[petsc-users] Cannot use KSP if I choose local Matrix/Vector ownership
William A. Perkins william.perkins at pnnl.gov
Thu Sep 26 16:37:30 CDT 2013
Hello,
I have run into a problem using KSP.  Attached is a hopefully short,
simple example program (which has nothing to do with my actual
application) demonstrating the problem.  Also attached is an output
log from several runs of the program.  The program runs fine if I
choose local ownership according to PetscSplitOwnership().  If,
however, I slightly modify that local ownership scheme, the program
will not run in parallel.  In my view, KSP appears to make its own
coefficient (or preconditioner, or whatever) matrix that has different
local ownership than the one I give to KSPSetOperators(), and so
cannot do matrix/vector multiplies.
I would like to be able to choose my own local ownership. Any help
would be appreciated. Hopefully, I'm not doing something stupid.
Thanks.
Bill
Bill Perkins
Research Engineer
Hydrology Group
Pacific Northwest National Laboratory
902 Battelle Boulevard
P.O. Box 999, MSIN K9-36
Richland, WA  99352 USA
Tel:  509-372-6131
Fax: 509-372-6089
www.pnnl.gov
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130926/9dacd86a/attachment-0002.ksh>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130926/9dacd86a/attachment-0003.ksh>
