[petsc-users] ex12 with Neumann BC
Olivier Bonnefon olivier.bonnefon at avignon.inra.fr
Thu Sep 26 08:04:50 CDT 2013
Hello,
I have implemented my own system from ex12.c. It works with Dirichlet
BC, but failed with Neumann one.
So, I'm came back to the example /src/snes/example/tutorial/ex12.c, and
I tried with Neumann BC:
./ex12 -bc_type NEUMANN
This leads to the following crach:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: No support for this operation for this object type!
[0]PETSC ERROR: Unsupported number of vertices 0 in cell 8 for element
geometry computation!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./ex12 on a arch-linux2-c-debug named pcbiom38 by
olivierb Thu Sep 26 14:53:32 2013
[0]PETSC ERROR: Libraries linked from
/home/olivierb/SOFT/petsc-3.4.2/arch-linux2-c-debug/lib
[0]PETSC ERROR: Configure run at Thu Sep 26 14:44:42 2013
[0]PETSC ERROR: Configure options --with-debugging=1 --download-fiat
--download-scientificpython --download-generator --download-triangle
--download-ctetgen --download-chaco --download-netcdf --download-hdf5
[0]PETSC ERROR:
[0]PETSC ERROR: DMPlexComputeCellGeometry() line 732 in
/home/olivierb/SOFT/petsc-3.4.2/src/dm/impls/plex/plexgeometry.c
[0]PETSC ERROR: DMPlexComputeResidualFEM() line 558 in
/home/olivierb/SOFT/petsc-3.4.2/src/dm/impls/plex/plexfem.c
[0]PETSC ERROR: SNESComputeFunction_DMLocal() line 75 in
/home/olivierb/SOFT/petsc-3.4.2/src/snes/utils/dmlocalsnes.c
[0]PETSC ERROR: SNESComputeFunction() line 1988 in
/home/olivierb/SOFT/petsc-3.4.2/src/snes/interface/snes.c
[0]PETSC ERROR: SNESSolve_NEWTONLS() line 162 in
/home/olivierb/SOFT/petsc-3.4.2/src/snes/impls/ls/ls.c
[0]PETSC ERROR: SNESSolve() line 3636 in
[0]PETSC ERROR: main() line 582 in
"unknowndirectory/"/home/olivierb/solvers/trunk/SandBox/PETSC/LANDSCAPE/REF/ex12.c
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 56.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
With Gbd, I saw that DMPlexGetConeSize is 0 for the last point.
Do I have forget a step to use Neumann BC ?
Thanks
Olivier Bonnefon
Olivier Bonnefon
INRA PACA-Avignon, Unité BioSP
Tel: +33 (0)4 32 72 21 58
