[petsc-users] The product of two MPIDENSE matrices
Mon Sep 30 13:36:26 CDT 2013
Joon Hee Choi <choi240 at purdue.edu> writes:
> Hello Hong,
> I tried to get Elemental but it does not support 64-bit integer now. I
> need to use 64-bit integer because the matrix I am using is very
> large. I need just MatMatMult() for MPIDENSE matrices, but it also
> didn't support MPIDENSE. Is there any method to multiply MPIDENSE and
> MPIDENSE?
I take it that you need 64-bit indices because your problems are that
big already, not that you're worried they will eventually be that large?
I assume Jack will reply to your other message which was cross-posted to
dev at libelemental.org, but I'm Cc'ing him here as well.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130930/f2418c0f/attachment.pgp>
