[petsc-users] Cannot use KSP if I choose local Matrix/Vector ownership
William A. Perkins william.perkins at pnnl.gov
Mon Sep 30 09:36:29 CDT 2013
Barry,
Thanks. I should have known that.
Bill
>>>>> "Barry" == Barry Smith <bsmith at mcs.anl.gov> writes:
    Barry>    Bill,
    Barry>     When you call
    Barry>  ierr = MatSetSizes(A,local_size, PETSC_DECIDE,imax*jmax, imax*jmax); CHKERRXX(ierr);
    Barry> you should pass local_size as the third argument as well
    Barry> instead of PETSC_DECIDE.  PETSc is making a choice here
    Barry> based only on the total number of columns imax*jmax and
    Barry> doesn't take into account what you provided for local row
    Barry> size.
    Barry>    Essentially you can either let PETSc decide all the
    Barry>    local sizes of the Vecs and Mats or you decide all of
    Barry>    them; but mixing that will usually not work.
    Barry>    Barry
    Barry> On Sep 26, 2013, at 4:37 PM, "William A. Perkins" <william.perkins at pnnl.gov> wrote:
    >> Hello,
    >> I have run into a problem using KSP.  Attached is a hopefully short,
    >> simple example program (which has nothing to do with my actual
    >> application) demonstrating the problem.  Also attached is an output
    >> log from several runs of the program.  The program runs fine if I
    >> choose local ownership according to PetscSplitOwnership().  If,
    >> however, I slightly modify that local ownership scheme, the program
    >> will not run in parallel.  In my view, KSP appears to make its own
    >> coefficient (or preconditioner, or whatever) matrix that has different
    >> local ownership than the one I give to KSPSetOperators(), and so
    >> cannot do matrix/vector multiplies.
    >> I would like to be able to choose my own local ownership. Any help
    >> would be appreciated. Hopefully, I'm not doing something stupid.
    >> Thanks.
    >> Bill
    >> Bill Perkins
    >> Research Engineer
    >> Hydrology Group
    >> Pacific Northwest National Laboratory
    >> 902 Battelle Boulevard
    >> P.O. Box 999, MSIN K9-36
    >> Richland, WA  99352 USA
    >> Tel:  509-372-6131
    >> Fax: 509-372-6089
    >> www.pnnl.gov
    >> file: versteeg.cpp
    >> This is a simple test of PETSC Matrix operations and Linear
    >> equation solvers.  This problem comes from Example 7.2 in
    >> Versteeg, H.K. and W. Malalasekera, 1995. An introduction to
    >> computational fluid dynamics, the finite volume method. Prentice
    >> Hall.  257 pp.
    >> Created October 10, 2002 by William A. Perkins
    >> Last Change: 2013-09-26 14:32:33 d3g096
    >> static const char* SCCS_ID = "$Id: versteeg.c,v 1.3 2008/05/24 23:04:39 d3g096 Exp $ Battelle PNNL";
    >> static char help[] =
    >> "Solves an example heat transfer problem from Versteeg and Malalasekera with SLES.\n\
    >> The following options are available:\n\
    >> -view_solution yes/no: write the initial and final solution to stdout\n\
    >> -problem       yes/no: cause problem by choosing local ownership\n\n";
    >> #include <stdio.h>
    >> #include <petscksp.h>
    >> assemble
    >> int
    >> assemble(const int imax, const int jmax, const double scale, Mat A, Vec b)
    >> static const float k = 1000;  /* conductivity, W/m/K */
    >> static const float t = 0.01;  /* plate thickness, m */
    >> static const float W = 0.3;   /* plate width, m */
