[petsc-users] Back to struct in Fortran to represent field with dof > 1
Christophe Ortiz christophe.ortiz at ciemat.es
Fri Sep 27 08:22:29 CDT 2013
There was a misunderstanding. There are n entries in total in the vector. I
thought it was a vector of n points, with 3 components associated to each
point, ie 3*n entries. This is clear now.
I've tested your example and I checked the values assigned to the
components with your piece of code:
      call VecGetArrayMyStruct(x,xarray,ierr)
      do i=1,10
      xarray(i)%a = i
      xarray(i)%b = 100*i
      xarray(i)%c = 10000*i
      enddo
      call VecRestoreArrayMyStruct(x,xarray,ierr)
I did it with:
       do i = 1 , 10
        write(*,*) xarray(i)%a,xarray(i)%b,xarray(i)%c
       end do
I obtained the following:
   1.00000000000000        2.00000000000000        3.00000000000000
   2.00000000000000        3.00000000000000        4.00000000000000
   3.00000000000000        4.00000000000000        5.00000000000000
   4.00000000000000        5.00000000000000        6.00000000000000
   5.00000000000000        6.00000000000000        7.00000000000000
   6.00000000000000        7.00000000000000        8.00000000000000
   7.00000000000000        8.00000000000000        9.00000000000000
   8.00000000000000        9.00000000000000        10.0000000000000
   9.00000000000000        10.0000000000000        1000.00000000000
   10.0000000000000        1000.00000000000        100000.000000000
First column if ok (1st component), but the other two columns show wrong
numbers. For component 2 and 3, only the very last value is ok. It seems
values from component b are copied from a, and those from component c from
b, with an offset.
What do you think ?
Christophe
On Fri, Sep 27, 2013 at 2:47 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Indices start in fortran arrays from 1 by default so don't even try zero
>    I've attached a new version that has three components,
>  30 TOTAL vector entries and 10 for each component. Please run it and send
> the results back.
>     Barry
> On Sep 27, 2013, at 5:40 AM, Christophe Ortiz <christophe.ortiz at ciemat.es>
> wrote:
> > Hi Barry,
> > I made some tests with your code that allows to use struct in Fortran90.
> It compiles and does not complain with the struct with 2 components
> but...it exhibits some strange behaviour. Here are the behaviours I
> observed. To make it simple, I used n=10.
> > - After using call VecSet(x,one,ierr), I checked the values of each
> component of the vector using
> >       do i = 0 , n
> >        write(*,*) i , xarray(i)%a, xarray(i)%b
> >       end do
> > I checked the values from i= 0 to n since I was not sure what was the
> convention (0- or 1-based). I obtained:
> >            0  0.000000000000000E+000   1.00000000000000
> >            1   1.00000000000000        1.00000000000000
> >            2   1.00000000000000        1.00000000000000
> >            3   1.00000000000000        1.00000000000000
> >            4   1.00000000000000        1.00000000000000
> >            5   1.00000000000000        1.00000000000000
> >            6   1.00000000000000        1.00000000000000
> >            7   1.00000000000000        1.00000000000000
> >            8   1.00000000000000        1.00000000000000
> >            9   1.00000000000000        1.00000000000000
> >           10   1.00000000000000       1.996650376645798E-314
> > As you can see, for component a, there is a 0 for i=0, then the values
> are correct. For component b, correct values go from i=1 to 9.There is
> garbage in second component for i=10 . I checked that if you define a third
> component c, its values go from i=-1 to n-2. It's like if values of second
> component started at the end of first component, and same thing for third
> component.
> > Then, instead of using VecSet(), I tried to assign values directly to
> each component of the vector with
> >       do i = 0 , n-1
> >        xarray(i)%a = 2.0
> >        xarray(i)%b = 3.0
> >       end do
> > Here I checked that indices actually start at 0 and not at 1. With a
> loop from i=1 to n I got a Memory corruption message.
> > and I checked that the values are correctly assigned with
> >        do i = 0 , n-1
> >         write(*,*) i, xarray(i)%a, xarray(i)%b
> >        end do
> > Then, I obtained:
> >            0   2.00000000000000        2.00000000000000
> >            1   2.00000000000000        2.00000000000000
> >            2   2.00000000000000        2.00000000000000
> >            3   2.00000000000000        2.00000000000000
> >            4   2.00000000000000        2.00000000000000
> >            5   2.00000000000000        2.00000000000000
> >            6   2.00000000000000        2.00000000000000
> >            7   2.00000000000000        2.00000000000000
> >            8   2.00000000000000        2.00000000000000
> >            9   2.00000000000000        3.00000000000000
> > Here the problem seems more severe. Values are not correctly assigned to
> the second component. There should be 3.0 in the second column. It seems
> values of the first component are copied to the second one. Only for i=10
> the value of xarray(i)%b is correct (3.0).
> > Any idea where it could come from ?
> > I guess it needs some fixes here and there but I think your idea is good
> and that it could work.
> > Christophe
> > On Thu, Sep 26, 2013 at 5:45 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >    I just put it with the Fortran source code and compile it with the
> rest of the application code; here is the makefile I used
> > On Sep 26, 2013, at 10:14 AM, Christophe Ortiz <
> christophe.ortiz at ciemat.es> wrote:
> > > By the way, what should I do with the small .c code ? Where should I
> put it ?
> > > Christophe
> > > On Thu, Sep 26, 2013 at 4:09 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > >    Christophe,
> > >      Despite my LinkIn Endorsement for expertise in Fortran :-) I
> cannot pretend to be an expert in FortranXX but I have cooked up an example
> demonstrating accessing the Vec entries as if they are in an array of
> derived types. I've attached the example code; there needs to be a small C
> stub that defines the functions for your specific derived type name.
> > > Note that it will only work I think if your N is a compile time
> constant.
> > >     It worked with
> > > ~/Downloads$ gfortran --version
> > > GNU Fortran (GCC) 4.8.1 20130404 (prerelease)
> > >     I do not understand exactly why it works since it uses
> F90Array1dCreate(fa,PETSC_SCALAR,1,len,ptr PETSC_F90_2PTR_PARAM(ptrd));
> which has a single PETSC_SCALAR as a building block but … I hope it works
> for you. If it doesn't, let us know the compiler you are using and we may
> be able to get it working for that compiler.
> > >    Barry
> > > On Sep 26, 2013, at 4:41 AM, Christophe Ortiz <
> > > > Hi all,
> > > > Me again !
> > > > I have read in previous posts that it is hard in Fortran to declare
> something similar to a typedef struct in C to manage a multicomponent
> problem.
> > > > Is it still the case ? Has the problem been solved ?
> > > > I am asking because my plan is to implement a multicomponent problem
> (in 1D), with many components that will be organized in arrays of two
> dimensions. In C I could define
> > > > typedef struct{
> > > > PetscScalar U;
> > > > PetscScalar V;
> > > > PetscScalar A[N][N];
> > > > } Field;
> > > > and then I could calculate the residual function with
> > > > F[i].U = ...
> > > > F[i].V = ...
> > > > F[i].A[k][n] = ...
> > > > which is quite convenient.
> > > > If in Fortran it is not possible to use a struct as in C, I am
> afraid I'll have to deal with
> > > > F(jdof,i) = ...
> > > > where I will have only jdof to address U, V and A[ ][ ], which can
> be difficult and not very convenient I guess. Before I move all my code to
> C, does anyone have an alternative idea to manage this multi(many)component
> problem in Fortran ?
> > > > Many thanks in advance for your help and suggestion !
> > > > Christophe
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130927/f6e22c4c/attachment.html>
