[petsc-users] Fwd: Building the same petsc matrix with different numprocs gives different results!
Analabha Roy hariseldon99 at gmail.com
Tue Sep 24 13:18:30 CDT 2013
On Tue, Sep 24, 2013 at 11:35 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Sep 24, 2013 at 10:58 AM, Analabha Roy <hariseldon99 at gmail.com>wrote:
>> Hi,
>>  Sorry for misunderstanding
>> I modified my source thus <http://pastebin.ca/2457850> so that the
>> rows/cols/values for each call are printed before inserting into
>> MatSetValues()
>> Then ran it with 1,2 processors
>> Here are the outputs <http://pastebin.ca/2457852>
>> Strange! Running it with 2 procs and only half the values show up!!!!!
> PetscPrintf() only prints from rank 0. Use PETSC_COMM_SELF.
Sorry. Modified accordingly and here is new
output<http://pastebin.ca/2457857>(I manually reordered the output of
the 2 procs case since the order in
which it was printed was haphazard)
All the elements do not match.
>    Matt
>> And even those do not match!!!!
>> On Tue, Sep 24, 2013 at 11:12 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Tue, Sep 24, 2013 at 10:39 AM, Analabha Roy <hariseldon99 at gmail.com>wrote:
>>>> Hi,
>>>> On Tue, Sep 24, 2013 at 9:33 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Tue, Sep 24, 2013 at 8:35 AM, Analabha Roy <hariseldon99 at gmail.com>wrote:
>>>>>> On Tue, Sep 24, 2013 at 8:41 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>> On Tue, Sep 24, 2013 at 8:08 AM, Analabha Roy <
>>>>>>> hariseldon99 at gmail.com> wrote:
>>>>>>>> On Tue, Sep 24, 2013 at 1:42 PM, Jed Brown <jedbrown at mcs.anl.gov>wrote:
>>>>>>>>> Analabha Roy <hariseldon99 at gmail.com> writes:
>>>>>>>>> > Hi all,
>>>>>>>>> > Compiling and running this
>>>>>>>>> > code<
>>>>>>>>> https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c
>>>>>>>>> >that
>>>>>>>>> > builds a petsc matrix gives different results when run with
>>>>>>>>> different
>>>>>>>>> > number of processors.
>>>>>>>> Thanks for the reply.
>>>>>>>>>  Uh, if you call rand() on different processors, why would you
>>>>>>>>> expect it
>>>>>>>>> to give the same results?
>>>>>>>>> Right, I get that. The rand() was a placeholder.
>>>>>>>> This original much larger code<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c>replicates the same loop structure and runs the same Petsc subroutines, but
>>>>>>>> running it by
>>>>>>>> mpirun -np $N ./eth -lattice_size 5 -vector_size 1 -repulsion 0.0
>>>>>>>> -draw_out -draw_pause -1
>>>>>>>> with N=1,2,3,4 gives different results for the matrix dumped out by
>>>>>>>> lines 514-519<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#514>.
>>>>>>>> The matrix itself is evaluated in parallel, created in lines263-275
>>>>>>>> <https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#263>and
>>>>>>>> evaluated in lines 294-356<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#294>
>>>>>>>> (you can click on the line numbers above to navigate directly to
>>>>>>>> them)
>>>>>>>> Here is a sample <http://i43.tinypic.com/zyhf2f.jpg> of the output
>>>>>>>> of  lines 514-519<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#514>  for N=1,2,3,4 procs left to right.
>>>>>>>> Thty're different for different procs. They should be the same,
>>>>>>>> since none of my input parameters are numprocs dependent, and I don't
>>>>>>>> explicitly use the size or rank anywhere in the code.
>>>>>>> You are likely not dividing the rows you loop over so you are
>>>>>>> redundantly computing.
>>>>>> Line 274<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#274>gets the local row indices of Petsc Matrix
>>>>>> AVG_BDIBJ
>>>>>> Line 295
>>>>>> <https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#295>iterates
>>>>>> over the local rows and the lines below get the column
>>>>>> elements. For each row, the column elements are assigned by the lines
>>>>>> up to  Line 344<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#344>and stored locally in colvalues[]. Dunno if the details are relevant.
>>>>>> Line 347<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#347>inserts the sitestride1^th row into the matrix
>>>>>> Line 353+<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#353>does the mat assembly
>>>>>> Then, after a lot of currently irrelevant code,
>>>>>> Line 514+<https://code.google.com/p/daneelrepo/source/browse/eth_question/eth.c#514>dumps the mat plot to graphics
>>>>>> Different numprocs give different matrices.
>>>>>> Can somebody suggest what  I did wrong (or didn't do)?
