[petsc-users] About MatTransposeMatMult
Thu Sep 26 10:01:42 CDT 2013
Karl Rupp <rupp at mcs.anl.gov> writes:
> Hi,
>> I am trying to calculate M = X^T * B. X is a seqaij and B is a seqdense matrix.
> This is not yet allowed in the latest 3.4. release.
You can explicitly transpose X:
  MatTranspose(X,MAT_INITIAL_MATRIX,&Xt);
and then use MatMatMult.
>> However, I used MatTransposeMatMult() but I got an error. Can someone why I got the error and how I should modify my code? I am attaching my simple code, error message, and result. Thank you very much.
> Do you use the master branch from our Bitbucket repository? It contains
> the commit where Hong added the respective functionality:
> https://bitbucket.org/petsc/petsc/commits/8949adfd119cb1d44c9fb5cf3dc01f4b6a02252d
This is only for MPI.  Hong, can you expose MatTransposeMatMult_SeqAIJ_SeqDense?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130926/3f3bb60d/attachment-0001.pgp>