    >> static const float H = 0.4;   /* plate height, m */
    >> PetscErrorCode ierr;
    >> int i, j;
    >> float ap, aw, ae, as, an, bp;
    >> float dx = W/(float)imax;
    >> float dy = H/(float)jmax;
    >> int iP, iN, iS, iE, iW;
    >> PetscScalar v;
    >> PetscInt lo, hi;
    >> ierr = MatGetOwnershipRange(A, &lo, &hi); CHKERRQ(ierr);
    >> for (i = 0; i < imax; i++) {
    >> for (j = 0; j < jmax; j++) {
    >> iP = i*jmax + j;
    >> if (! (lo <= iP && iP < hi) ) continue;
    >> iE = (i+1)*jmax + j;
    >> iW = (i-1)*jmax + j;
    >> iN = i*jmax + (j+1);
    >> iS = i*jmax + (j-1);
    >> bp = 0.0;
    >> ap = 0.0;
    >> if (j == 0) {             /* insulated south boundary */
    >> as = 0.0;
    >> bp += 0.0;
    >> ap -= 0.0;
    >> } else {
    >> as = (k/dx)*(dx*t);
    >> if (j == jmax - 1) {      /* constant tempurature (100C) north boundary */
    >> an = 0.0;
    >> bp += 2*k/dy*(dy*t)*100.0;
    >> ap -= -2*k/dy*(dy*t);
    >> } else {
    >> an = (k/dx)*(dx*t);
    >> if (i == 0) {             /* constant flux (500kw/m2) west boundary */
    >> aw = 0.0;
    >> bp += 500000.0*dy*t;
    >> ap -= 0.0;
    >> } else {
    >> aw = (k/dx)*(dx*t);
    >> if (i == imax - 1) {      /* insulated east boundary */
    >> ae = 0.0;
    >> bp += 0.0;
    >> ap -= 0.0;
    >> } else {
    >> ae = (k/dx)*(dx*t);
    >> ap += as + an + aw + ae;
    >> v = ap*scale;
    >> ierr = MatSetValues(A,1,&iP,1,&iP,&v,INSERT_VALUES); CHKERRQ(ierr);
    >> if (an != 0.0) {
    >> v = -an*scale;
    >> ierr = MatSetValues(A,1,&iP,1,&iN,&v,INSERT_VALUES); CHKERRQ(ierr);
    >> if (as != 0.0) {
    >> v = -as*scale;
    >> ierr = MatSetValues(A,1,&iP,1,&iS,&v,INSERT_VALUES); CHKERRQ(ierr);
    >> if (ae != 0.0) {
    >> v = -ae*scale;
    >> ierr = MatSetValues(A,1,&iP,1,&iE,&v,INSERT_VALUES); CHKERRQ(ierr);
    >> if (aw != 0.0) {
    >> v = -aw*scale;
    >> ierr = MatSetValues(A,1,&iP,1,&iW,&v,INSERT_VALUES); CHKERRQ(ierr);
    >> v = bp*scale;
    >> ierr = VecSetValues(b, 1, &iP, &v, INSERT_VALUES); CHKERRQ(ierr);
    >> ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
    >> ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
    >> ierr = VecAssemblyBegin(b); CHKERRQ(ierr);
    >> ierr = VecAssemblyEnd(b); CHKERRQ(ierr);
    >> return(0);
    >> Main Program
    >> int
    >> main(int argc, char **args)
    >> static const int imax = 3;
    >> static const int jmax = 4;
    >> PetscBool print_solution(PETSC_FALSE);
    >> PetscBool set_local_size(PETSC_FALSE);
    >> int its;
    >> Vec x, b;
    >> Mat A;
    >> PetscScalar v;
    >> KSP ksp;
    >> VecScatter ctx;
    >> int rank;
    >> int nproc;
    >> PetscInt local_size(PETSC_DECIDE);
    >> PetscInt global_size(imax*jmax);
    >> PetscInitialize(&argc,&args,(char *)0,help);
    >> PetscOptionsGetBool(NULL, "-print_solution", &print_solution, NULL);
    >> PetscOptionsGetBool(NULL, "-problem", &set_local_size, NULL);
    >> ierr = MPI_Comm_size(PETSC_COMM_WORLD,&nproc);
    >> ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
    >> ierr = PetscSplitOwnership(PETSC_COMM_WORLD, &local_size, &global_size); CHKERRQ(ierr);
    >> if (set_local_size) {
    >> // If there is more than one processor, alter the default local
    >> // ownership so that process 0 has one less row and the last
    >> // process has more row.
