[petsc-users] About MatTransposeMatMult
Joon Hee Choi choi240 at purdue.edu
Thu Sep 26 21:41:49 CDT 2013
Dear Hong,
Thank you for your reply. I think it reduces the number of flops to use a seqaij matrix C because I will use very large sparse matrix for A and also multiply C and another large matrix. If so, then I might create B as a seqaij matrix.
Joon
----- Original Message -----
To: "Joon Hee Choi" <choi240 at purdue.edu>
Cc: "Jed Brown" <jedbrown at mcs.anl.gov>, "PETSc users list" <petsc-users at mcs.anl.gov>
Sent: Thursday, September 26, 2013 8:56:39 PM
Subject: Re: [petsc-users] About MatTransposeMatMult
Joon :
Dear Jed,
Hello. I modified my code using MatTranspose and MatMatMult, and it works well.
BTW, the result of the multiplication of seqaij and seqdense was seqdense.
I thought C should be seqaij when A is seqaij and B is seqdense in C=A*B.
When B is dense, C=A*B is a dense matrix.
Is the way to get seqaij just seqaij*seqaij?
Why do you want store a dense matrix in sparse format?
Hong
To: "Jed Brown" < jedbrown at mcs.anl.gov >
Cc: petsc-users at mcs.anl.gov
Sent: Thursday, September 26, 2013 2:45:38 PM
> Thank you. I think MatMatMult runs well for multiplication between seqaij and seqdense.
> Joon
To: "Karl Rupp" < rupp at mcs.anl.gov >, "Joon Hee Choi" < choi240 at purdue.edu >, petsc-users at mcs.anl.gov
Cc: "Hong Zhang" < hzhang at mcs.anl.gov >
Sent: Thursday, September 26, 2013 11:01:42 AM
>> Karl Rupp < rupp at mcs.anl.gov > writes:
>>> Hi,
>>> I am trying to calculate M = X^T * B. X is a seqaij and B is a seqdense matrix.
>>> This is not yet allowed in the latest 3.4. release.
>> You can explicitly transpose X:
>> MatTranspose(X,MAT_INITIAL_MATRIX,&Xt);
>> and then use MatMatMult.
>>> However, I used MatTransposeMatMult() but I got an error. Can someone why I got the >>> error and how I should modify my code? I am attaching my simple code, error message, >>> and result. Thank you very much.
>>> Do you use the master branch from our Bitbucket repository? It contains
>>> the commit where Hong added the respective functionality:
>>> https://bitbucket.org/petsc/petsc/commits/8949adfd119cb1d44c9fb5cf3dc01f4b6a02252d
>> This is only for MPI. Hong, can you expose MatTransposeMatMult_SeqAIJ_SeqDense?
