[petsc-users] About MatTransposeMatMult
Joon Hee Choi choi240 at purdue.edu
Thu Sep 26 16:17:31 CDT 2013
Dear Jed,
Hello. I modified my code using MatTranspose and MatMatMult, and it works well.
BTW, the result of the multiplication of seqaij and seqdense was seqdense.
I thought C should be seqaij when A is seqaij and B is seqdense in C=A*B.
Is the way to get seqaij just seqaij*seqaij?
Joon
----- Original Message -----
To: "Jed Brown" <jedbrown at mcs.anl.gov>
Cc: petsc-users at mcs.anl.gov
Sent: Thursday, September 26, 2013 2:45:38 PM
Subject: Re: [petsc-users] About MatTransposeMatMult
> Thank you. I think MatMatMult runs well for multiplication between seqaij and seqdense.
> Joon
To: "Karl Rupp" <rupp at mcs.anl.gov>, "Joon Hee Choi" <choi240 at purdue.edu>, petsc-users at mcs.anl.gov
Cc: "Hong Zhang" <hzhang at mcs.anl.gov>
Sent: Thursday, September 26, 2013 11:01:42 AM
>> Karl Rupp <rupp at mcs.anl.gov> writes:
>>> Hi,
>>> I am trying to calculate M = X^T * B. X is a seqaij and B is a seqdense matrix.
>>> This is not yet allowed in the latest 3.4. release.
>> You can explicitly transpose X:
>>  MatTranspose(X,MAT_INITIAL_MATRIX,&Xt);
>> and then use MatMatMult.
>>> However, I used MatTransposeMatMult() but I got an error. Can someone why I got the >>> error and how I should modify my code? I am attaching my simple code, error message, >>> and result. Thank you very much.
>>> Do you use the master branch from our Bitbucket repository? It contains
>>> the commit where Hong added the respective functionality:
>>> https://bitbucket.org/petsc/petsc/commits/8949adfd119cb1d44c9fb5cf3dc01f4b6a02252d
>> This is only for MPI.  Hong, can you expose MatTransposeMatMult_SeqAIJ_SeqDense?