    >> if (nproc > 1) {
    >> if (rank == 0) {
    >> local_size -= 1;
    >> } else if (rank == nproc - 1) {
    >> local_size += 1;
    >> ierr = MatCreate(PETSC_COMM_WORLD, &A); CHKERRQ(ierr);
    >> ierr = MatSetFromOptions(A); CHKERRQ(ierr);
    >> ierr = MatSetUp(A); CHKERRQ(ierr);
    >> ierr = VecCreate(PETSC_COMM_WORLD,&x);CHKERRQ(ierr);
    >> ierr = VecSetSizes(x,local_size,imax*jmax);CHKERRQ(ierr);
    >> ierr = VecSetFromOptions(x);CHKERRQ(ierr);
    >> ierr = VecDuplicate(x,&b);CHKERRQ(ierr);
    >> ierr = assemble(imax, jmax, 1.0, A, b); CHKERRQ(ierr);
    >> v = 0.0;
    >> ierr = VecSet(x,v);CHKERRQ(ierr);
    >> if (print_solution) {
    >> ierr = VecView(x, PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr);
    >> ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
    >> ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
    >> ierr = KSPSetInitialGuessNonzero(ksp,PETSC_TRUE); CHKERRQ(ierr);
    >> ierr = KSPSetTolerances(ksp, 1e-06, 1e-12, PETSC_DEFAULT, PETSC_DEFAULT);  CHKERRQ(ierr);
    >> ierr = KSPSetOperators(ksp,A,A,SAME_NONZERO_PATTERN);CHKERRQ(ierr);
    >> ierr = KSPSetUp(ksp); CHKERRQ(ierr);
    >> ierr = KSPSolve(ksp, b, x);CHKERRQ(ierr);
    >> ierr = KSPGetIterationNumber(ksp,&its);CHKERRQ(ierr);
    >> ierr = PetscPrintf(PETSC_COMM_WORLD,"iterations %d\n",its);CHKERRQ(ierr);
    >> ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
    >> ierr = VecDestroy(&x);CHKERRQ(ierr);
    >> ierr = VecDestroy(&b);CHKERRQ(ierr);
    >> ierr = MatDestroy(&A);CHKERRQ(ierr);
    >> ierr = PetscFinalize();
    >> return(ierr);
    >>>>> mpirun -np 1 versteeg -print_solution
    >> Vector Object: 1 MPI processes
    >> type: seq
    >> 0
    >> 0
    >> 0
    >> 0
    >> 0
    >> 0
    >> 0
    >> 0
    >> 0
    >> 0
    >> 0
    >> 0
    >> iterations 8
    >> type: seq
    >> 260.037
    >> 242.275
    >> 205.592
    >> 146.322
    >> 227.799
    >> 211.195
    >> 178.178
    >> 129.696
    >> 212.164
    >> 196.53
    >> 166.23
    >> 123.982
    >>>>> mpirun -np 2 versteeg -print_solution
    >> Vector Object: 2 MPI processes
    >> type: mpi
    >> Process [0]
    >> 0
    >> 0
    >> 0
    >> 0
    >> 0
    >> 0
    >> Process [1]
    >> 0
    >> 0
    >> 0
    >> 0
    >> 0
    >> 0
    >> iterations 9
    >> type: mpi
    >> Process [0]
    >> 260.037
    >> 242.275
    >> 205.592
    >> 146.322
    >> 227.799
    >> 211.195
    >> Process [1]
    >> 178.178
    >> 129.696
    >> 212.164
    >> 196.53
    >> 166.23
    >> 123.982
    >>>>> mpirun -np 4 versteeg -print_solution
    >> Vector Object: 4 MPI processes
    >> type: mpi
    >> Process [0]
    >> 0
    >> 0
    >> 0
    >> Process [1]
    >> 0
    >> 0
    >> 0
    >> Process [2]
    >> 0
    >> 0
    >> 0
    >> Process [3]
    >> 0
    >> 0
    >> 0
    >> iterations 12
    >> type: mpi
    >> Process [0]
    >> 260.037
    >> 242.275
    >> 205.592
    >> Process [1]
    >> 146.322
    >> 227.799
    >> 211.195
    >> Process [2]
    >> 178.178
    >> 129.696
    >> 212.164
    >> Process [3]
    >> 196.53
    >> 166.23
    >> 123.982
    >>>>> mpirun -np 2 versteeg -print_solution -problem
    >> type: mpi
    >> Process [0]
    >> 0
    >> 0
    >> 0
    >> 0
    >> 0
    >> Process [1]
    >> 0
    >> 0
    >> 0
    >> 0
    >> 0
    >> 0
    >> 0
    >> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message ------------------------------------
    >> [1]PETSC ERROR: Invalid argument!
