 13  0  0  0  0  19  0  0  0  0     0
MGSmooth Level 1  208704 1.0 3.2475e+01 1.2 7.96e+08 1.0 1.3e+08 1.9e+02 2.6e+05  2  0 15  1 28   3  1 15  2 36  3139
MGResid Level 1   104352 1.0 1.4487e+01 2.4 3.61e+08 1.0 1.1e+08 1.9e+02 0.0e+00  1  0 12  1  0   1  0 12  2  0  3186
MGInterp Level 1  260880 1.0 1.7836e+01 3.7 1.11e+08 1.0 1.0e+08 6.4e+01 0.0e+00  1  0 11  0  0   1  0 11  0  0   797
MGSmooth Level 2  156528 1.0 4.2359e+01 1.1 5.96e+09 1.0 1.1e+08 6.4e+02 2.1e+05  2  2 12  4 23   3  4 12  5 29 18002
MGResid Level 2    78264 1.0 2.3577e+01 1.9 2.16e+09 1.0 8.0e+07 6.4e+02 0.0e+00  1  1  9  3  0   1  1  9  4  0 11747
MGInterp Level 2  208704 1.0 2.1986e+01 2.5 7.08e+08 1.0 8.0e+07 2.1e+02 0.0e+00  1  0  9  1  0   1  0  9  1  0  4121
MGSmooth Level 3  104352 1.0 1.8000e+02 1.1 3.69e+10 1.0 8.0e+07 2.3e+03 1.6e+05 11 15  9 10 17  15 26  9 14 21 26230
MGResid Level 3    52176 1.0 4.4884e+01 1.2 1.15e+10 1.0 5.3e+07 2.3e+03 0.0e+00  3  5  6  7  0   4  8  6  9  0 32911
MGInterp Level 3  156528 1.0 4.0354e+01 1.5 4.22e+09 1.0 6.0e+07 7.7e+02 0.0e+00  2  2  7  3  0   3  3  7  4  0 13388
MGSmooth Level 4   52176 1.0 3.4639e+02 1.1 4.75e+10 1.0 2.7e+07 1.6e+04 1.0e+05 21 19  3 25 11  29 33  3 33 14 17534
MGResid Level 4    26088 1.0 8.7990e+01 1.2 1.20e+10 1.0 1.3e+07 1.6e+04 0.0e+00  5  5  1 12  0   7  8  2 17  0 17410
MGInterp Level 4  104352 1.0 1.7549e+02 1.1 2.22e+10 1.0 4.0e+07 2.9e+03 0.0e+00 10  9  4  7  0  14 15  5  9  0 16211
              Vector 53063          53063  14013688680     0
              Matrix    38             38     14004608     0
           Index Set    47             47       534480     0
       Krylov Solver     7              7        27744     0
      Preconditioner     7              7         7352     0
              Viewer     1              0            0     0
              Vector 365232          365232  17352902784     0
Average time to get PetscTime(): 9.53674e-08
Average time for MPI_Barrier(): 1.28269e-05
Average time for zero size MPI_Send(): 2.4531e-06
-ksp_type fgmres
-log_summary
-mg_levels_ksp_max_it 1
-mg_levels_ksp_type richardson
-options_left
-pc_mg_galerkin
-pc_mg_levels 5
-pc_mg_log
-pc_mg_type full
-pc_type mg
Using C linker: cc
-ksp_type fgmres
-log_summary
-options_left
-pc_mg_galerkin
-pc_mg_levels 5
-pc_mg_log
-pc_mg_type full
-pc_type mg