>>>>> Different values are being given to MatSetValues() for different
>>>>> numbers of processes. So
>>>>>   1) Reduce this to the smallest problem size possible
>>>>>   2) Print out all rows/cols/values for each call
>>>>>   3) Compare 2 procs to the serial case
>>>> Thanks for your excellent suggestion.
>>>> I modified my code<https://code.google.com/p/daneelrepo/source/diff?spec=svn1435&r=1435&format=side&path=/eth_question/eth.c>to dump the matrix in binary
>>>> Then I used this python script I had<https://code.google.com/p/daneelrepo/source/browse/eth_question/mat_bin2ascii.py>to convert to ascii
>>> Do not print the matrix, print the data you are passing to
>>> MatSetValues().
>>> MatSetValues() is not likely to be broken. Every PETSc code in the world
>>> calls this many times on every simulation.
>>>    Matt
>>>> Here are the values of <http://pastebin.ca/2457842>AVG_BDIBJ<http://pastebin.ca/2457842>,
>>>> a 9X9 matrix (the smallest possible problem size) run with the exact same
>>>> input parameters with 1,2,3 and 4 procs
>>>> As you can see, the 1 and 2 procs match up, but the 3 and 4 procs do
>>>> not.
>>>> Serious wierdness.
>>>>>     Matt
>>>>>>>    Matt
>>>>>>>>> for (sitestride1 = Istart; sitestride1 < Iend; sitestride1++)
>>>>>>>>>       for (sitestride2 = 0; sitestride2 < matsize; sitestride2++)
>>>>>>>>>           for (alpha = 0; alpha < dim; alpha++)
>>>>>>>>>               for (mu = 0; mu < dim; mu++)
>>>>>>>>>                 for (lambda = 0; lambda < dim; lambda++)
>>>>>>>>>                     vecval = rand () / rand ();
>>>>>>>>>               VecSetValue (BDB_AA, alpha, vecval, INSERT_VALUES);
>>>>>>>>>           VecAssemblyBegin (BDB_AA);
>>>>>>>>>           VecAssemblyEnd (BDB_AA);
>>>>>>>>>           VecSum (BDB_AA, &element);
>>>>>>>>>           colvalues[sitestride2] = element;
>>>>>>>>>       //Insert the array of colvalues to the sitestride1^th row of
>>>>>>>>> H
>>>>>>>>>       MatSetValues (AVG_BDIBJ, 1, &sitestride1, matsize, idx,
>>>>>>>>> colvalues,
>>>>>>>>>                     INSERT_VALUES);
>>>>>>>>> > The code is large and complex, so I have created a smaller
>>>>>>>>> program
>>>>>>>>> > with the same
>>>>>>>>> > loop structure here. <http://pastebin.ca/2457643>
>>>>>>>>> > Compile it and run it with "mpirun -np $N ./test -draw_pause -1"
>>>>>>>>> gives
>>>>>>>>> > different results for different values of N even though it's not
>>>>>>>>> supposed
>>>>>>>>> > to.
>>>>>>>>> What do you expect to see?
>>>>>>>>> > Here is a sample output <http://i42.tinypic.com/2s16ccw.jpg>
>>>>>>>>> for N=1,2,3,4
>>>>>>>>> > from left to right.
>>>>>>>>> > Can anyone guide me as to what I'm doing wrong? Are any of the
>>>>>>>>> petssc
>>>>>>>>> > routines used not parallelizable?
>>>>>>>>> > Thanks in advance,
>>>>>>>>> > Regards.
>>>>>>>>> > *Analabha Roy*
>>>>>>>>> > C.S.I.R <http://www.csir.res.in>  Senior Research
>>>>>>>>> > Associate<http://csirhrdg.res.in/poolsra.htm>
>>>>>>>>> > Saha Institute of Nuclear Physics <http://www.saha.ac.in>
>>>>>>>>> > Section 1, Block AF
>>>>>>>>> > Bidhannagar, Calcutta 700064
>>>>>>>>> > India
>>>>>>>>> > *Emails*: daneel at physics.utexas.edu, hariseldon99 at gmail.com
>>>>>>>>> > *Webpage*: http://www.ph.utexas.edu/~daneel/
>>>>>>>> *Analabha Roy*
>>>>>>>> C.S.I.R <http://www.csir.res.in>  Senior Research Associate<http://csirhrdg.res.in/poolsra.htm>
>>>>>>>> Section 1, Block AF
>>>>>>>> India
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> *Analabha Roy*
>>>>>> Section 1, Block AF
>>>>>> India
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> *Analabha Roy*
>>>> Section 1, Block AF
>>>> India
>>> experiments lead.
>>> -- Norbert Wiener
>> *Analabha Roy*
>> Section 1, Block AF
>> India
> experiments lead.
> -- Norbert Wiener
*Analabha Roy*
Section 1, Block AF
India
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130924/5b73f6e0/attachment-0001.html>
