[petsc-users] Writing VTK output for vectors derived from DM Global vector
Garnet Vaz garnet.vaz at gmail.com
Tue Sep 24 08:16:40 CDT 2013
Hi Matt,
I did pull yesterday. My configure.log file has
          Defined "VERSION_GIT" to
""b4e904d1358c92c43842a940440f995d2117e40b""
          Defined "VERSION_DATE_GIT" to ""2013-09-23 12:36:08 +0100""
Is the change added after this?
Garnet
On Tue, Sep 24, 2013 at 6:08 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Sep 24, 2013 at 5:54 AM, Garnet Vaz <garnet.vaz at gmail.com> wrote:
>> Hi,
>> Thanks Jed. I will set the field names before I write them.
>> I need to create a clone and then change the default section
>> to have dof to 1 before I write them. I am not able to use clone with
>> DMClone(originaldm,&newdm);
>> The error I get when compiling is
>> "'DMClone' was not declared in this scope".
>> I do have #include<petscdmplex.h> which includes the
>> petscdm.h header. Other than clone I am able to use the
>> other functions.
> Have you updated? I think I forgot the declaration initially.
>   Matt
>> Thanks.
>> Garnet
>> On Mon, Sep 23, 2013 at 3:30 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> Garnet Vaz <garnet.vaz at gmail.com> writes:
>>> > Hi,
>>> > I would like to write out my solution to a VTK file where I use
>>> unstructured
>>> > grids in DMPlex.
>>> > The solution corresponds to  harmonic frequencies (~ 5-10 distinct)
>>> which
>>> > are
>>> > currently saved into a Vec* object. These vectors were created by
>>> > duplicating the
>>> > global vector for the DM object. (I know that they correspond to the
>>> right
>>> > cell.)
>>> > Is it possible to have one file which would contain the mesh from the
>>> DM
>>> > object and all the Vec* objects?
>>> > Would I have to clone the original DM and use
>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Viewer/PetscViewerVTKAddField.html
>>> > to include all the vectors?
>>> This is a private function.
>>> > In the above function does
>>> > PetscViewerVTKWriteFunction
>>> > just need to be
>>> > myWriteFunc(vec,viewer)
>>> > VecView(vec,viewer)
>>> > if I do not need to make any changes to the vector?
>>> This should work, but you may want to use PetscObjectSetName() so that
>>> the names of the different fields are sensible.
>> Regards,
>> Garnet
> experiments lead.
> -- Norbert Wiener
Garnet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130924/bcc0a96c/attachment.html>