    >> [1]PETSC ERROR: Must be square matrix, rows 7 columns 6!
    >> [1]PETSC ERROR: ------------------------------------------------------------------------
    >> [1]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
    >> [1]PETSC ERROR: See docs/changes/index.html for recent updates.
    >> [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
    >> [1]PETSC ERROR: See docs/index.html for manual pages.
    >> [1]PETSC ERROR: versteeg on a arch-complex named flophouse by d3g096 Thu Sep 26 14:30:33 2013
    >> [1]PETSC ERROR: Libraries linked from /net/flophouse/files0/perksoft/petsc-3.4.2/arch-complex/lib
    >> [1]PETSC ERROR: Configure run at Wed Sep 11 06:43:12 2013
    >> [1]PETSC ERROR: Configure options --with-scalar-type=complex --with-clanguage=C++ PETSC_ARCH=arch-complex --with-fortran-kernels=generic --download-superlu_dist --download-mumps --download-scalapack --download-parmetis --download-metis --download-elemental --with-mpi=1 --download-blacs
    >> [1]PETSC ERROR: MatGetOrdering() line 257 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/mat/order/sorder.c
    >> [1]PETSC ERROR: PCSetUp_ILU() line 194 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/pc/impls/factor/ilu/ilu.c
    >> [1]PETSC ERROR: PCSetUp() line 890 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/pc/interface/precon.c
    >> [1]PETSC ERROR: KSPSetUp() line 278 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
    >> [1]PETSC ERROR: PCSetUpOnBlocks_BJacobi_Singleblock() line 646 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/pc/impls/bjacobi/bjacobi.c
    >> [1]PETSC ERROR: PCSetUpOnBlocks() line 924 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/pc/interface/precon.c
    >> [1]PETSC ERROR: KSPSetUpOnBlocks() line 165 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
    >> [1]PETSC ERROR: KSPSolve() line 400 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
    >> [1]PETSC ERROR: main() line 216 in /home/d3g096/Projects/PerformanceLDRD/src/sandbox/petsc/versteeg.cpp
    >> [0]PETSC ERROR: Invalid argument!
    >> [0]PETSC ERROR: Must be square matrix, rows 5 columns 6!
    >> [0]PETSC ERROR: ------------------------------------------------------------------------
    >> [0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
    >> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
    >> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
    >> [0]PETSC ERROR: See docs/index.html for manual pages.
