[petsc-users] The inverse of seqaij matrix
Joon Hee Choi choi240 at purdue.edu
Fri Sep 27 07:21:29 CDT 2013
Hi.
I am trying to get the inverse matrix of seqaij. I followed FAQ of petsc manual, but I got error.
Could someone tell me what I am missing? I am attaching my code, results, and error message.
Thank you.
Joon
   PetscPrintf(PETSC_COMM_WORLD, "I \n");
   MatView(I, PETSC_VIEWER_STDOUT_WORLD);
   PetscPrintf(PETSC_COMM_WORLD, "invM2T \n");
   MatView(invM2T, PETSC_VIEWER_STDOUT_WORLD);
   ierr = MatCreateSeqDense(PETSC_COMM_SELF, R, R, NULL, &seqM2T); CHKERRQ(ierr);
   ierr = MatGetOrdering(invM2T, MATORDERINGNATURAL, &isr, &isc); CHKERRQ(ierr);
   ierr = MatFactorInfoInitialize(&info); CHKERRQ(ierr);
   ierr = MatLUFactor(invM2T, isr, isc, &info); CHKERRQ(ierr);
   ierr = MatMatSolve(invM2T, I, seqM2T); CHKERRQ(ierr);
Matrix Object: 1 MPI processes
  type: seqdense
1.0000000000000000e+00 0.0000000000000000e+00
0.0000000000000000e+00 1.0000000000000000e+00
invM2T
  type: seqaij
row 0: (0, 3.22689)  (1, 2.47603)
row 1: (0, 2.47603)  (1, 2.25324)
invM2T
  type: seqaij
row 1: (0, 0.76731)  (1, 0.353361)
[1]PETSC ERROR: --------------------- Error Message ------------------------------------
[1]PETSC ERROR: Detected zero pivot in LU factorization:
see http://www.mcs.anl.gov/petsc/documentation/faq.html#ZeroPivot!
[1]PETSC ERROR: Zero pivot row 0 value 0 tolerance 0!
[1]PETSC ERROR: ------------------------------------------------------------------------
[1]PETSC ERROR: Petsc Release Version 3.4.1, Jun, 10, 2013
[1]PETSC ERROR: See docs/changes/index.html for recent updates.
[1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[1]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR: ./tenfac on a linux named rossmann-b000.rcac.purdue.edu by choi240 Fri Sep 27 08:01:31 2013
[1]PETSC ERROR: Libraries linked from /apps/rhel5/petsc-3.4.1/64/impi-4.1.0.030_intel-13.0.1.117_ind64/linux/lib
[1]PETSC ERROR: Configure run at Sun Jun 23 10:20:51 2013
[1]PETSC ERROR: Configure options --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort --download-sowing --with-scalar-type=real --with-shared-libraries=1 --with-pic=1 --with-clanguage=C++ --with-fortran --with-fortran-kernels=1 --with-64-bit-indices=1 --with-debugging=0 --with-blas-lapack-dir=/opt/intel/composer_xe_2013.1.117/mkl/lib/intel64 --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --download-hdf5=no --download-metis=no --download-parmetis=no --download-superlu_dist=no --download-mumps=no --download-scalapack=yes --download-blacs=no --download-hypre=no --download-spooles=no
[1]PETSC ERROR: MatPivotCheck_none() line 589 in /apps/rhel5/petsc-3.4.1/64/impi-4.1.0.030_intel-13.0.1.117_ind64/include/petsc-private/matimpl.h
[1]PETSC ERROR: MatPivotCheck() line 608 in /apps/rhel5/petsc-3.4.1/64/impi-4.1.0.030_intel-13.0.1.117_ind64/include/petsc-private/matimpl.h
[1]PETSC ERROR: MatLUFactorNumeric_SeqAIJ_Inode() line 1422 in /apps/rhel5/petsc-3.4.1/64/impi-4.1.0.030_intel-13.0.1.117_ind64/src/mat/impls/aij/seq/inode.c
[1]PETSC ERROR: MatLUFactorNumeric() line 2889 in /apps/rhel5/petsc-3.4.1/64/impi-4.1.0.030_intel-13.0.1.117_ind64/src/mat/interface/matrix.c
[1]PETSC ERROR: MatLUFactor_SeqAIJ() line 971 in /apps/rhel5/petsc-3.4.1/64/impi-4.1.0.030_intel-13.0.1.117_ind64/src/mat/impls/aij/seq/aijfact.c
[1]PETSC ERROR: MatLUFactor() line 2716 in /apps/rhel5/petsc-3.4.1/64/impi-4.1.0.030_intel-13.0.1.117_ind64/src/mat/interface/matrix.c
[1]PETSC ERROR: cal_M2() line 83 in tenfac.cpp
[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[1]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[1]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[1]PETSC ERROR: to get more information on the crash.
[1]PETSC ERROR: Signal received!
[1]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 1