    >> [0]PETSC ERROR: versteeg on a arch-complex named flophouse by d3g096 Thu Sep 26 14:30:33 2013
    >> [0]PETSC ERROR: Libraries linked from /net/flophouse/files0/perksoft/petsc-3.4.2/arch-complex/lib
    >> [0]PETSC ERROR: Configure run at Wed Sep 11 06:43:12 2013
    >> [0]PETSC ERROR: Configure options --with-scalar-type=complex --with-clanguage=C++ PETSC_ARCH=arch-complex --with-fortran-kernels=generic --download-superlu_dist --download-mumps --download-scalapack --download-parmetis --download-metis --download-elemental --with-mpi=1 --download-blacs
    >> [0]PETSC ERROR: MatGetOrdering() line 257 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/mat/order/sorder.c
    >> [0]PETSC ERROR: PCSetUp_ILU() line 194 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/pc/impls/factor/ilu/ilu.c
    >> [0]PETSC ERROR: PCSetUp() line 890 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/pc/interface/precon.c
    >> [0]PETSC ERROR: KSPSetUp() line 278 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
    >> [0]PETSC ERROR: PCSetUpOnBlocks_BJacobi_Singleblock() line 646 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/pc/impls/bjacobi/bjacobi.c
    >> [0]PETSC ERROR: PCSetUpOnBlocks() line 924 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/pc/interface/precon.c
    >> [0]PETSC ERROR: KSPSetUpOnBlocks() line 165 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
    >> [0]PETSC ERROR: KSPSolve() line 400 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
    >> [0]PETSC ERROR: main() line 216 in /home/d3g096/Projects/PerformanceLDRD/src/sandbox/petsc/versteeg.cpp
    >> MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
    >> with errorcode 62.
    >> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
    >> You may or may not see output from other processes, depending on
    >> exactly when Open MPI kills them.
    >> mpirun has exited due to process rank 1 with PID 12459 on
    >> node flophouse exiting without calling "finalize". This may
    >> have caused other processes in the application to be
    >> terminated by signals sent by mpirun (as reported here).
    >> [flophouse:12457] 1 more process has sent help message help-mpi-api.txt / mpi-abort
    >> [flophouse:12457] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
    >>>>> mpirun -np 4 versteeg -print_solution -problem
    >> type: mpi
    >> Process [0]
    >> 0
    >> 0
    >> Process [1]
    >> 0
    >> 0
    >> 0
    >> Process [2]
    >> 0
    >> 0
    >> 0
    >> Process [3]
    >> 0
    >> 0
    >> 0
    >> 0
    >> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
    >> [0]PETSC ERROR: [3]PETSC ERROR: --------------------- Error Message ------------------------------------
    >> [3]PETSC ERROR: Invalid argument!
    >> [3]PETSC ERROR: Must be square matrix, rows 4 columns 3!
    >> [3]PETSC ERROR: ------------------------------------------------------------------------
    >> [3]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
    >> [3]PETSC ERROR: See docs/changes/index.html for recent updates.
    >> [3]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
    >> [3]PETSC ERROR: See docs/index.html for manual pages.
    >> [3]PETSC ERROR: versteeg on a arch-complex named flophouse by d3g096 Thu Sep 26 14:30:51 2013
    >> [3]PETSC ERROR: Libraries linked from /net/flophouse/files0/perksoft/petsc-3.4.2/arch-complex/lib
    >> [3]PETSC ERROR: Configure run at Wed Sep 11 06:43:12 2013
    >> [3]PETSC ERROR: Configure options --with-scalar-type=complex --with-clanguage=C++ PETSC_ARCH=arch-complex --with-fortran-kernels=generic --download-superlu_dist --download-mumps --download-scalapack --download-parmetis --download-metis --download-elemental --with-mpi=1 --download-blacs
    >> [3]PETSC ERROR: MatGetOrdering() line 257 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/mat/order/sorder.c
    >> [3]PETSC ERROR: PCSetUp_ILU() line 194 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/pc/impls/factor/ilu/ilu.c
    >> [3]PETSC ERROR: PCSetUp() line 890 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/pc/interface/precon.c
    >> [3]PETSC ERROR: KSPSetUp() line 278 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
    >> [3]PETSC ERROR: PCSetUpOnBlocks_BJacobi_Singleblock() line 646 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/pc/impls/bjacobi/bjacobi.c
    >> [3]PETSC ERROR: PCSetUpOnBlocks() line 924 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/pc/interface/precon.c
    >> [3]PETSC ERROR: KSPSetUpOnBlocks() line 165 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
    >> [3]PETSC ERROR: KSPSolve() line 400 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
    >> [3]PETSC ERROR: main() line 216 in /home/d3g096/Projects/PerformanceLDRD/src/sandbox/petsc/versteeg.cpp
    >> Must be square matrix, rows 2 columns 3!
    >> [0]PETSC ERROR: versteeg on a arch-complex named flophouse by d3g096 Thu Sep 26 14:30:51 2013
    >> [2]PETSC ERROR: --------------------- Error Message ------------------------------------
    >> [2]PETSC ERROR: Object is in wrong state!
    >> [2]PETSC ERROR: Matrix is missing diagonal entry 2!
    >> [2]PETSC ERROR: ------------------------------------------------------------------------
    >> [2]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
    >> [2]PETSC ERROR: --------------------------------------------------------------------------
    >> MPI_ABORT was invoked on rank 3 in communicator MPI_COMM_WORLD
    >> with errorcode 62.
    >> [2]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
    >> [2]PETSC ERROR: See docs/index.html for manual pages.
    >> [2]PETSC ERROR: versteeg on a arch-complex named flophouse by d3g096 Thu Sep 26 14:30:51 2013
    >> [2]PETSC ERROR: Libraries linked from /net/flophouse/files0/perksoft/petsc-3.4.2/arch-complex/lib
    >> [2]PETSC ERROR: Configure run at Wed Sep 11 06:43:12 2013
    >> [2]PETSC ERROR: Configure options --with-scalar-type=complex --with-clanguage=C++ PETSC_ARCH=arch-complex --with-fortran-kernels=generic --download-superlu_dist --download-mumps --download-scalapack --download-parmetis --download-metis --download-elemental --with-mpi=1 --download-blacs
    >> [2]PETSC ERROR: MatILUFactorSymbolic_SeqAIJ_ilu0() line 1653 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/mat/impls/aij/seq/aijfact.c
    >> [2]PETSC ERROR: MatILUFactorSymbolic_SeqAIJ() line 1756 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/mat/impls/aij/seq/aijfact.c
    >> [2]PETSC ERROR: MatILUFactorSymbolic() line 6238 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/mat/interface/matrix.c
    >> [2]PETSC ERROR: PCSetUp_ILU() line 204 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/pc/impls/factor/ilu/ilu.c
    >> [2]PETSC ERROR: PCSetUp() line 890 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/pc/interface/precon.c
    >> [2]PETSC ERROR: KSPSetUp() line 278 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
    >> [2]PETSC ERROR: PCSetUpOnBlocks_BJacobi_Singleblock() line 646 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/pc/impls/bjacobi/bjacobi.c
    >> [2]PETSC ERROR: PCSetUpOnBlocks() line 924 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/pc/interface/precon.c
    >> [2]PETSC ERROR: KSPSetUpOnBlocks() line 165 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
    >> [2]PETSC ERROR: KSPSolve() line 400 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/ksp/interface/itfunc.c
    >> [2]PETSC ERROR: main() line 216 in /home/d3g096/Projects/PerformanceLDRD/src/sandbox/petsc/versteeg.cpp
    >> [1]PETSC ERROR: Argument out of range!
    >> [1]PETSC ERROR: Cannot log negative flops!
    >> [1]PETSC ERROR: versteeg on a arch-complex named flophouse by d3g096 Thu Sep 26 14:30:51 2013
    >> [1]PETSC ERROR: PetscLogFlops() line 204 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/include/petsclog.h
    >> [1]PETSC ERROR: MatLUFactorNumeric_SeqAIJ_Inode() line 1312 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/mat/impls/aij/seq/inode.c
    >> [1]PETSC ERROR: MatLUFactorNumeric() line 2889 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/mat/interface/matrix.c
    >> [1]PETSC ERROR: PCSetUp_ILU() line 232 in /net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/net/flophouse/files0/perksoft/petsc-3.4.2/src/ksp/pc/impls/factor/ilu/ilu.c
    >> mpirun has exited due to process rank 3 with PID 12483 on
    >> [flophouse:12479] 3 more processes have sent help message help-mpi-api.txt / mpi-abort
    >> [flophouse:12479] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Bill Perkins
Research Engineer
Hydrology Group
Tel:  509-372-6131
Fax: 509-372-6089
www.pnnl.gov
